View Full Version : Parts Wanted
  1. fuel selenoid,and fuel rail line
  2. need a few parts
  3. Wtb: LS1 346CI Shortblock
  4. WTB camaro clear corner lenses
  5. WTB LS1 rear calipers
  6. WTB LS1 front brake conversion (spindles, hubs, calipers, lines etc)
  7. 45,000 mile 4L60E with Yank PY3400
  8. Need Six speed Upper Console for Formula
  9. intake manifold bolts
  10. Need a turbo. WTT: 18" solox kicker subwoofer. 5000watts rms
  11. Rims for my 97 trans am
  12. High HP auto
  13. WTB LTI Stock SS Intake
  14. Crank needed ASAP!
  15. WTB: AJE BBC k member for foxbody
  16. LT1 Power Steering & Accessories Bracket
  17. OEM 98-02 Rear Bumper
  18. oil dip stick tube and dip stick
  19. Looking for an obscure T/A headlight part.
  20. WTB: stock '98 f-body cam and throttle body
  21. WTB: LT1 Turbo kit
  22. WTB ls1 non t-c throttle cable and cruise control setup
  23. wtb: 99-02 f-body computer
  24. lt1 t56 crossmember, torque arm mount
  25. single 317 head
  26. WTB: tinted/vht'd tail lights!!!!!!!!!!!!!!
  27. Wtb 17x9.5 and 17x11 torq thrust 2's
  28. wtb valve cover
  29. Wtb!! 17x9.5 and 17x11 billit specialties with tires or nice ccw or hre wheels
  30. WTB new gm radiator support
  31. ls1 oil pan baffle
  32. WTB: Car Cover for ls1 formula
  33. WTB: stock aluminum driveshaft
  34. WTB G2 Harness Bar for 4th-gen f-bodies
  35. LT's and ORY or X
  36. WTB: 12bolt gears, cover, and posi and meth kit
  37. WTB 9 in moser or strange
  38. Hypertech Programmer for 1998 LS1 Camaro/Firebird
  39. WTB 9 in moser or strange
  40. Need 02 camaro maf sensor
  41. WTB STS turbo kit.
  42. WTB : AI CNC 200cc GM LT1 heads.
  43. WTB y pipe and catback
  44. Need this asap!! Anyone have one
  45. WTB: ABS control module
  46. Need pcv elbow!!!!
  47. Catback system/wheels
  48. wtb:METH KIT, posi unit, 3.90 gears, and cover all for strange 12 bolt
  49. WTB: 76-88mm Turbo
  50. LQ9 Parts Wanted
  51. Factory PCM Covers
  52. Fuel Lines
  53. SFC's for 4th Gen
  54. wtb motor , and heads
  55. WTB: LQ9 Flat top pistons
  56. Throttle Actuator Controller (TAC)??
  57. 98-2002 Camaro/Trans Am Console and shifter assemble
  58. WT trade granatelli maf 94-97 lt1 for ring&pinion+bearings for pinion
  59. WTB Billet Fuel Rails with crossover or? WTB converter LS1 to th350??
  60. WTB: Set of 6.125 Rods
  61. WTB: K&N FIPK 98-02 Fbody
  62. WTB: HP Tuners Pro
  63. WTB: Lower Air Box + Lid
  64. WTB F1A procharger kit
  65. speedline ws6 wheels
  66. WTB FBody Pan, Fuel Pump, 4L60E
  67. WTB: Rear axle for 3 channel/non TCS 10 bolt
  68. needing to trade c5 vette rims+tires for lt1 electric water pump
  69. want 3.42 gear for 98 ta?
