View Full Version : New LS1 Owners - Newbie Tech
  1. Cutting into the hood?
  2. Will a ls2 intake manifold bolt right up to a ls1?
  3. Identified my weird problem, put a hole in the power steering rail
  4. Header research...
  5. Why are longtubes louder?
  6. Question about 02 sensor
  7. Top end job
  8. weld up header kit for ls6
  9. Best way to spend 1500-2000$
  10. Is buying Heads a good investment?? couple newb questions inside...
  11. question about my y-pipe
  12. Headers *Important*
  13. Typhoon 96mm intake manifold w/fuel rails VS LS6 Manifold
  14. Stay 3.23 or go 3.73
  15. looking for a turnkey LS1 in NewZealand
  16. GMMG Vs. Cutout sound
  17. Taking off a/c belt
  18. difference between ls1 long and short blocks
  19. FAST 92 install question
  20. Security light on?
  21. Cam
  22. Trouble starting/ running
  23. Service Eng. light
  24. cooling fan switch mod?
  25. 02 ZO6 LS1 vs Fbody LS1, Whats Different?
  26. Collector's Plates?
  27. throttle body seal
  28. Best-value high-flow cat?
  29. Slight miss around 2200 rpm
  30. Longtubes?? Shorties??
  31. Newb looking for a place to start
  32. What Does This Mean???
  33. advice on small parts?
  34. P0443 and P0481 Code Help
  35. Installed a ported TB...
  36. Power stearing pullie
  37. Bolt Pattern
  38. A couple things...
  39. Car may be totaled what can i expect??????
  40. Noob Exhaust Question
  41. Help me with spark plug wires?
  42. so what is this
  43. Is my clutch going bad??
  44. What kind of power is expected? And how much $$$?
  45. radio noise
  46. Is it worth buying these pulleys??
  47. Spark plug question?
  48. Buying my first LS1...
  49. 3" TD's with an h pipe as a first mod?
  50. master and slave cylinder question
  51. black zo6 rims?
  52. Looking to buy Sunset Orange 01 SS (need input)
  53. 160* thermo stat and SES light?!
  54. 17 X 11 torque thrust question
  55. Removing pass. seat belt?
  56. Any LS1tech sponsor vendors for sensors?
  57. Bigger MAF= better or worse gas mileage?
  58. Ordering Handheld
  59. new here
  60. Full exhaust with California emissions?
  61. stall or nitrous???
  62. water damage, possible hydro lock HELP!
  63. Cam Stall Gas Mileage?
  64. Duals or ORY set up
  65. engines?
  66. How to take ou the factory head unit?
  67. Launching a 4L60E.
  68. Need advice
  69. I really need help!
  70. Power Gain
  71. Opinions Needed
  72. New to the real world GOT A ? need helpw 00,SS
  73. So i've installed an FTRA today...
  74. Gains from Borla Catback
  75. Exhaust tips
  76. Stock Wheel locks
  77. Cleaned my MAF
  78. question for goat owners
  79. Replacing a door.
  80. tb gasket reuse it?
  81. 98+ wheels
  82. Auto Radio Shut off wont work!
  83. 2000 z28 what will it run?
  84. programmers for LS1
  85. how do 4th gens cool? should be an easy answer
  86. TTS headers -- y-pipe
  87. Ls6 intake and tune
  88. Stock subwoofer on Monsoon 500W system
  89. purchasing heads, newbie ?'s.
  90. 1999 C5 Ridiculously High Oil Press What to do?
  91. Edmunds pricing for LS1 fbodies seems WRONG!
  92. Exhaust opinions/advice needed
  93. Chevelle Swap, LS1,2,6?
  94. Parts list: where to find and $
  95. Throttle body hose won't fit, help!
  96. I can not find this tranny mount! Please help!
  97. RPO Codes
  98. ???'s before I spend the $$$
  99. what can be done to make my stock 10 bolts stronger?
  100. Any GM workers? Need help finding EURO spec part number
  101. Auto or Manual???
  102. exhaust
  103. ported TB
  104. dyno tune
  105. Need Help with Monsoon system!
  106. Oil Pressure...
  107. Need help with EGR quick
  108. problems with c5 Z06's
  109. Radio is HOT
  110. installed ported tb
  111. Turn signal socket.
  112. heatshield for exhaust cutout
  113. driver side back higher
  114. O2 sensors... just for yalls info.
  115. LS 1 question
  116. stalls and dead spots!?
  117. a4 2 m6
  118. leather?
  119. side marker led??
