View Full Version : Parts Wanted
  1. Black WS6 Hood
  2. Ls1 Alternator
  3. WTB: SLP underdrive pulley
  4. WTB: 2 CHROME 10 SPOKE WHEELS and REAREND GIRDLE
  5. WTB: Silver Drive side Fender
  6. WTB: 2 Stock chroms 5-stars
  7. wtb: COMPLETE M6 T56 conversion swap for LT1 Z28
  8. wtb: stock ws6 or ss catback
  9. WTB:Built 4l60e
  10. WTB LS1 Throttle Position Sensor/Plug Pigtail
  11. Black Billet grille 98-02
  12. Looking for used STS kit
  13. WTB:LS6 Cam
  14. WTB 93-02 Trans Am seatbelts BLACK
  15. WTB 2 18" wheels
  16. WTB few things please look inside
  17. ls1 upgrades wanted!!
  18. I want red brake callipers! for 02 SS
  19. WTB 2 stock 5 spoke camaro rims.
  20. WTB: prostars with or w/o tires...
  21. straight waterneck
  22. BMR Panhard Rod
  23. WTB 98-02 Camaro Taillights
  24. 160* thermostat
  25. wtb: Charcoal TTop shades
  26. wtb:Door panel
  27. Wtb:camaro Lettering
  28. wtb stock axle, tire, rim
  29. Looking for a stock set of WS6 rims
  30. WTB: speed sensors for ASR/TCS
  31. WTT for 6-speed
  32. WTB: Complete turbo kit and fuel system
  33. WTB 3500-3800 Stall Converter
  34. Cleaning house. must sell!! lots FS!!!
  35. WTB: ASAP - Bell housing Bolts & Throwout Bearing
  36. 98+ Ram Air hood to fit a 96 TA
  37. shifter
  38. wtb: ls6 front timing cover
  39. Cheap/used set of headers for ls1
  40. WTB: Nitrous wet kit for LS1 w/o bottle...
  41. wtb front facia, right fender, and gfx
  42. Lt4 Hotcam
  43. WTB: Rear drag swaybar
  44. NTB: 99+ Coil pack brackets
  45. Needed: C5 Fuel Pump Bucket Assembly (w/o pump) or GM part ?
  46. T56 Quick Disconnect fitting/clutch line
  47. Want some afr heads.
  48. WTB stock ported tb
  49. WTB: lt1 Headers...
  50. LS1 Timing cover
  51. Wtb stock chrome 5 stars
  52. need some parts for my ls1, wheels
  53. Wtb: T56 In Perfect Working Condition
  54. Looking for a used/working opti spark for a 95-96LT1.
  55. cat for a 3.8
  56. Need Wheels And Tires
  57. need a starter
  58. MAF from newer style LS1/LS6
  59. wtb stock 17, pref w/ tires
  60. wtb A/C tensioner
  61. Rear Qa1's
  62. 1.6's
  63. WTT: your rims for mine
  64. LQ4/LQ9 Shortblock wanted...
  65. Used MS3 And Ls6 heads?
  66. Complete LS1 / t56 setup
  67. Wanted silver 10 spoke SS rims
  68. SS hood
  69. 85mm air lid
  70. WTB: a few 98-02 T/A body parts
  71. Stock Fuel Rail
  72. WTB: Stock 98-02 Camaro headlamps
  73. WTB: Driveshaft
  74. 1 or 2 torq thrust II's 17x9.5
  75. LS1 Bare Block/retailer? anyone
  76. WTB 15x8 convo pros, centerline, weld, etc.
  77. WTB 60 or 67 turbo for STS
  78. WTB 6.0 manifolds
  79. slave cyl?
