View Full Version : Parts Wanted
  1. WTB: Stock 10 bolt 7.5/7.625 posi unit
  2. WTB: Short Style LT1 Oil Filler Neck
  3. need help finding these wheels in any condition
  4. Needs list
  5. WTB: SS Spoiler
  6. WTB: LS6 Intake, Evap Canister, Exhaust manifold
  7. wtb ebony seat-belt guide pass side
  8. Looking for Solid Motor Mounts
  9. WTB Nitrous Dave's/ Nitrous Outlet moneymaker ls6 intake
  10. WTB LS1 AC BRACKET with idel pulley and tensioner
  11. WTB: TSP 224R cam
  12. Wtb: tsp 224r cam
  13. WTB: SDPC/HAWK/Kent Moore Pulley install Tool
  14. WTB: LS2,LS3 short,long or just block
  15. 10 bolt blew, need carier for it
  16. WTB: HP Tuners
  17. WTB: LS vette harm balancer
  18. Drivers side lower door hinge Asap
  19. Wanted: 4l60e High stall torque converter
  20. WTB 04 GTO Alternator
  21. WTB 9in rear for F-body
  22. WTB: LS1 4 corner steam tubes
  23. Catback
  24. WTB: OBX LT1 long tubes
  25. WTB Complete 98 Fuel sending unit
  26. WTT 17x11 TT2 for 17x9.5 or buy 17x9.5
  27. WTB: LS1 pickup tube
  28. WTB: Ported LS2 Throttle Body TB 90mm
  29. WTB Black drivers door shell
  30. Trade 00-02 ls1 block for used FAST 92" or 102"
  31. T56 Bellhousing, flyeheel, front plate
  32. WTB: SLP Air Lid
  33. Wtb ls1 timing tuner
  34. Wtb ls1 timing tuner
  35. Wtb: 98-02 camaro grille/front headlights
  36. a/c vents, dash pad, and flip out cup holder, misc interior pieces
  37. ls1 stock rear springs
  38. WTB: L92 bare block
  39. WTB: TPS and IAC
  40. Wtb hptuners
  41. got one
  42. WTB: '05+ returnless fuel rail\Marine injectors
  43. GI: WTB LS2 Short Block
  44. WTT- p1sc1 for D1sc plus cash !!
  45. WTB: 10 Spokes SS Wheels (preferably with tires)
  46. Need PCV Fitting or Perimeter Bolt Valve Cover
  47. WTB Aluminum drive shaft for 98 camaro
  48. Wtb some parts
  49. 408 rotating assembly
  50. WTB "smoothed" 5.3 valve covers
  51. PLEASE HELP!!!! N2B: TNT Nitrous Nozzle
  52. WTB: 4-pin alternator pigtail
  53. WTB: A-arms and sfc's
  54. Wtb: trans am fog lights and parking lights
  55. WTB LS-1 PS Bracket & Pump
  56. WTB LS1 Harness and ECU
  57. Passenger Head Tensioner Pulley Deal...
  58. WTB FJO progressive controller
  59. WTB: Stock Camaro headlights clear
  60. WTB: Driveshaft for T56/9" combo
  61. GTO oil pan, pickup, windage tray and solid c5/c6/gto engine mounts
  62. Wtb: clear lid
  63. WTB IAC & TPS sensors
  64. Need 98-02 TA chrome rim (1)
  65. WTB or RENT KENT MOORE TOOLS
  66. Wtb manual door panels
  67. Want to buy 2002 LS1 Corvette crank shaft pulley.
  68. Trade WS6 wheels plus cash for TT2s?
  69. WTB GTO shift knob
  70. Stock WS6 wheels
  71. F body factory trans mount, cubby hole pocket, lower rubber shift boot
  72. wtb single aza z1 18x8.5
  73. wtb: Trans am ws6 dipstick tube and dipstick
  74. Fast 92mm intake and nick williams 92mm throttle body
