View Full Version : New LS1 Owners - Newbie Tech
  1. Pro 5.0 ?
  2. radio lock?
  3. New to the LS1, not to f-bodies!
  4. Question regarding 02 Z-28!
  5. winter weather hurt tuning??
  6. Sellen my trans am
  7. 02 Camaro Clear Coner Install Help!!!
  8. Last of the Breed emblems
  9. Oil Pressure Port?
  10. BASIC header question, not about brand
  11. Performance intake info needed...
  12. quick yes or no question 4 manual fan switch
  13. do open headers make car run slow???
  14. y pipe ??
  15. What exhast
  16. I'm getting an MS4 cam, which intake should I get with it?
  17. fuel pressure
  18. ASR on non optioned car?
  19. Need Some Help, Quick
  20. How to remove IAT sensor to install SLP lid
  21. these rims about right?
  22. the weirdest thing jus happened on the way home!!
  23. Need A Clutch Quick
  24. what octane gas?
  25. dyno w/ls1 intake or ls6
  26. Which Battery?
  27. window shot out, problems now
  28. 05 Mustang Gt Vs 98 Trans Am
  29. Bolt On's or Weld On's!!
  30. [Q] AC/FAN Regulators Panel replacement
  31. Installed LT Headers No Cats Check Engine
  32. LS1/LS7 Swap
  33. Purchasing New C5 Wheels/Tires
  34. Who Would Win
  35. Tune Up?
  36. Which is faster?
  37. Sub Frame Connectors?
  38. a4 burnout---newb
  39. Getting a stall with stock rearend?
  40. Gas Mileage
  41. Holiday Time -- Get your calendars!!!
  42. Can anyone stop me from selling my car?!!
  43. K & N Air filter VS. Paper Air Filter ?!
  44. BG Ram Air Work???????
  45. Mufflers?!
  46. Help with front end rattle!
  47. Why do people never reply to classifed ads here?
  48. Is the SLP Cold Air system worth it?
  49. Much sound change when headers are put in?
  50. t-56 trans fluid
  51. superchips handheld tuner
  52. What to get when going with a lid?
  53. Top Speed For 98 Trans Am???
  54. fuel tank ground wire?
  55. Whats the difference between a MS3 cam and a MS4 cam?
  56. 1/8 times at the TRACK
  57. Is manual hard to master?
  58. LS1 purchase question
  59. Need new window motor? Ebay?
  60. XRumer Platinum Edition is the best program for advertisement!
  61. Picking up my 99 Z28 in the morning!!! Yay
  62. Gmmg Chambered Exhaust
  63. 98 trans am needs help
  64. LQ4 vs. LQ9
  65. How fast can i go before shift?
  66. So I just got my 02 WS6 (advice needed)
  67. question on cams/pushrods
  68. what should be my new mod?
  69. Traction Control button...
  70. Header Install, How hard is it really
  71. OBX headers good or bad
  72. ASP pulley question.
  73. engine tore down, now what?
  74. Attachment lift points for LS1 installation...
  75. Piston Return Springs!
  76. problem?????
  77. Free Ls1 Mods???
  78. ASP Pulley- alternator belt issues, please help
  79. What am I gettin' for power?
  80. gas smell when accelerate hard
  81. what do u think bout my oil color???
  82. Help with tb p&p
  83. Help with exhaust!!
  84. Headers/exhaust?
  85. Can a plug be bad if it appears Ok?
  86. 2004 GTO newbey!
  87. Newbie with questions
  88. Just baught 00 Z28 a4
  89. New 1998 LS1
  90. Tubes across valley cover?
  91. FTRA question
  92. -6 AN to hard line nipple?
  93. 1997 c5
  94. Motor Noise
  95. Gto Will Not Go Into Gear
  96. rough idle after 02 sensor install
  97. estimated e.t.
  98. $7500 to spend on mods. Need help and or ideas.
  99. Help with cooling fans
  100. you guys would know best...
  101. ? about Seafoam vs. Auto-Rx
  102. Unknown RPO Codes
  103. Superchips tuner
  104. Value of Modifications
  105. lt1 values
  106. Should I go Speed Density?
  107. Needing some lug nut advice!
  108. Is the FIPK worth it?
  109. LS1 TPI convered to TBI??
  110. Anyone have any good cam ideas to break 400hp?
  111. n00b q about dual 3inch exhaust out the back ....
  112. my first mods
  113. FAST intake height...
  114. 2000 z28 41,000 miles NEWBIE!
