View Full Version : Parts Wanted
  1. WTB exhaust tips
  2. WTB: LT1 Heads
  3. wtb. 2 z06 motorsport wheels
  4. WTB License Plate Filler (Pewter) for '02 T/A
  5. wtb chromoly adjustable panhard bar
  6. WTB Beehive springs & Roller Rockers - LT1
  7. abs wheels wanted
  8. wtb lt1 valvetrain stuff
  9. WTB: LS Center bolt valve covers and coil brackets
  10. YTK Rim Cap also looking for upper dash
  11. WTB: 6.0 shortblock or complete unit
  12. LS6 valley cover?
  13. Looking for a 3" catted y pipe
  14. 99 under hood wire harness
  15. Y3F/SAP Package Passenger front spoiler.
  16. in need of tires
  17. wtb rear end
  18. Line lock kit
  19. WTB Patriot Performance Dual Gold ValveSpring Kit
  20. HSW 78mm wet plate
  21. WTB: Auto shifter assembly
  22. Front pair of drop springs
  23. WTB: 3 series differential
  24. Need 98+ Firebird transam Passenger tail light
  25. ***Want to BUY Factory Head Unit***
  26. lt1 intake elbow
  27. WTB lt1 6 speed conversion
  28. Wtb Lt's For A Sb Chevy 350
  29. LS6 intake
  30. WTB TH350 and other parts
  31. wtb ls1 shortblock and lowering springs
  32. WTB Big and littles for my GN
  33. WTT - Wolfe Six point roll bar
  34. wtb 98 or 99-02 computer and harness
  35. WTB C5 Hubs/Wheel Bearings
  36. WTB LS1 F-body Clamshells or solid mounts and dipstick tube w/dipstick!
  37. WTB 60 lb INJECTORS FOR LT1
  38. Carpet for 2001 SS - grey/black - NO TAN
  39. iron 6.0
  40. Wtb Lq4
  41. Hi flow cats
  42. I need clutch master cylinder hydraulic line. Will pay $20!!
  43. oil filler neck, tranny linkage cable
  44. WTB: SLP Firehawk Deck Mat
  45. wtb 98 - up trans am headlight kit
  46. LT1 T56 Conversion
  47. WTB Turbo or Procharger Setup
  48. Need a 3 Series Posi Unit for my stock 10 bolt
  49. WTB Converter
  50. silverado maf 85mm
  51. need both stock rear springs...
  52. Master/Slave Cyclinder hydraulic line
  53. LOOKING FOR A BORLA XR1 MUFFLER (round case)
  54. ls2 oil pan for vette without wings
  55. Need A Ls1 Oil Dipstick and Tube
  56. Wtb: Sfc
  57. Looking for wheels and tires.
  58. I NEED LS1 or LS6 ECU
  59. relo brackets
  60. Need F-body A/C compressor, p/s pump
  61. WTB Stock Monsoon Trans AM Head Unit
  62. **WTB- (2) 16" Camaro 5 spoke wheels** TEXAS??
  63. WTB: perimiter style valve covers
  64. WTB: magnaflow muffler/daul tips
  65. NEED ONE 98-01 WS6 rim!!!!
  66. WTB: ***10 Bolt *** 4 channel 4.10 or 4.11 gears
  67. used clutch
  68. WTB Fiske FM5s 17s or 18s
  69. WTB LS1 Block on west coast
  70. URGENT T/A LS1 taillight driver side!!!
  71. WTB VHP handheld tuner for 98
  72. WTB: Blackwing lid
  73. WTB: 25% underdrive pulley(f-body) and ls2 timing chain
  74. Anyone want to trade 2 SS rims 2 WS6
  75. WTB * HP Tuners *
  76. OEM WS6 Hood
  77. Have an old stock T56 shifter laying around you don't need?
  78. WTB: Skinnys/front drag rims with tires
  79. WTB: 1 Stock 00 TA Chrome/Polished 5 poke Wheel...
  80. need headlights ASAP!!!
