View Full Version : New LS1 Owners - Newbie Tech
  1. **Trans Am Down :(** Help me confirm problem.
  2. Ported and polished fast 92mm throttle body, check out pictures.
  3. Best ls swap
  4. New car dilemma help
  5. first time at the track, I suck!
  6. Need more power
  7. circle track questions quick ish
  8. Help out the new LS guy!
  9. ls1 blocks prior to 2001?
  10. Will this Timing set fit??
  11. New injectors Vs. Resizing
  12. 2003/2005 - Gen III/Gen IV what a nightmare
  13. Camaro 2013 zl1 top speed per gear???
  14. Future LS1 owner ?'s
  15. 5.3 to LS1 Swap
  16. Define SAFE skinnies
  17. Methanol ?'s
  18. Need Advice On Performance Muffler
  19. 2002 ls1 swap for 2002 ls1
  20. Lq9 swap
  21. First Dyno Pull, need a few tips
  22. 317 heads
  23. Idler and pulley bolts.
  24. glowshift gauges??
  25. nitrous on stock 5.3
  26. 02 ws6 Air delete
  27. Blew my engine @ road america..looking for advice
  28. Slp intake
  29. 5.3l
  30. wont start after header install
  31. Nova subframe
  32. more exhaust ?
  33. headers
  34. First LS1 build!!!! NEED HELP
  35. set up question
  36. Ticking.. loudly
  37. What the heck is this wire? *PIC*
  38. Replacement torx screw wanted. (europe)
  39. ls6 intake question?
  40. losing brakes after full throttle
  41. Can someone please explain what the numbers in oil ratings are?!
  42. I just need help in general haha
  43. what brand electric cutouts
  44. How do I fix Fan wash?
  45. rear mount turbo?
  46. To Fly cut or not ?????
  47. totaled my built '94 m6,replaced it with a stock 2000 a4,and have a few questions
  48. fog light question?
  49. 2.73 to 3.42
  50. LS1 intake bolt question
  51. LS Chevy Engine Breakdown needed
  52. PCV fresh air hose...
  53. will no cats hurt performance?
  54. UGHH WHAT CAM lq4
  55. Painted ls block
  56. Hood hitting air lid
  57. Anyone know what this part is?
  58. Help with 5.3 to 6.0 Conversion
  59. Any benefit
  60. Calling fast 92 and 102 owners.
  61. Longtube headers fit?
  62. Dip Stick Length?
  63. What are these parts and what are they worth?
  64. V8 muffler on V6?
  65. 3600 stall
  66. Power steering question
  67. free mods
  68. need help choosing shorty headers
  69. project ls1 z32 dumping fuel # 3 cylinder plug soaked help.
  70. good harness, safe and "relativley" cheap
  71. stall help
  72. Forged Internals question from a newb ?
  73. 2002 SLP SS Emissions Test FAIL :(
  74. Gaping hole in A4 tranny
  75. Motor sitting for 4 Years???
  76. magnaflow universal 99175HM cat
  77. First time LS1 owner, 2000 T/A
  78. 5.3L options
  79. Need HELP!!! Fuel Tank Capacity 02 SS Camaro
  80. Intake Manifold???
  81. 2002 Trans Am fog lamp replacement?
  82. im need help!!!!
  83. Your most aggravating install(s)?
  84. Best valve spring compressor for the Fbody?
  85. Just got me a new 02 z/28
  86. trick flow heads combustion chamber chewed up cyl 7
  87. Clutch pedal fading to floor
  88. Cam in 98 camaro ls1
  89. Tick Master/Monster Clutch Stage 2
  90. Thinking about possible build options, stroker 6.0 comes to mind
  91. Cat or no cat?
  92. What cam???
  93. quick check on my marking compund please!
  94. Car sat for 3 years
  95. t-rex cam and good push rod combo
  96. LS3, Can switch it to a manual trans??
  97. First upgrade?
  98. Something wrong or expecting too much?
  99. muffler delete
  100. Going to the track
  101. C5 install issues
  102. In a bind, need some good advice, or HELP!
  103. LS6 Slp intake questions.
  104. another noob, asking opinions.
  105. First time taking apart an engine, need tips.
  106. Advice please on oil temperature sender fitment on 5.3 Vortec
  107. 2001 T/A Ws6 Ls1. Any ideas?
  108. exhaust
  109. Just got 2001 camaro ss HELP PLZ
  110. Question on egr tube
  111. Noob, First time owner lots of questions
  112. getting tune from Frost.. hows it work
  113. Front Jack Points?
  114. what would be an upgrade to this TB?
  115. Make New WS6 Faster!
  116. 200k 5.3 LS?
  117. new intake and throttle body
  118. Are LS1s noisy?
  119. 99 Camaro Headers and deleted AIR/EGR - do i need a tune?