  115. FRC's with strut tower brace?
  116. What times out of a 99 z28 with a shot?
  117. newb to domestic's
  118. Engine Mount -->international!
  119. Contemplating my first LS1
  120. parts list
  121. Anyone using a CRT throttlebody?
  122. Newb to F-body, what to do?
  123. Electric Cutout worth it?
  124. ASP pulley??
  125. Just bought my first LS1
  126. Ls motor in sandrail
  127. Drivability of MS3
  128. Bolt-on compilation
  129. Engine RPM Surging
  130. Custom Bellow??
  131. Car bogs and dies anything over 1/2 throttle
  132. where???
  133. Newbie Burd
  134. underdrive
  135. Stalling!!!
  136. difference between Long and short blocks??
  137. Fuel Pump Access Door difference
  138. LS1 build up questions
  139. Motors stuck
  140. real quick question on porting tb
  141. dynotune
  142. Motor is running a little warm...
  143. whats up guys, just bought a bird!
  144. 2000 Firebid pop up headlight motors...
  145. LS6 Heads
  146. cat delete for xpipe = meaningless air pump?
  147. Loud pop when shifting hard into 2nd
  148. Ls1 headers
  149. What power and ET do you think?
  150. cam info please
  151. dumb question
  152. headers
  153. LS series engines
  154. Light on Dash?
  155. Best mods - for best POWER
  156. Best mods - for best power.
  157. lift point question
  158. changing from regular oil to synthetic
  159. Intake swap?
  160. cold air intake on 2000 z28?
  161. how do you take off the egr valve?
  162. TB=Tune?
  163. sponsor catalogs
  164. Z06 suspension???
  165. Turning off Headlights
  166. 00 ta
  167. cam or stall????
  168. quick ? about stick driving
  169. LS engine series
  170. How to build for the future?
  171. SeaFoam Oil Change
  172. Interesting thing I noticed
  173. rev limiter
  174. whats my slp #?
  175. What should I do first?
  176. Having a problem with my blinkers, please help
  177. More from What a Rush
  178. skip shift
  179. Hows your driving position?
  180. tune up
  181. New To forums have a question.
  182. Can't Catch A Second Anymore
  183. Launch, Burnout, EtC.
  184. Pre-seafoam fuel economy was 17.8 mpg
  185. Wrecked ls1 formula, thinking of getting a gto next
  186. Opinions please
  187. differant ls6's
  188. cam swap info
  189. Can Anyone Tell Me What's Done Under The Hood?
  190. Borla owners; open exhaust or closed?
  191. 98 A4 Transmission Mount?
  192. 241 heads are for LS1?
  193. Engine idle for new cam and heads...
  194. new tachometer, help....
  195. how to cut rad. support for free ram air??
  196. headers
  197. Green Stuff??
  198. pacesetter tfx kat back
  199. Track #'s
  200. Motor mts for l'02 LS1 to '66 Vette
  201. z06 questions?
  202. i hate cats
  203. Throttle body cable linkage
  204. o2 simulators
  205. Cold start knock/ lifter or piston slap?
  206. What causes this?
  207. How hard is it to put a cam in a LS1?
  208. Patience pays off/spelling bee
  209. Stupid Question...
  210. Weird idle for first few seconds on cold start.
  211. Whats it worth?
  212. Carmax and there warranty??
  213. Starts great cold, but struggles to start/find idle when hot
  214. Carburated LS 6liter?
  215. My First Dyno Session...
  216. true dual clearance
  217. This was weird, any advice?
  218. Belt Tensioner problem after UD Pulley?
  219. To Restomod Or Not To RestoMod, Now This Is The Question
  220. Bolt-on results
  221. What would you do with 2000
  222. newbie question?
  223. O2 sensor problems after header install please help
  224. where can I get my TB ported??
  225. Y pipe
  226. Buildin' a 402'.
  227. CRT throttle body vs. Ported stock TB
  228. Rattleing over bumps
  229. 2002 Ss Original Exhaust Components For Sale
  230. What Do I Need
  231. 540 ci BBC TKO 600 vs. LS1 t56 HELP ME CHOSE
  232. Patients pays off
  233. Parts for a Camaro
  234. twin turbos
  235. hit the rev limiter did u screw anything up??
  236. Knocking sound when turning/ ASR Turning off
  237. uh oh! random knock
  238. Fast Intake and Nuked #7 ???
  239. need TB ported and is it worth it to get MAF ported too?
  240. Knocking/Grinding.
  241. LS6 ported heads? clutch? 00T/A
  242. Ram air kit
  243. What would you guys pay?(First Time LS1-Buyer
  244. How compatible are lsx heads?
  245. Differential Lockers
  246. how far to insert braided line into red AN fitting
  247. When will they fully restore search?
  248. Baffles help
  249. My car is dead!!!
  250. Fuel Pump
