View Full Version : Parts Wanted
  1. Drivers side speaker cup
  2. WTB 42 lbs green tops AND late model LS1 valve covers
  3. Wtb :passenger tan sun visor, tan t top shades
  4. WTB: TSP y-pipe
  5. air dam cheap!
  6. WTB ls6 zo6 cam
  7. Wtb d1sc
  8. Need rear shocks
  9. wtb short stick and air lid.
  10. wtb ls1 meziere "race" water pump
  11. parting out 98 z28..
  12. WTB 9" or 12 bolt plus 6.0 block
  13. ported LS1 tb
  14. WTB a cheap or broke T56
  15. needstock parts rear,trans , suspension etc
  16. Wtb ls1 backing plates & reluctor rings
  17. 6speed shifter boot clip needed
  18. Poly Mounts
  19. Longtube headers for a LS6 C5
  20. Complete carrier with 3.42 gears
  21. WTB 100mm maf and holley 90mm TB
  22. WTB G5X2 maybe an X 3
  23. Happy Hooker Engine Removal Tool
  24. WTB Happy Hooker
  25. Wtb: T56
  26. lowering springs
  27. Wtb: Stock ls2/lq9 pistons
  28. holley 90mm l76 intake
  29. WTB Panhard Bar-Non Adjustable-Black
  30. WTB: L92/LS3 rocker arms/stand
  31. WTB: Complete Set of T/A AC vents
  32. WTB: 12 bolt or 9" rear end near MI
  33. Front Subframe and/or clip
  34. wtb 1 SILVER SS WHEEL
  35. strut tower brace
  36. wtb lt1 94-97 camaro/firebird power steering pump
  37. WTB 2000 LS1 Emissions parts
  38. WTB LS6 Intake, heads (243 casting) and cam
  39. wtb asa cam
  40. WTB asa cam
  41. WTB: LS1 6-speed tailshaft
  42. wtb 3" mufflers
  43. wtb used transmission
  44. Need more engine parts.
  45. LS1 block???
  46. WTB: truck accessory bracket w/alt & pwr steering. I have PCMs, Harness to TRADE
  47. WTB: CHEAP Meth/Water Injection
  48. WTB F13 Cam
  49. WTB: Console lid for '98 Trans Am
  50. master cylinder hose
  51. Red fuse link box by battery.
  52. WTB: LQ4 or LQ9 bare block, 6.0
  53. WTB: 4L60e A4 stuff
  54. wtb ring that holds shift boot on
  55. WTB LS7 Bare block new or used
  56. wanted: camaro billet grill, clear corners, exhaust parts
  57. WTB Left Intercooler for P1SC Procharger
  58. LS3 Accessories
  59. ltx fuel rail covers and hardware
  60. WTB: LT1 engine
  61. 1 WS-6 rim
  62. WTB: 78mm HSW, NX, or NOS plate
  63. ls2 block wanted
  64. Billet Specialties Street Lites
  65. patrot springs
  66. wtb 17inch dr
  67. WTB: One (1) Pro Magnum Roller Rocker # 1318
  68. WTB: Torque Converter 3400-3600 Stall
  69. WTB 3 series carrier for LT1
  70. charcoal a4 console top /shift knob
  71. pcm case
  72. WTB Nitto 555r2 s 275 40 17s
  73. WTB: Stock Camaro Antenna
  74. 00 - 02 passenger cat
  75. WTB stock catback, 4" electric cutout, 4" cutout
  76. Lower spring perches(front)
  77. WTB Chrome Firehawk Wheel(s)
  78. WTB D585 truck coils with brackets #10457730
  79. WTB: 98-02 trans am LHS Tail lamp
  80. LT1 cyl head coolant line
  81. WTB: assembled LS3 intake manifold, assembled L92 heads
  82. WTB Stock power steering pulley
  83. 98+ convertible top frame
  84. Side mirror bracket and center console lid
  85. WTB Flat Dash Panel Black for 2000 Trans Am
  86. WTB-Clockspring #26069709
  87. Wtb ls2 tb
  88. Wanted to buy ZR1 Wheels
  89. wtb pacetsetter long tubes
  90. WTB miscellaneous interior parts
  91. WTB battery trap asap
  92. C5 leather seat covers
  93. Turbo
  94. Window Motor
  95. wtb pistons and rods for 402
  96. WTB (1) KYB AGX front strut or sell mine
  97. trq arm mount
  98. WTB: Turbo action Cheetah
  99. WTB 3.85" 8 rib Procharger pulley
  100. WTB ASAP: T56 stock shifer, LS1 Coils-brackets-harnesses
  101. Wanted: stall 2800-3600, wideband, vette underdrive
  102. rear bumper cover
  103. WTB - EFI Live V2
  104. WTB LT1 parts
  105. need a 1997 Interior wiring harness
  106. WTB: DG Dash Pad., AshTray Lid, RH SB Guide
  107. wtb drag wheels/tires for my TA!
