PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 [159] 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368
  1. WTB: ls2, ls3, lq4, lq9, or l92, SE michigan or close
  2. Red passenger fender
  3. ls6 cam
  4. ATTN. Zexel Torsion owners
  5. Looking for CCW's...
  6. WTT ls6 for fast90
  7. TRADE/BUY 85mm Throttle Body
  8. t56 crossmember and TA mount
  9. WTB 6pt or 10pt roll cage
  10. need side vents
  11. WTB ABS body to rear connector/pigtail for 3ch ABS rear
  12. WTB zexel 3 series differential
  13. wtb ls6 intake
  14. WTT: Black SS hood for wheels!!!
  15. WTB LS3 L92 intake and heads. CASH READY!
  16. WTB a nice 6.0 iron block
  17. Passenger side headlight cover white and firebird (non-TA) front bumper cover
  18. Passenger seat belt guide
  19. Wanted:Keyless Entry Reciever 1994 Firebird
  20. WTB 2 trans am red doors
  21. WTB Interior item-Tray that goes in front of the shifter in non-tcs firebird models
  22. WTB headers y pipe ls6 intake, and blowdown tube
  23. WTB 243 heads or worked heads
  24. LQ4 short block wanted! CASH IN HAND!
  25. WTB (Non) Working Power Antenna
  26. Wtb/wtt zr1s
  27. WTB: SLP SS grille with silver (only) letters or plain
  28. WTB: Black Driverside Mirror housing for 98 TA
  29. WTB: Msd Dash Hawk
  30. WTB F body dipstick, pressure tree, oil filler cap
  31. WTB 10 bolt w/ 3.42 gears. Located in NJ.
  32. WTB: LT1 Camaro Tail Lights on Long Island
  33. A/c lines!!!!
  34. WTB: O2 Sensors
  35. WTB: Cheap LT1 TA spoiler
  36. ISO: 95-97 Dynaspark
  37. WTB LS2 Fuel Rail Cover
  38. stock plus cash deals....local to pa?
