View Full Version : New LS1 Owners - Newbie Tech
  1. LT1 or high mileage LS1?
  2. you guys' opinions?
  3. T/A head light question
  4. Weird gas tank question out of curiosity...
  5. Jet opinions?
  6. Just bought high milage LS1. Questions. *HELP*
  7. z06 mass sensor
  8. need fast answer...what battery should i get
  9. Trans Am OR Ws6
  10. Questions from a new LS1 owner
  11. SLP installed options question
  12. ashtray
  13. 14,250 a good price for.....
  14. emissions:to delete or not to
  15. tubular k member
  16. Rear hatch squeak/rattle
  17. howling noise between 25-60 MPH
  18. White smoke from tailpipes during dyno run
  19. Just Bought a 1998 Trans Am
  20. Tire rod replacement?
  21. High Pitched Drill Sound On Start-up
  22. After one week of ownership, car dies on hi-way....
  23. Exhaust
  24. holley/lingenfelter ls6 intake coolant lines?
  25. blackbird stripes
  26. I need help what should i do
  27. horsepower
  28. setting keyless entry
  29. Did I hurt anything?
  30. I sold my Camaro
  31. So if my Firehawk has 345hp...........
  32. Opinions Please...
  33. Still looking
  34. GU 5 Gear Ratio?
  35. SS vs. Z28
  36. Will Kooks headers work with......
  37. Ram Air Question
  38. torque converter writeup?
  39. Skinnys
  40. Tranny Maintenance
  41. What would you pay for this car?
  42. Things to look for in a used ls1?
  43. 300 rpm idle
  44. How much more would you pay for 01 over 00?
  45. '98 - '99 Issues
  46. Proud new owner
  47. what mod to do next?
  48. Best Bang for the Buck? 3.73's or Underdrive Pulley
  49. Visual difference between Hurst and non-Hurst
  50. about a grand left...
  51. What does LS1 mean?
  52. LS1 to LS6
  53. Which is the better car #2 ?
  54. New to the forum
  55. What to buy with this money
  56. Difference between Corvette LS1s and Camaro LS1s
  57. Gas tank size ???'s
  58. Change oil indicator flash when engine starts
  59. Passenger seatbelt
  60. I'm almost ready to buy...
  61. Stock gear ratio in a 98 z28
  62. Inspecting a Used LS1. Tips?
  63. Dash electrical gremlins?
  64. Hey Now!
  65. What do you think of this?
  66. Questions about Seafoam(already did a search)
  67. Have About 1g to spend
  68. I Need A Carfax Report
  69. Saying Hi and wanting info
  70. C5 or GTO Purchase advice.
  71. speed governor
  72. Water temp gauge question...
  73. 205 miles to a full tank?
  74. New Trans Am M6 Owner Need Mod Tips
  75. Side view mirror help...
  76. car engine cleaning
  77. stock 02 Z28 LS1 going 7.94 in the eighth ?????
  78. oil filter change question...
  79. do drag radials have enough sidewall...
  80. Regular to synthetic oil?
  81. car has weird studder, what could it be?
  82. Lookin for a new hood
  83. T Top info needed
  84. spark plug replacement gone awry
  85. Carfax please!
  86. fuel filter/gas drain
  87. clutch problems
  88. can someone run this car fax for me
  89. whats a good asking price for camaro leather seats?
  90. bmg ram air or free mod or both?
  91. backfire
  92. Header install ?
  93. SLP question
  94. whats next?????
  95. I Need heeelp Nitros
  96. loosing power
  97. Where can I find my paint code???
  98. Will it hurt..
  99. LT1 vs LS1 Need Help Please!!
  100. What Octane for a certain compression ratio?
  101. Gettin an T/A
  102. Loudmouth 2
  103. What's needed for full exhaust swap
  104. Casper V-plus Volt booster, worth buying?
  105. Question about buying used parts
  106. How to find Dyno for benchmarking?
  107. ? clueless a little help
  108. Anyone ever ship a complete engine?
  109. New guy from Sweden
  110. New Clutch
  111. Which car is the best of the two? Help
  112. Help
  113. 7-0, for now..but im a bit bothered..any suggestions?
  114. Picking up a 98 Z28 in a couple of days
  115. how much for a dyno tune?
  116. OBD port for LS1's
  117. Newb Here. Federal Emissions Warranty question.
  118. where are the cats?
  119. car is bad
  120. How do you know when your cars are clogged?
  121. cats or long tubes
  122. Free Mods?
  123. Rear Cover or Lid?
  124. Just bought an 02 Z but the inside stinks (literally)
  125. Oil too hot?!!..
  126. whats wrong w/ my SS
  127. Let us Review
  128. Should I Change My Oil?
  129. Differences of 98-02
  130. Air Filter Tray Part Number
  131. How will the car be running after these mods ?
  132. Rear End Vs Cam
  133. If my car has been sitting for a while.....
  134. how much is a 5.7 LS1 worth?
