View Full Version : Parts Wanted
  1. wtb after market k-member for a 98-02 f-body
  2. WTB: Stock fog light for 98-02 Camaro
  3. wtb 4 silver 10 spoke ss wheels
  4. wtb: lt1 polished intake elbow
  5. charcoal console lid for 98 Trans Am. A4
  6. WTB: camshaft, cat-back, 6-spd swap
  7. Need LT1 Pass. Side Rear Caliper
  8. I need LS1 throttle parts.
  9. WTB : FAST computer system
  10. WTT 96 z28 black berger for green polo metallic berger
  11. wtb fab9 housing for 2000 camaro
  12. Yank Converter 3500 stall
  13. wtb dual valve spring kit good to .650 lift
  14. Parking brake stuff
  15. Front Caliper Mounting Brackets
  16. WTB:Black Ram air style hood in/near NJ
  17. wtb....15x4 PROSTARS....
  18. WTB: M6 Center Console (ebony/gray)
  19. Z28 Emblems
  20. SLP Bowtie Grille
  21. WTB suspension parts for drag racing....
  22. Shift kit
  23. WTB: Black Camaro/ Corvette 17" rims
  24. wtb: tail lights, hatch, etc.
  25. WTB: TSP 224r or 228
  26. WTB Adjustable panhard back
  27. Thirdgen Camaro parts wanted....
  28. need rear axle for 10 bolt
  29. Looking for Bigger RK Sport Spoiler, like the RS One only Bigger
  30. WANTED: BROKEN electric exhaust cutout
  31. M6 upper console
  32. Wtb bolt in 12 bolt rearend for 2001 Z28 Camaro
  33. looking for parts.