  70. WTB: formula bumper with foglights and sidemarkers
  71. cam for an lq9
  72. WTB 2 xr-1s
  73. WTB: Clutch braided hose
  74. WTB: Taillight for 1998 firebird
  75. WTB: 1 Gunmetal ZR1...maybe 2
  76. WTB:c6 z06 replica wheels
  77. WTBL c6 zr1 Replica's
  78. 6.0 bare iron block
  79. needed lt1 throttle body terre haute in area
  80. WTB LS1 shortblock
  81. WTB HP Tuners
  82. Wanted: drive shaft and wideband
  83. WTB prostars
  84. WTB: LS2 Timing Chain Tensioner
  85. WTB: Ram Air Intake
  86. W T B: 4thGen Front seat belts
  87. WTB: 98 Non-TCS ABS Control Module
  88. WTB: Pontiac logo center caps
  89. WTB: t56 hydraulic line and ls1 oil pressure sensor
  90. WTB: New/Used IAT sensor and Pigtail
  91. Wtb: t56 input shaft
  92. WTB Rear Lowering Springs
  93. WTB: Y-pipe
  94. whanted;;;ms4 cam,ls6 intake,ls6 and lt1 heads,converter
  95. need thrust block or paddle for torsen dif
  96. WTB:4l60e tailshaft housing, flywheel
  97. wanted: motor
  98. WTB 224 cam
  99. WTB ls1 intake bolts&valve springs even ls6 springs&TH350 to ls1 converter.
  100. ****Need a complete F-body LS1****
  101. Ls1 maf
  102. Wanted asap
  103. WTB driver and passenger ebony leather T/A seats!!
  104. wtt SpohnTorque Arm Crossmember for headers for a standard version
  105. LS1 f body oil pan
  106. Need oil fill neck/elbow
  107. SBC solid Roller
  108. WTT: stock black ss hood for VFN 3" SS hood
  109. wtb rear lowering springs
  110. Msd 6010 box
  111. LS3/L92 Shortblock!
  112. 98-02 Ramair/superhawk hood
  113. Wtb: Cc503 cam and accesories
  114. WTB: Third gen gauge cluster
  115. Wtb; aem boost controller
  116. WTB T/A Diff Girdle
  117. WTB: Built Short Block
  118. wntd electric cut out for 96 trans am
  119. Wtb camaro head lights good cond asap!!!
  120. WTB 96-97 SS SLP Ram air intake
  121. stock front struts...or
  122. WTB: Pacesetter Headers, Trans Cooler, 3k Lock Up Stall
  123. nitrous jets/ nozzle
  124. wanted- 90mm TB, and 85 mm MAF for 01-02
  125. WTB 2001-02 Speedline WS6 wheels...
  126. Wanted: Trans Am Front Bumper
  127. 383 pistons,Intake
  128. 4l80e info and a trans
  129. Need some mounts....
  130. wtb Driver headlight assy 99-02 t/a
  131. LS1 Crank Needed
  132. WTB 3" Muffler any will do!!!
  133. LS1 Power steering pump
  134. WTB: 2001 Camaro/Firebird Factory Service Manual set
  135. WTB: LT1 Performance Heads
  136. WTB: New belt and belt tensioner
  137. wtb non ws6 lower air box
  138. CME Valance
  139. A/C compressor for lt1
  140. WTB: Export Tail Lights
  141. WTB: Coil pack harness, Coil pack mounts, and LS1 sensors,
  142. WTB:1" Wheel spacer for f-body
  143. WTB Nitrous Bottle Opener
  144. WTB d1 procharger
  145. WTB: Ported Intake LS6 or BBK
  146. WTB: LS3 or L92 valve covers
  147. wtb spohn straight pipe cross-member
  148. tail shaft housing
  149. WTB Round and Square Coils
  150. WTB 17x11 chrome ZR1's
  151. WTB - 78mm wet plate, window switch
  152. WTB: Convertible top boot cover for Camaro
  153. Need front bumper cover and hood
  154. WTB -- Complete EVAP Canister and A.I.R pump
  155. wanted: 02-04 ls6 zo6 camshaft
  156. American Racing Rebel center cap
  157. WTB: 5.7 or 6.0
  158. Seeking 4L60E dipstick & tube from LS1 F-body
  159. WTB Oil pressure crossover plate aka pressure tree
  160. Wtb zexel block and bolt
  161. shift fork
  162. WTB: Fuel Injector Retaining Clips 8
  163. Left headlight bucket 93-97