  120. Is there a gain
  121. Understanding LS history. Interesting LS1,LS6,LS2,LS3,L99,LS4,LS7,LS9.
  122. 99 6 Speed
  123. What should I do?
  124. grade of oil
  125. Which pacesetter headers?
  126. 99' Trans Am potential?
  127. Race car project.
  128. What timing chain to go with???
  129. wolfe 6 point bolt in, advice please
  130. head gasket?
  131. 1/8 mile help ..stock 02 z28 a4
  132. lq4 cam options with T-5 trans
  133. clutch line issues(quick disconnect)
  134. Just bought a 98 Z28
  135. What muffler to get
  136. Help with CME sound
  137. Economy 5.3 build
  138. new to the modern thing
  139. Car keeps bouncing off my AC belt
  140. New to the ls1
  141. Normal valvetrain noise?
  142. Headers & Exhaust Leak
  143. LS1 drivetrain swap from C5
  144. Tick
  145. scangaugeII options/help
  146. Alternator question!
  147. Installing headers, need advice
  148. A Newbies Mechanic Journey
  149. Jack stand placement please help
  150. T56 reverse
  151. vendor that sells msd wires
  152. thought i share my first engine build and swap!
  153. Newbie Driveshaft question
  154. Lets spend $230
  155. Replace Bellhousing?
  156. LM1 exhaust questions
  157. stripper car 1sc questions
  158. from this, how can i tell if the car i bought has had a programmer?
  159. LQ4 Stock Internals
  160. Ls6 intake?
  161. stock springs on ported 243s?
  162. 317 OR 243 Heads LQ4
  163. when to get a tune
  164. Need help with a rpm question (newbie)
  165. fast help.please
  166. Looking at buying a block, whats the difference?
  167. 5.3/6.0
  168. Ls1 98-02 rear end
  169. Shave Rear Quarter Lip for Tire Clearance
  170. Narrowed rear what size wheels can i run? PLZ help
  171. Engine mount and trans mount question
  172. Engine Lift Points
  173. Ls2 engine swap won't start
  174. 4.8 and 5.3's
  175. Help me build my car
  176. 99 ta lq4
  177. Most HP you can recover from dirty fuel filter?
  178. anyone with frost mail order tune?
  179. shifter ID
  180. Lifter tick after oil change?? :(
  181. Possible transmission install damage
  182. Knock sensor problem
  183. No emissions headers
  184. Starting a minor build, got a few questions
  185. longtubes with no cats, not showing codes
  186. Coolant temp
  187. driveabilty with these mods?
  188. Plug change help
  189. How to obtain 500hp?
  190. Issues after shift light install
  191. very basic wiring
  192. Need a good name for transmission and auto repair shop
  193. cylinder head info
  194. newbie ?? what trans in a 02?
  195. Ls2 steam lines, need some help
  196. Need some professional help
  197. Lifters and cam swap
  198. Slp cam 51014 is this a good cam to run in my 00 camaro ls1
  199. 99 Z28 and Gates 38006 idler pulley
  200. pcv all messed up..heelp
  201. LS1 Block years and differences
  202. Help figuring out what year 6.0 block
  203. Crossover parts for ls1
  204. How to fabricate or where to buy mounting bracket
  205. How Long Do Ports Jobs Last
  206. rear end swap
  207. Frost tune or cat back?
  208. stock ls1 rocker trunions
  209. Hit the gas, nothing happens
  210. Throttle Not Engaging HELP!
  211. Water Pump Heater Hose Fitting 90?
  212. LS Newb
  213. Injectors for LT-LS swap
  214. IS this Normal?
  215. Wheelspin @ 60mph?
  216. LT/ORY/Cutout vs Catback
  217. Computer memory?
  218. LS3 oil pan
  219. Extremly high idle
  220. New to the LS1
  221. New to LS1 scanning
  222. QTP Long Tube Header. Paint? Ceramic coat?
  223. Milky oil w/ pic. Please Help
  224. reprogram your vehicle’s computer
  225. c5 z06 headers,exhaust....whats next?
  226. Oil fill cap replacement with breather?
  227. Headers?
  228. PCV Valve replacement options?
  229. 98 T/A cheap mods
  230. Lean, Backfiring, Rough Idle?
  231. Just got my hands on a 98 z28
  232. AIR Exhaust Manifold Bolts
  233. ls1 diagnosis
  234. 8.1 knock sensor relocate
  235. 98 c5 bucking and tac bounces
  236. Engine swap
  237. Water meth injection on naturally aspirated ls1
  238. LS6 Intake question
  239. Steering column swap question.
  240. How much coolant for a fresh 408?
  241. What is this and where does it go?!
  242. Loose throttle cable!! how do i adjust it?!
  243. Need help please before i burn something up!!!....
  244. NV3500 with a 5.3
  245. LS6/BBK intake manifold swap
  246. O2 sensors
  247. 98 z28 need help
  248. emissions/intake leak/bad o2 sensor
  249. Anyone seen or used the 1000 cfm MAF ends found on ebay?
  250. $10,999 swap
