- header question
- Sub-frame connectors question.
- oil pressure question
- Should I get a tune?
- identifying ls7 lifters
- Oil change light comes on then goes off Need help
- stock block HP
- Help with shift knob
- hp added...
- T/A magazine?
- What free mods can u do to a C5 coupe
- drag tires. which is best?
- Floor mats
- 4,500 rpm sputter...
- What!?!?!
- A question about engines???
- tires out of round???
- valve lift/power with rpm
- Where to get a parts numbers/catalog?
- Bad Fuel Injectors Causing Failed Inspection?
- Gauges
- what engine should i use?
- squeaking in back...
- finally got my lt headers on
- fuel pressure bouncing
- noise in engine
- Quick intro and first question
- new lifters what kind?
- Starting a LS1 build. Need advice please.
- MAF wiring
- Help disconnecting slave cylinder
- C5 Corvette
- Ticking From Lifters?
- ??? about 3rd brake light 98ss
- Weird noise in car?
- tune vs. shocks/swaybars
- gauge cluster background
- How does this setup sound
- crackling sound
- What ignition is this?
- ls6 engine
- how do you know if its a4 or m6
- Straight coolant?
- Got A SS!
- spark plug ques.
- AIR system question
- Shortblock Rebuilt!?
- Exhaust help for a newb...
- Intermittant wont start
- Dyno'd my car. Very disappointed.....
- how to blackout the front and back side markers?
- Need headers any suggestions
- swap a4 to m6 on a trans am ..is it possibble?
- Will kook's Y-pipe work with Pacesetters?
- Lights Flickering
- Completed LT install, funny noise
- What would make a more reliable 450-500whp set-up?
- Who Wants to guess!!!
- car check
- A.I.R. removal
- True duals..
- ram air question
- C6 Z06 rear end?
- Drag tires
- Need Help Calculating Final Gear Ratio
- need advice about installing headers.
- Sluggish motor
- 02 Camaro Z28 wont start, need help!
- Help needed BADLY
- really dumb question
- noob cubic inch question
- Some problems...need diagnosis please
- Dyno2003 profiles
- Need help spending money!!!
- Which setup?
- I hate to do this
- Planning Rebuild
- Missing Washer Fluid reservoir??
- Dash lights???
- grrr.....
- Plug problem?
- Aftermarket Y-pipe...who has the best ground clearance/price?
- horse power/torque
- Y pipes on 98-02 Camaros
- Not your same old headligt problem.
- Car shaking at idle
- OK, what color is my car!!?
- Mods that free up HP?
- air box clips
- valve noise
- my rather.. SAD ownership story.. and pics of my never ending project
- [B]10 Seconds on ALL engine???[/B]
- What mod to do first?
- Fan Switch Help!
- Anyone with MTI lid?
- Making my own?
- Shift Boot
- fan belt problem
- Just for instance...
- resonable price?
- oil change light on startup?
- Questions for '98 Trans Am convertible
- What order for mods?
- 10 Bolt/ 4.10 gear question
- 1st oil and filter change in ls-1?
- beginner mods -pros what do you think?
- ABSInop and ASR
- K&N Air Filter Assembly...
- How much hp will this add?
- TTop shades
- Oil Pressure!!! WAY TOO HIGH!!!
- Rod bearing?
- Faint knocking sound down low.
- which fuse....?
- Which Ls1 Car Should I Get
- What Next?
- Need gauge cluster wiring help
- slack in throttle cable
- Can anyone help
- Changing your spark plugs? READ ME!<pics>
- Royal Purple Purple Ice
- did the free ram air mod
- Traction HELP!!!
- 98 Trans am intake ?
- "Another" Wheres The Oil Going?
- LS1 NooB
- help on finding free mods
- My Dad trumped me, He got an LS1
- removing centre console
- for all you what is"PISTON SLAP"guys............
- mass air flow sensor
- SLP Lid Really worth it?
- Engine Knock
- problems shifting
- LS2 GTO vs 02 Hawk argument
- No power past 5k
- My Z28 Feels Slow?
- Relocation wires
- Probably a dumb question,But...?
- questions about 2001 WS6 TA
- 5252 Rpm
- wheres the oil going?
- Gear/Slicks Question
- My new 02 SS
- Decisions to make concerning upgrades-long
- Parking lights
- What kinda of MPG can i expect??
- PCV delete guys - How often do you change your oil?
- Quick and Easy Question
- BBk throttle body question?
- Cat warranty???
- 2500-3000 rpm stumble
- Critique my Setup...
- what is the ground wire connected to the pcv valve for??
- 2002 Ws6 Headers?
- '98 Z28 Door Chime
- quik fix. do you think it will work
- How Often Does Everybody Run Their Fans?
- How to remove the front grill?
- Trouble code P0174
- oil pressure
- Got my first LS1
- EGR Headers or Offroad Headers
- Confused WS9??
- Intake question.
- Exhaust for 02 Firehawk Suggestions
- 1st mod woo hoo!
- weird noise when trying to shift????
- Knocking when cold
- fuel gauge ?
- Stock LS6 cam?
- securety light stays on in 98 trans am?
- The best Spark Plugs for me
- Ram air
- new ls1 owner with wiring question
- oil change
- 799 Vs. 243 Heads
- help with 97 t/a tune up
- Wobbling crank pulley + oil pan leak... coincidence?
- Need book to guide a LS1 rebuild
- Solid Roller Lifter Adjustment?
- Help with Trouble on vacation
- How to tell?
- Exhaust Question
- RV cam 220/230dur/ 440/475lift Good?
- Does my car have the 1LE package?
- Coating headers??
- ses light
- Removing Cigarette Lighter
- 98 ls1 camaro engine rebuild or convert to ls2 ?
- Intake Manifold
- 2004 Gto / Ls1
- Headlights Shutting Off Car
- moisture in the pipe
- car jacked up wrong?
- hyperpac
- What should it cost to replace thermostat?!?
- stall on idle
- problem with shifter---pls help
- Service Engine Soon?
- CD player "Err"
- New exhaust
- head swap reliability (help)
- O2 Light
- lost hose
- need help
- Broke wires to sensor/power
- Sweet, first mod!
- Exhuast Question
- Quick question...
- Pin On/Bolt On Difference
- Adjusting Borla Exhaust!!?
- Gauge help
- typical prices for header install?
- Too high mileage?
- SES light on. I got it scan and this is the code.
- Hesitation at 2,500RPM. What is it?
- What next?
- Dyno Questions On Modded 99 Z28...
- help!!!!
- Need help picking new motor
- oil pressure dropped?
- New 1998 Camaro SS
- In the process of selling my car
- clickin
- Lights cant turn off
- Head Lights Now Pop Up When Alarm Is Armed??
- Charging/Voltage issue?
- What to do with $1200
- I want more hp for my daily driver help!
- Crazy repair cost necessary?
- Proud new owner of a 00 WS6!
- Lowering the car BUT......
- basic cam question
- Plugs
- Going to buy a 99 T/A today!
- First Z28, QUESTION!
- Help
- New car
- Help: Rear Hatch won't open w/o....
- a/c problems.
- pointers on installing ory & L/t...
- What the hell...
- Rev limiter...
- Nooooooobie Whats Up All
- wet nitrous guys in here please
- Lowering Gas Prices
- Where to find a new shifter boot
- What is a sequential tail light kit?
- air not blowing cold