  108. Need antenna grommet
  109. Wanted: 1999 to 2000 LS1 that has thrown a rod.
  110. WTB - Stock MAF
  111. WTB or WTT Bare LS1 block
  112. 99-02 PCM Bracket
  113. stock lt1 intake elbow and dashmat or pad
  114. wtb: dipstick, switches
  115. WTB YELLOW bird plate filler
  116. HPtuners
  117. WTB shortblock
  118. door panel
  119. WTB ARP 2000 rod bolts for Eagle h beam 6.125
  120. wtb: c5 zo6 maf sensor
  121. WTB: Front runners Pro stars or draglites
  122. wtb a clear air lid for my 00 camaro ls1..
  123. Wtb power Steering pump
  124. WTB lt1 cam
  125. Wtb tr224
  126. Fuel level sensor
  127. WTB Silver driverside fender
  128. WTB 08 Chevy Avalanche plastic quarter panel trims [pics inside]
  129. WTB: 2x Chrome 5 spoke wheels
  130. WTB: SS hood
  131. WTB Power Steering Pump Assembly
  132. Need a Shifter Cable (00' Z28 A4)
  133. WTB: Driveshaft
  134. need t56 rear extension tail housing
  135. Lt1 tb intake elbow
  136. Lt1 slp intake
  137. WTB: 95+ opti (factory or MSD)
  138. WTB Stock LS1 Throttle body
  139. wtb: 60# mototron injectors
  140. WTB: Corsa or GMMG exhaust
  141. Need ZR1's
  142. WTB F13 cam.
  143. WTB Oil filler neck for my LQ4
  144. WTB T56 or T5 setup
  145. WTB taillight harness for 94 trans am
  146. Stock Spring Perches
  147. Clutch Master hose and reservior Needed
  148. WTB Complete Wet Nitrous Kit
  149. wtb clutch
  150. 98-02 TA WS6 Shocks
  151. Floor Mats 1996 WS6
  152. wtb 3.89 gears for midwest 9"
