View Full Version : Parts Wanted
- Wtb 99-02 Pcm
- WTB: 98-02 Driver and Pass Headlights
- coil harness
- Radiator air dam/ intake box!
- 98 Firebird parts needed
- Stock Parts wanted Inside please.
- WTB: LSX 90 mm Intake Manifold.. new or used.
- Need 1 newer style WS6 wheel!
- off road y-pipe 00 trans am manifolds
- need 98 fuel pump assembly
- WTB nitrous blow down tube
- WTB: Wheels
- Wanted: Pair of LS1 Camaro headlights...
- 80 series flowmaster
- WTB: Pewter trans am drivers side mirror assembly
- WTB rear end.
- WTB 00-02 Camaro Parts
- WANTED: Eibach ProKit/Hotchkis springs for Sportlines
- WTT Trans Am embroidered headrests.....
- wtb, LS1
- WTB: ASP pulley and PY4000 or SS4000!
- Headlight parts
- Need starter
- WANTED: Bilstein or Tokico Shocks
- WTB UNmolested ws6 lower air box
- ls6 intake
- Oil filler neck-for vavle cover to cap.
- Need center bolt valve covers
- Need Spacers For My Ride...........
- I need of an aftermarked rear sway bar. 25mm
- Need a rearend for my 00 SS Please HELP!!!!!!!!
- stock unmolested fuel sender
- I neeeeeed a clutch
- I Need Corsa Premium Tips!
- slicks and skinnies
- WTB ORY pipe
- 99 Trans Am Foglight
- wanted: 2 01-02 Speedline WS6 wheels
- wolfe race craft 6 point cage
- WTB: Fast 90mm intake - TB (or any 90 TB) - 1 7/8 headers
- wtb TA / FIREBIRD DOOR PANELS ANY CONDITION
- WTB a set of 60# injectors
- WTB NOS steel braid line
- WTB SNAP ON LONG FLEX HEAD SOFT GRIP 3/8 drive ratchet
- wtb: tall valve covers/w breathers
- Stock Paddle Block from ZT diff
- WTB: Posi unit for 10 bolt
- WTB: Engine Coolant Tempeture Sensor Module
- WTB: T-56 Core good or bad. Must be cheap!
- WTB: Rear Bilstein HD Shocks (3rd or 4th Gen)
- CME wanted
- LS6 Intake & Cam, Roller Rockers, Valves, and other Valvetrain Related Parts
- Engine Cradle
- wtb 42lb injectors
- WTB: Driver side ls1 spindle
- NOS 15lb bottle
- wanted: M6 ashtray light
- Need a stock rearend
- WTB: shifter, sfc, stb, etc. for LT1
- Need a back windshield
- F/S Black 98-02 stock trans am hood
- need 12 bolt for m6 car.
- I need a 01 ls1 fuel rail and belt tensioner
- Looking for Firehawk or Raptor hood
- upper dash
- Need t-56 setup
- Lower Air box
- WTB: LS2 Throttle body wiring connector pigtail
- Ram Air Intake
- WTB: LT Headers
- Wtb: F13
- SLP Grill
- want cat back and 17" c5 wheels
- Wanted 93-02 f-body instument cluster wiring/plug
- WTB: 98 LS1 Valve Covers
- LT1:Want to trade some self alinging 1.6 Roller rocker for 1.6 non-alingning rockers
- WTB: firehawk wheel
- wtb coil harness
- WTB: Stealth Box
- wtb: t56
- WTB: Stock Springs, 98+ F-Body
- WTB: Kooks Long Tubes No Air and Y-Pipe
- WTB: SS spoiler
- Need Longtube LS1 headers....
- Need some parts so let me know!!!
- WTB quickly built 12bolt or 9 inch
- weld draglites
- WTB: LS1 w/ ECU and T56
- I NEED Air block off plates ASAP
- ps pump complete...
- TA filler plate.
- wanted oem ram air hood
- Wanted: sheet metal intake
- need sbc 305
- WTB: front license plate cover
- SS hood
- shift knob
- WTB: Torque Arm
- Z06 cam
- WTT: 18'' zo6 rims for Prostars!!
- WANTED 1 17' 2001 or 2002 ws6 Chrome Rim
- Needing a Aluminum Driveshaft ASAP
- wtb: 98 valve covers
- WTB stock exhaust manifolds, stock cats, and stock y pipe
- WTB junk cat
- Gmmg???
- Need Airlid Clips
- Where to get Trans Am hatch...
- Wtb: Pacesetter Long Tubes And Ory
- MAF For 2001 F-Body LS1...
- Wtb****tnt Power Ring****
- WTB ls6 manifold
- WTB-1.8 Harland Sharp Roller rockers
- slp 2otl muffler
- wanted: Busted LS1 block
- Brake Light for SS Spoiler
- WTT SS CME for GMMG
- WTB Harlan 2 step
- I need a stock LS1 F-body clutch master cylinder with hose.
- Dominator 2000 cfm Throttle body
- Trade Eibach prokit for Sportlines
- bell housing...
- WTB" Lowering Springs
- WTB battery tray
- Ltb: 98+ Camaro Front Clip Parts
- Solid motor mounts and poly tranny mount
- wanted : ebony leather camaro door panels
- WTB Harlan 2-step
- WTB: 10bolt with 4 channel ABS
- WTT...True Duals for ORY Setup
- need another ecm i have 2 if u need to trade
- WTB: 3 Channel 10 bolt 3:42 or higher
- WTB: Adj panhard rod
- Wtb Asap Z06 Wheels And Tires
- Looking for some parts!