  81. WTT:89F150 for ls6 intake
  82. WTB: GTO rear filler piece!!!
  83. WTB: Camaro SS Spoiler / Wing
  84. Y-pipe for RK Sport/AS&M midlength LT1 headers
  85. SLP Dual/Dual catback
  86. Graphite 4th Gen T/A door panels
  87. WTB 98-02 Camaro White Front Bumper Cover
  88. wtb PCV boot
  89. Black 98-02 TransAm Driver Side Mirror
  90. wtb: fast intake manifold, typhoon 96mm or ported ls2. Maybe cam!!
  91. wtb...cd player head unit aftermarket
  92. WTT SS Hood For Vfn Sunoco
  93. Wanted LS-1 Engine & 4l80e Tranny
  94. WTB Off Header Exhaust (fitted bullets?)
  95. Shorty headers wanted
  96. m6 lower boot, sun visor, headlighs
  97. 85mm maf(car/truck), 3gauge pillar pod
  98. Driver side sun visor, Ebony
  99. wtb: Ws6 hood for 97 Trans Am
  100. WTB: Camaro Export Taillights
  101. I need SOme PArtttssss
  102. WTB: B&B Tri Flo Catback w/ Quad Tips
  103. stock LS3 cam
  104. WTB: F-Body Brakes
  105. Trans Am LT1 Positive cable!
  106. WTB: adj LCA's & adj PHB
  107. WTB Factory SS Spoiler
  108. need valve cover bolt
  109. WTB Front Bumper cover 93-97 Firebird
  110. wtb turbo 400 or 350
  111. stock suspension springs for 98-02 fbody
  112. Bump Stops for 1995 TA
  113. WTB Intake Bolts and Injector Clips
  114. wtb ls1 rear brakes
  115. WTB: 93-97 Trans Am front bumper cover
  116. WTB carb intake for a L92 6.0
  117. WTB: 18'' tires 245/255/275/295
  118. wtb m6 counsel
  119. WTB LS1engine and tranny
  120. WTB Stock fuel rail and injectors
  121. WTB: LQ4 or LQ9 Longblock
  122. WTB complete 4.8L
  123. need 9 inch LCA relo brackets and adj. LCA's
  124. wtb ls1 heads
  125. WTB/WTT Exhaust
  126. WTB/WTT: 16x8 aluminum Firehawk style wheels
  127. Need stock LS1 crank
  128. Need 1 old style comp 918 spring
  129. WTB: 02 camaroSS rims
  130. 2x 15x8 Jegs Track Lights with Nitto 555r
  131. WTB: NX single 'Shark' nozzle system..
  132. ls1 pcv system
  133. WTB LS-1 Coils for old style valve covers
  134. t56 for ls1
  135. Fog Light opening from an LS1 Camaro
  136. WTB: (2) 15x10 prostars w/7.5 bs.
  137. WTB LS1 Cam
  138. wtb: uncracked turn signal housings 98-02 trans am
  139. WTB: 99+ A4 LS1 engine harness
  140. LS1 Accessory Brackets
  141. Wtb Ls6 Valley Cover!
  142. WTB Strano lowering springs
  143. WTB: 243 heads
  144. lt1 arp bolts, main caps, gaskets, timing chain
  145. wtb trans am ws6 hood
  146. WTB: Firebird Breathless Performance headlights
  147. 94-96 LT1 Head Castings
  148. WTB: walbro 255, injectors, spec stage 3
  149. WTB Posi from F-body 10 bolt
  150. Need LS1 Fbody oil pan, accessories, wiring harness and PCM, etc..
  151. 98-99 SS computer
  152. Gen I SBC Heads
  153. ls7 clutch shopping
  154. WTB Silver ZR1 Wheels
  155. Need black Passenger Sunvisor
  156. 98+ Headlights, bumper support, Fender brackets, center support
  157. I need a drivers side window!!
  158. Need a NON TCS throttle cable
  159. WTB stock camaro goods, leather ebony auto shifter, leather ebony ebrake handle
  160. Wtb-98-02 wrecked camaro,or trans am ls1
