View Full Version : Parts Wanted
  1. wtb D1 procharger
  2. wtb 243 or 799 heads
  3. Need lifters
  4. WTB: Wheels & Tires
  5. WTB - stock ls1 intake manifolds
  6. WTB Kooks Exhaust
  7. wtb driver side exhaust maifold
  8. wtb: LT1 over valve cover plug wire kit
  9. WTB: Lid, 98-02 Firebird/TA AC Vents
  10. wtb 430 gears for a 3 series 12 bolt rearend
  11. WTB:Lowering Springs
  12. WTB:T-Top Shade Covers
  13. WTB ASAP 90mm ls2 dbw throttle boddy
  14. WTB: Front and Rear Swaybars, SFC, LCAs, TA
  15. WTB: LS6 Heads fully CNc'd 64cc
  16. WTB Headers, intake, heads, block, suspension, wheels, rear, etc. (EVERYTHING!!)
  17. 4l60e Stall converter wanted
  18. WTB Master Power Exhaust Housing
  19. WTB - Camaro Convertible Sunvisors
  20. WTB - Camaro Convertible Sunvisors
  21. WTB 90mm ls2 drive by wire throttle body
  22. WTB/WTT Ebony Trans Am seats
  23. WTB: Leather Trans Am Seats
  24. WTB Cam, Poly Mounts, DS, etc
  25. WTB: 99-01 harness and pcm! paypal ready
  26. WTB: Bare LS1/LS6 block
  27. WTB-complete take out LS engine/auto transmission
  28. WTB upper panhard bar with relocation bracket
  29. WTB: VFN 3'' SS hood
  30. Working a/c compressor
  31. WTB:front fenders for 98+ trans am
  32. WTB: 6bolt heads bare or setup for SR - Trickflow or AFR
  33. *WANTED* A4 Center Console & Stock Headlights
  34. alt w bracket
  35. WTB: LS6 coolant crossover pipe
  36. 98 trans am door
  37. Looking for Parts to Finish My Swap. Tick Master, PCV Fitting, etc
  38. wtb fbody oil pan.
