View Full Version : Parts Wanted
  1. WTB: Leather, center trim, Stock speakers
  2. Anyone parting out their car?
  3. wanted blk automatic cetre console just the top piece not the whole thing
  4. 4th gen red Passenger side mirror
  5. Need Clutch?
  6. Patriot gold springs and thirdgen wheels
  7. WTB 98-02 trans am Front Bumper
  8. WTB Headlight motor bracket. 98 trans am
  9. WTB: Stock posi
  10. WTB:Edelbrock Victor Jr. or Super Victor EFI intake
  11. 10 bolt rear with 4.10's --- trade for a 3.73 rear end
  12. Looking for a 6.0 ls2 steel block
  13. want to trade 98 a4 harness. for any 99 harness
  14. WTB driver door monsoon speaker ASAP
  15. Need transgo shift kit hd2 for 4l60e
  16. Stock LS1 Exhaust/ 02 extensions and Polys wanted!!!
  17. WTB: Center caps for Camaro salad shooters
  18. sensors needed
  19. O2 Simulators
  20. Export taillights
  21. WTB: ARP T56 P/P bolts & Low Mile MN12 T56 transmission
  22. WTB LS1 water pump 98-2002 Fbody
  23. looking for 3inch catback for my 94Z
  24. aluminum gas tank
  25. Slp loudmouths
  26. need tps and iac throttle body sensors and wiring
  27. WTB- Low mileage Bilstein front and rear shocks or equivalent.
  28. WTB: Valve Covers for LS1
  29. WTB : Clutch master cylinder fluid reservoir
  30. WTB Camaro Headlights
  31. wtb fuel rail and boost reference regulator
  32. WTB: 2 10 spoke 16 inch Camaro wheels
  33. WTB: LS1 Electric Fans
  34. Needed: Ebony floor mats for TA
  35. WTB - Front Bumper and Hood
  36. GM Chrome 5 Spoke 16X8
  37. 04 gto cai
  38. Wtb f/s door speakers
  39. steam / vent crossover tube, valve covers needed
  40. T56 Conversion / Swap for LT1
  41. WTB 6.0 shortblock
  42. need 2 chrome oem zr1 wheels for my ss
  43. WTB Front TTII's 17x9.5
  44. trade my 58mm tb for 52 mm tb
  45. wtb hp tuners
  46. 98-02 ss hood
  47. WTB M6 Pedals
  48. wtb a set of 317 heads
  49. wtb a rearend for my 2001 z28
  50. Need a 2wd 4L60e output shaft (98 and later)
  51. Need Rear Struts (F-body)
  52. wtb: ws6 Box
  53. Transmission?
  54. WTB: Mosier 12 bolt lcas panhard brakes full setup!!!!
  55. wtb ls1 good alternator
  56. looking for Z06 cam and springs
  57. WTT 4 10 spoke SS Wheels
  58. 1993 94 95 96 97 6 speed shifter boot plate and surronding console peice
  59. WTB 98-02 Firebird or Trans Am Front Bumper Cover and More
  60. WTT: MS4 cam 1500 miles....for a MS3 or close cam
  61. WTB: Fbody Hood Gasket
  62. WTB: Goodyear Eagle F1 GS-D3's 295/35/18's TEXAS
  63. WS6 center caps
  64. WTB: LS2, LS3, LS7 Crate motor stand offs
  65. headers
  66. Need Passenger side door sill plastic.
  67. Convertible Top Exterior Drivers Trim Triangle - (See picture)
  68. Bbk ssi
  69. WTB: Neeed good low mileage, clean/ready to run ONE LQ4 6.0L Piston
  70. WTB: Nitrous kit... 90mm Plate
  71. WTB Hood inserts 95 t/a WS6 hood
  72. WTB front ls1 acc with all brackets and ls6 intake and tb
  73. WTB: Built 4L60E
  74. LT1 fogs
  75. C6 z06 shift knob for fbody???
  76. WTB: M6 Poly Tranny Mount
  77. Wtb epp cam
  78. WTB Sail Panel Speaker
  79. Wanted: T56 Countershaft ASAP!!!!!
  80. WTT 2 oem 18" z06's for your 2 oem 17" z06's
  81. WTB: Carbon Fiber Valve covers / Motor Plate
  82. looking for a converter with some stall
  83. WTB LS6 intake manifold bolts
  84. WTT Complete 4" Mufflex Catback for True Duals
  85. Need a few ls1 parts
  86. WTB: coated LT's, and cam
