View Full Version : New LS1 Owners - Newbie Tech
  1. I'm getting closer just need a little more guidance
  2. Good tune shop in Central FL
  3. For those that wanted charts on the latest dyno session
  4. Help Me Please! Calling All Ls1 Experts!!
  5. Found perfect Z28
  6. Factory Build Sheet?
  7. E.T estimate and which header/exhaust?
  8. A4 powerband
  9. Heeeeeeeeeeeeeeeellllppppp
  10. Screws for Firebird front license plate cover
  11. Power shifting write up
  12. Cam without headers
  13. Need Suggestion what you think.
  14. ?Question?
  15. Cutouts
  16. Which mods?
  17. lS1 Edit ?'s!! Pros and Cons
  18. Girlfriend just bought a...
  19. oil usage normal??
  20. Urethane rear letter inserts?
  21. Loudmouths are Scary
  22. SEARCH is your buddy.
  23. WTF i can not put my jack back in correct
  24. Engine Oil Qestion.
  25. Auxilary emissions control
  26. Storing engine parts?
  27. Suspension Question
  28. Powdercoated Thermostat housing?
  29. Just checking avator
  30. What next?
  31. I'd like your opinions for the next dyno pull
  32. Lake Pipes?
  33. Airbox???
  34. 1999 Camaro Z28 question
  35. What to look for when buying a T/A
  36. 12 bolt and spring ???
  37. bfg comp t/a or headers or vig 3200 multi disc
  38. Alternator Issues
  39. Two Q's before I can get my LS1 (hopefully tonight)
  40. how much should i gain?
  41. How much would insurance be for me.....?
  42. Is $150 per month for insurance average for a 2000 trans am ?
  43. kinda funny story
  44. Posi Traction
  45. What is an RPM
  46. Clear Air Lid
  47. pvc hose collapsed causing miss?
  48. Need Help With Ssra Please !!!
  49. Debaffle Firehawk Hood or FTRA
  50. Help a noob Seafoam his LS1?
  51. LS6 Head Identification + Help
  52. Catch can for an 04 GTO?
  53. 1/4 et
  54. Borla true dual (pics)
  55. I should replace the factory Hurst shifter.....
  56. Lingenfelter cold air intake?
  57. New TB installed, idle too high, please help!
  58. mileage?
  59. Center Brk. light loose??
  60. Cam/Converter First???
  61. Blinkers!
  62. Air filter preference?
  63. Found out my SS had sort of a Frankenstein engine last night, lol.
  64. PLEASE READ! (Funny)
  65. How to out run a Z06
  66. v6 to LS1!!!
  67. Compression ratio
  68. I think i have a lemon z28
  69. Opinions and/or Projections?
  70. Running into other LS1 owners...
  71. Anyone having trouble with Ethanol blend fuel?
  72. quick question
  73. what are !Cags?
  74. New to LS1tech
  75. Just Getting to Know the Place
  76. CARFAX Report
  77. spark plug breaks in 1/2 stuck in head HELP
  78. What should I expect for ET?
  79. Carfax for a friend...
  80. ? about 0W-40 Mobil
  81. Questions quick...
  82. Will there be a difference in performance...
  83. how much are brand new jet hot headers?
  84. Need to drill and retap a hole. Suggestions for keeping hole straight as possible.
  85. Part numbers/Diagrams
  86. ws6 airbox vs. regular t/a airbox
  87. I cannot get air to come out of my vents
  88. I too have a CarFax request.
  89. LS1Edit
  90. Making car lighter
  91. launching a 6 spd
  92. &#$$%@@!!!!!
  93. Torque converter help
  94. Whats the casting number on LS6 heads?
  95. New Idler Pulley and Tensioner
  96. height issue
  97. Solution to car sputtering and falling on its face but idling ok.
  98. Car seems unusually slow after ssf3500 converter install???
  99. Header install tomorrow...
  100. CarFax Please
  101. Can someone explain !EGR and !AIR
  102. Alternator Question?
  103. looking for a few good shops
  104. Headlamp adjustment
  105. I have $500, suggestions on next mod
  106. Rear Shock nuts
  107. Anyone use sound dampening for the exhaust?
  108. limiter on headlight?
  109. Cold Air Kits
  110. Best of Tech!!
  111. Tranny swap question
  112. Checkin' in...
  113. drift with a z28 LS1???
  114. Firehawk has many faces?????
  115. O2 went bad AGAIN-help!
  116. I will give you an LS1..
  117. tornado fuel saver
  118. Question on O2 Sensors
  119. quarter et?
  120. Which company had the....
  121. My LS1 is here!
  122. Funny Site
  123. Under drive pulley
  124. Which BFGoodrich Drag Radial?
  125. loud "creaking" noise over bumps...
