View Full Version : New LS1 Owners - Newbie Tech
  1. "c6 seat swap""
  2. lq4 whats the highest compression i can run on pump gas?
  3. Mod suggestions
  4. How to change running lights lens
  5. Ls?
  6. lq4. 12.1 compression?
  7. Air Conditioning Help Please!
  8. T Top ?
  9. Best way to clean intake runners and valves
  10. Newb needs advice
  11. chris1313 urgent hood latch question
  12. ls1 fuel sending unit
  13. "Tighten" Rear View Mirror?
  14. Need Help
  15. Need help with cam and stall size..
  16. Missfire
  17. Power Steering Help
  18. Plastic piece under car?
  19. LS1 upgrade help needed
  20. t56?
  21. Swapped 5.3 into 84 c10 wont start, please help!
  22. water pump ? belt jumping
  23. Getting exhaust fabricated need advice
  24. ..What mod to choose first!?...
  25. What air lid choices do I have?
  26. Long tubes and y pipe
  27. Need to know nut size
  28. charging light wiring
  29. heads OR 383 for a DD
  30. Where can I buy just an "I pipe"?
  31. LS1 Electronics + Cam help?
  32. Nicee..
  33. Im Going LT's/ORY... Just finished installing them!!! clip
  34. Bad mpg
  35. advice needed for a rookie's ls1 bottom end
  36. Torquing rocker arm bolts on LS1
  37. Fog light installation
  38. Metal Chunks found on oil drain plug
  39. 01 SS Y pipe question
  40. Reliability of cam car
  41. A little help for a rookie!
  42. ls6 intake
  43. LS1 vs LQ4 vs LQ9...which is better??
  44. True WS6??
  45. Does changing my exhaust mean I have to change my tune?
  46. heads and cam
  47. LS swap vs. Emissions Laws...
  48. Few newbie questions.
  49. Best place to get P&P TB with Bump Stop Mod
  50. 98 formula fan amp draw/ cfm?
  51. Difference between 10 bolt and 9 inch
  52. How to make it fit??
  53. Looking to buy an 02 z28...need input
  54. screwed up and i need help
  55. Trans am lights acting up
  56. Can't decide what path to take... Nitrous or Stall/Cam.. Your input please.
  57. Headlight changing
  58. LS1 intake manifold.
  59. Valve cover removal/serpentine belt?
  60. Super charger
  61. 2000 T/A Headlight Motor Polarity Issue
  62. Pacesetter headers
  63. A4 4.10 guys
  64. After some LS1/V8 advice?
  65. hi
  66. HVAC #74 socket part number
  67. New LS1 owner.....2002 Formula 6mt
  68. Quick coolant flush question
  69. FAST 102MM throttle body???
  70. Milled 317's
  71. New guy H/C swap
  72. help please asap
  73. fuel cell street setup
  74. hard to get into 1st and reverse?
  75. Oil cooler used for power steering cooler?
  76. My LS1/LS2 dilemna
  77. how to get a 5.3L swap to start and run???? HELP
  78. Ls1 Hot Cam 317 milling
  79. Porting heads
  80. Where is the weak link in my build?? Where should my $$$ go now...
  81. Traction control Kicking in Randomly during normal driving in my 2000 trans am
  82. Urgent help needed - Can you identify this pulley?
  83. agx
  84. input on this combo!?!?!?!?
  85. New ls1 owner
  86. Lowered car (abs inop/tcs off)came on
  87. with regards to ls3 5.3 or ls1 engine 5.7
  88. A couple newbie questions...
  89. Just bought 99 Z28....tune up time
  90. I have a few problems with my Camaro.
  91. Piston Slap
  92. Next Mod: Headers, Wheels, or WS6 Hood?
  93. New Owner with questions on where to go
  94. ls1 blowing bluish black smoke under WOT
  95. What are these parts called?
  96. Cold Start car only starts in first gear
  97. Stumbling LS1 at the dragstrip
  98. Motor?
  99. oil pan gasket
  100. slp cold air kit and jaam ram air together??
  101. 1998 C5 breaking up
  102. How to make a LS1 run in an Air Boat
  103. What would be a better intake?
  104. Best sounding/performing exhaust for the $
  105. Neutral safety/Backup light switch
  106. 3.73 gears
  107. 2005 5.3
  108. Name that plug
  109. Has anyone mated a 99-00 6.0 to a 4l60e????
  110. true duel xpipe required??
  111. Questions regarding an LS1 with milkiness....
  112. Magnaflow cat back muffler delete.
  113. '02 WS6 Fuel Tank Capacity?
  114. mid tubes vs long tubes
  115. what is high miles on a Ls1
  116. Always do you own work...
  117. ABS delete kit.. the problems .. **Urgent**
  118. 6.0 & L92 Heads
  119. Part number for corvet O2 sensor???
  120. 550-600rwhp DD?
  121. springs
  122. Spark plug gap
  123. I think I have a freak...
  124. Buying a POTZ throttle body ASAP! Do I need the MAF ends too?
  125. Best Spark Plug
  126. WILL NGK tr55 SPARK PLUGS FIT?
  127. Where's the thread with all the accessory drives?
  128. So I am currently in search for a 4th gen Trans Am
  129. SLP loudmouth exhaust missing elbow what degree is it?
  130. straight pipe or highflow cats?