  161. WTB: aftermarket lid
  162. WTB 99 m6 pcm
  163. wtb interior wiring harness
  164. wtb electric cut out
  165. 17 by 9 wheels
  166. pewter mirrors
  167. WTB WS6 lower air box
  168. SLP Tri-Y headers & Y pipe, single or dual
  169. Lug Nut Covers
  170. Rear Wheels with Slicks
  171. Stock Trans mount
  172. LS1 Oil Pan
  173. I need a set of ls6 intake and exhaust seals
  174. WTB F-body LS1 Oil Pump Pick-up
  175. Wtb Fast
  176. WTB LID, Strut Tower brace, and SLP fan switch for 99 z28
  177. Looking for a ProCharger P-1SC Cash in Hand
  178. Wtb-wheels With Tires
  179. need lt1 fuel lines
  180. WTB headers for my 02 ls1
  181. wts/wtt: 863 (5.3) heads for sale or trade!
  182. WTB TSP True Duals and Eibach lowering springs
  183. Asap!! Power Steering Pump!!!
  184. WTB: One Michelin Pilot Sport A/S tire
  185. WTB Sway bar
  186. WTB LS2 Block
  187. wtb: sway bars
  188. mild cam and headers.
  189. wtb gmpp valve covers
  190. Need : LT1 Stock 10 Bolt
  191. Headlight assemblies/ Ramair
  192. Wtb: Ls1 Short Or Longblock
  193. wtb: where can i get an egr blockoff plate
  194. WTB: ls1 crank
  195. 93-97 Firebird Energy Absorber
  196. Stock... Rockers, Pushrods...
  197. reloc bracket
  198. W.T.B. Stock 2000 Z28 A4 PCM
  199. TCS/TOP Bezel for vert T/A
  200. PRC 2.5 5.3 heads and ms3 or equivalent setup
  201. WTB Stock springs 98-02 F-body
  202. WTB: 2x 01-02 WS6 Speedline Wheels (or w/tires)
  203. Mirror mounting 'triangle'
  204. cnc ported l92 heads
  205. WTB trans am honeycomb passenger taillight
  206. Ebony Dome Light...
  207. wtb: hurst shifter stick
  208. want to buy ws9 hood
  209. WTB: Parts
  210. WTB: T-56 swap
  211. WTB: t56 w/bell housing, gto pan...n more
  212. wtb patriot gold compatable valve guide seals
  213. WTB: chrome or black rims
  214. FM13 or FM14 Cam
  215. wtb:ls1 complete or blown up
  216. driving light covers
  217. **NEED** shorty headers
  218. Ebony leather seat! Need ASAP
  219. rear end bump stops...
  220. WTB LS1 / LT1 Efan motor and connectors
  221. Wanted Fuel pump bucket 99+ F body
  222. WANTED: RS Ground Effect Pieces
  223. vette competition gray wheels
  224. Wanted: 18/19" chrome Z07 or black Z06 wheels
  225. wanting ported throttle body for 98-00
  226. Skinnies...
  227. WTB--Hood release cable
  228. STILL LOOKING TO BUY A SET OF 243 heads
  229. looking for a 6.0 6.2
  230. Ls6 Corvette Covers
  231. wtb: cc503 cam, 1.6 roller rockers, Valve Springs
  232. ZO6 or similar cam for 03 5.3
  233. WTB LS2/LQ9 Crank
  234. wtb: 98+ foglights for ta
  235. Need Adj Phbar
  236. Corsa clones
  237. WTB or trade for timing set other parts
  238. ls1 rear backing plates
  239. WTB need misc engine hardware
  240. WTB SS Hood & Spoiler
  241. SS/TA computer
  242. WTB: 16" camaro, firebird, s10 wheels
  243. Lid
  244. Taillight center pannel
  245. wtb 93-97 camaro billet grill
  246. WS6 rims
  247. WTB: Adj panhard bar
  248. Need Stock LS1 Air Box+Lower Base!
  249. WTB: Complete t56 swap
  250. multi-function lever
