View Full Version : Parts Wanted
  1. Borla Exhaust Tips
  2. wtb full set of tt2's or ttm's 17x9-17x11
  3. LS6 intake manifold
  4. wtb used ls6 hollow & sodiem filled valves
  5. wtb zo6 cam 02-04 $100 shipped to 91722
  6. Wtb 6.0 ls iron block
  7. WTB: fuel injectors
  8. Greg weld 15x 3.5" stars and Hoosiers
  9. want to buy a alky kit
  10. push penny for hole on slp lid
  11. WTB/NEED Morel/Crane Link Bar lifters
  12. WTB: PS fender 98-02 firebird/ta
  13. WTB Drag chute
  14. WTB: Owners Manuals and Sales Literature
  15. WTB stock bore dome pistons
  16. LS6/Z06 cam
  17. wanted fuel pressure gauge
  18. wtb used stock lengh ls1 push rods 7.400 hardened
  19. wtb zo6 cam 02-04 $100 shipped to 91722
  20. WTB: Flexplate/Bellhousing
  21. WTB bottom plate for LT1 throttle body
  22. injectors and fuel rails
  23. in desperate need of 275/50/15 et streets
  24. WTB: 1 Center-cap
  25. trade lids?
  26. WTB GTO oil pan
  27. ORP, High Flow Cats. WTT CB for TD's
  28. pro stars or draglites
  29. Wtb springs
  30. WTB 04 LS6 cam or GT2-3 cam.
  31. wtb transmission
  32. rear axle housing
  33. WTB: Torquer V.2 or TSP 233/239 Camshaft
  34. wtb!!!!!!!!!
  35. WTB seat for 98 camaro
  36. WTB: Textralia EXO-SKEL Twin Disc
  37. Wtb 315-35-17
  38. WTB LS1 rear brakes
  39. 00-02 black interior needed.
  40. 6 speed console
  41. complete LS1 with all accesories-
  42. WTB: Fbody oil pan
  43. 98-02 ws6 hood for sale??
  44. zr1's for sale??
  45. wtb ls2 block!!!!
  46. Plate on LS6 intake manifold.
  47. T56 Yoke
  48. WTB: Stock radios
  49. looking to trade ls1 longblock for aftermarket rearend or performance parts!!!
  50. need!!! arp head bolts and fly cutting tools
  51. looking for 99 up LS1 engine harness
  52. WTB: Weld Wheels 15x8 w/ 4" BS
  53. rear panel screws
  54. standard bore lq4 forged pistons
  55. Wanted GTO starter/will trade for MSD 5096
  56. stock rear shocks
  57. WTB Alternator
  58. wtb lt1 maf
  59. WTB axle for 93-97 10 bolt
  60. WTB: Pass side cat '00-02 LS1 F-body (catalytic converter)
  61. NEEDED LS7 Lifter
  62. WTB: AC Belt Tentioner
  63. WTB: Window regulator 93-02 f fody
  64. WTB several things
  65. springs...
  66. 18x10.5+ wheels
  67. wtb: ss spoiler around kansas
  68. WTB/WTT Bose Driver side door speaker
  69. rear spare tire panel and left side windows defroster vent
  70. WTB Passengers side Firebird/trans am door
  71. stock 2000 ws-6 wheels
  72. wtb used ls6 hollow & sodiem filled valves
  73. ls6 zo6 cam 02 -04 used
  74. WTB SFC's, Short throw shifter, Floor mats
  75. 93-96 Center Consol lid
  76. LT1 Long Tube headers
  77. WTB: Center Console LID
  78. WTB: Sun visor
  79. 97 Firebird / Trans Am Gauge cluster.
  80. Throttle Body, Drive by Cable
  81. Draglite rears
  82. LS1 Wet nos kit wanted
  83. WTB patriot extreme dual spring also 7.4 ls1 pushrods
  84. WTB: Corvette front accessories
  85. Need a rear axle for a 99 camaro
  86. lt1 hooker y pipe.
