View Full Version : Parts Wanted
  1. Shorties, clutch
  2. WTB ASP pulley's
  3. WTB: Camaro Gauge Cluster
  4. fuel fump
  5. WTB: ram air hood for 94z28
  6. WTB driver side headlight bracket
  7. Clutch Kit
  8. WTB 2.73 or 3.23 gear set (stock rear)
  9. 10 spokes
  10. 1998 Lid for TA
  11. WTB: LT1 Induction Elbow
  12. Anybody want to trade an M6 for my A4 setup?
  13. WTB: Interior Pieces
  14. Stock LT1 fuel pressure regulator
  15. WTB intake and springs
  16. Wtb: Z06 Springs...
  17. T/A rear spoiler
  18. DMS Lowering Springs and BMR Adj. Pan Rod Wanted
  19. looking for Cheater cam comp 921 springs titanium retainers ect..
  20. Black z06 motorsports wheels/tires
  21. 12 disk factory changer wanted!
  22. Wtb : Tr 224 114
  23. Looking 4
  24. Need (1) Privat Profil 17x9.5 wheel
  25. WTB:Weld Center Caps
  26. WTB AFR 205 Heads 66cc
  27. Wtb T-56
  28. need m6 swap
  29. wanted: stock pcv system
  30. purge kit
  31. Wtb: 17 X 11 Zr1
  32. WTB Clear Lid
  33. Looking for Hooker LT
  34. Z06 heads... 243 castings!
  35. WTB: Cam
  36. Looking for bare 5.3 heads for cores.
  37. WTT Cam and Headers for Chrome ZR1's
  38. 17x9.5 ZR1's w/ tires
  39. WTB: ratchet shifter & misc. th400 items
  40. Bilstien Shocks?
  41. Need Ebony Seat Belts Asap!!!!!!
  42. clutch line
  43. Autometer Pro shift light pills
  44. Wtb : Mbc
  45. WTB: ZR1's
  46. WTB: Rear Axle off a V8, Manual
  47. wtb: moser or strange rear end
  48. WTB: Procharger or Vortech kit
  49. 6 speed center console and pedals
  50. WTB Black ZR1's or Black Z06 's with tires ...
  51. factory CD player for 1998 TA
  52. Wheels
  53. Need a piece from driver's side mirror
  54. WTB SLP 85mm maf good condition
  55. Need LS6 Intake ASAP
  56. WTB: LS6 clutch
  57. O2 Sims
  58. need a rod
  59. Need 2 P275/40/ZR17 Tires or Interested in New Wheels w/ Rubber
  60. Looking for 98 TA LID and an SLP Mass-Air-Flow Sensor
  61. Ls1 F-Body exhaust manifold
  62. WTB T-Top Shades
  63. WTB:damaged ls1 / ls6 cylinder head
  64. 1 or 2 Chrome Firehawk Wheels needed
  65. Wtb 98 F-body Ecm
  66. Looking for Fuel Pump Sending Unit Assembly
  67. WTB D-1SC for Corvette
  68. WTB LS2 Short Block
  69. WTB: stock LS1 intake manifold from C5 corvette.
  70. Need a Hpp3,or Diablo Predator, Granatelli that will work on a 2001
  71. WTT:4L60E for T56..all parts included.
  72. WTB: 15x3.5 prostars
  73. WTB Driver's Side T-Top
  74. WTB : LID ( used, but real good shape )
  75. wtb: CME tips
  76. WTB: LT headers...
  77. alternator OVERDRIVE pulley
  78. WTB - LT1 Performance parts
  79. Wtb: Lid
  80. WTB Healiner
  81. 98 or newer f body dash wiring harness
  82. 918 springs
  83. LS1 scanmaster
  84. wtb vs - vt v6 ecotec motor
  85. 85 mm zo6 or truck maf and lid!
  86. 1.7 Rockers Wanted
  87. WTB:T56-Clutch master with steel braided line
  88. WTB Drag Radials/Rims, in Ohio...
  89. fog lights, headlight motor
  90. wtb=98-02 sun visors,dr door panel
  91. coil brackets and air valves
  92. Need a ls6 manifold without Egr provision.
  93. LT1 6 speed Tranny
  94. WTB stock battery tray
  95. WTB: Procharger,Maggie,or Vortech for C5
  96. wtb - Harlan shift light
  97. WTB: Anything for a 3.8 V6!!! (1997)
  98. WTB:Power Antenna
  99. WTB: 6.0 alum. block
  100. M6 trans tq arm mounting bracket.
  101. looking for aftermarket throttle body for ls1
  102. WTB: LS6 stock pistons/rods
  103. WTB stock Short Block
  104. 1998 WS6 ram air hood
  105. 12 Bolt
  106. Looking for '01 Z06 Cam with matching springs
  107. WTB: Exhaust & headers
  108. Wtb
  109. T56 tranny conversion stuff
  110. WTB: 99+ ls1 wiring harness
  111. WTB: Rear Blackouts
  112. WTB a/c idler set up
  113. WTB Misc. parts
  114. WTB: any brand sub frame connector for 4th gen camaro
  115. monsoon speakers????