  131. daily driver build
  132. what do i need to remove my a/c?
  133. New 383 in and tuned still some issues
  134. Cam??
  135. Cam-Only or Nitrous Shot
  136. Shifter knob question?
  137. Worthwhile first mods?
  138. How to delete my f***ing EGR
  139. What should my first mod be?
  140. thinkin about cheap engine build
  141. Intake tube length ?
  142. LS1 Options???
  143. Just finished a built motor h/c build, few small issues.
  144. Texas Speed Headers on a 2002 z28
  145. help
  146. 02 sensor simulator help
  147. Rear end help
  148. 5.3 basic questions
  149. car blowing coolant out of cap, but not overheating
  150. Air Lid, Ideas HELP !
  151. Higher oil pressure after oil change
  152. 2004 LM7 Questions.......
  153. C5 engine harness
  154. Why isn't my temperature gauge working?
  155. 5.3 Gasket Kit
  156. help
  157. New LS1 owner question....
  158. Don't know much exhaust. Looking for reccomendations
  159. SLP LT headers
  160. Formula or Trans Am ???
  161. Engine stand bolts
  162. Catalytic converters
  163. Does this sound like a fuel issue?
  164. Tuning to minimize cam idle loop?
  165. Noob Jackstand placement question
  166. SES light problem..
  167. New camaro seats in F body?
  168. Just bought a '98 M6 and I'm having trouble with the trans and clutch.
  169. New LS1 Owner.. Please help!
  170. Quick! I've got wet o2's...ok to drive?
  171. Headlight sync after new motor install
  172. SS SLP Info
  173. Hot Cam Z06 valve spring?
  174. Hoses for engine
  175. Anyone else have a hard time with the fernco coupling?
  176. ls3 crate motor with 4l60e trans
  177. Soon Corvette/GTO ls1 owner!!!!
  178. 2000 trans am where to start????
  179. Saving a high mileage LS1 with cam? or no...
  180. Head Removal / Options for 5.3 Truck
  181. help me troubleshoot driver's side running rich
  182. Getting to 150MPH stock. Can it be done?
  183. Replacing rear axel seals
  184. 99 Corvette Oil Usage! Bad!
  185. head selection help
  186. 02 CETA what is this part??
  187. bump stop with aftermarket tb?
  188. New fog lights orded
  189. Did a Few Free MODS
  190. Castrol Edge with Syntec 10w30 for summer, good choice or could've get a better one??
  191. Windage tray??
  192. 400 rwhp with bolt-ons?
  193. rings or valve seals
  194. what hos is this and what does it belong to?
  195. Reverse light issue(m6 to a4)
  196. New ls1 owner ticking/knocking HELP!!
  197. New guy with a C5
  198. cant figure out what injectors i have
  199. For those pesky tune ups and that horrible last spark plug! see this!
  200. Checklist for Header Install + Extra's, Do I have everything?
  201. 2000 vette ac problems
  202. 3.73 Gears and Dyno Question
  203. Quick question on a intake and cam on my 99 ws6 M6
  204. looking for a air box lid
  205. headers headers headers- HELP
  206. Blinkers
  207. Question about headers.
  208. Oil Pressure Question??
  209. Magnaflow Direct Fit Cats
  210. 98 ls1 no frc's??
  211. 7.5 10 bolt question?
  212. 5.3 SES light on / Tuner question
  213. Temp sensor problem
  214. 02 sensor noob
  215. need crank angle sensor camaro
  216. Valances
  217. Sending off my ls block and need advice on my build.
  218. Fuel pump/relay/other
  219. Lights flickering like strobe light, volts above 15, HELP!!!!
  220. Need help, corrosion on coils and plug wires
  221. 99 F-Body engine harness & PCM wiring diagram
  222. 2002 WS6 ignition issues
  223. Thick oil in oil pan
  224. LS1 240sx SWAP question's :)
  225. Flashing SES light after LT/ORY/poly mounts/plugs&wires
  226. Need help please
  227. question about ls6 intake
  228. Push Rod Length
  229. 241's LS1 Heads or 243's LS6 heads?????
  230. 2000 WS6 Trans AM LS1 swap to a LS3?
  231. Hello ls1tech .. got questions about my camaro
  232. 862 Heads swap on my 99SS
  233. Should you run "regular" gas or "premium" in a WS6?
  234. need help with vin#
  235. Possible New LS1 Owner
  236. Ls6 Manifold install
  237. Trying to get my stock 02 Camaro SS to 400hp, any suggestions??
  238. Want a Procharged Fbody???
  239. First build and need help
  240. Hellllp
  241. need help buying 2002 ws6
  242. Engine swap help
  243. throttle position cpu
  244. PLEASE HELP!...name that wire
  245. Help for 1998 Trans Am engine replacement
  246. 10 bolt rear
  247. biggest tires on 17'' rims
  248. G-Body with 5.3 which cam?
  249. header wrap
  250. Ls1 overhaul
