View Full Version : Parts Wanted
  1. WTB: ls1 efan input harness wires
  2. stock front 02 sensors
  3. WTB: LS1 Pistons/Connecting Rods
  4. WTB rear brake backing plates
  5. WTB 06 z06 brakes frt and rear
  6. WTB, Stock Y pipe for LT1
  7. WTB: TB stock p/p, bbk/pro prod. etc
  8. WTB CSR LT1 Electric Waterpump Motor
  9. Wtb: Misc engine and accessory bolts for ls
  10. Wtb: Fbody alternator brackets with bolts and pulley
  11. wtb: main cap side bolts
  12. wtb: lifter tool and spring tool
  13. Wtb 93-02 camaro z28 shifter cable a4
  14. Looking for deals on a few parts. (Headers, Lid, Chris1313, MGW Shifter, etc)
  15. wtb cam in 224-226 range
  16. WTB Pontiac Monsoon TAPE Player....yes, a CASSETTE PLAYER!
  17. Wtb fast 102, for ls7
  18. LT1 blower cam ~230/242 @ .050, .585"/.600" 114 LSA-HR
  19. WTB LS1/LS2/LS7 Coils/harness for LTCC Setup
  20. WTB: Stock LS1 TB, TPS sensor, Stock injectors
  21. wtb some 295/45 r17 drag radials.
  22. park/turn signal lights
  23. 1 7/8 fbody headers
  24. WTB: Electric Cutout
  25. WTB LS1 water pump
  26. wtb a 9 inch
  27. WTB corbeau seat brackets
  28. WTB WS6 hood
  29. drivers side tail light camaro
  30. ford 9 inch/12 bolt
  31. wtb 373 gears
  32. camaro leather front seats... ebony only
  33. Drivers Side Stealth Enclosure
  34. WTB Procharger Race Bypass Valve
  35. WTB- LS7 Fuel rail covers - red or black
  36. Nitrous
  37. LS1 T56 bellhousing
  38. 99-02 ECU f-body w/ A4
  39. wtb broken ss slp grill
  40. WTB 93-96 style camaro taillight
  41. LS6 intake
  42. WTB/WTT Wheels
  43. WTB 46mm PTE wastegate
  44. WTB Zo6 exhaust for C6
  45. WTB LS1 or LS6 intake
  46. WTB: Ls6 intake for my 99 ls1 formula
  47. WTB/WTT Kooks Off Roady for Catted Y-pipe
  48. WTB exhaust manifolds
  49. Needing Interior Pieces
  50. WTB: HP Tuners
  51. Right side brake backing plate assembly needed!!!
  52. wtb throttle cable bracket
  53. Wtb oem fasteners !!!!!!!!!
  54. WTB DC Outlet
  55. WTB Yank converter
  56. WTB Lots of Parts: Paypal Ready!!
  57. WTB/WTT SS HOOD and SS WING
  58. wtb ac line
  59. WTB: Cheap dry nitrous nozzle kit
  60. LS1 OEM Fuel Rail
  61. wtb ls1 parts
  62. WTB: Long Tube Headers/Offroad Y pipe for 2000 Camaro SS
  63. T-Top for 1999 Pontiac T/A
  64. Need 3.42 4ch 10 bolt in charlotte or close!
  65. Borla XR-1
  66. WTB: Corvette or F body accessories
  67. 18x9 C5 Z06 chrome wheels
  68. Wtb adjustable master cylinder
  69. Need Bolt ONs for 04 GTO (Zex kit Long Tubes pulley)
  70. LS3 throttle body intake gasket
  71. WTB 1999-2002 ECU and Harness.
  72. WTB American Racing Headers for 02ta
  73. wanted used custom grind ls-1 2 3 7 style cams all sizes needed
  74. wtb used 427 ls7 crankshaft 4inch
  75. Dual 12 sub enclosure
  76. WTB 9inch third member
  77. WTB AR Rebel 699 Chrome plastic bolts
  78. Wtb: GMMG catback or trade for my SLP Dual Dual
  79. stall converter....
  80. coil pack harness and bolts
  81. 98-02 oem camaro ss hood
  82. Wtb fbody radiator
  83. WTB 243/799 heads 400 shipped
  84. Need a Junk (or well used) LS1 M/T Flywheel
  85. WTB: 18" rear tires for 10" rim
  86. WTB LS6 Intake
  87. WTB: OEM WS6 hood (pewter)
  88. WTB AJE Fox Body K Member
  89. WTB Strano 22mm rear sway bar
  90. 98-02 Trans Am/Firebird Parts.
