View Full Version : Parts Wanted
  1. wtb OEM SS spoiler
  2. wtb: tr224 114lsa
  3. WTB rear end
  4. WTB 17x11 Fikse FM5's Black Anodized
  5. WTB: Valve locks for LS1 heads
  6. WTB: Alternator 4-pin plug w/ pigtail
  7. ls1 alternator & pwr steering brackets
  8. 35th anniversey seats
  9. WTB 93-97 ss hood
  10. Wtb: Stock camaro amber corner markers/or black housing
  11. WTB top half of gauge cluster
  12. WANTED 94 harness 6 speed
  13. WTB: 3rd brake light (LED) for 98-02 SS
  14. WTB: Stock LS1 throttle body plate
  15. Looking for good set of stock 3.42 gears
  16. Wanted: 93-97 Camaro Front Bumper, Bumper Core
  17. bump stops
  18. wtb 00 WS6 Rim
  19. wtb: 98-02 firebird foglights & parking lamps
  20. WTB: LT1 cold air and 1LE elbow
  21. waterpump asap!!!!
  22. Wtb: 2001+ front coolant pipes
  23. 98-99 bell housing bolts
  24. WTB 02 Weather Pack fuse blocks/wiring
  25. Lt1 T56 crossmember
  26. Radiator support and cruise control module
  27. WTB broken electric cut out
  28. WTB: CCW centercaps
  29. WTB: LS1 fox swap stuff
  30. WTB: Ls1 Fbody Oil Pan, pickup tube, windage tray
  31. eboost 2
  32. Stock LS1 valves
  33. Magnaflow catback
  34. WTB: GTO T56 Bell Housing
  35. wtb driver side fender, long tube headers for camaro
  36. **We Need a Late Model GM LS1/6 block**
  37. wtb oil pump
  38. Wtb turbo xover pipe
  39. wtb. t56 shifter
  40. WTB:Stock C6 exhaust manifolds
  41. Carb Small Block and TH350
  42. WTB: Mint taupe T/A drivers door panel
  43. wtb trans am passenger eye lid
  44. WTT: black 17" y2k's for black 17" zr1's
  45. wtb gen IV engine harness, gas pedal
  46. wtb rockers
  47. WTB: T56 trans + parts for a t56 swap
  48. wtb used ls 6.2 liter pistons for 3.622 stroke
  49. wtb used ls 6.0 /// pistons 0.60 over bore
  50. wtb: stock fuel bucket uncut
  51. 94 lt1.. want ss hood, cam, suspension..
  52. Rear Control Arms
  53. Wanted:preformer RPM intake,please!
  54. wtb LT1 short or long block 350-396?
  55. WTB: F-body LS throttle bodies.
  56. 93-97 Front plate bracket Formula/firebird/Trans Am
  57. F-body A/C compressor, GTO shifter
  58. WTB manual windows? WTT for power?
  59. ls with manual and all acc.
  60. looking for a black fender for 2000 trans am texas
  61. Dash pad
  62. Need A 4L60E
  63. wtb used ls 6.0 pistons 0.60 over forged
  64. wanted used ls2 or ls1 forged rods stock stroke
  65. wanted used ls 6.3 or 6.2 liter stock pistons all 8
  66. wtb rear brake calipers
  67. Wanted: FAST Intake and TB
  68. like new fuel pump lt1
  69. WTB LS1 F-Body oil pan
  70. LSx power steering pump
  71. WTB: 04-06 GTO oil pan
  72. WTB: 93-96 Console Lid
  73. <<<<<<<<<<<<<WTB RAM AIR HOOD FOR 93-97 T/A "chicago"