  87. WTB: Front bumper for a 94 T/A
  88. Power steering Pump
  89. 9" third member needed
  90. WTB vented MSD opti.
  91. Center Caps for WS6 wheels
  92. Monsoon Audio 500 Watt Complete Sound System From a 00+ T/A
  93. want2trade my ls1 4 lt1
  94. Black Driver side sideview mirror
  95. WTB: HP Tuners for '98
  96. Wanted: Chrome Wheels 17/18 Zo6's or 17x11 zr1s
  97. Trade: Twin turbo kit for your D1/F1A FMIC setup
  98. WTB: Hotchkiss-BMR-G2 Springs!!
  99. WTB:good running 4l60e trans with converter
  100. WTB 2004 or newer connecting rods
  101. Wtb 96 Lt1 Timming Cover
  102. needing alternator asap in mocksville, nc
  103. WTT Black spohn lower A-Arms for Red UMI lower A-Arms
  104. WTT Red BMR upper PHB for Red UMI upper PHB
  105. WTT black BMR LCA's (poly) for your red UMI LCA's (poly)
  106. WTB catback for 99TA
  107. looking to trade 68 firebird
  108. WTB: Stock exhaust hangers
  109. Wtb 12 bolt rearend
  110. WTB AFR 205 Heads
  111. WTB/WTT: Full 4L60 to T-56 Conversion.
  112. mac off road y-pipe
  113. chrome 10 spokes
  114. wtb: loudmouth II
  115. Looking for some rims... for a 1999 trans am
  116. TRADE: MY 2 series 410's for your 273's (10 bolt)
  117. WTB: Trans cooler
  118. WTB:LS6 Intake
  119. WTB: Borla tip
  120. 1999 doors (Manual crank windows)
  121. torque arm and bolts
  122. WTT GTO Oil Pan (complete) for F-body Oil Pan (complete)
  123. looking for 98-00 maf and a fipk kn filter
  124. WTB: D585 coils with brackets and harnesses
  125. Trying to piece procharger kit together
  126. WTB: Bolt-in Relo Brackets, LCAs, energy suspension!
  127. WTB: Ls2, Ls3 or stroked for $5000
  128. wtt my borla adjustable cat back
  129. WTB: ATI or other 8 rib pulleys
  130. WTB Torque Converter and tranny cooler!
  131. WTB used low mile LS1 front struts
  132. WTT: Stock 18x10.5 Z06 whees/tires for stock 17s
  133. WTB PS Bracket & Alt Bracket !!!!! ASAP
  134. Wtb: Lt1 shortblock for boost 383/355
  135. 97 formula front bumber absorber
  136. Looking for a good used wastegate
  137. 1998-2002 front clip-camaro
  138. WTB Accufab 4 barrel 4150 TB
  139. WTB: (2) 295/35/18 tires
  140. Fuel pressure regulator
  141. a/c compressor
  142. JPR cam install tool
  143. WTB: eight ls1 pistons
  144. WTB: Hurst Leather Knob
  145. WTB 402/408 long/short block
  146. WTB: F-Body LS1 oil pan 98-02
  147. wtb- Air/Water intercooler
  148. WTB LS-7 Cam & Katech New Style Coil Brackets
  149. Gears 3.73 or 4.11 2 or 3 channel LMK What you have
  150. need ls parts..
  151. WTT SLP Dual/Dual for Magnaflow
  152. Passenger side rocker panel needed!!
  153. WTB: Hooker catback
  154. 2 corbeau racing seats
  155. WTB : Shifter boot & harness
  156. WTB lq4/lq9 shortblock
  157. WTB - Futral F14
  158. WTT: My Firehawk wheels w/ tires for your set
  159. ls1 fbody MAF
  160. Prokit
  161. WTB: 2000 Corvette Racetronix pump and harness
  162. WTB: 3rd Brake Light for 02 SS Spoiler
  163. WTB: Passenger Tail light
  164. LT1 refresh kit
  165. ls1 and lt1 injectors needed
  166. extended driveshaft
  167. WTB - stock LS1 fuel rail
  168. body parts
  169. wtb used stock 6.2 liter pistons car or truck type 4.065
  170. wtb used ls 6.2 block only car or truck type
  171. WTB: 97/98 LS1 PCMs
  172. wtb ls 3.90 inch stroker crank or 4 inch crank cheap? pm me
  173. Ls1 maf
  174. 02 WS6 A4 to M6 any parts?