  120. 10 bolt, 12 bolt, 9 inch
  121. New At Modn Help
  122. List of options?
  123. Spark Plug Help!
  124. Header and Exhaust Question
  125. Will this tape player fit in my car???
  126. I need some suggestion about getting 400rwhp on my 99 a4 Formula
  127. Value of Ls1
  128. Started off backwards
  129. Throttle Body Question
  130. Magnaflow exhaust
  131. Throttle body install
  132. top end?
  133. new 2 this gettn exhaust
  134. need advice
  135. do LTs scrape with eibach pro lowering kit???
  136. Improving LS1 city mileage?
  137. Is my fuel pressure too high?
  138. cleaner
  139. Real world weight
  140. Header install?
  141. noob question reprograming key fab!!
  142. Tapping noise in the motor?
  143. Gutting Cats?
  144. What Heads
  145. MAC Catback???
  146. Question about LS1 Engine
  147. newbie fog light question
  148. A couple dumb newb questions
  149. Im excited
  150. free mod questions
  151. 400 rwhp NA LS1 F-body...how much?
  152. What oil filter for my F body pan
  153. What should i expect to pay for mid headers???
  154. Time for a tune up?
  155. Were my spark plugs very bad?
  156. questions about my header install.
  157. what exactly is the heater hose mod?
  158. My alarm is starting to piss me off
  159. Catback exhaust?
  160. Wheel clearance
  161. Exhaust Shopping! Need some ideas.
  162. What does the "Formula" Mean???
  163. Header Question
  164. Spark Plugs!! ahhh
  165. Quick question on......
  166. Leaking Coolant, HELP
  167. what should i do? (non-ls1 question)
  168. newbie question on a blower
  169. lid and bellow help
  170. Beginner enthusiast cam swap package!
  171. best drs??
  172. Vin breakdown
  173. alternator
  174. I need my car tuned-HELP???
  175. Brought her home.
  176. Took Car to Get Code ran!
  177. What makes a high mileage car "lose power"?
  178. What are all the fluids that need to be regularly changed?
  179. Torque spec ?
  180. Turbo
  181. 4.8 Vortec crate engine and box????
  182. bump on passengers side floor?
  183. headlights blow dimmer fuse
  184. hurst pistol grip shifter
  185. Safe to start???
  186. Water Pump Question
  187. Just put on Magnaflow catback
  188. Making it last
  189. Headlight Roar
  190. SLP air filter tray
  191. Whats Next [Suggestions Needed]
  192. what motor should i go with... Bang for the buck
  193. 89 Octane gave me an extra 50 miles
  194. crankshaft positioning sensor??
  195. rear end noise
  196. slp 160 degree
  197. skipshift eliminator y??
  198. Headlights won't work?!!
  199. Quick noob question!
  200. New 2002 Trans AM WS6
  201. need help with 85mm setup! asap!
  202. is this true??
  203. Did my First MODs!
  204. corvette xhaust manifolds
  205. rough idle, bogging, dies.....tried search
  206. Oil in Throttle Body
  207. Tranny issue
  208. Is it worth Buying 99 Camaro SS??
  209. Straight trade for this?
  210. Are jet performance chips pretty good??
  211. Cat code affect performance?
  212. Just became a new LS! owner!! Help?
  213. Check Engine Light-what's this code mean?
  214. Thinking about getting intake/exhaust help please
  215. y pipe rubbing on frame
  216. Should i get it (trans am ws6)?
  217. Vin check
  218. help with exhaust?
  219. holes in ram air baffle?
  220. rear-wheel or crank HP?
  221. cooling funs wont shut off
  222. How to change gauge face...???!!!
  223. Red check engine flashes: oil?
  224. Look at this car
  225. does turning crank by hand affect starter motor??
  226. Slight knocking on idle
  227. problem with shifting
  228. Help getting to the coolant plug
  229. idle weird
  230. Head light problem, help
  231. Spare key?
  232. Help!! with LSX swap in 70 Chevelle
  233. Should I get it (Z06) ?
  234. brake, tcs off light, abs inop light
  235. What year car have I got?
  236. TB bypass kit question
  237. Very nooooobbbb question
  238. Help!
  239. car wheelhops 2nd
  240. Quick Question about Factory available SLP Options...
  241. Is smooth intake bellow really worth the money??
  242. Air breather question
  243. Thought u might
  244. Little rant...
  245. LQ9 to LS6 intake Conversion help!!!
  246. So I got an M6
  247. 2000 z28 camaro auto (where do i put in tranny fluid)
  248. 2001 ls1 mods done need to know some info. . .
  249. noob intake question
  250. What to do (or what would YOU do)
