View Full Version : New LS1 Owners - Newbie Tech
  1. Synthetic Oil question???
  2. Pregapped Bosch Platinum II
  3. Now you really can call me a snake
  4. Victory is Mine!!!
  5. Ngk Tr55
  6. Help
  7. Possible new F-Body Owner--Guess Who
  8. Slower w/ drag radials???
  9. What should I do first?
  10. Give your car some TLC
  11. nitrous kit or HPtuners?
  12. SLP or TSP
  13. clutch issues
  14. Front Tag inserts...
  15. Pictures of my new car 35th LE SS
  16. I have a question...
  17. Airbag Module Part Number
  18. getch questions please??
  19. Autometer Cobalt Gauges ... Possible to replace LED ?
  20. LS1s fall apart after 500hp?
  21. Newbie dyno question
  22. oil pressure
  23. Anyone have a 98+ Formula with W68 ground effects?
  24. Can anyone help?
  25. Question about electrical plug I found...
  26. Swimming Pool in Trunk?!?!?!
  27. Got my Page going and Updated
  28. What Is A Headlight 180 Swap???
  29. times
  30. Camaro Power Window Motor
  31. Its not the thermostat, so why is it overheating
  32. traction control
  33. Selling Exhaust
  34. What spark plug to use?
  35. Steering wheel shake???
  36. Anyone experienced speakers hitting against door panel?
  37. Help the camaro beat the civic
  38. Grinding problem??
  39. Just picked ip a 2002 z28
  40. Need part Number for Rear Hanger Mount
  41. What causes an o2 sensor to go out?
  42. Plugs Gapped Out of the Box?
  43. help...
  44. ls1 for sale
  45. ticking sound! need some info!!
  46. Locking gas caps exist for our 98 year cars?
  47. LS1- LS6 swap.
  48. pros and cons to the LS1 Alum. block?
  49. Always look when crossing a street
  50. F-Body stock times what are they? and...
  51. to any mechanics or chop owners out there
  52. Extra cash in the bank, what should I do to make car FAST
  53. Help, prothane tranny mount?
  54. Diablo Programmer (98 LS1)
  55. How do I display a picture in a message?
  56. traction control question.
  57. Need to know what this is?
  58. Gonna do my first mod and need some advice.
  59. Good Chevy Parts Dealer?
  60. MAF Sensor quick question
  61. how to ajustjust PHR?
  62. leather steering wheel falling apart
  63. Is It Possible??
  64. time to vent about my retarded car
  65. Bellows?
  66. LT1 T56 question
  67. On average, how much torque does a stock 02 LS1 have?
  68. Cam Swap
  69. Cam Change
  70. 6000 vortec
  71. T56 Question
  72. CAM ONLY times?
  73. What to do with $2000
  74. Looking for a C5
  75. True Duals..
  76. How does the AIR system work?
  77. A/C blows softer after long period of time
  78. A few quick Cam questions
  79. Cheapest place to get a 12 bolt or 9"
  80. weiland alum intake
  81. Car Idling Funny
  82. 1st post
  83. WS6 or Firehawk?
  84. How fast?!
  85. car wont start need help
  86. Book written by former mod?
  87. DOH! just dropped my mass airflow...
  88. times updated
  89. finaly picked up my new car
  90. All Around Tool Set Question
  91. Rear Seat Removal Question
  92. Is Converter worth getting if you don't drag race?
  93. manual/gas mileage
  94. Stock Shifter Stick Question
  95. Official: "How much u spent thread"
  96. WS6 Suspension
  97. $800.00 Budget
  98. Front end shakes at high speeds and light breaking...
  99. ahh... the squeeze of tight finances
  100. What color is my car?
  101. going from Shorties to LT.. should i?
  102. Car running hot.
  103. hydraulics clutch ?
  104. which car is faster?
  105. What's the difference...?
  106. wtf is a "four bolt main" (and other lingo)
  107. Z06 Rearend Size?
  108. Auto Math Calculators
  109. are 98's good cars?
  110. how many miles are too many on ls1??
  111. Trans mount
  112. LS1 world record
  113. new TB or port my stock one?
  114. LSX vs LS6
  115. Where is the starter located?
  116. Torque arm or control arms?
  117. All indicator lights go on and gauges sweep
  118. Possible to install a Apexi S-AFC on our cars?
  119. What gears for my setup
  120. How to get a freeway race started
  121. T/a at the shop!
  122. 1/8th mile time for stock ls1s??
