PDA
View Full Version : New LS1 Owners - Newbie Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109
  1. How do I display a picture in a message?
  2. traction control question.
  3. Need to know what this is?
  4. Gonna do my first mod and need some advice.
  5. Good Chevy Parts Dealer?
  6. MAF Sensor quick question
  7. how to ajustjust PHR?
  8. leather steering wheel falling apart
  9. Is It Possible??
  10. time to vent about my retarded car
  11. Bellows?
  12. LT1 T56 question
  13. On average, how much torque does a stock 02 LS1 have?
  14. Cam Swap
  15. Cam Change
  16. 6000 vortec
  17. T56 Question
  18. CAM ONLY times?
  19. What to do with $2000
  20. Looking for a C5
  21. True Duals..
  22. How does the AIR system work?
  23. A/C blows softer after long period of time
  24. A few quick Cam questions
  25. Cheapest place to get a 12 bolt or 9"
  26. weiland alum intake
  27. Car Idling Funny
  28. 1st post
  29. WS6 or Firehawk?
  30. How fast?!
  31. car wont start need help
  32. Book written by former mod?
  33. DOH! just dropped my mass airflow...
  34. times updated
  35. finaly picked up my new car
  36. All Around Tool Set Question
  37. Rear Seat Removal Question
  38. Is Converter worth getting if you don't drag race?
  39. manual/gas mileage
  40. Stock Shifter Stick Question
  41. Official: "How much u spent thread"
  42. WS6 Suspension
  43. $800.00 Budget
  44. Front end shakes at high speeds and light breaking...
  45. ahh... the squeeze of tight finances
  46. What color is my car?
  47. going from Shorties to LT.. should i?
  48. Car running hot.
  49. hydraulics clutch ?
  50. which car is faster?
  51. What's the difference...?
  52. wtf is a "four bolt main" (and other lingo)
  53. Z06 Rearend Size?
  54. Auto Math Calculators
  55. are 98's good cars?
  56. how many miles are too many on ls1??
  57. Trans mount
  58. LS1 world record
  59. new TB or port my stock one?
  60. LSX vs LS6
  61. Where is the starter located?
  62. Torque arm or control arms?
  63. All indicator lights go on and gauges sweep
  64. Possible to install a Apexi S-AFC on our cars?
  65. What gears for my setup
  66. How to get a freeway race started
  67. T/a at the shop!
  68. 1/8th mile time for stock ls1s??
  69. Carfax on car??
  70. PCV valve help
  71. Is it possible to roll back odometer on LS1?
  72. Wrinkles in quarter panel???
  73. Good hiding places ?
  74. how do I improve traction.
  75. 180 mod ???
  76. auto light
  77. What Does WS6 Stand For?
  78. TBODY for a 01 z28
  79. 1st 12 second pass in the new ride.
  80. top speed?
  81. stock wheel stud size
  82. Torque converter??? What stall?
  83. Which spark plugs should I use
  84. exhaust
  85. does your car ever get slow to you?
  86. shift light help
  87. driving lights not working
  88. How often should I change my O2's?
  89. Window Brush Replacement/Repair
  90. How Fast is an rx7
  91. Track times inside
  92. First fbody kill
  93. Mod money?
  94. Ticking noise.... solved!
  95. Birthday Ta
  96. What is this?
  97. Just outta curiosity...
  98. oil additives questions. Patman, hopefully you will see this!!
  99. New to list: Converting 94 GMC1500
  100. More Horsepower? More Torque
  101. Need help!!!!
  102. noise
  103. Lowest Profile and Smoothest Lid?
  104. next mod.....suggestions?
  105. 6.0L Builders need your advice
  106. Really fully loaded T/A?
  107. help! Need V.A.T.S. turned off
  108. Which FSM should I get?
  109. Please Help
  110. Throttle body bypass adapter?
  111. loudest meanest exaust
  112. Alignment shot, almost blew belt!!
  113. Warranty Info Please help!!!!!
  114. Need Help w/ lid!
  115. Pics of My "Black Hole Of Money"
  116. Forum Member Guidelines, or...
  117. Should I keep it?
  118. ticking noise
  119. How do I drop the gas tank?
  120. Oil
  121. LS-6 & LS-1 design differences?
  122. how to clean slp car cover??????
