View Full Version : Parts Wanted
  1. super victor intake for LSx motor
  2. I need a TR224
  3. LS1 Shortblock (Clost to Texas if possible or would do shipping?)
  4. WTB: 85mm thottle body
  5. WTB:93-02 camaro black driver/pass side door panel bezel/insert
  6. WTB: Various Suspension, Appearance, StealthBox Stuff
  7. Interior in IA and misc parts for 93 trans am
  8. wtb:rear trans am passenger quarter 93-02
  9. Corsa Tips
  10. WTB front license plate filler
  11. Wilwood rear disc brake setup for Ford 9" housing
  12. WTB 98+ Spindles, Rotors, Calipers
  13. Wtb::::upper dash pad
  14. Ls1 motor
  15. WTB: Center bolt valve covers...
  16. WTB Forged ls1 pistons
  17. wtb lt1 billet grille
  18. Need-Fbody Shifter Cup
  19. camaro ss gronund effect
  20. wtb stage 2 ls6 heads
  21. LT1 valvetrain stuff
  22. Wtb:::drivers side window motor
  23. WTB: LT1 EWP and Prostar or Greg Weld Skinnies
  24. springs
  25. WTB Idler Pulley Bracket
  26. WTB LS2 engine/long block in or near CT.
  27. 12 Disc Changer
  28. WTB front lowering springs
  29. corvette drive accessories
  30. 98 trans am front turn lenses
  31. wtb qa1 adj struts with springs
  32. 97-02 gray/graphite M6 console needed
  33. WTB - FAST intake bottom shell
  34. Factory Hurst Knob
  35. I need a REAL SS hood.
  36. WTB LS2 / LS3 Block
  37. wtb,,255 pump, 36 or 42 injectors
  38. ls1 m6 harness and pcm bellhousing
  39. Wtb: Ewp
  40. 1.7 LS1 Roller Rockers
  41. WTB: Single plane intake for LT
  42. WTB Reichard 3.75" 6 rib D1-SC pulley
  43. WTB dual electric 2.5 inch cutouts
  44. I need trans am seats!!!!!!!!!!!!!!
  45. looking for powerglide
  46. WTB LS6 intake
  47. Window Switch Wanted
  48. WTB both T/A running lights housing and sockets.
  49. wtb ms3 112 cam and 4 barrel tb or trade for my turbo cam or 90mm tb.
  50. a4 coolant lines wanted
  51. WTB front EBONY seat belts
  52. Wtt 3.42 for 3.73
  53. looking for boost loving 370
  54. need body parts!