- Need a converter!
- lookin for pro 5.0
- WTB: Magic Stick 3 camshaft
- TR6 plugs wanted!!
- WTB Black 98+ Trans Am bumper
- WTB: 6 speed center console
- FW: [4] WTB CD player/radio from a 95 w/ 10 spk system.
- I need a LT1 T56 clutch and fylwheel
- LT1 vortech aftercooler..
- WTB: a OEM '98-02 SS Spoiler
- WTB: Corsa/GMMG, G5X2 on 114
- WTB: 02-06 LS6 Cam/Springs/Purshrods/Retainers etc..
- WTB-'98 up Stock Camaro Grill
- WTB hood and 16" wheels and tires for TA
- WTB SLP LS6 Intake Manifold
- power stearing lines
- WTB: LS1/2 Corvette motor mount brackets
- WTT my a4 for your m6
- WTB: 6.0L Block or Shortblock, Cam, Springs
- need ls1 front and rear main covers
- WTB: Lower part of LSX 90 manifold, ASAP..
- WTB Z06 Screens
- WTB: 93-02 Camaro or Trans Am rear body clips ! INDIANA !
- clip that holds the rod to the clutch pedal
- WTB: 02 gmc 5.3 PCM.
- Wtb Gray head liner gray
- WTB: 5 pin MAF plug or 3 to 5 pin MAF adapter, Also want C5 intake
- Need some stuff
- center consol shift peice w/ ash tray...
- Need Oil Pan
- WTB: GM OEM 3.73 gears
- moser 12b gears, th400
- LT1 aluminum heads
- wanted: Wideband O2 Gauge
- WTB:42 lb Injectors and Walboro 255LPH Fuel Pump
- Wanted: ls1 f-body throttle cable
- WTB: Black z06 rims with polished lip
- 9" spool
- WTB: one 853 head
- WTB: Blackwing Intake
- LS1 knock sensor harness
- wtb: front bumper cover support 98+
- WTB: Seat belt loop
- BMR tranny mount/ torque arm relocation
- WTB: MMS crank pulley
- Wtb: O2 Sims
- WTB: 12 bolt
- *** Stock Starter Wanted ***
- WTB: Good daily driver TC
- WTB: 2000+ mani/cat flanges; LS1 F-Body Throttle Cable
- Fuel Pump Assembly For 2000ss Needed
- WTB: GM 7.5 ten bolt rear end / traction control
- WTB: Torque Thrust 2's
- Needed to Buy....SS Spoiler
- 12 bolt or 9" rear
- Procharger
- WTB-GM Navigation Head Unit non-Y91 Bose
- wtb: ws6 wheels (not 01-02) or y2k
- A Few More Parts Needed Now
- WS6 Wheels, 96-2000
- looking for lid & filter for 99 z28
- Front Bumper
- WTB : Lower rubber shifter boot. 94 z28
- Pass side front Fender firebird 98+
- wtb lt1 longtube headers coated
- WTB purge, nitrous solenoid, Halo ring, 90mm power ring
- Wtb: clutch line from master to slave/plastic shim
- WTB: hood for my 2000 Trans Am
- WTB: Ebony door panels,headliner,seat belts.
- wtb: t56, pass side glass, rear bumper
- Corsa Exhaust Tips!!
- wtb: black zr1s
- wtb: ram air hood for lt and spoiler/fender
- Wtb Headers, Y-pipe, And Stall
- Looking for wheels
- Warbird/Raptor Style hood And High rise T/A hatch for my 01 formy!
- WTB: ASP pulley & LS6 intake
- wtt: my f10 114 for your f13 112 or114
- stock z exhaust
- WTB: TT ll's
- WTB SLP Bowtie Grille
- drivers side headlight motor for 98-02 t/a
- WTB: Manual shifter boot
- !32-42# injectors, adj. LCA's, and relos!
- wanted: stock exhaust collector manifolds
- LS1 covers, ls1 starter needed
- WTB: 02+ LS6 Cam and Springs
- Need a good ls1 block,asap
- WTT: LM + Cash for magnaflow catback
- WRB:HeadlampCovers
- WTB: Stock Exhaust Manifold, Stock I-pipe 3000+ Stall TC.
- wtb: camaro headlights
- WTB : Iron Block
- WTB: LS6 Intake
- WTB ported TB, FTRA
- NEED Kooks or QTP Headers!!!
- 93-02 t-tops
- Rear brake backing plates 98-02
- WTB:3.5x15/10x15 Weld Prostars
- NEED ASAP wiring harness
- WTB: 150 shot nitrous kit, 17 inch wheels, and ram air hood.
- Need LS1 M6 Torque arm mount ASAP
- 99,00,01,02 Fuel Rail assy wanted
- Complete A4 conversion package
- Wtb:test Pipes/cat Bypass Pipes
- fog light switch
- WTB: Black Privats
- need black auto console for 99 Z28
- Need 114 Cam!
- WTB: tall valve covers
- Need some drop springs. Can anyone in Help?
- WTB: gear
- Need Asp Underdrive Pulley New Or Used
- intake,ory,n20/dual dual
- WTB: Camaro black halo headlamps