  123. Track ?
  124. cut-out's in
  125. CARFAX Please
  126. nittos or BFG
  127. AIR pump Qs
  128. ABS light
  129. how much does the camaro weight
  130. Front Headlight Issue
  131. Anyone have pics of a Maple Red WS6?
  132. piston slap got the best of me
  133. Need some help quick...
  134. Tach issues
  135. Stock cat pics
  136. How does the EVAP system work
  137. Vibrating Headlight Assembly
  138. goes anyone know here to find?
  139. Headlight lens Drama!!!
  140. Another "How Much HP" thread
  141. Anyone ever had their warranty voided b/c of a lid?
  142. trotle body
  143. What Can I Do NOW?!?!
  144. What to expect with cam and LT's.
  145. Making noises at wot
  146. Air Lid & Fernco Question
  147. my finalized plan for my hybrid
  148. Part Numbers Listing
  149. Qiestion about my hood
  150. Ls1 in a 240sx????
  151. HELP REQUESTED: Couple of coolant related questions
  152. What is the BEST PCV system mod?!
  153. Gas Mileage
  154. Not happy with Dyno results
  155. Keep blowing fuses...
  156. Will be a Camaro in 2007?
  157. What does WS6 stand for?
  158. SLP MAF opinion or is there better?
  159. Just saying hey
  160. Where is ur heat gage indicate?
  161. Smell
  162. Rims or finish nitrous install?
  163. to Spray or Not to Spray?
  164. z28 or trans am?
  165. Flowtech y pipe
  166. Just some info
  167. 35th anniversary door badge
  168. Positraction?
  169. Torque Arm ? M6 car w/Duals
  170. just installed ssf 3500
  171. Breaking in new ET Streets
  172. Newbie Intro - Come on in...
  173. New Guy
  174. Definition of "Bottom End"????
  175. C5 VS my SS??
  176. Need good advice, LS1 champs inside!!
  177. First time at the track with my Z28!!!
  178. WOOT! Pics of my 2002 WS.6
  179. ...car wont start :-/
  180. Choosing heads
  181. Tune Shops
  182. no start
  183. What does "forged" mean?
  184. LPE / Lingenfelter GTO
  185. "service engine soon"
  186. Camaro Is Back ! ? ! ? ! ? !
  187. finally some pictures of my new Z28
  188. Gmmg?
  189. how to gain more torque..
  190. 95 Gauge Cluster in a '00 Car.
  191. Quick Question.. I'm headed to the track...
  192. WSrice?
  193. EGR Removal
  194. Upper radiator hose can get scared by pulley
  195. Do I really need the EGR?
  196. i got a problem.. want to help?
  197. High Sulfur Shell Gasoline
  198. Word of advice... planning
  199. Which exhaust to get?
  200. Results After LSX.
  201. A/c Problem
  202. Hiya! I got me a 2000 Z28, Nice to meet you all :)
  203. I'm getting closer just need a little more guidance
  204. Good tune shop in Central FL
  205. For those that wanted charts on the latest dyno session
  206. Help Me Please! Calling All Ls1 Experts!!
  207. Found perfect Z28
  208. Factory Build Sheet?
  209. E.T estimate and which header/exhaust?
  210. A4 powerband
  211. Heeeeeeeeeeeeeeeellllppppp
  212. Screws for Firebird front license plate cover
  213. Power shifting write up
  214. Cam without headers
  215. Need Suggestion what you think.
  216. ?Question?
  217. Cutouts
  218. Which mods?
  219. lS1 Edit ?'s!! Pros and Cons
  220. Girlfriend just bought a...
  221. oil usage normal??
  222. Urethane rear letter inserts?
  223. Loudmouths are Scary
  224. SEARCH is your buddy.
  225. WTF i can not put my jack back in correct
  226. Engine Oil Qestion.
  227. Auxilary emissions control
  228. Storing engine parts?
  229. Suspension Question
  230. Powdercoated Thermostat housing?
  231. Just checking avator
  232. What next?
  233. I'd like your opinions for the next dyno pull
  234. Lake Pipes?
  235. Airbox???
  236. 1999 Camaro Z28 question
  237. What to look for when buying a T/A
  238. 12 bolt and spring ???
  239. bfg comp t/a or headers or vig 3200 multi disc
  240. Alternator Issues
  241. Two Q's before I can get my LS1 (hopefully tonight)
  242. how much should i gain?
  243. How much would insurance be for me.....?
  244. Is $150 per month for insurance average for a 2000 trans am ?
  245. kinda funny story
  246. Posi Traction
  247. What is an RPM
  248. Clear Air Lid
  249. pvc hose collapsed causing miss?
  250. Need Help With Ssra Please !!!