  39. WTB TSP 228 cam, valve springs, pushrods
  40. Wtb wheels and tires
  41. WTB HP Tuners
  42. WTB LS3 DBW gas pedal
  43. WTB: 93-97 Trans Am Passenger Side Skirt,in NJ
  44. Oil Pan
  45. Looking for chrome c6 or c6 zo6 wheels
  46. passenger Camaro Mirror Glass
  47. Wtb: Mwc sub frame connectors
  48. wtb flywheel bolts
  49. PCV lines / EGR intake block off plate
  50. want to buy pipe with catts for ls-1
  51. WTB: external pump, starter, misc crap
  52. WTB: Air Conditioning Lines
  53. Wtb 1 LS6 hollow intake valve
  54. Wtb stock 98-02 pass side camaro headlight
  55. W T B 20 mm drop rear springs...
  56. WTB: LT1 Hooker y-pipe
  57. Lower rubber m6 shifter cover, mint ebony m6 shifter plate
  58. old PCV lines
  59. WTB 42# Marine Injectors
  60. WTB: 22mm hollow or 21mm solid rear sway bar
  61. WTB Fast 90/90
  62. WTB - Headlight covers 98-02 Camaro
  63. WTB 4L60 Torque arm bracket
  64. 3" cutout
  65. LT1 oil pressure sensor fittings
  66. WTB: LS6 or FAST like... RIGHT NOW
  67. WTB t4 turbo cross over and down pipe
  68. WTB LSx motor 6.0 + preferred
  69. ARP 234-4317 Head Studs Kit
  70. WTB: 98 LS1 Engine harness
  71. wtb aeroforce gauge
  72. ls1 fbody oil pan and pcm and wire harness
  73. ls2 /ls3 pieces
  74. wtb: red driver side camaro door and fender
  75. F-body front lower a-arms, ls1 aftermarket kmember, and torque arm
  76. clutch/chris1313 no ac/injectors
  77. trade sweetthunders for something else
  78. Wtb
  79. WTB ASAP: GTO one-piece driveshaft
  80. WTB LS2 conversion throttle body DBC
  81. WTB Longblock
  82. WTB 102mm Nitrous Plate
  83. WTB: BMR Or Strano Lowering Springs
  84. gray door panels wanted, very nice shape
  85. WTB- Driver side T-top 2002 Firebird
  86. WTB: 02-04 LS6 Cam
  87. water pump and sensors
  88. WTB GM Tech II
  89. WTB Powerglide, stock or built
  90. WTB: LS1 Stock Throttle Body and MAF
  91. WTB 3" exhaust
  92. WTB: SS spoiler and cowl hood or SS hood
  93. Looking for a CME valance
  94. WTB MS3 camshaft or similar
  95. WTB 5.3L LH6 Camshaft
  96. WTB: GMPP ASA cam.
  97. WTB TCC006 - Torque Arm Relocation Crossmember, T56 / M6, LS1
  98. WTB: magnaflow exhaust
  99. Need 2 Triangular Truck Coils (LQ9)
  100. Do Want!
  101. stock throttle body
  102. anything for 240sx 5.3 swap, need gto pan NOW
  103. WTB Universal MSD wires for ls1
  104. wtb forged pistons and rods for a 6.0- ls3 holley hi ram
  105. WTB: GTO Spares, LS1 front accessories, Trans Am Bumper
  106. Wanted: Lt4 Hot Cam
  107. WTB LS1 rods/pistons & LQ9 rods/pistons
  108. 16" dr
  109. Looking for 98-02 ss hood
  110. Need a cam
  111. Wtb: Gm t56
  112. 98 trans am exhaust stuff
  113. 98 trans am exhaust stuff
  114. 98-02 camaro auto shifter bezel
  115. whole exhaust system 98 trans am
  116. WTB: LS6 intake and cross over tube!!
  117. Headlights: Halo/Whistler/Stocks
  118. WTB th400 to stock 10 bolt driveshaft
  119. Headlights: Halo/Whistler/Stocks
  120. trade 2 st bullets for 4x9 magnaflows
  121. wtb seat spring
  122. wtb 92mm throttle body
  123. WTB FAST fuel rails #146028
  124. WTB: 10 spoke SS rims
  125. Wtb: Gm t-56
  126. any thing for a ls swap in a notch mustang
  127. wtb camaro passanger tail light.
  128. WTB 5.3 wiring harness, MAF, flywheel, throttle cable, and manifolds?
  129. Wtb 4l60e lt1 stall
  130. WTB: last second LT1 pieces
  131. WTB: 2005-2010 Mustang 4.0
  132. WTB: LS2 waterpump
  133. valve covers???
  134. WTB ls fbody starter, non tcs throttle cable
  135. WTB: Nitrous Outlet plate, torque arm
  136. WTB: camaro Ebony AC bezels
  137. WTB : ANY programmer for correcting Speedo
  138. WTB: Twin plate clutch. Nothing aggressive
  139. WTT/WTB: Gray NOT Ebony Camaro Radio Bezel in PERFECT condition. No vents or switches
  140. WTB LS2 Intake manifold
  141. Wtb ls1 cam 212-230 range
  142. Wanted: Dead Starter Motor
  143. WTB Weld wheels
  144. 4 channel 10 bolt needed in cleveland
  145. WTB Ebony leather front seats, Hardtop headliner, LS6 intake, 99+ ls1/A4 harness&pcm
  146. wtb F body ls1 oil pans (2)
