View Full Version : Parts Wanted
  1. WTB: SLP Fan Switch
  2. WTB 3 series carrier w/373 gears.
  3. Stock Rear Springs
  4. WTB 3-Piece RS Rear Spoiler
  5. Need Big ls1 Cam
  6. need 9 inch rearend for 95 Trans Am
  7. WTB:LT1 o2 extensions
  8. WTB:Console Lid/Armrest & shift boot 98 Camaro
  9. WTB: 98+ Ultra Z hood
  10. Parts I need! I have parts to trade!
  11. steering parts
  12. wtb:m/t et streets
  13. lt1 ign
  14. Stock Fan Electrical Connectors
  15. Drag radials - 325/50-15 or 275/40-17
  16. WTB: 12 Disc Changer, WS6 Emblem, Front license filler
  17. LS2 cam sprocket and LS2 front cover
  18. FAST XFI system wanted!!!!!
  19. Need Fender Hood & Nose piece
  20. WTB:Strano 36mm or SS 35mm front sway bar
  21. LS1 T56 Transmission
  22. Stock air lid and tubing
  23. WTB Springs/shocks and wheels
  24. WANTED: SLP Blackwing lid
  25. WTB 60# or larger injectors
  26. WTB LS1 tranny,coils,GTO oil pan and more.
  27. WTB: Stock ls1 K-Member, Fuel Tank, y-pipe. pref. 2k local
  28. Last of the breed badges
  29. lca brackets 94 z28
  30. WTB Borla! 97 Z
  31. K&N Filter for 93-97 WS6 air box
  32. Body Parts Wanted!!
  33. WTB: 2 Dual tips
  34. '98 up blacked out tail lights
  35. WTB: Pro 5.0 short stick
  36. Wtb 99, 00, 01, 02 Pcm
  37. I need a headliner!!
  38. ls6 cam
  39. WTB SLP air lid & filter
  40. Ls1 T56
  41. WTB Shifter Console Insert
  42. WTB bottom plastic intake shroud
  43. et drags
  44. WTB: LS6 coolant lines!!!!
  45. LT1 Clear Corners
  46. WTB: T-top shades!!!!
  47. WTB: LS1 T56 bellhousing
  48. black leather seats and door panels, carpet, msd
  49. gm 847
  50. WTB: LS6 valley cover
  51. WTB Misc.... bolts and nuts...
  52. WTB: FAST LSX Intake(will consider LS6) + TB + LT headers
  53. bell housing
  54. 12" stealth sub box- black
  55. wtb: Cam
  56. WTB SLP badge
  57. 26 inch slicks!
  58. WTB: Turbo
  59. WTB: Z28 Factory Rims
  60. Camaro SS hood grill
  61. WTB: stock fbody exhaust mounting hardware ASAP!
  62. Pacesetter Headers.
  63. 17 inch chrome 10 spoke ss wheel
  64. WTT T-Maxx Nitro R/C car For Nitrous Kit.
  65. Wtb: Mti X1 Cam
  66. Camaro Tail Light Blackouts needed!!!!
  67. LS1 Engine Parts
  68. WTB: Sport Comp Gauges
  69. WTB: LT1 Cam
  70. Flowmaster Muffler...
  71. Parts in Raleigh NC area
  72. Drag Slicks Needed Asap
  73. WTB: 9" rear end
  74. Wanted: Gauge Cluster Bezel
  75. WTB Underdrive Pully
  76. WTB Throttle Body
  77. Need Dual Gauge Pod for a C5...
  78. How about a firehawk hood?
  79. LS1 engine harness and ECU
  80. WTB, Stock LT1 crankshaft, rods, and pistons.
  81. Rims
  82. Wtb: 3000-3600 Stall Tc
  83. WTT:Stockers for Halo's
  84. Driver's Mirror Assembly
  85. wtb; calipers, center piece of tail lights
  86. WTB: BBK intake mainfold
  87. WTB: rear marker lenses for a 'bird
  88. 18" CCW's
  89. clutch
  90. Wtb Valley Cover
  91. WTB Cleal lid..
  92. drivers side seat foam
  93. 4 channel/mono Amp
  94. Oem ws6 or SLP ram air hood from 96/97 TA
  95. WTB iron 6.0 block
  96. wtb LS6 intake valley cover
  97. WTB: 10 bolt posi
  98. VFN 98-02 TA 5" cowl hood
  99. 4L60e in our around Houston
  100. pre 2001 WS6 wheels, 2 of them
  101. WTB: Hood Hinges for '96 Z. Preferably Black!
  102. NEEDED! 99-02 LS1 Fuel Pump
  103. WTB: 4l60E Shift kit, BIG trans cooler, oil pump,timing chain, and gasket set
  104. LS1 / T56 wanted for swap
  105. WTB SLP TOTL exhaust
  106. WTB: Borla XR-1
  107. WTB MAC Y pipe for mid length header
  108. 1998 camaro interior parts wanted!