  135. New Tachometer
  136. Carfax please!!!
  137. CarFax Pretty Please....
  138. Anybody thinking LSx engines are not that good?
  139. Stock RWHP ratings for 2000 SS M6
  140. March Pulley Problems?
  141. WHICH Fuel System Cleaner?
  142. SETUP q...help please
  143. air lid question
  144. Which car to buy?
  145. Rear Main Seal !
  146. Which baffles to put back in???
  147. PATMAN...please come in.. (engine oil)
  148. Engine coolant ?
  149. replaced the wrong o2 sensorer
  150. 95 T/A with Ram Air????
  151. stock thermostat temps??
  152. Can anyone help define some engines for me?
  153. Got a RWHP ?
  154. New member...Old car
  155. What to do next??
  156. need good tuner
  157. what year did Camaro LS1 ......
  158. Waterpump suggestions, and other ?'s
  159. illustration guide for A/C blower fan check/replace?
  160. Tb bypass
  161. any ideas what a c5 with these mods would run?
  162. For Sell "95" Chrysler LeBaron GTC
  163. Which Gel top battery?!??!?
  164. runnin tooo rich
  165. How To Retrieve Ses Codes?
  166. LS6 intake swap a few questions.
  167. missfire??
  168. Weird surge/idel issues **TAKE A LOOK PLEASE**REPOST
  169. its time for an another episode of Name That Noise!!
  170. Brand new 2002 Trans Am
  171. 95 V6 to 350 carb Swap ?
  172. Why is my stock alarm doing this? Help!
  173. 1000 to spend... what to buy based on my setup...
  174. what # ss ?
  175. Noise coming from steering column
  176. Anyone need a carfax?
  177. Whatt should I do?
  178. Some newbie ?'s (continuation from tb coolant by pass thread)
  179. stumble at cruise
  180. Finished spark plug change....
  181. ticking after seafoam
  182. Retarded blinker question...
  183. Turn signal problems
  184. Tire pressure for M/T STREETS
  185. Tips for doing a show????
  186. Silver State Classic Challenge
  187. What PSI
  188. LID with SLP Hood?
  189. Car won't start
  190. First Mods
  191. Howdy I think I bought a slow car
  192. Finally got some pics of car.
  193. Short in the brake light
  194. Gonna sound lame but.....
  195. need new engine, suggestions? (95 camaro)
  196. piston slap
  197. Got an 00 slp z28
  198. 01 lightning or WS_6
  199. K&N Filter cleaning question
  200. Taking Opinions
  201. 99 SS problems...any awnsers or ideas
  202. air filter
  203. Problem areas on 98-00 LS1 Camaro's
  204. Need Tires Question
  205. Programming 2001 Z-28 Remote
  206. Is this a good deal?
  207. whats the deal with lids?...
  208. ABS issue
  209. Does anyone elses engine "sound" change when you rev it?
  210. Bought my first LS1!!!
  211. Question about an '02 Z28.
  212. Looking for info on my new 98 Z28
  213. just I want help
  214. Day Time Running Lights, how do I???
  215. Camaro guys I gotta 02 SS need opinion on upgrades I'm doing...
  216. Coolant light, need some help
  217. tehnical qestion
  218. PCM question
  219. whats this car worth ??
  220. Free CarFax inside!!!
  221. Check Gauges Light Came On, Why?????
  222. spark plugs and cables
  223. How Long Does It Take To Piss Off The ECU?
  224. Crap, ad flyer down into my door ... help
  225. top speed gear selections
  226. 1/4 times for stock '98 A4 Z28
  227. Just bought LS1 TransAm
  228. CARFAX Please
  229. Stupid question about cleaning engine.
  230. Smoothing out "slides"
  231. went on a top speed run
  232. Power Tour...
  233. Its not an SS!!!
  234. Question about the airlid/whisper lid
  235. My first MODS!
  236. Changes through the years 98-02
  237. Best Mod So Far!
  238. Your immediate plans for your car(s)?
  239. Anyone have experience with dealers fixing rattles?
  240. Service engine soon light
  241. A-pillar gagues
  242. Strange noise when first accelerating hard
  243. Two mods checked off the List
  244. Moronic Newbie Question
  245. Got my LS1 two weeks ago
  246. tire recommendation...
  247. I think my carpet is restricting my gas pedal...
  248. Where can I find what number my car is?
  249. Valvoline Synthetic
  250. Pics of 2000 SS.