  75. WTB: 4l60 3600 stall
  76. WTB Ls2 fuel rail and OEM ls3 injectors
  77. WTB 402/408/LS2 Motor
  78. wtb used ball hone
  79. Looking for Trans am Hatch
  80. wtb 06 gto input shaft
  81. s475
  82. WTB Tubular lower A arms
  83. wtb: pass side honeycomb tail light 98-02
  84. wtb: 98-99 factory cats and ypipe
  85. WTB LQ4/LQ9 bare block near DC preferably
  86. WTB: Red Gas Cap Door and molding (Trans Am)
  87. Waanted! LS1 Coil Brackets
  88. WTB: factory gto wheels
  89. wtb fast 102 to fit 243 heads
  90. 10 Spoke chrome wheels
  91. WTB: foxbody dash plate!!!!
  92. Wtb: 98-02 procharger
  93. WTB: LS6 Intake
  94. Wtb gto goodies
  95. wtb cam 230s 113 lsa
  96. WTB: RPM 505's with tires 18 or 19's
  97. Looking for some 799,243 possible others
  98. Lower shifter boot
  99. WTB: ASAP , 4L60E Tail shaft housing
  100. wtb Ls6 intake
  101. LS6 Intake Manifold W/EGR Provision
  102. stall for a 4l60e for a 2001 camaro
  103. WTB: full nitrous 92mm wet plate kit
  104. WTB subframe connectors
  105. WTB Spiral Flow Mufflers
  106. WTB G-8/2010 Camaro v-8 heater core hoses
  107. LS 4 bolt 92mm TB
  108. Need ls6 intake now
  109. WTB patriot gold valve spring kit.
  110. WTB.LS6 Intake,LID,LT headers,any bolt ons for 99 ls1
  111. Wtb: Main studs
  112. wtb tt2 17x11 rears
  113. 28/11.50/15 slicks
  114. 17" rims for trans am
  115. need 4 channel backing plates
  116. Camaro headlight bracket
  117. WTB/WTT...T56 Fbody shifter lever
  118. LS1/6 OR FI LONGBlock ENGINE Low miles or crate
  119. WTB: 2001 WS6 Wheel
  120. Wtb 6.0 block/shortblock
  121. 5 star wheels Chrome Center Caps
  122. 5.3 or 6.0
  123. NEED GTO FRONT BUMPER, pass fender, HELP SAVE A GTO from INSURENCE!!!
  124. 93-02 camaro charcoal gray sun visor
  125. wtb 7.2 comp cam pushrods #7940-16, svo red top injectors, 1.6 self al rr 1418-16
  126. Truck parts wanted-Harness for DBC,DBC TB, and more
  127. WTB: 4-channel 10-bolt with factory gears and low miles
  128. WTB 2001ish 5.3 truck ECM
  129. WTB 4pt Seat Belt Harness:
  130. Wtb: Slp loudmouth exhaust
  131. WTB lS2/3 FRONT TIMING COVER
  132. WTB: Clam Shell mount
  133. WTB: th400 3200-3600 N.O converter, torquer cam etc...
  134. 02 sensors & extensions
  135. WTB 98-02 firebird trans am licence plate cover
  136. Need these parts.
  137. Wtb fbody 15x8 wheels
  138. wtb cam kit
  139. 85mm nitrous plate for ls1
  140. fast 4150 throttle body
  141. wtb: 98 camaro exhaust manifolds - both or just passenger
  142. Wtb wheels and tires
  143. Wtb front sports one springs
  144. WTB 35th le wheels!
  145. WTB Spohn Torque Arm Crossmember
  146. Koni's, Strano's, and Ultra-Z
  147. 4.8 or 5.3 complete, 4l60e, xfer case, ls1 intake, & oilpan
  148. WTB 3.90 gears
  149. WTB: One 317 head
  150. 98 Charcoal Grey Leather Seat Cover...