  116. WTB: Borla hangers
  117. Wanted!!!! Ws6 Lower Airbox!!!!
  118. Looking for 2 Goodyear Eagle F1 275/40/17 tires
  119. WTB torgue arm
  120. WTB: C2, TSP 225 or TSP 224
  121. need 2 wheels for slicks, 2000 TA
  122. lt1 roller rockers
  123. WTB: LS1 M6 center console
  124. WTB: Lou's SS for Hurst shifter
  125. Need a new 75mm TSP lid.....
  126. looking for a cam
  127. WTB: Upgrades Z06 slave cylinder
  128. wtb 98/02 firebird or trans am parts
  129. WTB: Camaro Wheels center caps (2)
  130. WTB: 6.0L block
  131. WTB: FAST 90MM intake and TB..
  132. WANTED: SS Hood
  133. Engine head front cover plate
  134. WTB LS6 pcv system
  135. mufflex single exit tailpipe
  136. WTB Fikse FM/10's.
  137. WTB Cam
  138. NTB 6.0 pistons
  139. wtb: sub-frame conectors 99 ss
  140. WTB tail light nuts andddd more
  141. WTB: WS6 Speedline Wheels
  142. WTB Used Stroker motor
  143. WTB: Broken Monsoon Camaro CD/Tape players
  144. WTB: MTI C2 cam "Hammer cam"
  145. WTB - t-56 mainshaft.
  146. t56
  147. WTB: 17X9-9.5 wheels w/wo tires
  148. WTB: 98-02 Tail light
  149. Shaner S3 ported TB for '01 or '02
  150. need a torsen posi
  151. WTB Grille
  152. Prostar skinnies
  153. WTB - Power Window Motors
  154. Wtb...........lid!!??
  155. WTB 3channel ABS controller.
  156. wtb 4:10 gears
  157. Clutch
  158. WTB: LS1 PCV setup
  159. Wtb Ls6 Intake!!!!!!
  160. WTB: Aftermarket LCA's
  161. Okay, really need CD player
  162. Tail light housing 98-up Trans Am
  163. LS1 ASP Pulley
  164. camaro tail panel
  165. Adjustable panhard bar/weld in LCA brackets
  166. WTB white leather
  167. 16" Z28 Stock Wheel (silver)
  168. Shaner or Equivilent TB wanted
  169. m6 center console
  170. WTB: an Aftermarket Y-pipe
  171. wtb: LS6 intake
  172. Need a rear also
  173. 4" Mufflex
  174. speakers
  175. NEED a 90mm Throttle Body
  176. WTB Unmolested MAF for 2001 LS1
  177. ls6 intake or pulleys or stall
  178. WTB: stock oil pan
  179. WTB: Crankshaft position sensor
  180. Need Rearend
  181. WTB : JL Audio Stealthbox
  182. looking for an ls6 intake, heads, etc...just curious...
  183. WTB: Lowering springs
  184. WANTED! Wolf Racecraft SLEEVE CAPS!!
  185. wtb: slp center-mount
  186. WTB 4L60e asap
  187. Ls1 driveshaft
  188. ATI 8-rib super damper and pulleys and more!
  189. Looking for a low mile Comp Cam 206/212
  190. mcleod clutch
  191. WTB: 00-02 F-Body Throttle Body
  192. WTB: 2 Bilstein rear shocks
  193. LS6 intake..
  194. LS1 Oil Pan
  195. WTB steal main caps LS1
  196. rear prokit springs
  197. Calipers Wanted
  198. SS hood! poor college kid!
  199. WTB: Black 10 spoke SS rims
  200. WTB: Stock Rear Exhaust Hangers
  201. 02 front clip for sale on ebay
  202. WTB: LS1 fans, leather seats
  203. sell me your LT1 f body radiator!
  204. WANTED: WANTED: Front Bumper cover for a 94 Z28 - Red good-great condition.
  205. looking for shift light.
  206. Looking for LS6 Intake Manifold
  207. WTB -Valentine One Radar Detector..
  208. FMIC Trade!
  209. Factory CD player
  210. WTB LS1 Edit or HP Tuners for 98
  211. 2.5" inlet Exhaust tips
  212. WTB (LS1 intake tract)
  213. WTB: Ls1 Shortblock,Heads,Intake Ect
  214. WTB: Stock Flywheel
  215. asp pulley..
  216. Wanted Ls1 High/tech Rockers 1.7
  217. Wtb 4th gen brivers inside door panel any condition any color
  218. WTB: Electic 3" cut out
  219. WTB:99- up vavle covers and coil brackets
  220. LS6 intake
  221. stock part needed!
  222. WTD: LT's and DR's
  223. Convertible parts
  224. Wtb: TNT Bottle
  225. Weld Prostar XPs
  226. Looking for an MAF mesh screen, '02 LS1
  227. wheels
  228. NEED A LOW MILEAGE T56 >50kmiles
  229. WTB: Totaled F-Body with LS1 & T56
  230. WTB: rear shocks, girdle, torque bar, lower control arms, panhard bar
  231. German Castrol 0w-30
  232. Pcm/ecm
  233. Wtb: D1sc Procharger Unit
  234. Rt passenger side fender wanted for 98 up camaro z28
  235. WTB Weld Pro Stars
  236. LT4 Heads Wanted
  237. WTB: Hawk HPS Brake Pads
  238. wtb laptop stand
  239. WTB SS air box
  240. How about some black 17 inch wheels anyone?????
  241. Wtb: Wheels!!!!!
  242. manual pedals and center console
  243. Wtb Futral F13
  244. WTB: Headlight motor
  245. Looking for ATI 6-rib 4.25 pulley
  246. WTB: slp loudmouth/tsp rumbler and GMMG oval tips
  247. WTB ATI twin intercooler setup, F body.
  248. wtb aftermarket TB for LS1.
  249. WTB ls1 headers Dings & dents OK
  250. WTB Door Speaker