  39. WTB Top Front Fender brackets
  40. need pistons and rods for 6.0
  41. WTB TT'2 OR Boyd Smoothie
  42. WTB: E-brake Cable and Bracket
  43. 93-97 v6 front springs
  44. needed 16 inch 28inch tall slicks or 15 w rims thanks
  45. WTT: Wet NX kit for Cam kit, or Clutch/flywheel, or...?
  46. WTB LS1 swap parts.
  47. WTB A/C Compressor
  48. wtb: ls2 gto power steering kit
  49. wtb front runners
  50. LS1/6 Shortblock!
  51. wtb door panels and seats
  52. WTB: LS1 water pump, starter, oil pressure sending unit
  53. WTB: NEEDED: Driver's side rear quarter panel 99 Trans Am
  54. WTT:nitrous kit for heads or fast90
  55. wtb f-body oil pan
  56. LS PArts wanted-Crank.Pistons.Rods...
  57. LS6 Valley Cover
  58. WTB: 99' trans am Catalytic converters
  59. WTB.... N2O with extras
  60. WTB: Fbody coil brackets
  61. need 98-02 4l60e trans
  62. WTB: Used OBD1 Interface Cable
  63. WTB: Driver side mirror. ASAP!!!!!
  64. Nitrous Pistons
  65. WTB: LS6 intake
  66. WTB A/c Line!
  67. WTB: Magnaflow or Hooker catback for 98-02 Z28
  68. WTB Charcoal Visors, Window switch, fuel rail bolts.
  69. WTB: Complete 9" Rear end
  70. stock ride height 98-02 z28 suspension springs
  71. need turbo cam for ls1.i have comp cam to trade
  72. wtb or trade lt4 intake
  73. WTB:2 5/8 Guages - OP, Fuel level, water temp, voltmeter
  74. accessory brackets needed
  75. WTB: battery tie down
  76. WTB: A4 camaro shift selector overlay for 93-96 center console
  77. Wtb 6.125 h-beams
  78. Need a adjustable panhard rod !
  79. WTB: 1LE Foglight Deletes
  80. WTB factory MAF housings...
  81. Wtb: Ls6 intake
  82. Nitrous bottle opener
  83. WTB rear brake complete set up
  84. Wtb: Fast 90/90
  85. WTB: Motor mounts, p/s setup, crank sensor etc...
  86. WTB 243 Z06 or LS6 heads
  87. WTB Ported Throttle Body
  88. wtb L92 heads ready to bolt on
  89. wanted ms3 cam
  90. Wtb ls6 intake, c5 z06 wheels-near virginia beach
  91. 99+ ls1 pcm / ecu
  92. Need LT1 LT Headers
  93. WTB MAC offroad pipe
  94. need wiring harness ls1/t56 / and more stuff
  95. WTB...Lm2 Bullet
  96. wtb: GTO T56 (M12)
  97. Wanted: Vinci VHP/Crane Powermax tuner
  98. WTB Stock LS2 Crank and stock LS2 Block
  99. WTB Center consol for 2002 Trans Am
  100. 98-02 fbody power steering parts
  101. 98-02 Fbody Alt brackets
  102. Need asap
  103. WTB a couple of things
  104. WTB- LS1 front accessories and coil brackets
  105. lt1 full exhaust
  106. WTB: LS1/6 block
  107. WTB console lid
  108. Slp 2otl
  109. WTB BBK SSI Intake
  110. Ford 9"
  111. Valve cover bolt!
  112. WTB TT2's anthracite
  113. WTB F-Body engine accessories and brackets
  114. Need ls2 timing chain and double valve spring kit
  115. WTB stock hood, stock intake for camaro
  116. 2000 ws6 hood
  117. need silicone couplers
  118. WTB: 93-02 crown nut from front lower ball joint
  119. WTB: 93-96 camaro A4 center console ash tray cover
  120. needed 16 inch street slicks thanks
  121. WTB 241 heads
  122. need LS1 parts - LS6 cam and valve springs - etc.
  123. oil pickup
  124. Still looking for...
  125. WTB: oil pan & starter
  126. WTB/WTT Black ZR1 Centercaps
  127. WTB: .96 housing for mp70
  128. Oil pan bolts for a truck pan.
  129. WTB VFN camaro hood! sunoco bolt on or pin on is fine!
  130. WTB F-body power steering pump
  131. Loudmouth I, speaker cover, tune knob
  132. WTB: Corsa Sport Muffler
  133. WTB: FAST 78 and Underdrive Pulley
  134. WTB: 2 17 x 9.5 o.e. concept c5 z06 rims
  135. looking for z06 wheels!
  136. WTB: worked 243's, 5.3's, or afr's
  137. wtb: front sway bar/bushings/pins
  138. wtb some mls head gaskets for 01 z28 near austin tx
  139. WTB: Console lid
  140. F-body pulleys
  141. I need gears!!
  142. 96MM Typhoon NEEDED
  143. Monsoon Head Unit
  144. WTB 98-99 WS6/SS coil springs
  145. WTB: 2 5/8 or 2 1/16 Guage Set
  146. wtb or wtt
  147. looking for front lowering springs
  148. WTB comp cam
  149. 99+ Engine Harness (Auto)
  150. looking for 2000 ws6 hood and bumper a.s.a.p.
  151. 98-02 fb/ta parts wanted
  152. Slave shim
  153. wanted: BELLHOUSING for LS1 T56
  154. trans am clear plastic gauge bezel
  155. th400 relocation bracket
  156. ford red tops 30#
  157. WTB: Eibach Pro Kit Front Springs
  158. Wtb: 15x8 Summit stars
  159. WTB: HP Tuners Pro
  160. WTB: 2 C5's Chrome Rims
  161. wtb: ls1 coils
  162. need a 97 Trans am Wiring harness and computer
  163. WTB: Kooks Y-pipe with cats (maybe trade for Kooks ORY + cash?)
  164. WTB: F-Body oil Pickup and 2bar map sensor
  165. k-member
  166. Get rid of your broken T56! Sell it to me!
  167. trans am emblems
  168. WTB MAF '04 Corvette
  169. Wtb caliper brackets
  170. WTB- LS1 pcm, harness, and coils
  171. borla
  172. WTB: a4 console, power antenna,t-top shades for 99 TA
  173. I broke my T56, Looking for parts T56, Cluster Gear
  174. WTB 00 Z-28 power steering pulley and rack and pinion
  175. wtb Hydraulic roller ls1 turbo cam
  176. Vortech superchager impeller
  177. WTB Rearend cover (preferably TA)
  178. wtb 12 bolt 9 inch or dana s60 even 8.8 rear end for 2002 camaro
  179. trans am converson headlights
  180. WTB: C5 thin spoke polished wheels 00-04
  181. wtb carb style vic jr.
