View Full Version : Parts Wanted
  1. Still looking for a red passenger fender 98-02
  2. WTB: Blackwing Lid
  3. zr1 chrome 17x11, 1 nitto 315 35 17 drag radial.
  4. WTB Dual Springs and 7.4 Hardened Pushrods
  5. SLP Headers
  6. wtb stock door tweeters
  7. Wtb Ud Pully
  8. Stock F-Body Throttle Body Needed
  9. 3" Exhaust Cutout (pipe only)
  10. WTB: GM LSx Block.. Will Pay Well!!
  11. looking for set of rims anything..drag, street w/e
  12. wtb iroc z wheels
  13. ws6 wheels
  14. wtb double adjusable controll arms
  15. WTB: Comp 918 s
  16. WTB: SFC's
  17. pillar pod
  18. wtb 3200 stall
  19. Wtb:drag Rims And Tires
  20. o2 sims, o2 ext., any header instal parts!
  21. 4.8 pistons
  22. WTB Kooks LT Headers and Y-pipe
  23. GI: looking into Low mile Torquer v. 2 Cam 112LSA
  24. 93-97 Power Steering Fluid Reservoir
  25. LS6 heads
  26. sway bar and computer
  27. wtb: camaro driver side switches
  28. wtb driveshaft
  29. WTB LT1 supercharger kit
  30. WTB: LS6 intake
  31. WANTED~A4 Shifter and Cable~
  32. WTB 02 extensions
  33. 02 sensor hole plugs
  34. Wanted-- WS6 Hood!!!
  35. Wanted-- 98-00 Ws6 rims!!!
  36. 98-00 WS6 rims---- Wanted!!!!
  37. E water pump WANTED
  38. WTB: Seatbelt Loop
  39. WTB ls1 rocker arm pedistals
  40. WTB plastic peices to inner splash guards PIx Inside
  41. WTB Stock LS1 Intake
  42. maggie/whipple
  43. WTB: LS1 accesories
  44. WTB O2 sims
  45. Need Rims!!!!!!!!!
  46. 93-97 firebird fender
  47. floor mates
  48. Wtb: Lcarb
  49. WTB: LS1 Parts
  50. looking for any c5 engine mods
  51. Forged H beam 5.7 rods
  52. ls2 front cover and sensor harness
  53. 93-97 Rear brakes
  54. WTB: GM motor mounts
  55. WTB: F-body oilpan
  56. wtb svo red top 30's
  57. WTB- Ram air nostril rain shields
  58. Wtb
  59. full dual gauge pillar pod with guages
  60. WTB: Torque Converter for TH400 and LT1
  61. wanted cheaTR cam for nitrous trade???
  62. Catted Y-pipe for LT's and Catt back Exhaust
  63. Carpet, fuel rails, 6.0 head
  64. SLP smooth bellows
  65. WTB: CME Center Mount Exhaust tips/valence
  66. WTB...stock rear seat Bose speaker
  67. Looking for two 245/40/18 tires
  68. 1997 Camaro Z28 rear O2 sims wanted
  69. Wiring
  70. Wtb: Electric Cut Out
  71. 6 bolt heads
  72. Computer
  73. wtb 02-present Z06 cam and yellow springs
  74. Wtb Stock Y-pipe,cats,and Manifolds For 1998 Z-28
  75. Wtb: Corsa Clones
  76. 01 ls6 cam
  77. VFN "Sunoco" Cowl Hood 98-02 Camaro
  78. wtb stock parts
  79. 1-2 ft NO2 line
  80. Wtb: 2 Chrome 17x 9.5 Z06 Rims
  81. WTT: EV1 Plugs for EV6 plugs
  82. tough request but lets see
  83. Sport Appearance Package Ground effects wanted
  84. WANTED LT1 1994 or 1995 Engine harness.
  85. twin turbo kits
  86. Parts for a 95 z28
  87. WTB: A stall and front bumber filler
  88. Need Trans Am Tail Lights!!!!
  89. WTB 243 heads Asap
  90. WTB injectors
  91. WTB Passenger Side Tail Light!!
  92. wanted: drag wheels
  93. WTB: Stall, Gears, misc....
  94. WTB:LS1 throttle cable bracket
  95. wtb 93-97 camaro front bumper cover
  96. camaro engine brackets
  97. Wtb: Lowering Springs
  98. lookin for autometer shift light rpm pills
  99. WTB: Eibach Prokit for LS1 Camaro
  100. LS2 nitrous kit
  101. wtb 6.0 cast iron block
  102. Turbo Parts
  103. WTB:Pillar Gauge Pod (Wideband A/F, Fuel Pres., Boost/Vac)
  104. WTT: LS1 Block for parts
  105. stock lt1 fltwheel
  106. CAM Kit wanted
  107. SLP Y Pipe or any aftermarket Y pipe (almost)
  108. WTB: Driver's side seat belt guide GRAY!!
  109. PCM for 98 Z-28 Automatic
  110. EGR blockoff plates, stock O2's
  111. wtb a t5 trans for gm
  112. LT1 throttle cable
  113. WTB 1 ws6 wheel
  114. looking for a clutch
  115. gauge bezel????
