View Full Version : Parts Wanted
  1. WTB: Induction piece from WS-6 hood
  2. **WTB 1LE springs!!**
  3. LT1 valve cover
  4. LS1 engine
  5. SLP Lid
  6. I need stock stuff
  7. WTB: Ls1 Shortblock
  8. Looking for two ten spoke SS rims
  9. wtb:driveshaft yoke or driveshaft
  10. Vendors] What Torque Converter can u offer?
  11. wtb: ls6 intake manifold
  12. WTT: 15x8 Prostars for 15x10s.
  13. Looking to swap my complete 98 m6 for an auto.
  14. Looking for some exhaust tips
  15. looking for free rims for the cause!!!
  16. W2B ORY and Cat. Back...
  17. 94-97 Firebird Cluster....
  18. WTB:coilpacks,brackets and harness
  19. WTB T/A Rear Bumper Cover & 1 98+ Foglight Assembly
  20. maybe headers finally?
  21. WTB: LS1 Fans
  22. ls1
  23. 6.0 short block
  24. WTB: Med Gray Upper Console for A4 Camaro 98-02
  25. wtb headlights camaro 1998 2002
  26. WTB: 1 rear 17x9.5" 2000 and up argent corvette wheel
  27. Headlights
  28. Wtb!
  29. 1.7 roller rockers for LS1
  30. WTB - 220 or 224 cam
  31. 4k+ stall,aftermarket fuel pump, timing tuner,drag springs/shocks,nitrous accessories