  80. Anyone got an extra purge kit there not using??
  81. NTB: Front o2 sensor!
  82. 15x3.5 drag lights 1.75 bs
  83. wtb a torque converter for my 94 z28
  84. Need head bolts for 2000 C5
  85. need an lt4 intake
  86. WTB: Borla Quad (Round or Oval) for C5
  87. WTB Stock lower box from WS6
  88. WTT for 17" Chrome ZR1's or SS Wheels
  89. WTB Trans Am Door panels/steering wheel
  90. hvac delete plate needed
  91. WTB power steering pump..
  92. lt1 cam and ignition
  93. wtb t-56 front plate
  94. Show Me Some O2 Sims!!!
  95. Rear Hatch Lock Screws Wanted
  96. WTB: Trans Am side molding(ground effects)
  97. WTB: Fatties, skinnies w/ rims for LT1
  98. LS1 Block Only
  99. WTB: 93-96 Camaro D-Side A Pillar
  100. 98-00 WS6 hood
  101. Borla Plates
  102. ZO6 rear sway bar wanted
  103. WTB SLP Loudmouth LT1 Adapter Kit
  104. 315/30-18 rear tires (pair)
  105. WTB: GM LT4 Hotcam Kit
  106. 98 manifolds and 5inch bullet muffler
  107. alum. driveshaft & torque arm
  108. Need 02 Manifolds
  109. Lt1 T-56
  110. wtb paddle key
  111. Grand National Steering Wheel
  112. wanted f14 cam
  113. WTB A4 console tray, broken ashtray lid for A4
  114. Wanted OEM Gray Z06 wheels
  115. WTB LS1 parts: mids/lt's, lid, ls6 intake, etc
  116. taupe rear seat upright portion-excellent condition
  117. Looking for a set (4) stock springs
  118. SLP CME exhaust
  119. 98-02 Firebird console....
  120. In need of a GM LT1 hot cam
  121. WTB: taillight reflector for 94 formula
  122. WTB slp loudmouth exhaust
  123. wtb 98 up ta tail lights
  124. LS2 Block or Shortblock
  125. WTB : 2002 + z06 transmission
  126. Really Need To Buy
  127. drag racial tires
  128. WTB: Morel Hydrolic Lifters
  129. Need SHOCKS!!!
  130. cat-back
  131. WTB short block
  132. WTB: Rear SLP Dual/Dual exhaust hangers
  133. wtb bassani catback for ls1 fbody
  134. Exhaust Tips
  135. Converter wanted
  136. WTB LS1 parts (Fuel Rail, Coil Packs, Water Pump, TB, Starter)
  137. WTB Intake Manifold (LS6 or BBK)
  138. Wtb Stock Zo6 Wheels
  139. WTB: Chrome Zr1's or 10 spokes with tires
  140. WTB Interior parts
  141. Wanted Trim Piece
  142. WTB: ZR1 or early SS wheels
  143. futral f14 cam
  144. 2004 Factory Air box neeed..
  145. WTB: 17" wheels
  146. wtb caliper brackets
  147. Needed 1997 and up harness
  148. 2000 MAF and shorty headers
  149. Gm ws6 ram air hood
  150. WTB: 1" lowering springs
  151. WTB Weld Pro Stars or Drag Lights
  152. wtb 93-97 firebird or trans am headlight assemblys
  153. wtb slp air lid to fit ls1
  154. Wtb: Mccloud Adj. Master
  155. WTB DS Back Seat Speaker Cover
  156. WTB stock trans mount
  157. Monsoon camaro Headunit for 2000 or newer
  158. slp/powerbond pulley
  159. WTB: Pistons, 4.00 bore, 8cc - 12cc dish, 6.125 or 6.2 rod
  160. camaro grill
  161. WTB single 2 5/8" gauge pod.
  162. WTB: HP Tuners for 1998 Firebird
  163. Need an autometer phantom gauge
  164. i need these parts baddddddd.