  34. WTB LQ9 or LQ4 6.0L (somewhat near TN)
  35. WTB:98-02 "Rear" Calipers, Brackets, etc.
  36. wtb 2 gt35r turbos
  37. 01-02 Ported throttle body
  38. WTB: PRC LS6 stage 1
  39. WTB: Blackwing F-body
  40. WTB Fiberglass Cowl Hood For Chevy Truck
  41. WTB LS1 valve covers w/ bolts 99 & up
  42. WTB a rev ss 2.02 ls1 intake valve
  43. WTB: LS1 Ram Air lid & filter base only
  44. wtb ls engine harness
  45. WTB or trade for a G5x3 cam
  46. Black ZR1's
  47. WTB X-pipe for PS LT,s and LT1!!
  48. wtb: front clear plate for 98-92 trans am/firebird
  49. wtb: 98-02 trans am wings west front lip
  50. wtb: 93-02 black or dark charcol grey B-pillars for t-top firebird/camaro
  51. LS1 GMPP hot cam wanted
  52. WTB: Fog Light Assembly
  53. WTB 243 or 799 LS6 Heads
  54. SJM ABS delete, Madman limiters, sya bars
  55. Stock ypipe needing in TX ASAP
  56. WTB: Stock 98-02 Camaro Grille
  57. WTB lowering springs
  58. WTB - TA Seats
  59. WTB: Looking for a CHEAP "any mileage" LT1 for back up engine.
  60. WTB: Edelbrock Longtube headers
  61. WTB: 5.0 Shifter ASAP
  62. WTT A4 set up for M6
  63. WTT: Turbo kit for heads/cam or 6.0L block
  64. Wtb-t56 core
  65. GM 847 cam
  66. WTB: 10bolt 3.42 posi with LS1 brakes
  67. Front brake caliper bracket
  68. ls2 intake/ cable TB
  69. 255 Fuel Pump
  70. WTB 1 ws6 wheel
  71. LS1 block wanted, cracked sleeves ok
  72. WTB gas pedal assembly-throttle cable
  73. WTB Misc. Interior Parts
  74. WTB M6 pedal assembly and M6 driveshaft
  75. injectors wtt/wtb/fs
  76. cam shaft
  77. Wanted: 4l60e
  78. Pacesetter Y pipe
  79. Stall 3600 plus
  80. WTB 2 18 Z06 chrome rims
  81. WTB LT1 a/c delete pulley and underdrive pulley
  82. WTB- '96-'97 LT1 timing chain cover
  83. LT1 Heads
  84. WTB: Air Injection Pipes
  85. WTB 90mm Nitrous wet plate!
  86. WTB Chrome Wheels and possibly tires with it
  87. WTB 4th gen backing plates
  88. need a/f gauge
  89. Wtb built 4l60e
  90. WTB or Trade (salad shooters).
  91. WTB: Heads, Stall
  92. WTB: Clutch m/c and slave cylinder for lsx fbody
  93. WTB lower shifter boot for 6 speed car
  94. WTB BIG injectors, 120 to 160lbs
  95. Wanted: Fuel rail & injectors, cam plate
  96. Wtb 2 245/45r17 & 2 275/40r17
  97. Wanted: Magnafuel 4303 Fuel pump
  98. need ws6 wheels asap need to drive to work and school
  99. WTB: Wings West Firebird/TA Front Spoiler and WS6 Ram Air hood
  100. wtb: ported 241s w/stock combustion chamber size
  101. WTB 5.7 block, rod and piston
  102. looking for etp 215 heads and 9 inch rear
  103. oil pan
  104. wtb forged ls1 crank
  105. WTB: TFS 215s 4" bore
  106. WTT Stall
  107. WTT: Weld draglites for LS6 243 heads
  108. H pipe true duals
  109. Wtb:stock 7.425 pushrods and springs ls6
  110. WTB: 6.0 iron block
  111. WTB 1 black Taylor 10.4mm
  112. Wtb intake/tb
  113. Wanted!!! Power Steering Pulley F-Body
  114. WTB: stock cats off 2001-2002 F-Body
  115. WTB:: SPARCO Seats
  116. WTB- LS2 bushing small end connecting rods
  117. V6 3.8L Firebird/Camaro Power Steering Pump
  118. Textralia Exoskel Twin Disc
  119. 12 bolt type 4
  120. Wtb: Asp underdrive pulley and lowering springs
  121. 93 lt1 harness
  122. wtb ls1 bellhousing
  123. wtb: STS Turbo kit for a 99 z28
  124. Need one ls6 243 head
  125. WTB one chrome ZR1
  126. Looking for the bolt that holds the dipstick.
  127. low milage t56 clutch and flywheel
  128. Wtb fast intake
  129. WTB Asap: Cheap, used/new stock clutch/flywheel/pressure plate
  130. wtb: 6.0 block
  131. wtb ls1 oil pan
  132. WTB Griffin radiator
  133. Wtb atl black box surge tank
  134. wtb upper control arms for f body
  135. WTB alot!
  136. WTT hollow bullet muff, for XR-1
  137. WTB-Stock exh & susp
  138. LS based Header flange needed
  139. WTB: Center bolt valve covers, coil brackets
  140. Flywheel from a 6.0
  141. ls7 clutch
  142. 1998-2002 Rocker Panel
  143. wtb stock LS1 crankshaft
  144. EGR and AIR for 2000 Z28
  145. WTB: Harness side injector clips & more
  146. WTB diff for 10bolt and other parts!!!
  147. WTB ls1(f body)motor mounts
  148. WTB: manual wire harness and pcm for a 05 or 06 gto and t56 gto tranny
  149. WTB 93 M6 engine harness
  150. 99 F-body Random Parts, used is fine!