  147. 3000psi nano set up
  148. WTB rear end 12bolt/9"/8.8/maybe 10bolt
  149. WTB anything to do with lt1 H/C
  150. WTB: LT1 Valvesprings
  151. WTB camaro headlights
  152. Valve covers
  153. Look for a reverse split cam or ls6 cam, springs, and pushrods
  154. Torque are relocate for T-56 and Long tubes
  155. Aluminum 5.3 block, how much are they?
  156. WANTED: Bad 99-02 PCM
  157. LSX Center bolt valve covers and bolts.
  158. WTB: MGW Shifter 04 Z06
  159. wtb f body ac compressor
  160. WTB 2000 Camaro front end parts
  161. WTB "Trans Am" door emblems Arctic White
  162. looking for a 99-02 pcm for an auto
  163. WTB LS3 heads rockers intake!
  164. corsa or clone dual side exit exhaust tips
  165. ls1 Steam port blocks need 2
  166. 6 liter long block
  167. WTB right Meow!!! A4 shift lever
  168. AC condensor and lines
  169. WTB Siemens Deka Injectors
  170. WTB nitrous bottle
  171. Ls6 intake and injectors
  172. ls1 camaro front accessories and injectors
  173. WTB LS6 Long / Short block
  174. WTB: AC Components (Lines, compressor, etc)
  175. adj poly bushing lcas
  176. WTB: ls1 valve covers
  177. WTB A/C bracket with tensioner
  178. WTB-Trickflow 225s or 235s
  179. In need of NBM Camaro Passenger Mirror
  180. 98-02 Camaro LS1 Engine Wiring Harness and PCM
  181. LS block
  182. WTB: Will pay $20 for all A/C underhood BOLTS/SCREWS for A/C re-install in 2002 TA
  183. looking for chris1313 no ac
  184. anyone have a quad tip cme tip or valance
  185. wtb 96-97 ss hood
  186. WTB: 3ch rear, hard brake line pass side
  187. WTB: Edelbrock 65073 Swap Headers 70-81 Fbody
  188. WTB: wheels- RPM 505, MMR GT-1 or something similar
  189. WTB 9 inch
  190. Microedge
  191. WTT:P600b Procharger Setup for complete 6.0L with accessories, harness, ecu & T56
  192. WTB: LT1 ac delete pulley
  193. WTB Firebird/TA front license filler
  194. black carpet for a 00 SS
  195. Air Conditioning Compressor For 2000 SS
  196. WTB-LS1 Camaro complete accessory brackets
  197. wtb: new delphi or ac delco vented opti
  198. WTB: A/C compressor for 2000 5.3 silverado
  199. wtb: T56
  200. WTB: Clutch Master Cylinder Reservoir
  201. WTB: 18x12 c5 zo6 wheels or 18x12 c6 z06 wheels for c5
  202. WTB CME valance
  203. Need a/c line for 2000 firehawk
  204. lock and window panel
  205. WTB: Dakota Digital sgi-5c
  206. WTT or WTB- RIMS/wheels/tires- post what you have
  207. wtb ls2/ls3 58x crank
  208. WTB LS1 intake
  209. WTB shifter
  210. need 5th/6th shift fork
  211. 98-02 radiator ASAP!!!!!!!!
  212. WTB Interior Carpet Ebony No Stains Rips Tears
  213. Stock tq arm and bracket
  214. Buy or barrow jpr cam install tool for holding up lifters
  215. WTB aftermarket heads
  216. Need 15x10 7.5bs prostars
  217. WTB turbowerks oil scavenge pump
  218. Wtt 4l60 setup for th350 or th400 setup
  219. WTB: starter for LS1
  220. WTB. Ls1 F-body engine mount
  221. My WTB thread.
  222. WTB: 4" Cola crankshaft....NEW
  223. WTB - V6 rear springs, electric water pump
  224. Need driver side speaker basket - Z28 Monsoon
  225. WTB: 241/243/799 ported heads
  226. got a c5 cat back laying around
  227. air cond. compressor
  228. WTB 317s
  229. Slave cylinder and clutch
  230. WTB Rear strano springs ASAP
  231. WTB GTO stuff
  232. WTB: LS1 fuel rail
  233. Wtb: 408 pistons
  234. WTB Cometic 4.065" bore head gaskets
  235. need a 10 bolt with 4.10s
  236. wtb BAD MASS AIR FLOW SENSOR 85mm GM
  237. 6.0 liter block/ pistons
  238. 80# EV1 High impedance flow matched injectors
  239. WTB ls2 valley cover
  240. WTB: 65lb-75lb Injectors
  241. Ls1 A/c Compressor bracket ONLY
  242. WTB: Passenger Side T/A Tail Light
  243. WTB: Stock LS1 Passenger Side Cat
  244. Wtb: wheels/tires for c5 fikse ccw etc.
  245. WTB: ls1 intake manifold, injectors, water pump
  246. Wtb:bare ls3/l92/l99 heads
  247. WTB a couple of interior parts
  248. WTB: C6 ZO6 Wheel Center Caps
  249. Wtb 6.0
  250. WTB: CCW wheels, SP500/505 especially. Also consider Fikse