  126. CarFax for a '98 Z28 'Vert? :)
  127. What Price???
  128. how to stop wheel hop???
  129. Advice needed
  130. Old Z soon getting a new heart.
  131. What to watch when buying 98-02 T/A
  132. New Chevy High Performance
  133. Brand new motor with 300 miles on it now running like crap. Any help????
  134. More Horsepower or More Torque, which moves you faster?
  135. VT Coupe
  136. price of longtubes and true duals?!?!
  137. new car
  138. Decals and engine plaques?
  139. Oil ? for Patman...
  140. Can Somebody PLEASE Carfax this VIN!?
  141. What do ZO6's put down at the wheels?
  142. Anyone else upgrade from V6 to the LS1
  143. I Need Some High Qualty Pics
  144. Loving the LS1
  145. Short intro
  146. 580rwhp 98 supercharged 4.6 BS?!?!?
  147. new member, need trans advise
  148. Mod Question
  149. those with gmmg?
  150. Cooling Question
  151. rear end question, body shop guys
  152. Autocross events in the Kansas City area?
  153. Somebody hook up a carfax please :)
  154. C5 M6 vs. A4
  155. Bike rack on Camaro
  156. Uneven idle
  157. Removing !AIR Question
  158. knocking noise?
  159. cam question
  160. Turbonator? Anyone heard of this before?
  161. Headers and Y-pipe??
  162. pulley system
  163. Plug under d/s back seat. What is it?
  164. True water temp readings?
  165. Edelbrock shorties/nitrous/programer
  166. What valvesprings for the F11?
  167. In a bind.. tell me what you would do...
  168. got some money together....what next?
  169. Lucas Upper Cylinder Lubricant with Injector Cleaners: anyone use it?
  170. My Borla True Dual video...
  171. uh oh look what i found!
  172. tranny cooler?
  173. Help with Purchase
  174. Thinking of selling the Camaro!! Opinions needed..
  175. Whats the best motor oil?
  176. 02 Camaro SS with LS6 block?
  177. A Site every LS1 owner should see!
  178. K&N FIPK & Air Charger Kits
  179. 24,000 mile service
  180. Not typical "Which mods..?" thread
  181. Firebird Emblem
  182. Is there an epoxy stronger than JB Weld?
  183. What mods would be needed to get into the 11s????
  184. Head Unit
  185. Why do stock LS1s make so much power...
  186. First Dyno lastnight!
  187. What all would you need to get, to make the electronic/induction system on the LS1???
  188. 150 shot for $100
  189. Better for Racing D or OD
  190. HELP!!!, I'm stuck on lt1 hub
  191. Gearing question
  192. best X-pipe settup?
  193. GM Nationals in Carlisle PA June 18-19
  194. Hi Everybody!!!!
  195. why does my 1/4 mile time suck?
  196. Intake Questions
  197. Tire Help.. Best tires..?
  198. What can be wrong??
  199. Definately a little lost.....
  200. Need Carfax
  201. 3200, 3600, 4000...?
  202. how much....
  203. Getting some squealing from front of engine..
  204. 8 rwhp gain From oil?
  205. Honed but not bored
  206. People with Pro 5.0 and LSS
  207. PA Sniffer Test???
  208. Puckered Quarter Panels
  209. Are pulley's really worth doing?
  210. hp calculator
  211. Is the LS1 reversed cooled.
  212. t/a vs vt
  213. Cutout question
  214. Electric Cutout
  215. Bypass power steering???
  216. Engine temps
  217. maf adapter question
  218. Ss?
  219. please read this: formy wrecked ?????
  220. check engine light
  221. Looking for a few 1/10's
  222. High RPM noise ??
  223. Home dyno
  224. New Mods
  225. what is your opinion on free mods?
  226. ZL1 Headlight Mod
  227. Everyone doubts me..
  228. Have exhaust and airbox lid..now what?
  229. ?s for convertible owners
  230. Hey guys! Can you help me with a few things?
  231. Looking for Firebird in AutoCAD or MicroStation format
  232. soprano's - 4th Gen IROC-Z?
  233. Little smoke at WOT.
  234. Fog light replacement bulb
  235. Windshield Wipers not Working
  236. What are highest stock HP ratings for Camaros and TA"s
  237. Best place to buy QTP Cutout
  238. whats wrong with my car..?
  239. why is there that slight off idle hesitation with fuel injection?
  240. Help!!!!!!!
  241. power help!!!
  242. block and head combo comparisons?
  243. Plastic trim/clip/housing on driver's seatbelt
  244. Question about hurst skip shift?
  245. Who's Z28 is this (pic included)
  246. Newbie's wheel question
  247. Kooks Are Mounted!
  248. WOW, build #0001
  249. M6?
  250. selling car
