View Full Version : Parts Wanted
  1. Shift knob, black HVAC knobs
  2. WTB: Stock LS1 rear in Florida
  3. WTB: Fuel injectors for LT1
  4. WET Nitrous
  5. WTB front clear corner lenses for 98-02 Z
  6. I Need Head Bolts Quick
  7. wtb: g-tech
  8. lt1 a4 to an m6
  9. wtb: Catback, and a few others
  10. Door speakers
  11. WTB: LS1 F-Body Calipers Front & Rear w/ brackets
  12. 98 trans am dash pad grey
  13. WTB Whistler Headlights
  14. Looking for LS6 valves and Keepers
  15. WTB Underdrive crank pulley
  16. WTB: NX remote Bottle Opener
  17. WTB Procharger/Fi stuff
  18. WTB Tail light
  19. 10 Spoke Chrome Ss Wheels!
  20. WTB Prostars
  21. wtb asap nitrous plate
  22. Shocks and springs
  23. Wtb !! Spec Stage 3 Clutch Or Nice Clutch, Lower Control Arms, Strut Bar, Rockers
  24. Looking for 28in MT Drag Radials
  25. wtb: pro stars
  26. fuel pressure guage
  27. Autometer 5" Tachometer
  28. cat back
  29. WTB Mirror/rs ground effect (NBM)
  30. Coolant Level Sensor/Module for my 94 Z28
  31. WTB: T Tops for 2000 Trans Am
  32. WTB: LT1 performance valvetrain parts
  33. WTB: ashtray lip and TC switch cover piece
  34. need maf connector for 85mm maf to fbody harness
  35. WTB complete wet nitrous kit
  36. Wheels
  37. WTB: center console for firebird 98-02
  38. 700hp clutch and flywheel for lt1(95z28)
  39. tubular k-member for lt1(95z28)
  40. WTB - Passenger side Monsoon Door Speaker
  41. wtb t56 or trade for fully built a4
  42. WTB: LG brake relocation brackets
  43. AC Bracket
  44. sphoon adj torque arm
  45. WTB: LS1/4L60E/ECU/Harness Swap Kit
  46. WTB front right ground effect piece 98 up camaro
  47. 94-95 PCM harness
  48. WTB TSP Catted "y"
  49. LS6 or FAST 78mm Intake
  50. MIG welder
  51. 97 firebird tail lights
  52. Wanted: Trans Am 3rd brake light lens
  53. WTB: Low mile LS1/LS6 with accessories/Wire harness/ECM possibly trans
  54. Need Interior Pieces for Firebird
  55. lots of aftermarket parts wanted
  56. WTB: LQQkin for some rims.......
  57. LT's headers wanted please
  58. WTB Big n Littles for 01 F-body
  59. 2 step
  60. 98-02 Trans Am Front Bumper And Passenger Fender!!!
  61. ROCKERS and VALVE SPRINGS
  62. WTB adj MASTER cyclinder for ls1 t56
  63. WTB: Misc. Tan Interior pieces, Monsoon CD, Front License Filler, Lid, Cat-back
  64. WTB: LS1 Driveshaft, 17" Tires, Elec. oil pres. guage, LT1 Engine parts
  65. wtb 98-up 4l60e and sell 93 4l60 with tci converter
  66. y pipe
  67. Stock dual horn assembly
  68. WTB Weiand or BBK intake
  69. WTB Headlights.
  70. 2 step
  71. wtb:stock throttle plate
  72. WTB: '95 Z passenger side wheelwell panel
  73. Air Lid
  74. **WTB** LS2 Block
  75. I need replacement stock Monsoon Speakers
  76. WTB MSD Digital 6
  77. WTB 8 pistons for 395, 4.125-6.125 -14cc
  78. WTB Rebuildable T56
  79. oil cap extender for ls1
  80. WTB 55 + lb injectors
  81. wtb 78 0r 80 mm tb
  82. WTB: 3rd Gen Camaro Parts
  83. **WTB** TA speakers
  84. WTB: stock rockers
  85. WTB: 12-bolt, cf driveshaft, c5 brake kit
  86. Lt1 engine
  87. **WTB Throttle Cable Bracket, and Fuel Regulator Bracket for 4150**
  88. WTB camaro 99+ manual harness
  89. 2001-2002 stock rocker arms.
  90. wtb weld draglites or cragar superlites 15x8 5.5" backspace
  91. Wtb...90mm Tb
  92. Autometer Cobalts
  93. wtb a 4.3 v6
  94. WTB stock blade for throttle body
  95. wtb nitrous kit for lt1 !!!!
  96. wtb ls6 intake or fast 90
  97. Looking for Pewter Camaro front bumper
  98. Wtb Ls1/ls6 Block!
  99. WTB:Misc Parts(exterior/interior)
  100. WTB: 10 bolt posi
  101. need LS1 shortblock
  102. WTB: SLP Exhaust tips
  103. T56 and parts
  104. Engine covers, Coil covers
  105. ac compressor for 95 trans am needed
  106. WTB Centerbolt Valvecovers
  107. Camaro Monsoon Door Speaker
  108. WTB lt1 exhuast manifolds
  109. LS1 Cooling Fans
  110. WTB salad Shooters and an LS1 fuel pump
  111. Lower control arms
  112. Charcoal Grey Interior Peices [PICS of Whats Needed]
  113. WTB weiand ls6 style intake and LT's
  114. WTB New LS1 flywheel
  115. LS1 Lifters
  116. WTB: E-Fans
  117. Need LS6 intake! Got cash ready!!!!!
  118. NEED 10 anniversarry Hawk hood stripes
  119. wtb weld prostars
  120. need new...ish...stock rockers and pedestals
  121. Need 3000-3200 stall for TH350/400
  122. Stock Z28 or SS exhaust
  123. need pushrods!