  151. WTB: Blackwing Lid
  152. WTB:Black nitrous feed line...
  153. 10 bolt w/410s
  154. WTB/WTT: Y2K Deep Dish
  155. WTB: R/H head light Motor and Radiator
  156. WTB Two 295/35/18's
  157. WTB Interior driver side mirror cover for a 2000 SS
  158. Stand alone box for 4l60e 1994
  159. wtb nitrous kit ls1 corvette
  160. Wtb advance induction heads and 92 mm tb
  161. Wtb/t
  162. WTB clutch anticipation switch
  163. WTB f body passenger side lower a arm
  164. WTB: Forged Flattop Pistons 4.005-4.030 Bore
  165. WTB Strano sways/end links
  166. I will buy HP Evo's or 505's...
  167. WTB: LS1 Corvette Engine Covers
  168. WTB: LT1 Fuel lines, fuel pump assembly
  169. Sunvisor (Vin Specific color match needed)
  170. WTB: Crappy Stockers For Winter Storage
  171. I need an ls6 cam
  172. wtb ls6 intake
  173. WTB - SLP Camaro SS Portfolio, Car Cover, & Key Fobs
  174. WTB Emission control valve plug
  175. wtb fronts for weld 3.5x15''
  176. WTB 98 style dash pad
  177. WTB Quick time Bell for t56 trans
  178. WTB: Aftermarket Valve Springs
  179. WTB 17 x11 chrome zr1s
  180. WTB BMR/Umi torque arm ( full lenght )
  181. Catted kooks ypipe ls1
  182. delete
  183. Wtb: florda 50 gauges or something similar for lsxfox
  184. wtb: ls1 power steering bracket
  185. WTB: long tube headers for GTO!
  186. WTB: 98 Camaro Interior Pieces
  187. WTB cheap cam for budget 6.0 build
  188. WTB Clear Air Lid 02 WS6
  189. WTB: Melling Oil Pump
  190. Injectors
  191. need some 275/40 17 drag radials
  192. lt1 ram air intake
  193. power steering
  194. WTB: FAST 90/92 and LS2 throttle body
  195. WTB - Cali Cam, Mild 22X Range, 112/14 LSA, 224R/228? Nitrous Maybe?
  196. WTB: F-body windage tray
  197. 52mm or 58mm Holley/LPE/AS&M throttle body 94-97 LT1
  198. WTB LS3 block
  199. need sun visors
  200. Wtb ls1 intake bare or with injectors,tb
  201. a few parts wanted! paypal ready
  202. WTB Manual Pedals from a 4th gen
  203. wtb wolferacecraft roll bar and chrome c5 z06 rims
  204. wtb: pcm & coil packs
  205. WTB stock rad support
  206. Wtb a turbo cam,timming chain
  207. T-Top Shades
  208. wtb: high 22x, lo-mid 23x cam, 7.4 pushrods, l92-ls3 cometic gaskets, ls7 lifters
  209. WTB 98+ Fuel Pump Bucket
  210. Wtb gears 3.730r 4.10
  211. WTT: LS6 intake + ported TB for Fast 90/92 +TB plus cash
  212. Chicago Area! WTB A/C components for LT1
  213. WTB: LS1 Parts
  214. WTB: Corvette C5 or C6 Alternator
  215. WTB: F-body A/C Parts
  216. WTB slightly used rearend or cheap new
  217. WTB: 98-02 Dash Pad
  218. WTB: C5 Stainless Works chambered exhaust
  219. Desperately need manual/instructions for HSW The Interface
  220. WTB: Trans Am Driver's door panel (Ebony) w/ NO CRACKS!
  221. NTB: Stock Cooling Fan Grill
  222. Race star wheels
  223. WTB w/pmp drive shaft LTx
  224. WTB: Oem LS7 Intake Manifold
  225. WTB: Oem LS7 Intake Manifold
  226. wtb ls7 heads
  227. WTB ls1 intake
  228. WTT: LS6 intake+ cash for 90 or 92 mm FAST
  229. Wtb nitrous kit, 99 ls1 harness, ms3 or raptr cam with push rods
  230. WTB - Monsoon CD Head Unit
  231. 4000 stall
  232. WTB water pump bolts
  233. WTB FAST Fuel Rail Setup
  234. C5 Fuel Rail Covers...
  235. WTB 4l60e Shifter Cable and bracket
  236. wtb ported throttle body
  237. WTB: 98-02 FBODY Strano HP7 kit/parts & Watts link
  238. WTB/WTT: 10+ Camaro manifolds for truck manifolds
  239. wtb 7.4 push rods
  240. WTB - SINGLE Comp Cam Trunion Upgrade
  241. wtb drivers side t top
  242. C5 stock manifolds
  243. wtb 98-99 ypipe and driver side cat
  244. wtb convertible seat belts
  245. 98 F body wire harness
  246. WTB oil cooler adapter or entire oil cooler setup - 2010 camaro
  247. WTB- 317 Cylinder heads
  248. Wtb:exhaust
  249. Wanted : 85mm Nitrous Plate for BBK/ PP Intake
  250. LT1 T-56 odds and ends