  74. WTB Driver Side Window Motor
  75. WTB ls1
  76. Need ls1 y-pipe ASAP
  77. wtb: ls1 headers
  78. wtb or wtt for cme
  79. Wtb trans am headlight full assembly
  80. 99 ls1 coil needed
  81. clutch master cylinder line
  82. LS1 exhaust gaskets
  83. LS1 exhaust bolts
  84. WTB: Corsa Clones
  85. SLP grill
  86. Need tranny for 95 Z28.
  87. Wtb ls1 engine
  88. WTB: LT-1 Engine &/or Transmission
  89. WTB: Chrome 16x8 2002 Trans Am Wheel
  90. WTB: 99+ 6sp wiring Harness
  91. WTT: Zr1 & Welds for bogarts
  92. WTB: 5.3, 5.7, or 6.0 shortblock in good condition.
  93. wanted tr224 camshaft 112 lsa fair price
  94. wtb used 02 - 03 ls6 valves zo6 int. & ex all
  95. wanted used stock 6.2 liter ls3 pistons
  96. need 2 buy 3'' elec. cutout asap!!!
  97. wtb: LS1 alternator
  98. G.I/WTT 1987 Yamaha Exciter 570 L/C
  99. wtb trick flow 225's
  100. WTB aftermarket cyl heads
  101. wtb t56 parts
  102. Ls1 harness p/s pump
  103. WTB: SPEC STAGE 3 clutch
  104. WTT: headrest and shifter. WTB front gfx
  105. WTB: LS1 hot cam and z06 springs
  106. F.A.S.T 90mm Intake
  107. WTB Vizage body kit 98-02
  108. WTB: MAC or other catless Y Pipe
  109. Main cap for '86/7 block
  110. LS2 C6 MAF needed
  111. WTB: LT1 383 or bigger fully assembled block
  112. 99-02 camaro ss ground effects
  113. shocks and springs
  114. LS2 / LS3 front cover
  115. WTB 98-02 RH Tail light
  116. Need M6 swap parts!!!!!!!!
  117. looking for a 4in cowl hood for lt1
  118. Parts wanted!!!!!!!!!!!!!!!!!!!!!!!!!!
  119. WtB lq4/LQ9 block
  120. WTB: stock LS1/T56 pullout
  121. WTB: Charcoal Gray Consle Lid T/A
  122. I need an L76 Intake manifold
  123. WTB LS2 bare block
  124. Wtb headlights 98 to 02 trans am i
  125. wtb ls1 or ls2 oil pan
  126. WTB: smooth bellow,ebony visors,floormats...
  127. WTT: 12 Bolt for Narrowed 12 Bolt
  128. 4.8, 5.3 or 6.0
  129. W. T. B. LS1 Oil Pan, Waterpump
  130. WTB Stock Hurst shifter
  131. wtb: cc beehive or crane cams valve springs.