  164. Power Antenna Motor+Mast / Rear Seat Speaker (monsoon)
  165. WTB: Goodyear GS D3 F'1
  166. d1 procharger
  167. Any one with a totalled out vehicle F-BODY! Need a part!
  168. lt1 starter
  169. WTT: Ported LS2 Intake for Stock LS2 Intake
  170. WTB C5 Z06 wheels or Y2k wheels
  171. Wtb red trans am passenger door
  172. WTB: LS7 Block - New or Used
  173. WTB: NBM Ram Air WS6 hood in Texas
  174. WTB stall converter
  175. WTT my Stuff for your procharger!
  176. Wtb t-tops 4 98-02 camaro ss asap!!!!
  177. WTB: Line Lock, Proportioning Valve
  178. WTB black leather seats ASAP!!!
  179. 4 inch stroke crank
  180. Trade a New 38mm WG for 44mm+...
  181. LS1/LS6 car style MAP sensor, intake mani. Bolts
  182. WTB 4.30 gears for Moser 12 bolt?
  183. interior parts
  184. WTB: Stall for 4L60E
  185. WTB: Camaro coil pack brackets
  186. NEED!!! 98-02 Black trans am front bumper!
  187. NEED!!! 98-02 Black trans am front bumper!
  188. WTB: center support Bracket for lsx camaro
  189. WTB 1998-02 center console
  190. Despeately need asp pulley for ls1
  191. stock maf in good shape and a set of o2 extentions.
  192. WTB F1A procharger kit
  193. kooks headers???
  194. WTT: CCW Classics and GSD3s for nice set of 18s
  195. Wtb:ms3
  196. WTB : Auto Shifter Cable Bracket 4L60E
  197. Where to buy an ultra z hood
  198. WTB grey ashtray lid
  199. ls6 cam....
  200. Rubber piece as part of intake system
  201. Wtb- Thunder racing 224 cam or =. And intake
  202. WTB: IAC sensor
  203. wtb: LS1 power steering pump, LS1 fbody steering rack/linkage, LS1 M6 driveshaft
  204. Wtb: 15x10 draglites
  205. WTB: T-56 for LT1!!!
  206. WTB : FAST 78MM Intake
  207. WTB: WS6 hood and torque thrust II'S
  208. WTB various 98-02 camaro parts
  209. wtb 3" v-band clamp asm.
  210. WTB AFR heads 225/ 72cc ls1
  211. WTB: Pass. side headlight motor for 00 TA
  212. WTB 7004 transmission for my 93 Z28 in FL only.
  213. wtt patriot stage 2 59cc for 64cc
  214. Wanted! 2 rear weld prostar wheels
  215. WTB: LS3,L92 Long Block m
  216. WTP: GREY 6-spd console top plate for 98 TA
  217. URGENT headlight motor T/A driver side.
  218. WTB-camaro starter ls1
  219. camaro or corvette engine accesory drive
  220. Torque Arm, adj and Tranny mount
  221. Looking for
  222. wtb timing chain cover
  223. WTB: MAC midlength Fbody headers
  224. wtb: 4l60e tb starter egr block off kit
  225. WTB: Which is better 3.73 gears or LS6 Intake
  226. EGR / AIR compatible with 2000 manifolds
  227. WTB: 2 Front wheels for SS (ZR1)
  228. WTB F-body heater/ac box
  229. WTB rear seat bucket 00 Z28 color code 19B Ebony Cloth
  230. UD Pulley
  231. wtb an lsx motor
  232. WTB late model Valve covers ASAP!
  233. Wiring and Screws
  234. i need SPEC Clutche
  235. i need SPEC Clutche
  236. wtb Evolution E-1 bumper
  237. WTB: 2000 Z-28 parts. exterior, DS, etc
  238. WTB LS1 Oil Pan and accessories pickup baffle etc
  239. T Top Weatherstripping
  240. WTB: Centerline Convo Wheels
  241. [WTB] Motor Mounts, P/S setup, Harness / PCM
  242. wtb: lsx Fast intake/tb
  243. WTB: 98-02 Black SS hood and Spoiler.
  244. wtb: stock a-arms
  245. Stock Clamshell Motor Mounts
  246. WTB: Stock Monsoon Radio, Tires in good condition
  247. Wanted: LS1 motor/t-56 any condition
  248. WTB short block
  249. looking to buy or trade. gray TT2's.
  250. WTB rear caliper brackets for a 98-02 camaro