  153. bring 6.0 parts
  154. Ebony interior
  155. WTB: ls7 clutch or better...
  156. WTB: Piece of trans tunnel (A4 car)
  157. 3.73 gears
  158. wtb ls1 oil pan
  159. Wanted - Stock Air Box
  160. Wtb: chassis and suspension components fbod
  161. WTB: rear hatch shocks
  162. wtb cheap heads 243 casting or better
  163. wtb ls1 6spd tail housing
  164. WTB stock rockers
  165. wtb ls1 poly motor mounts and ls7 lifters
  166. WTB manual window conversion parts T/A
  167. wtb ls1 t56 tailhousing
  168. I need Fast 90 or ls6 intake asap
  169. WTB 4.10's
  170. WTB Ebony Front Seatbelt(s)
  171. WTB:----- Motor mount CLAM SHELLS and POLY MOUNTS
  172. WTB solid motor mounts
  173. T56 3rd Gear
  174. wtb trans am parts
  175. Wtb, ws6 style ram air hood AND REAR DECK SPOILER IN NC
  176. hotcam or a cam for ls6 springs
  177. WTB: Aftermarket Cylinder Heads
  178. WTB: Subthump Sub Box
  179. 93-95 dash TransAm
  180. WTB non-egr Ls1 intake or cheap ls6 intake
  181. Wanted: RKsport and Wings West GFX
  182. I NEED ONE ZR1 17x9.5 OE Gunmetal Gray with Polished lip rim!! 56mm offset
  183. Wtb:powerglide w/brake
  184. Wtb drivers side a piller cover t-tops
  185. LS1m Interface Cable
  186. Wtb: 1998 ls1 pcm
  187. 93-96 gauge cluster CONNECTOR
  188. WTB G5X2 or G5X3
  189. Used- Lt1 Spec 4 or 5 clutch
  190. MAC Midlength Headers-99 camaro
  191. Greg weld front dragstars
  192. WTB: Passanger window switch trim
  193. WTB stock LS2 throttle body
  194. Cylinder head valves
  195. 4.10 gears for 10bolt
  196. Vigilante 2400 - 2800 stall TH350 TC
  197. Your old ugly headlights, LS1 style
  198. WTB full front and rear caliper set with brackets for 01 SS
  199. WTB: Some wheels
  200. WTB: CCW Dragpack for C5
  201. WTB ls6 intake manifold
  202. WTB Shifter cable for 93' camaro Z28 or any year that will fit
  203. WTB: Knock sensors and harness
  204. WTB: Motor and corvette exhaust
  205. HID conversion kit for a 2002 Trans Am wanted.
  206. WTB: SS Fiberglass Hood Struts and SS Scoop "Grill".
  207. WTB VALVE SPRINGS FOR .600 lift
  208. WTB Crank pulley, Power Steering Pulley
  209. clutch
  210. WTB 2 Tires (265 or 275 40 17)
  211. Firebird parts inside and out I need asap!
  212. tach
  213. 35th LE Wheel Center Caps
  214. WTB: One ss 10 spoke
  215. WTB Fuel Line Kit!!
  216. WTB SBC cam/valvesprings ect ect
  217. WTB Ls6 intake
  218. Wtb asa cam
  219. wtb tsp true duals
  220. WTB tubular K-Frame for 98 up F-Body
  221. WTB: AC hose and A4 dust cover
  222. drivers side window sweep
  223. NEED LS1-3 or L92 engine...WTT/B
  224. WTB Stock Sensors and other stuff
  225. lLSX emblems
  226. WTB: Motor
  227. WTB: LS2/LS6 clutch flywheel set-up
  228. WTB 224 cam for D1SC car
  229. WTB WS6, Raptor or Firehawk NBM Hood, 3 channel Rear end with 3.23-3.42 gears (98-02)
  230. WTB: 10 Bolt near Phoenix, AZ!
  231. wtb tahoe grey cloth sunvisor
  232. Wanted to Buy WS6 Hood and Front Bumpr for 2002 Trans-Am
  233. WTB: Lid
  234. wtb knock sensors good condition or new
  235. WTB: F-Body Alternator Brackets
  236. Wanted strut tower brace and nitrous parts
  237. wtb: arp studs
  238. wtb: -8 fuel line about 20 foot
  239. WTB: BCM from car equipped with Keyless Entry (LS1)
  240. Traction Control Cover
  241. wtb 02 extension for a 2002 camaro.
  242. WTB 243 or 799 bare heads
  243. WTB: Ported TB
  244. WTB: Coil covers
  245. WTB: LS1 T56 pedals
  246. wtb lt y pipe and cat back
  247. WTB throttle cable bracket
  248. Looking for 98 F-body front/upper dash
  249. need stock Ls1 parts
  250. WTB Parking brake mechanism 98-02