  165. Need ASP Crank Pulley
  166. WTB: Front parking/turn signal socket
  167. WTB: SLP air lid, or other brand lid.....
  168. used cheap cam small
  169. WTB : 2002 Camaro IAC Valve
  170. LS1 Scanmaster
  171. LS1 intake
  172. Need Ls1 T56
  173. Stock MAF for $40
  174. WTB LS6 Heads
  175. WTB StOCK Ws6 Rims..
  176. WTB T/A front park/turn signal housings
  177. WTB: A4 pedals and A4 upper console
  178. WTB: Stock LS1 Flexplate
  179. WTB Stock WS6 hood inserts - Black, etc
  180. 1 3/4" Kooks Stainless headers w/ 3" stainless true duals
  181. WTB SS Hood and chrome wheels,
  182. Wtb: Oem Ss Hood
  183. Need MAF from a '99 LS1 ASAP!
  184. 15X10 weld prostars wanted
  185. WTB: LS1 Cam tsp 231/237 or comparable in size
  186. Passenger Side Headlight Assembly
  187. WTB flexplate for and LS1 to 4L80E stock preferably
  188. want to buy or trade stock TA wheels for FIKSE FM5's or FM 10's
  189. 7.425 or 7.450 pushrods...
  190. Looking for a drivers door panel, 97 t/a gauge cluster, rear deck lock w/key
  191. need some long tube headers
  192. 02 sims
  193. WTB vortech/procharger/whipple w/bracket
  194. WTB Left Side Headlight Motor
  195. wtb Non computer controlled quadrajet
  196. 98-02 stock f-body y-pipe
  197. WTB 2000 LS1 engine wiring harness for a 6 speed
  198. brake light
  199. SS wheels wanted
  200. Y Pipe for LT's
  201. i need a ls1 motor asap
  202. Looking for mti polished throttle body
  203. Wtb Lt1 Front Lowering Springs IN GOOD CONDITION ONLY
  204. Motor Mounts
  205. WTB: Procharger Pulley
  206. WTB: ls1 lowering springs
  207. Wheel spacers
  208. WTB 00 -02 Front Wheel Hub
  209. WTB Lower Airbox
  210. WTB: Procharger 12rib pulleys
  211. WTB stock 10-bolt in NJ area
  212. 255L Walbro INline fuel pump
  213. Ported LS1 throttle body
  214. WTB: Trans-Am Front Bumper
  215. WS6 hood???
  216. WTB: Black SS Spoiler
  217. WTB: T/A Ws6 functional hood [For 99+ years]
  218. WTB Damaged Harness or Just Injector Plugs
  219. need a boss speaker
  220. 373 gears
  221. WTB stock MAF for ls1
  222. 99+ pcm, drag lights/bogarts
  223. looking for rear springs
  224. LS6 Intake and TB
  225. wtb 4th gen bumper/body kit
  226. Wtb: MAC Catted Y Pipe
  227. ash tray and ash tray cover
  228. I need a couple things
  229. Oxygen Sensor Extensions
  230. C% Wheels
  231. Gen III 6.0L truck coilpacks
  232. wtb rear O2 simulator for a 97 and up gm
  233. lower air box
  234. WTB 2 chrome 10 spoke SS wheels or all 4
  235. WTB LS6 oil pump
  236. WTB: 6.0L crank
  237. WTB 10 bolt! Preferably E. TX or SE. AR
  238. Wtb!! Supercharger For 97 Lt1
  239. WTB- 26" or 28" M/T ET'S
  240. WTB: T/A Stock side skirts, ground effects
  241. looking for BMR springs and BMR spring cups for QA1/HAL's
  242. 16 by 8" firebird rims
  243. WTB: 2 Weld 15x3.5 draglites
  244. 4 sale 93-97 firebird/trans am fender drivers side
  245. 4 sale hoosier dot tires
  246. wanted slp ls1 air box
  247. Firebird front bumper cover or trans am
  248. WTB: Stock 98-02 Trans Am Side Marker Lights
  249. WANTED: TRANSAM Stock torque arm bushing (LS1)
  250. Wtb: Lt1 Ecu