  32. WTB: 98-02 LS1 front brakes... cheap!
  33. WTD Rear End
  34. WTB Z06 camshaft
  35. LS1 F-Body Oil Pan needed
  36. wtb t56 vent tube CAP
  37. WTB 4l60e
  38. WTB slave cylinder
  39. WTB: Tq Arm Relocation
  40. WTB 98-02 Stock Monsoon Speakers
  41. looking for a messed up t56
  42. WTB Lowering springs (preferably Pro-Kit)
  43. posi unit out of 98-02 fbody
  44. m6 parts belhousing, clutch and slave
  45. wtb:Muffler
  46. Looking for an OBD1 LT1 engine harness for automatic
  47. looking for 17"+ wheels
  48. Gauging interest AGAIN...WTT my T56
  49. TC switch needed
  50. t-56 98-02 rebuildable
  51. WTB used cheap auto trans for a '94 6cyl.
  52. Ls1 T56
  53. WTB: 35th LE 10 Spokes
  54. Need stock Camaro SS exhaust tips!!
  55. Trade? Halo lights for stock headlights
  56. catback
  57. Wtb: Stb
  58. T56 conversion parts!!! pedals, master cylider >> maybe a trade for th400 stuff
  59. 99-2002 Camaro Engine bay wire harness-relay-fuseblock
  60. WTB:Rear 21 mm sway bar for a 98 ss
  61. WTB 12" subwoofer steal box drivers side
  62. Need 98 ECM
  63. bottom cover piece to 4L60E
  64. Wtb: Lt1 Slp Cai
  65. oil pan
  66. WTB: 93-96 Camaro Tail Lights
  67. LOOKING FOR: 96 Firebird front body panels
  68. I need pistons
  69. 95 k member and a arms
  70. Need One Stock Silver Snowflake Rim
  71. stock lockss
  72. stock locks
  73. stock locks
  74. WTB 2000 ws6 rim
  75. WTB T-56 inspection cover/dust cover.
  76. WTB A Arms, struts!!
  77. wanted ls1 motor with T56 and complete harness
  78. Posi
  79. Guages
  80. Chrome strut tower brace.
  81. Looking for ARP Header studs and Front Rotors
  82. wtb LT1 headers
  83. F-Body Y Pipe
  84. 1995 LT1 computer and wire harness
  85. WTB 7.400 pushrods.
  86. Possible Lt4 for Lt1 trade??
  87. Looking for TPI acc Bracket
  88. coil brackets, 342 rear
  89. Wanted: LS1 motor!
  90. WTB 2002 PCM and Engine Harness
  91. LT1 f-body low coolant sensor
  92. Wtb Sts
  93. WTB Enkei V1's
  94. WTB: Lowering Springs
  95. Power steering pump pulley
  96. turbocharger
  97. LT1 FRC 30# Injectors Chrome Valve covers
  98. WTB Ram Air or Firehawk style hood & Deck lid
  99. WTB Stock Z28 or SLP Dual/Dual Tips
  100. Spintech mufflers
  101. WTB: 18" drag radials or 17" DR w/rims for C5
  102. Weld Draglites Front Runners Wanted
  103. WTB: TSP's Catted Y-Pipe
  104. WTB: Nitto 555R 275/40/17 or 315/35/17
  105. Need Conversion Parts
  106. stock retainners
  107. MOSER 9" REAR-END
  108. Driver side t-top!!
  109. 60lbs injectors
  110. WTB T/A Rear bumper cover and 98+ passngr taillight
  111. Looking for a stock 10bolt with low miles
  112. wtb SS emblems
  113. Ac Control Panel
  114. WTB: Remote bottle opener
  115. Need stock y pipe hanger (2001-2002)
  116. WTB 06 Zo6 mufflers
  117. WTB: Auto Meter Gauges
  118. In Need Of A Powersteering Pump Pulley
  119. 2000 LS1 Dr Side Valve Cover Needed!!!!
  120. Oil dip-stick tube
  121. WTB red manta stripe
  122. Need!!!!
  123. WTB piece around A4 shifter for 98 z28
  124. wtb injectors
  125. clutch,driveshaft,flywheel and bolts,duels
  126. hp tuner
  127. wtb autometer phantom tachometer
  128. WTB: T56 tranny or complete swap for LT1
  129. WTB: Stock Black Camaro "ball shifter"
  130. ANTI roll bar.....rear sway needed
  131. WTB LT1 T56 input shaft & front plate or WTT LS1 T56 input shaft and front plate
  132. wtb spohn double adj lca and Qa1 Coilovers
  133. roll bar wanted!!
  134. wtb: ls6 intake, underdrive pulley, and longtubes
  135. Need Fuel Rails
  136. centerbolt valve covers
  137. WTB Camaro Body panels, Front Bilstein Shock, and Driver's Side Front Control Arm!!
  138. t-56 swap....still looking
  139. WTB: LS1 Electric fan setup
  140. WTB: LS1 or LS6 Block
  141. Need Vette Ls2 Flywheel
  142. wtb: lots of stuff.
  143. nw 90mm tb
  144. 98 valve covers
  145. wtb: cme valance!! prefer black but im up for any color.
  146. WTB: LOTS of Parts... L O O K >>>>>>>>>
  147. Wanted Ar Rebels
  148. wtb Lt1 rear disc brake setup.
  149. Exhaust tubes!!!!!!!!
  150. wtb 36lb injectors for ls1.
  151. Hi flow Cat, E-Cutout, Clear Corners
  152. WTB Drivers Side Headlight cover or assy! (BLK)
  153. WTB Centerbolt valve covers
  154. Wtb: Lowering Kit
  155. Artic white rear bumper..Bilstien Hd's..eibch prokit
  156. WTB- Spohn Trans mount Torque arm
  157. WTB: Need turbo stuff + supporting mods
  158. SLP Grill....
  159. Needed: Foam gasket for underside of SLP lid
  160. Stock Foglights....
  161. looking for stock Y pipe/rear 02 sensors
  162. need 2 good working o2 sensors
  163. need lt4 heads and intake
  164. 2000 up cd or tape trans am monsoon
  165. WTB: Tires 275/40ZR17
  166. WTB: Loudmouth Muffler, Seats, belts or harness, radio, panels, etc.
  167. Stock Chevy Camaro Cd Changer
  168. Passenger T-top for 4th gen
  169. Wtb Ls6 Springs
  170. WTB: 3 series posi for 4th gen Camaro
  171. Wanted: T56 conversion
  172. WTB motec Air/Fuel Meter
  173. Spohn Suspension Parts in RED
  174. need 99-02 ecm and harness ASAP!!!