  151. WTB: F Body Power Steering Pump
  152. WTB: T56 Tq arm mount. ASAP
  153. WTB 1988 GTA digital dash
  154. WTB nitto drag radial 18in
  155. WTB noz bottle warmer
  156. WTB: 18" TT2s
  157. Looking for a ls2 block
  158. WTB 3 inch ss hood for 98-02
  159. need stock valve covers for fbody
  160. WTB: 3.73 or 4.10 Ring and Pinion
  161. Anybody got a 3600 stall they wanna let go of in the Central FL area???
  162. th-350 conversion DRIVESHAFT
  163. wtb CCW drag pack
  164. WTB or Rent: Flycutting Tool
  165. WTB: Camaro Leather wrapped shift knob.
  166. WTB: 3 in y pipe
  167. WTB 16" stock wheels
  168. 95 trans am ac connection 2 main connections
  169. Clear Lid!
  170. WTB T56 F-body Shifter Cup
  171. WTB asap passenger side mirror
  172. WTB: Stock F-body exhaust manifolds
  173. Dash Pad
  174. WTB 35th Anniversary Camaro Wheels
  175. Weiand 871 Blower
  176. WTB Driveshaft for my t56
  177. 243 casing heads wanted BARE
  178. Ebony Rear Speaker Covers. 98-02
  179. 16" Stock Chrome Firebird Wheel
  180. WTB Silver Painted ZR1 wheels.
  181. I need a Flexplate!!!!
  182. 18' Fikse prof S5 or CC 505A wheels wanted
  183. Wanted HP tuners
  184. WTB: Dynotune Nitrous switch panel 2 1/16 gauge size
  185. t-56
  186. GTO oil pan
  187. WTB: 6spd Leather wrapped shift knob.
  188. 98 6-speed pcm and engine harness
  189. WTB HP tuners
  190. 99 trans am diablo predator
  191. WTB Passenger Side Subwoofer Box
  192. WTB gm 847 cam !!!!!!!!!
  193. WTT or buy T56 for LT1 & misc
  194. WTB: LS Center console 6spd and Pacesetter Ypipe
  195. 17x11 Black ZR1s /w Chrome Lip (2)
  196. Ported tb for ls6 & slp cold air kit
  197. 04 5.3 trailblazer o2 sensors
  198. LS3 Valves
  199. WTB 6.0 engine around Chicago
  200. F-body bellhousing
  201. Need 255lph fuel pump
  202. WTB LS2 & T56 Combo
  203. Front Ground Effects
  204. Need an ebony (black) A4 console top.
  205. looking for a 12 bolt r a 9"
  206. WTB 98-99 f body exhaust manifolds
  207. WTB Injectors
  208. WTB: Rear disc brake setup for LT1 F-body
  209. spohn k member
  210. wtb: Z06 ls6 Cam
  211. Misc lsx engine parts
  212. WTB manual steering rack
  213. 4 in cowl hood 2002
  214. 10 bolt needed!!!
  215. Wtb aqua green lt1 driver side door
  216. 98-02 camaro SS hood
  217. need a passenger mirror
  218. wtb morel hydraulic ls1 lifters new
  219. brake lines
  220. WTB Slp Bow-tie Grille
  221. WTB: Grinded Brake Calipers (front & back)
  222. WTB: fog light and drivers seat belt 2000 Z28
  223. o2 simulators
  224. WTB LC1 wideband with gauge
  225. WTB: 1998-2002 Headlights
  226. Lookin for a Turbo kit or supercharger kit!!!!!!98-02 F-body!!!
  227. WTB: Good Condition 94 Z28 Dash Pad
  228. wtb: ls6 cam!
  229. WTB title for 93-95 F body
  230. Coolant crossover tube
  231. wtb 383 ls1 stroker kit
  232. WTB 93-97 Ram Air Hood
  233. Looking for Iron Truck block lq4 or lq9
  234. WTB: BMR/UMI sway bar
  235. wanted: passenger (or driver in good shape) lower seat cushion 1993-95 T/A
  236. 60lb injectors
  237. super victor intake for LSx motor
  238. I need a TR224
  239. LS1 Shortblock (Clost to Texas if possible or would do shipping?)
  240. WTB: 85mm thottle body
  241. WTB:93-02 camaro black driver/pass side door panel bezel/insert
  242. WTB: Various Suspension, Appearance, StealthBox Stuff
  243. Interior in IA and misc parts for 93 trans am
  244. wtb:rear trans am passenger quarter 93-02
  245. Corsa Tips
  246. WTB front license plate filler
  247. Wilwood rear disc brake setup for Ford 9" housing
  248. WTB 98+ Spindles, Rotors, Calipers
  249. Wtb::::upper dash pad
  250. Ls1 motor