  109. Tr224, Tr228, Tr230
  110. wtb ss oem hood & spoiler
  111. Wiper arm covers
  112. wtb throttle body blade
  113. WTB power steering pulley
  114. Center Console Door that fits 00 Bird
  115. Wtb Ws6 Rims Or Black Zr1 Rims
  116. Cat-Back Exhaust
  117. passenger side side skirt for a TA
  118. LS1: NEED 1 FACTORY TB AND 2 MAFs
  119. WTB: TPS Switch
  120. Wtb: Ls1/ls2 T56
  121. Will pay someone to fix my spedo
  122. wtb: seat tracks
  123. 2002 SS 10 Spoke Lug Caps Wanted
  124. WTB LS1 engine/trans/wiring harness/PCM
  125. I need some valve seats and seals
  126. LS1 T56 1300 Before shiping
  127. WTB: Panhard Bar
  128. injectors
  129. ORY to fit stock manifolds
  130. WTB various items for an LT1 Camaro
  131. Needed 98-02 Fbody Oil Pan
  132. WTB: 2 wheels at least 9 inch wide
  133. wtb linelock
  134. need a t56 m6 for a 94 trans am
  135. WTB Helm Service manual for 1997 firebird
  136. ls1 pullout engine!!
  137. Tb
  138. 4 or 6 point cage 02 ss
  139. WTB 5.3 LSX engine or long block
  140. wtb fast 90mm top shell
  141. LS1 Steering Rack
  142. WTB c6 oil pan
  143. WTB: Upper Console
  144. 98-02 ss spoiler led brake light
  145. Wtb: Coilpack (1)
  146. gauges and fuel pump
  147. LT4 springs and SFCs
  148. Got a Cheap LS1 console?
  149. wtb head bolts/gaskets
  150. Camaro HVAC control panel???
  151. need 99-02 PCM
  152. WTB WS6 Lift Off Hood
  153. WTB LS1 Dipstick Tube
  154. Maybe selling my n2o
  155. Grey Top Dash Plastic
  156. WTB: two 17 x 9.5 chrome c5 zo6 rims.
  157. WTB: 17x11 TT II's
  158. Need driver side front fender, and side skirt for TA
  159. WTB: Performance Exhaust System
  160. needed bose speakers for vette
  161. Need Ls1 Ss Spoiler
  162. WTB: TPS & IAC sensor from throttle body
  163. wtb lingenfilter gt2-3 cam, mti stealth cam, or tr cheater cam
  164. WTB: Complete 10 bolt
  165. Need ss hood GRILL insert for scoop.
  166. Need Tan Leather Seats!
  167. ***WTB*** Need dual E-Fan Setup
  168. WTB Chrome lug nut covers/ Jounce Bouncers
  169. attention, wanted 4 point roll bar
  170. WTB fuel line,flexplate, booster line
  171. Need front brake calipers and rear brakes!
  172. WTB B&B exhaust tips
  173. o2 extensions asap
  174. WTB drag radials
  175. WTB: 275/35/18, 275/40/18 OR Any that will fit 18x10
  176. WTB long tube headers for lt1
  177. F-body LS1 Accessory Bracket/Accessories
  178. WTB: A/C Parts
  179. WTB: Truck manifolds
  180. headers and y pipe needed asap
  181. looking for an LT1 T56
  182. WTB: Stock LS1 throttle body w/ sensors
  183. Need O2 Sims ASAP
  184. Mac mids for 01' TA
  185. procharger wanted or other
  186. Wtb Bgra
  187. I Want A Ls6 Intake Now!
  188. Prods, retainers and timing set
  189. kooks headers
  190. Gunmetal 17x11's
  191. WTB stock crank pulley
  192. WTB Firebird Body Parts
  193. springs/shocks
  194. wanted..ory pipe
  195. rear pro kit springs
  196. Wideband O2
  197. WTB: Mickey Thompson's
  198. WTB: Smooth Bellow
  199. WTB 243 Heads
  200. wtb: slp cai
  201. needed someone parting out an A4 98car
  202. wtb front drag wheels
  203. wtb y pipe and exhaust
  204. "Do You Want To Trade a Gauge"
  205. WTB: LT1 2xO2 extensions. need these badly
  206. WTB 15x8 wheels
  207. I want your broken vette O2 sensors! ;)
  208. WTB coils,wiries and brackets.
  209. xxXX Sponsors: Cadilliac Lifters Needed XXxx
  210. WTB stock LS1 parts....
  211. WTB: Lower Shift Boot
  212. WTB: 17" front C5 vette wheel
  213. WTB: 10 Bolt Rear!
  214. 6 speed upper console
  215. t-rex cam (or trade for T2?)
  216. 90mm Throttle Body
  217. WTB LT1 shortblock
  218. Z06 calipers and rotors
  219. Oil Pan
  220. 853 Bare Heads?
  221. need a pair of front o2 sensors
  222. WTB: 90mm Throttle Body
  223. Wiring
  224. 10 spoke wheels
  225. WTB LT Headers
  226. Gaskets, bolts, valve cover and more needed !!!
  227. WTB: one 10 spoke rim
  228. Look for a Ls1 engine harness
  229. Centercap for 02 WS6 wheel
  230. a/c
  231. Turbo or supercharger
  232. WTB: Stock 01-02 Exhaust Manifolds
  233. looking for an Lq4/Lq9 take out w/auto trans
  234. True Duals Wanted
  235. WTB ls1 connecting rods
  236. WTB Ls1 Intake, Driveshaft, Airbox, Engine Harness
  237. 36lb injectors, O2's w/ extensions
  238. WTB Good machinable 6.0L bare block
  239. WTB: Cam
  240. WTB wheels with tires whatcha got?
  241. rims
  242. WTB Flowmaster 40 series
  243. WTB Weld Draglite XPs 16x8
  244. WTB set of ZR1's
  245. WTB weld draglites 15X4
  246. Wheel Spacers and shank style lugs for Weld Prostars
  247. T-56 conversion kit needed
  248. wanting parts 98 z28
  249. o2 sims and extentions
  250. WTB: good 6.0L shortblock in or around CT