  55. WTB: 94-95 M6 LT1 harness
  56. wtt or wtb 12 bolt dana 60 or nine inch
  57. WTB: Upper Dash Pad For T/A
  58. lt1 trans am cold air intake and intake elbow
  59. wtb cc503,1.6rr, ported heads, 3:73's, LT
  60. want ls6 hollow valves & sodiem style stock
  61. wtb used -02 - 04 zo6 cam 551 lift only
  62. Wanted Strange Single Adjustable Front Shocks for 98-02 QA1's also
  63. Fog Lights
  64. Cam
  65. oil blockoff, need one bad for my turbo feed
  66. wtt black cloth racing seat and harnesses for gray leather firebird seats
  67. Want 2002 - 2003 used zo6 cam 551 lift
  68. WTB a Lt1 Supercharger kit.
  69. WTB Stock Hurst SLP Leather Shift knob
  70. WTB Roadrunner
  71. Gears pulley
  72. Adjustable tq arm
  73. WTB U7193 diablo tunner
  74. LT1 short block
  75. body parts
  76. wtb: LS1 ENIGINE WIRING HARNESS AUTO OR M6
  77. WTB 01-02 10bolt rear, with single port abs slot, limited slip, 3.42 gear ratio
  78. WTB: LS2, LS3 or L92 engine - low mi.
  79. WTB: LS1 T56 core ASAP
  80. wtb Lsx intake ANY condition
  81. WTB Driver Window Motor, paypal asap.
  82. parts needed
  83. WTB fuel pressure sending unit for autometer gauge
  84. Stock LS1 Crank. Oil pan. Hi Volume Oil pump, various sensors
  85. wtb: TRUCK ACCESSORIES & BRACKET & LS6 Z06 CAM
  86. WTB a converter
  87. wtb a set lowering springs
  88. WTB: LS1 car coil wiring
  89. WTB: C5 Corvette Steering Rack
  90. Looking For WHEELS!!!!
  91. carb. intake
  92. MSD Wires/ Z28 16" wheel
  93. Rear End-Looking for a 4 channel-3 series
  94. wtb drag radial's 18" near atlanta
  95. WTB Camaro Seat or Seats MO area
  96. Wtb salad shooter rims in ct area
  97. WTT: Corsa Clones or Clear Lid for SLP Induction or Intercooler
  98. Interior parts
  99. WTB 87-92 GTA Wheels
  100. WTB SLP LS6 Intake with EGR
  101. RCI or Summit 20 gallon aluminum fuel cell??
  102. wtb used 30 lb svo injecters at ? lowest price pm your prices
  103. wanted used ls6 zo6 valves sodiem & hollow int. ex all 16
  104. WTB ported throttle body and underdrive pulley
  105. WTB kick pannels for cheap
  106. WTB - C5 OEM Z06 Chrome Wheels 01-04
  107. looking for an aftermarket shifter for a good price!!
  108. Trade 2 WS6 wheels for a nice Cam!!
  109. Ls1 Waterpump
  110. Want to trade my perfect grey cloth seats for Black or white leather!
  111. Coolant Crossover Line and Plugs
  112. WTB several interior parts
  113. 1.25x0.95 dom tubing
  114. Wanted!!! oil dipstick and tube needed, transmission dipstick also needed ASAP
  115. WTB 3 channel rear with 3.73 or 4.10 gears
  116. need a slp lid and
  117. water pump
  118. Wtb: Blown ls1
  119. efi live or hp tuner
  120. looking for afrs,tfs etp's or ?