  132. Tan Leather Door Panels w/ dual speaker setup... PLEASE HELP!
  133. a few parts wanted
  134. wtb: lt1 heads
  135. 15in weld pro to stars
  136. ls6 and tb
  137. WTT corsa with pacesetter ORY for TSP true duals
  138. Looking for new wheels and tires
  139. I need a fuel injector connector!
  140. WTB: LS6 cam/springs/retainers/etc...
  141. WTB K member, oilpan, qa1 shock
  142. wtb grille& Ebony seat belt & seat trim 2002 ss
  143. WTB Super Charger
  144. WTB Long tube headers
  145. WTB F-body LS computer bracket.
  146. WTB LS engine stuff
  147. TA hatch, preferably pewter
  148. WTB: Cowl Hood
  149. C Clips
  150. Whistler headlights
  151. Tick clutch master cylinder
  152. Camaro mirrors (pewter)
  153. NEEDED: Engine parts
  154. Need many part to kuwait
  155. WTB single adjustable timing chain set. and othe cam/head swap parts
  156. TCS Switch!
  157. Weld Draglights, B.S., Bogarts!
  158. WTB: Long Tubes
  159. l92 or ls3 longblock
  160. need fbody front drive acessories
  161. 36# Injectors, 23x Cam (112LSA), LS6 Intake
  162. Borla+Dmh cutout trade for corsa
  163. wtb 2.05 intake valves
  164. WTB: Front Brake Line
  165. wtb: 98-02 trans am Wings West front ground effect
  166. looking for some 402 internals
  167. Wtb ls1
  168. WANTED- Fuse Box Bracket- Engine Compartment- 98-02
  169. WTB complete turbo/supercharger kit
  170. WTB: Shaft Mount Roller Rockers For Gen 1 SBC
  171. WTB Bare LQ9 Or LQ4 Used Block
  172. WTB new gmpp lsx block
  173. intake and TB
  174. WTB: Cheap n2o Kit?
  175. WTB Ram Air Hood
  176. 98 T/A Chrome 16x8 Wheels
  177. Need to buy Front Ground Effects for 2000 bird
  178. wtb LT1 harness
  179. 10 bolt ta cover
  180. ls1 coil
  181. WTB: window suports
  182. Wtb 275/40/17
  183. Ls1 t56 input shaft
  184. Oil Filler Neck and Cap
  185. WTB 243 heads
  186. wtb ebony interior pieces
  187. stock radio from camaro
  188. WTB Stock Camaro t-56 shifter
  189. WTT...17x9.5=17x11 blk Zr1's
  190. Looking for a SLP LOUDMOUTH
  191. WTB: stock Bose CD for C5
  192. WTB: LS6 or other ported oil pump
  193. headers+y pipe
  194. WTB: '98 stock F-body LS1 exhaust manifolds
  195. WTB:Aftermarket TPI intake and runners
  196. WTB: C5R Timing Chain - New
  197. 10 Bolt Rear End Cover
  198. WTT: Prostars
  199. WTB Front Tires that fit 15x3.5" Weld Pro Stars
  200. F-Body, Stock Lower Control Arms (rear)
  201. 93 starter..
  202. WTB xfi 292 or xr294
  203. automatic pedals
  204. WTB: STB for '98-'02 LS1
  205. wtb: ls1 performace parts
  206. Wtb Black wheels for 99 t/a
  207. WTB: 7.425 Pushrods
  208. passenger side valve cover
  209. Looking for a torsen carrier and 3.42's
  210. Good speakers
  211. lt1 parts!!!
  212. wtb 98 m6 ls1 harness
  213. Looking for LS1 Alternator, Power steering pump and brackets
  214. slp longtubes
  215. WTB: 7-1/2" x 3" Mecham exhaust tips.
  216. WTB: Black Headlights
  217. wtb: freedom design wing or rksports performance wing
  218. WTB air conditioning stuff
  219. wtb prostars 15x10 7.5bs 15x3.5 with drag radials and lt1 rear breakes
  220. WTB LSX tubular k-member
  221. WTB: motor 500+ N/A 700+ sprayed
  222. complete ls1 and t-56
  223. WTB: Cruise control module
  224. Wanted: Stock 243 (LS6 or LS2) Heads
  225. 00 SS grill insert
  226. Shifter Cable Wanted
  227. lt1 fuel rail covers
  228. wtb c5 alternator
  229. C5 Corvette ATI blower bracket
  230. wtb supercharger for a c5 vette
  231. WTB Painted Z06 wheels
  232. wtb:: rear bumper cover
  233. wtb: 4:10 gears!!
  234. Wanted: LT1 SS Hood, LT1 SS Spoiler
  235. Want 2000 Trans Am Rear Bumper Cover
  236. WTB Raptor hood and other goodies.
  237. WTB:Patriot Gold Valvesprings
  238. WTB: Shifter Boot / E-Brake Boot
  239. WTB ls1/ls2 shortblock dfw area...
  240. i need o2 simulators asap!
  241. wtb ls2 fuel rails
  242. WTB: trailblazer ss wheels
  243. WTB: Complete Clutch for Ls1
  244. Stock LS1 flywheel....
  245. need 99-02 ram air hood, Trade for VFN
  246. WTB Traction Control Cover
  247. pro kit
  248. wtb trickflow 235's
  249. Looking for a Magnaflow catback
  250. Wtb aem uego