  87. WTB 98-02 F-body oil pan
  88. WTB - Fbody carpet (no tan) - Fbody Manual Pedal Assembly.
  89. WTB Cold Air Intake or Exhaust(3.4 V6)
  90. wtb 2 electric cutout flanges
  91. Need A Rear End
  92. WTB: T70 STS Turbocharger
  93. WTB KB or Magna boost a pump
  94. WTB - MSD 6010 box
  95. fbody accessory brackets with or w/o accessories
  96. 98 gauge cluster
  97. WTB: Zexel Torsen 2-Series
  98. wtb asap shorty headers with egr
  99. sunvisors, headliner, center arm rest, ashtrey cover
  100. WTB: A factory hurst short throw shifter
  101. need!! asp pulley,100mm maf,fly cuting tools
  102. wtb interior parts
  103. Need good used set of headers 4 94 lt1 camaro
  104. stock lt1 camaro hood, and lowering springs
  105. WTB, good spec 1,2,3 or ls7 clutch
  106. wtb computer harness and tb 98-02
  107. WTB: LT1 Ram Air Box
  108. Ls1 t56
  109. 10" subthump box
  110. BFG 245/50-16 KDWS or KDW
  111. Need a Cherry Picker and Engine Stand in Miami
  112. looking for ls6 heads
  113. WTT 228/232 -112 LSA for 114+ LSA
  114. a4 parts needed asap
  115. Ashtrey Lid wanted
  116. Lowering Spring
  117. WTB: T56 Torque arm mount with hardware
  118. WTT: New NX wet kit for wheels.
  119. Pontiac 455 starter, 1st gen bird..
  120. Fuse Cover
  121. Need parts for 99 Camaro v6 to ls1 swap
  122. Bmr turbo k-member,stock c6 manifold
  123. HP Tuners Pro
  124. Parts
  125. WTB Ls6 Ported oil pump
  126. WTB: cheap rims for/with snow tires
  127. Need exhaust tips
  128. WTB stock lt1 k member
  129. >>Wanted: LS2/LS7 valley cover & cam sensor harness
  130. WTB: 228R Camshaft
  131. jounce bump stops pn 10164173
  132. Hydrolic Line
  133. WTT c5z06 for wheels+cash
  134. Edelbrock 65173 LS1 Conversion Shorty Headers
  135. Auto pedel assembly
  136. WTB: 98+ T/A side skirts
  137. WTB: rods and pistons
  138. WTB - QA1 adjustable front struts with springs
  139. Borla Adj/Catback
  140. wtb 98-02 camaro/firebird harness, computer and throttle body
  141. WTB Rs ground effect 98-02
  142. 245/40-17 drag radials
  143. LT1 Trans Am front bumper cover
  144. 9 inch rear
  145. WTB -6an N20 feed line
  146. Stock Oil Pan
  147. Tuner!
  148. WTB- Kook's Y-Pipe with or without cats
  149. wtb oem ss spoiler
  150. WTB: DOT approved tire for skinnies!!
  151. WTB NW or PTM 90mm Throttle Body
  152. wtb ls1 backing plates
  153. Wanted: Stock hurst T-56
  154. wtb 355 or 383 lt1
  155. WTB LS1 Cam for 5.3L truck, around the 220-224 range
  156. wtb 3600 yank stall
  157. WTB: 93-97 Trans Am Tail Light Harness
  158. WTB: 10" Driver side Sub Box
  159. car cover
  160. wtb bottle blankets black
  161. SLP ss grille
  162. WTT SLP DUAL/DUAL for True Duals
  163. Stock Cats off '01-'02 Camaro or T/A
  164. LF good deal on Drivers Side Door panel
  165. WTB: Griffin Radiator
  166. Iso cheap lt1 4l60e
  167. ~99-02 engine harness~
  168. WTB (2) Coil Packs and wires
  169. C6 Zo6 Rims (trade for my perfect c5's)