  121. wtb ls7 lifters
  122. WTB: 98-02 Camaro tail lights
  123. WTB Front Hubs With Long Studs
  124. WTB- Corsa or GMMG cat-back
  125. WTB Bellhousing for LT1-T56
  126. wtb posi with 373's for 2 series
  127. WTB - Diablosport Predator - U7198
  128. Where to get bigger Valve covers!
  129. wtb 2000-02 complete ebony console
  130. wtb r rent flycutting tools asap
  131. WTB: Aftermarket Valve Covers
  132. need 9" or s60
  133. 96-01 polished or chrome WS6 wheels
  134. WTB...Synergy/Harlen 2 step box
  135. NEED! Hooker Lt's
  136. Grill
  137. Anyone looking for cme tips???
  138. WTB GTO parts (ls2)
  139. SBC 6.125 rod
  140. SBC crank
  141. WTB Trans Am Body Parts (Rear Bumper, Spoiler, etc)
  142. Stock 98-02 Lid
  143. wtb nitrous kit
  144. WTB 3 T/A dash vents.
  145. SBC mechanical lifters
  146. WTB: UMI/BMR suspension parts
  147. WTB: OBX Y-pipe or Y-pipe i can use with OBX headers!
  148. WTB: Coil bracket to valve cover bolts
  149. 98-02 Firebird Black Automatic Shift Knob
  150. Wtb ls6 yellow springs
  151. WTB- 4.10 Gears and install kit for-- 10bolt
  152. WTB: multi-function lever
  153. need injectors
  154. WTB 85mm MAF..
  155. WTB Oil pump bolts and pickup bolt
  156. WTB interior parts
  157. Deer smashed my car-2000 WS6 Arctic White
  158. WTB LT1 Headers...
  159. Stock crank
  160. Headers for 2006 GTO
  161. slp cold air lt1
  162. NEED ASAP! 5.3 Shortblock decent miles in TX or close
  163. WTB: 97-04 Corvette C5 engine stands/mounts
  164. WTB: port and polished throttle body
  165. want to buy new hp tunner
  166. Hptuners deal
  167. F-body 2000 driveshaft
  168. WTB: LS1, LS6, or LS2 engine, T56 tranny, wiring harness, etc...
  169. Full Dash
  170. 96 lt1 parts needed
  171. 16" zr1's
  172. wtb lt-1 mcleod clutch
  173. wtb.ls1 underdrive pulley
  174. WTF 93-97 WS6 Ram Air hood
  175. WTB stock head lights and tail lights
  176. wtb rear trans am hatch shocks
  177. wtb ls1 race parts
  178. WTB: 98-02 RKSport Camaro Body Kit
  179. 2 2000+ Z28/Camaro 16" (painted)
  180. wtb ls1 used torqe converter from 2500 - 3500 any brand
  181. wtb -02 - 04 zo6 cam 551 lift only
  182. wtb used l92 6.2 liter pistons only 8 stock
  183. wtb used ls6 zo6 hollow & sodiem valves int / ex all 16
  184. 98-02 WS6 hood or front clip wanted
  185. WTB Fuel rail
  186. wtb 295-35-18 and 275-35-18 tires, also black front camaro bumper
  187. Looking for LTs and ORY
  188. WTB RED strut tower brace
  189. WTB- Stock 93-02 V6 F-body front springs
  190. 16" drag radial
  191. WTB: 3600 stall
  192. WTB ported throttle body
  193. fog lamp connector
  194. wtb used ls1 stall converter 3000 - 3900 cheap $$
  195. wtb ls6 zo6 cam 02 -04 used
  196. wtb used ls 6.2 liter stock pistons
  197. wtb used ls6 hollow & sodiem filled valves
  198. Parts needed for 95 LT1 car! Bolt Ons mainly!
  199. I need a GMPP Carb Intake!
  200. LS6 Intake
  201. tunercat obdII (obd2)
  202. 12 Disc CD Changer Cartridge
  203. WTB 1990 ZR1 wheels
  204. WTB: TSP 224r Cam
  205. wtb 03 truck harness-paypal ready
  206. cutout cap
  207. Clutch & Flywheel
  208. blowen up head
  209. MSD or TAYLOR WIRES!!!!!!!!
  210. WTB:long tubes needed
  211. WTB:Idle Air Control Sensor
  212. Need a Transmission
  213. WTB: Fbody 99+ECU & M6 wire harness
  214. Needed Lower A Arms both sides
  215. LS1 Camaro Oil Pan, WTB, however...
  216. WTB Center console top And Seat belt holder
  217. LT Headers, Y-pipe, catback or duals
  218. Wanted to Buy: 98-02 Camaro stock 16" Chrome wheels
  219. WTT: My TR 230/224 for your MTI X1 Cam
  220. prostars
  221. WTB ZR1s
  222. WTT 295/35 18 BFG DR for 295/35 18 KDW
  223. Ls2 GTO headers with mids
  224. used procharger kit, or used TT kit
  225. WTB: LS6 valves
  226. WTB door panels
  227. trade my turbo cam for your ms3
  228. Spoiler please!
  229. wheels
  230. WTB oem red WS6 emblem
  231. WTB LS1 throttle cable bracket
  232. 4th gen f-body right front lca
  233. Trans am 98-02 hatch ( for sale)
  234. WTB!!! stock 10 spoke ss wheels or 18" zo6
  235. WTB ram air setup for LT1
  236. i need a ls1 drive shaft
  237. WTB: Aftermarket Catback exhaus for 05-06 GTO
  238. need pcv vent hose for LS1
  239. Tips needed
  240. 94-95 lt1 IAC
  241. wtb stock ls1 shortblock
  242. Wtb efi live setup..used..v1
  243. WTB: T56 Reverse Lockout Solenoid
  244. WTB:CME Valance
  245. I am looking for taillight blackouts!!!
  246. Manual cutout!
  247. fuel pump sleeve
  248. wtb black trans am door emblems.
  249. WTB: LS2 timing chain, LS6 oil pump and more
  250. vette wheels Wtb