  123. Carfax on car??
  124. PCV valve help
  125. Is it possible to roll back odometer on LS1?
  126. Wrinkles in quarter panel???
  127. Good hiding places ?
  128. how do I improve traction.
  129. 180 mod ???
  130. auto light
  131. What Does WS6 Stand For?
  132. TBODY for a 01 z28
  133. 1st 12 second pass in the new ride.
  134. top speed?
  135. stock wheel stud size
  136. Torque converter??? What stall?
  137. Which spark plugs should I use
  138. exhaust
  139. does your car ever get slow to you?
  140. shift light help
  141. driving lights not working
  142. How often should I change my O2's?
  143. Window Brush Replacement/Repair
  144. How Fast is an rx7
  145. Track times inside
  146. First fbody kill
  147. Mod money?
  148. Ticking noise.... solved!
  149. Birthday Ta
  150. What is this?
  151. Just outta curiosity...
  152. oil additives questions. Patman, hopefully you will see this!!
  153. New to list: Converting 94 GMC1500
  154. More Horsepower? More Torque
  155. Need help!!!!
  156. noise
  157. Lowest Profile and Smoothest Lid?
  158. next mod.....suggestions?
  159. 6.0L Builders need your advice
  160. Really fully loaded T/A?
  161. help! Need V.A.T.S. turned off
  162. Which FSM should I get?
  163. Please Help
  164. Throttle body bypass adapter?
  165. loudest meanest exaust
  166. Alignment shot, almost blew belt!!
  167. Warranty Info Please help!!!!!
  168. Need Help w/ lid!
  169. Pics of My "Black Hole Of Money"
  170. Forum Member Guidelines, or...
  171. Should I keep it?
  172. ticking noise
  173. How do I drop the gas tank?
  174. Oil
  175. LS-6 & LS-1 design differences?
  176. how to clean slp car cover??????
  177. Track ?
  178. cut-out's in
  179. CARFAX Please
  180. nittos or BFG
  181. AIR pump Qs
  182. ABS light
  183. how much does the camaro weight
  184. Front Headlight Issue
  185. Anyone have pics of a Maple Red WS6?
  186. piston slap got the best of me
  187. Need some help quick...
  188. Tach issues
  189. Stock cat pics
  190. How does the EVAP system work
  191. Vibrating Headlight Assembly
  192. goes anyone know here to find?
  193. Headlight lens Drama!!!
  194. Another "How Much HP" thread
  195. Anyone ever had their warranty voided b/c of a lid?
  196. trotle body
  197. What Can I Do NOW?!?!
  198. What to expect with cam and LT's.
  199. Making noises at wot
  200. Air Lid & Fernco Question
  201. my finalized plan for my hybrid
  202. Part Numbers Listing
  203. Qiestion about my hood
  204. Ls1 in a 240sx????
  205. HELP REQUESTED: Couple of coolant related questions
  206. What is the BEST PCV system mod?!
  207. Gas Mileage
  208. Not happy with Dyno results
  209. Keep blowing fuses...
  210. Will be a Camaro in 2007?
  211. What does WS6 stand for?
  212. SLP MAF opinion or is there better?
  213. Just saying hey
  214. Where is ur heat gage indicate?
  215. Smell
  216. Rims or finish nitrous install?
  217. to Spray or Not to Spray?
  218. z28 or trans am?
  219. Flowtech y pipe
  220. Just some info
  221. 35th anniversary door badge
  222. Positraction?
  223. Torque Arm ? M6 car w/Duals
  224. just installed ssf 3500
  225. Breaking in new ET Streets
  226. Newbie Intro - Come on in...
  227. New Guy
  228. Definition of "Bottom End"????
  229. C5 VS my SS??
  230. Need good advice, LS1 champs inside!!
  231. First time at the track with my Z28!!!
  232. WOOT! Pics of my 2002 WS.6
  233. ...car wont start :-/
  234. Choosing heads
  235. Tune Shops
  236. no start
  237. What does "forged" mean?
  238. LPE / Lingenfelter GTO
  239. "service engine soon"
  240. Camaro Is Back ! ? ! ? ! ? !
  241. finally some pictures of my new Z28
  242. Gmmg?
  243. how to gain more torque..
  244. 95 Gauge Cluster in a '00 Car.
  245. Quick Question.. I'm headed to the track...
  246. WSrice?
  247. EGR Removal
  248. Upper radiator hose can get scared by pulley
  249. Do I really need the EGR?
  250. i got a problem.. want to help?