  124. looking for tires
  125. Center Bolt Valve Covers
  126. WTB Camaro SS Subframe Conn and Strut Tower brace
  127. WTB GMMG Oval Tips
  128. WTB 98-02 ls1 headers with ypipe ory or catted
  129. 215cc AFR Raised Runner Heads.
  130. Need a camaro 2000-2002 steering wheel
  131. Looking for good tires for stock 16" or tires with black Z06 rims
  132. looking for complete ls1 front end ddddddddd
  133. WTB 98+ T/A rear bumper cover ASAP
  134. WTB: coil pack harnesses
  135. Wtb Borla Exhaust
  136. WTB coated longtubes w/ or w/out ypipe
  137. wtb valve springs
  138. Aluminum Driveshaft
  139. 98+ T/a shifter plate a4....
  140. Grommet for Power Antenna
  141. wtb ls1 wiring harness and pcm for auto
  142. WTB Nearly New Clear MTI LID for 00-02
  143. WTB: Comp 918 valve springs
  144. HP Tuners Wanted
  145. slp exhaust
  146. wtb lt1 mod for good price
  147. Big Big want list inside.
  148. WTB front turn signal socket
  149. WTB: LS1 Clutch Line T-56
  150. WTB LS6 Intake and 99+ valve covers
  151. Fuel Pump Aeromotive
  152. shocks!
  153. Need Panhard Rod Relocation Kit
  154. WTB LS6 heads
  155. WTB 4l60e transmission lines (need!)
  156. Pacesetter Headers !!!!!!
  157. WTB: GTO oil pan
  158. Wtb: Stb
  159. Supercharger Pulley
  160. WTB Fuel pressure gauge
  161. valve springs
  162. power antenna
  163. WTB: '95 Z Seatbelt holders
  164. SLP Bellow
  165. spiral flow or bullet
  166. 2000 WS6 17 inch rim (1) needed
  167. Feeler/WTB LT1, T56, ECU, Uncut Harness (I'm in OH)
  168. WTB electrical everything for an 04 silverado 5.3
  169. K Member
  170. WTB: Complete LSx dropout
  171. !!WTB!! 26x10.5x16 MT ET STREETS
  172. hardened push rods 7.4
  173. doing body swap
  174. WTB: HP Evos rims
  175. 98+ headlights
  176. WTB dark grey carpet and floor mats
  177. Stock Ls1 Throttle Body!
  178. Wanted:LT1 shortblock with low miles
  179. WTB stock 00-02 throttle body
  180. WTB: True duel exhaust near TX
  181. ac pulleys and tensioner w/ pulleys ls1 98-02
  182. SVO 42lbs injectors.
  183. intake and tb
  184. WTB: dipstick+tube, m6 torque arm mount, motor mounts
  185. WTB: Trans Am Interior Parts
  186. anybody wants to trade 42lb injectors for 30 or 36
  187. WTB Harlan or similar shift lite
  188. WTB Block and Pistons
  189. WTB Parts
  190. WTB: LS1 + T56 or wrecked LS1 car
  191. WTB: LS6 Intake and LT headers
  192. WTB Corsa Kit #14141
  193. WANT JEGSTER TORQUE ARM!!!!! new or used
  194. Sportlines
  195. DS front side marker for a 98+ ta
  196. T-56 from LS1 car
  197. Group purchase Koni SA's
  198. 1996 Z28 interior harness under dash
  199. ls1 f-body accessories
  200. wtb: converter
  201. Fuel Pump for a v6 93 Camaro
  202. Seat wiring harness GM pn 12177553
  203. Stock 97-02 Camaro Taillights
  204. WTB: Brake calipers
  205. WTB:procharger
  206. WTB:procharger
  207. Accufab
  208. cam needed
  209. looking for tires........
  210. WTB Wheels and tires
  211. WTB SFCs & LCA Relocation
  212. I need a coolant tanks(00 ss)
  213. WTB: Front bumper cover and hood for 2000 Trans Am
  214. Wtb Stock Ls1 Cams
  215. Sub 10" Stealth Enclose/Amp Rack
  216. WTT my Z06 rims for TT2's
  217. 94-97 LT1 AC Hard Lines... Drier to!!
  218. 01-02 ls1/ls6 valves 5.3 truck valves
  219. WTB: Corsa TIPS!!
  220. stock valves for 241 heads
  221. asr or fog light switch
  222. WTB polished fuel rails
  223. drivers side t-top
  224. 4L60E tailshaft
  225. Need a stock shift knob for a 93+ ta
  226. LT1 ram air box setup (for trans am)
  227. Looking for 6.0 in WI
  228. slp grill
  229. WTB:98 computer and harness
  230. WTB BCM Body control Module
  231. WTB: drag radials
  232. a4 console
  233. wtb comp can xr275 or 281
  234. Stock short block LS1
  235. ram air setup
  236. Wanted: Interior Parts and Upgraded Sway Bars
  237. WTB: T56 transmission for LS1, wiring harness and pcm
  238. TA taillight
  239. M6 tranny to convert from A4
  240. WTB: SPEC Stg. III+ clutch for 2004 GTO
  241. Sub Box // 6.5 inch speakers
  242. LS1 Center Console for M6
  243. LS1 intake manifold
  244. few nitrous things...
  245. dmh 3" electric cutout
  246. Black interior/racing seats!!!!
  247. Honeycomb Tails
  248. Valve Covers, Oil Pan, Accessories
  249. 93-97 M6/M5 Ash Tray Lid W/Spring needed...
  250. WTB: 3.23 or 3.42 10-bolt rear end - quiet and problem-free only (SoCal)