  116. Looking For LSX Block
  117. ls1 long block
  118. WTB: Radiatior Shroud and Air box
  119. Sell Me Your Black Halos!
  120. WTB factory hurst shifter
  121. WTB 1 or 2 Chrome 10 spokes
  122. WTB: hardened 7.425 pushrods
  123. SLP Dual Dual exhaust
  124. WTB: EFI Victor Jr. with fuel rails
  125. WTB ARP rod Bolts
  126. wtb lt1 style t56 around GA
  127. HPTuners
  128. SLP Y pipe
  129. Wtb Ls2/7 Flywheel Aluminum
  130. 6-Speed shifter plate
  131. Turbo 350
  132. Parts I Need for 3rd Gen Conversion
  133. LE2 cam??
  134. WTB: firebird ebony interior
  135. WTB: Ebony seatbelts and Ebony sun visors
  136. Corvette fuel rail covers!
  137. WTB ARP head studs, for LS2 block. And Racetronix hot wire kit.
  138. O2 SiMuLaToRs and O2 ExStEnSiOnS
  139. WTB: 98 Camaro PCM Bracket
  140. WTB: 98-02 ebony door panels
  141. WTB: 02 extensions & 02 sims
  142. Wtb: Stock 10 Bolt With Stock Panhard And Control Arms
  143. WTB Spohn extreme drag sway bar
  144. C5 Brake kit
  145. Trans am wheel
  146. Key Fobs
  147. Wtb Broke 6 Speed
  148. WTB billet grille and clear corners
  149. WTB Complete ls1 with m6
  150. WTB:Chrome ported MAF ends
  151. Wtb Vig 3600 Verte
  152. WTB-spanner wrench
  153. Need an LS1 harness and TB
  154. electric cutout or manual
  155. WTB: Headers and ORY
  156. WTB: 2 bullet or any muffler that is loud w/good tone
  157. door panels
  158. WTB bolt in SFCs for '01 formula hardtop
  159. Want to buy comp 918 or pac 1218 springs!
  160. 6-speed for built A3+3800 converter
  161. WTB: Chrome 10 Spokes
  162. Strano Rear Bar
  163. WTB: Front draglite wheels
  164. WTB-1998-2002 Halogen head lamps
  165. WTB: 4.10's
  166. WTB: Floor mats!!!
  167. LS6 Valley Cover
  168. WTB: 10 bolt
  169. Want to buy bare 6.0 iron block
  170. WTT 04 z06 cam
  171. WTB Magnaflow #15684 Over Axle & Mid-Pipes
  172. !!!!<<<<<<(((((((Seat belt guide wanted)))))))>>>>>>!!!
  173. Long tube headers & MORE for C5
  174. 1998-2002 F-Body front brakes
  175. (1) stock valve cover bolt
  176. Looking For 98 And Newer T56
  177. WTB: Pewter SS Hood and some new chrome 18 or 19 in rims.
  178. Cated Y-pipe For Pacesetter LT's needed
  179. wtb 3.73 gears
  180. need GTO front sump oil pan
  181. WTB: Poly Motor Mount Pass side
  182. Looking for Y-pipe with Cats for Pacesetter LT's
  183. ls1 crankshaft
  184. wtb cd changer magazine
  185. WTB: Some good heads
  186. WTB: LT1 SS Airbox
  187. 98 Grey Cloth Interior and Door Panels
  188. WTB LT1 Camaro Rear lights
  189. WTB (1) 17x9 CHROME ZR1
  190. WTB: LT1 Radiator
  191. 2 series carrier gears 10 bolt
  192. WTB" Nitrous Timing tuner
  193. WTB Fuel rail bolts
  194. 98-02 TransAm - front end parts needed
  195. Wiring harness
  196. WTB: OEM Clutch Master Cylinders Dead or Alive
  197. z-o6 rims
  198. LS1 throttle cable bracket
  199. Where Did The Fender Roller Go?
  200. WTB LS6 Intake & Heads
  201. WTB: 99-02 Coil Brackets
  202. WTB 36lb injectors
  203. 6.0L truck manifolds
  204. WTB: corvette drive by wire throttle body
  205. WTT MS4 cam for smaller cam
  206. LS1 complete swap
  207. Throttle Body Blades Needed
  208. WTB: Slp ss grille & stock ss muffler
  209. LS1 long tube headers
  210. Big stuff or fast with data logger.
  211. WTB: HID's for trans am
  212. WTB: Stock 5.3 MAF
  213. WTB 35mm Hollow (Strano) front sway bar
  214. 01 WS6 Rear End wanted ASAP
  215. wanted ram air hood 99
  216. WTB : 98+ Firebird tail light wire harness
  217. parts i need
  218. WTB Turbo stuff.
  219. wtb ebony rear seat belts and mirror and visors
  220. WTB. Dome pistons!
  221. wtb edelbrock victor jr elbow and tb
  222. WTB set of new lifters for Ls1 01
  223. LT1 HARNESS and ECU Needed!
  224. black/ charcoal top dash piece needed 99 TA
  225. adjustible rear shocks!!!
  226. wtb stck ws6 springs
  227. fuel rail covers
  228. Need lt1 or ls1 fans
  229. wtb:part over front strut....
  230. GM847 or LE1/2/3 cams.
  231. WTB: ZR1"s
  232. WTB: 02 Camaro Ebony Leather Door Panels
  233. USED ASP or Powerbond UD Pulley 25%
  234. WTB 4th gen rear seats
  235. Gears for a 2 series carier
  236. Bare LS2 , Holley blue fuel pump and regulator, Torque Arm
  237. Wanted broken programmer
  238. Wanted: HPTuners software
  239. WTB: 8.1L truck injectors (31#)
  240. slp lid
  241. looking for stock 2000 -2002 SS Wheels
  242. Stock Shocks
  243. WTB: eliminator fuel pump
  244. 90mm throttle body ford style
  245. tires 275/40/17
  246. Need ashtray lid for t/a.
  247. WTB white firebird hatch
  248. WTB: Aeromotive A1000 fuel pump
  249. WTB : LS1 Block!
  250. Need LS1 Block