  170. WTT Corvette Acc. for GTO Acc.
  171. WTB NW 90 Throttle body (may consider other **EXCEPT** POS FAST90)
  172. Mild clutch setup (LS6, LS7, Spec I)
  173. WTB LS2 Stock fuel Rail--
  174. WTB : Catback
  175. I need this bolt from a headlight assembly hard to find!!!!
  176. ******wtb*****lug nuts full set***
  177. Wanted Stock Trans Mount A4
  178. WTB cheap rims for/with snow tires
  179. WTB Looking for Cowl Hood 98-02
  180. WTB: Stock car oil pan, car LS1+ intake
  181. WTB: Lot's of engine parts and engine bolts
  182. WTB: TR224 or 224XE Cam for 5.3 05 Truck
  183. WTB Stock clutch line
  184. WTB: LT1 TFS or Dart Heads
  185. WTB 9in or 12 bolt
  186. fbody balancer
  187. WTT GTO parts for car
  188. WTB: GTO headlight
  189. WTB:Nasty Performance Fuel Tank-Fbody
  190. WTB engine and transmission harness t56
  191. WTB: C5 18x12 Reproduction Wheels (DFW,TX)
  192. Wtb: 98-02 ls1 bellhousing
  193. WTB Stock LS1 Fuel Rails
  194. WTB:Lid
  195. WTB: Red LS6 Corvette Coil Covers
  196. brand new to this forum and looking for a 93-97 procharger kit
  197. Want to buy ls6 manifold.
  198. WTB: rear prostar's or summit stars
  199. need heads,and rocker arms
  200. wolfe 6pt bolt in roll bar
  201. Wtb: Gto shifter asap!!! (05-06)
  202. wtb GTO 04-06 Oxygen sensor
  203. Hooker ORY
  204. Wtb------strut tower brace------
  205. Hp tuner pro
  206. WTB: LS1 Foglight, bumper, and center console brackets
  207. WTB LQ4 or LQ9 block and crank
  208. Rear end
  209. Center console flip up, Radiator Support
  210. line lock
  211. WTB tan leather driver seat cover
  212. WTB: lt1 m6 flywheel
  213. WTB rear end for 98 SS M6
  214. WTT 2001 KX 250 Incredible hulk dirtbike for LS1 parts
  215. WTB 17 inch single ws6 wheel
  216. WTB T56 in chicago land area or with in reason
  217. WTB Exhaust + Lid
  218. wtb black rims
  219. WS9 Outlaw Hood
  220. Iroc wheels~!!
  221. harland sharp roller rocker (s)
  222. ss hood grille and ss emblems
  223. gto parts
  224. Nice used Clutch
  225. Subframe Connectors
  226. WTB 12 bolt or 9" 4 channel with TCS and ABS
  227. Wanted LS7 heads and the exhust manifolds
  228. Camaro clean corner lights...
  229. wtb ls1 stuff
  230. WTB: Corvette Engine Stands
  231. WTB: LS2 Intake
  232. ss third brake light
  233. WTB 12 Bolt or 9"
  234. Rear End/DS
  235. 275/40r17 Tires
  236. i need 4:10 gears
  237. ls1 ls2 or ls6 electric water pump wanted asap
  238. wtb zo6 stock valves hollow & sodiem filled all set
  239. wanted 02 - 04 zo6 camshaft
  240. Headlamp Assembly, Fender ( black)
  241. WTB: CCW SP500/SP550 or iForged Aero/Astra for C6 w/ZO6 rear quarter panels/widebody
  242. I need a T56
  243. console cubby
  244. 18" Drag Radials
  245. WTB POWER ANTENNA!!!! or reg one
  246. LT1 alum heads (casting number 374 or 643 only) LT1 manifold
  247. WTB: Factory SS suspension!!
  248. WTB: Driverside OEM speaker 01 Camaro
  249. WTB LS6 243 and shorblock
  250. WTB Torque Converter