  182. WTB Camaro Seats and carpet
  183. WTB: Some nice ported 243 heads
  184. WTB black ZR1s 17x9 17x11
  185. looking for 01 02 speedlines
  186. WTB 243 heads and Valve springs
  187. 99+ Gas tank filler tube/neck
  188. WTB front v6 springs
  189. WTB front ground effect 98
  190. WTB. D/S interior mirror cover, rubber m6 console piece, and stuff...inside
  191. WTB Z06 18x10.5 Speedlines or Alcoa
  192. LS1 T56 anyone?
  193. WTB: Pro Stars
  194. WTB: 3500-4500 stall for a 4L60E
  195. wtb: stock LS1 parts and other stuff
  196. wtb ls1 lower air box and lid
  197. looking for a good set of heads
  198. WTB: Fast 78
  199. Center Console Lid for LS1 style cars any color
  200. WTB:99 Z28 Coil packs and RR speaker panel
  201. WTB: Ls1 Flywheel Bolts and Pressure Plate Bolts
  202. WTB A4 Center console lid, ebony
  203. WTB Billet Street Lites
  204. Fast toys 85mm lid, Delphi 85 maf, Svo 30#, Z06 28.8#
  205. 90mm MSD throttle body
  206. powerdyne or vortex pulley
  207. wtb: GMMG exhaust
  208. WTB: 6.0l parts for build from scratch
  209. Need Hood, bumper, headlights.
  210. Wtb: Cartek- tea- tfs- afr heads for ls1......
  211. Need CAT for a 00 3.8L camaro
  212. WTB: Deep Auto Tranny Pan 4L60E ( Truck or aftermarket )
  213. Corvette fuel line wanted
  214. WTB- Complete F-body ls1/Trans
  215. WTB: a set of 4.10 gears w/ or w/o posi unit
  216. WTB: 3.73 gear and ls6 intake
  217. Darton mid sleeves for ls1 wanted or the block with sleeves installed for a 2nd proje
  218. CARTEK 4X heads wanted!!
  219. WTB prostar 15x10rears 7.5bs - 15x3.5 front with tires if possible
  220. Water Pump wtb
  221. WTB 98-02 Camaro/Trans am LS1 oilpan
  222. I NEED parts
  223. Coil Pack Brackets
  224. WTB Maganaflow Catback (new)
  225. wtb: ls2, ls3 engine or 416..
  226. WANTED! Tire/Wheels and Cat-Back System!
  227. WTB flywheel locking tool for LS1
  228. WTB 97-02 6 speed console
  229. WTB: Tial 38mm Wastgate Spring
  230. WTB: Tial 38mm Wastgate Spring
  231. wanted t/a fog lights
  232. WTB: Stock Catback (just the I-pipe no muffler) FS: OBX, TSP Rumbler
  233. F-body stock rear shock
  234. WTB: #16825 Hooker Cat Back Exhaust System
  235. wtb ls1 coil packs
  236. Want To Buy: 12 Bolt Rear End/ 9" Rear
  237. Wanted: ls1 shorty headers
  238. WTB; Dual valve springs
  239. WTB 350 or 383, built, bare or inbetween.
  240. Wtb stock exhaust, willing to pay shipping
  241. ls6 intake
  242. Need LH rear tail light 98-02 camaro
  243. WTB front Appearance piece
  244. WTB lowering springs
  245. WANTED: 35th Anniversary SLP grille
  246. Wtb:1 nitto extreme nt-555R P275/40R17 tire
  247. Does anyone have a gmpp lsx block for sale???
  248. WTB: FAST 90mm intake bottom
  249. WTB: 3.85 6 rib pulley
  250. wtb th350