  175. WTB: ls6 intake and 90mm throttle body
  176. Wanting 4:10's
  177. Wanted Bogarts
  178. WTB 4L60E core
  179. Coil Packs wanted.
  180. WTB: Hardwire FM Modulator
  181. Wtb: Salad Shooters With Tires
  182. Looking for the abs sensor!
  183. wtb:lt1 clutch, prefer used and cheap :)
  184. wtb 8.1 marine injectors.
  185. 99 camaro drivers side rear tail light
  186. Triple Guage Pillar
  187. 1998-2002 Trans Am Front Bumper
  188. 6.0 heads
  189. Eibach Prokit, TTII's, Clear corners...
  190. WTB Procharger P1SC or D1SC head unit.
  191. 87 Grand National Fuel Rail
  192. wtb 98 LS1 PCM
  193. Wanted: GT2-3 cam & Vig 2800
  194. Wtb:T/A Passenger Door Panel Blk
  195. WTT: 17x9.5 Chrome Z06's for 17x9.5/10.5/11 Chrome ZR1's
  196. yank s600-3800 stall possible trade.....
  197. stock exaust (cats to tail pipes)
  198. wtb car cover for 98z28
  199. WTB 2 solid lifters for piston to valve checking
  200. needed lt1 rear brakes
  201. WTB: 04 GTO Slave Cylinder
  202. WTB 06 ZO6 wheels
  203. need ls1 rear brake backing plates
  204. WTB: Pacesetter Headers
  205. WTB knock sensors
  206. wtb: ARP HEAD BOLTS, BMR TORQUE ARM AND RELOCATION CROSSMEMBER
  207. WTB 93-02 taillight harness and fog lights
  208. Weld Skinnies!
  209. WTB LS! motor tranny ecm and engine harness
  210. wtb: passanger side t-top
  211. t56
  212. WTT TR224 for Futral Motorsports F13
  213. LT1 SS Hood.
  214. WTB: Set Of 4 WS6 Polished Wheels
  215. gauges
  216. looking for injectors...
  217. Air bags...
  218. Rack and Pinion
  219. Air box tray and clips
  220. red formula front bumper?
  221. red formula front bumper?
  222. WTB LT1 Headers
  223. Looking for LS6 intake reasonable.
  224. 275/35/18 tires
  225. WTB 93-96 stock tail lights
  226. Looking for LS1 short-block
  227. WTB Ported TB - Shaner S2, S3, Bo White etc.
  228. WTB: LS1 power steering pump
  229. Ported/90mm fast or any tb chrome/polished
  230. WTB:speakers for 98-02 TA w/monsoon
  231. I need a CME valance
  232. WTB: cheap running carbed small block *socal
  233. WTB stock cd changer for f-body
  234. WTB ASAP! LS1 99-02 fbody engine harness
  235. WTB body wiring harness for 1998 z28 A4
  236. WTB: FPSS & RPM activated switch
  237. WTB: LS1 T56 Transmission
  238. Lg4 wiring harness?
  239. Electric Cutout!
  240. WTB G5x3 112 lsa
  241. WTB: factory SS spoiler
  242. wtb or trade:Draglites or Dragstars!
  243. need 10-bolt!!!!
  244. WTB cutout
  245. T56 Main Shaft & 5/6 driven gear
  246. NEED 98-02 parts bad
  247. Broke my junk, need help asap!
  248. WTB: Purge kit & bottle heater
  249. WTB: 6 speed console top plate w/ boot for trans am 93+
  250. WTB LS1 complete for retro swap - Wichita KS area