  175. oil dipstick and tube 5.3 and exhaust bolts
  176. WTB: lowering bolts for 99 C5
  177. rims and n2o stuff - wtt
  178. wtb: Innovators West C5 8-rib pulley #843
  179. wtb: 2 black 17X11 ZR1 rims
  180. WTB: LS-1, LS-2, or LS-6 complete engine
  181. lt1 wiring harness and 95 ecm
  182. Pistons
  183. WTB: LS1 F-body engine accessories
  184. WTB/T: LS1 Headers/Ypipe
  185. Z06 stock camshaft
  186. Wanted gto seats 04-06
  187. WTB: Upper console shifter plate 6 speed 98
  188. WTB 99 formula or trans am complete body wireing harness
  189. WTB 918's
  190. WTT SVO 30# Red tops for 42# or bigger
  191. wtb 90 or 92mm throttle body
  192. WTB: LS1 Engine Compartment Fuse Box
  193. Amp rack
  194. Stock ls1 M6 tranny mount
  195. WTB: Set of stock chrome T/A rims - Must be excellent condition
  196. WTB: 3600 Stall.
  197. 15x3 draglites 15x10 draglites
  198. black ws6 hood
  199. wtb: .600+ valve springs
  200. Aftermarket LCA's
  201. Looking for a 98 Camaro ECU
  202. WTB Chrome C6 wheels
  203. wanted hurst shift knob
  204. wtb oem ss hood
  205. WTB 1998 Camaro right rear quarter panel
  206. WTB - stock rocker arms, good condition, low miles
  207. WTB 2002 Trans Am Headlight Wiring Harness Connector
  208. wanted 99 and up engine harness
  209. WTT: magnaflow catback for SLP Dual/dual
  210. lt1 slave cyl extension piece
  211. Looking for 9" or 12 bolt complete rear end
  212. Wanted - Grey Drivers side front floormat In nice shape .
  213. (1) MSD plug wire wanted
  214. WTB: Crank Pulley Install Tool
  215. WTB 4" Crank
  216. need black sun visors and power antennea
  217. WTB 315/35/17 BFG KDW's
  218. WTB 98 rs body kit
  219. WTB: Good Cond. Dashpad/Shift Kit/Cap/Rotor/Plug Wires
  220. In need of a posi unit.
  221. belt drive and balancer for D1sc needed
  222. WTB: LS1 Long Block
  223. LS1 return type fuel rail and injectors needed
  224. WTB or WTT magnaflow for slp loudmouth or dual/dual
  225. LS backing plates and e-brake cables
  226. WTB 6.0 LQ4 or LQ9 crank
  227. Wanted wanted wanted!!
  228. WTB shifter boot or upper console for t-56
  229. WTB: LT1 T56 swap setup PLEASE
  230. 18x10.5 z06 (single)
  231. I need a C6 Corvette LS2 oil pan
  232. Center bolt valve covers + Coil Brackets
  233. WTB: slp 2otl muffler
  234. WTB: New or Used Forged Shortblock build for boost
  235. wtb cam $200 in hand
  236. SLP lid
  237. Strano or BMR Springs
  238. WTB: ls1 starter!
  239. **wtb** 3000 to 3200 stall******
  240. WTB: Valve Springs!
  241. WTB 3" high flow cats
  242. wanted 2001 z06 cam
  243. WTB: LS1 Camaro Dash/Console
  244. Wtb: Lt4 knock module
  245. WTB: Cobra Heat Exchanger
  246. Wtb:injectors & tb
  247. QTP y-pipe
  248. WTB: beat up 17" wheels (10 spokes or ZR1s)
  249. WTB 02 fbody pcm and wiring harness
  250. i want to trade my 12 bolt for yours