  91. Need everything for rebuilding a rolling 98 z
  92. WTB: LT4 Knock Module
  93. WTB: Pacesetter ORY
  94. Boost cam for an 06 lq4
  95. Wtb. Black leather seats
  96. caddy (ls7r) lifters
  97. factory rs camaro body kit
  98. WTB: 98-02 Firebird Passenger Tail Light and Power antenna!!!
  99. WTB: cam for carb'd ls2
  100. wtb upper and lower a-arms
  101. WTB - stock TB
  102. WTB rear leather seats
  103. MGW 93-02 T56 F-Body Shifter
  104. BG Ram Air Kit
  105. WTB Patriot 7° Valve locks
  106. Kenny Brown Double Diamond SFC's for Hardtop
  107. WANTED- LS engine package with trans- LS1, 4.8, 5.3, 6.0
  108. wtb ford 9" aftermarket pinion support
  109. WTB: 60lb EV1 Long injectors ('98-02) Camaro
  110. WTB: Turbo stuff; c6 manifold(s) / truck manifolds, injectors, piping, IC, etc
  111. WTB Fast 92mm Intake, 92mm Throttle Body, 42lb Injectors
  112. Wtb ls1 block
  113. WTB 98-02 Trans Am/Firebird stock metal hood Red in color Central Florida Area only
  114. WTB 4l80e multi disk stall 3200-3600
  115. wtb 99+ t56 trans and motor harness
  116. WTB 2000 Camaro Owners Manual
  117. Rear Door seals
  118. SLP lid, corvette frc
  119. WTB: 70 camaro conversion kit and ls1 parts
  120. WTB: Strano Lowering Springs
  121. wtb valve spring compressor
  122. rocker arms
  123. WTB: 2x 5.3L motors
  124. WTB 6.0 Lq4 or Lq9 block and crank with main caps
  125. WTB: 2005-2011 C6 Exhaust Manifolds - LH or Set
  126. WTB: fast intake and TB 90/90 , 92/92, 102/102
  127. WTB t56 swap!!!
  128. WTB: LS1 intake
  129. WTB/rent/borrow/etc: Foam LS1 Mock Up Block
  130. WTB: Truck Coils
  131. WTB: 243/799 heads and Texas Speed 228R cam
  132. Wtb- prosport electric gauges
  133. WTB: Coil Harnesses
  134. WTB: 2 ls1 knock sensors
  135. wtb: GTO oil pan
  136. WTB: Fbody water pump and power steering pump with brackets
  137. WTB: LS1 O2 sensor and o2 sensor extension
  138. Forged shortblock or rotating assembly wanted
  139. WTB: Good used set of dual springs. PRC,etc..
  140. WTB Vetronix GM tech 2
  141. WTB: Burkhart master Cyl. Manual
  142. WTB lt1 adjustable master cylinder
  143. ls6 intake and tb
  144. Looking for some Z28 emblems
  145. WTB: chris1313 or Mega mouth ram air
  146. WTB 97-04 corvette DBW pedal and TAC module
  147. 275/60/15 radials+17" tires
  148. wtb wideband and hp tuners pro
  149. WTB 9 in REAR END.
  150. WTB: The Tuning School Beginners guide.
  151. Wtb ls1 power steering pump
  152. WTB stall and other performance parts
  153. WTB ARP main studs for 2001 6.0 iron block
  154. WTB- Trans Am Drivers Manual Seat Track
  155. Wtb: 92mm nitrous outlet plate kit
  156. WTB Procharger D-1SC LS1 Supercharger
  157. wtb used ls7 rocker arms n pedistals push rod
  158. WTB LS7 INTAKE with FUEL RAILS
  159. WTT Full OBX Header+ORY+LM1 for GMMG Catback
  160. WTB Lingenfelter 58x reluctor conversion harness/box.
  161. WTB: Any G8 GTO CTS-V or C6 Corvette Throttle Body!
  162. WTB: Any LS7 Alternator!
  163. WTB NGK AFX Wideband
  164. WTB 1997 gauge cluster Firebird/TA
  165. wtb lt1 t56
  166. WTT/TW PT76GTS for ST80
  167. WTB ls1 lid and magnaflow cat-back
  168. Wtb nice arctic white Berger panel
  169. WTB: hurst billet plus or pro 5.0 shifter for ls1 f-body t56
  170. Wtb crazy motor setup
  171. WTB 95-99 Steering wheel & airbag
  172. WTB: LS1 98 Camaro Alternator
  173. WTB: LS1 AC Bracket Bolts, Compressor Bolts.
  174. WTB "638" 350 block 1pc main
  175. WTB LSXr 102mm intake
  176. WTB: random interior panel/trim screws
  177. WTB F-Body LS1 RADIATOR for 6speed manual
  178. 2006 Head Studs
  179. WTB A/C Setup for F-Body
  180. WTB-Greg Banish Calibrated Success DVD
  181. wtb t56 swap parts
  182. WTB: HP tuners
  183. wtb third ford 9" case with 3.25 bearing
  184. wtb lt headers
  185. WTB: F body power steering pump
  186. WTB: F Body oil pan kit, 99-02 ECU, katech rod bolts, cable throttle body
  187. wtb camaro interior pieces
  188. Wanted....C5, Z06 aftermarket, Chrome wheels
  189. Rubber piece inside door *Pic Inside*
  190. WTB LS1 tuning software
  191. Wtb :: 90mm cable throttle body 4 bolt
  192. wtb hp tuners pro
  193. Wtb: 98-02 black and silver ss camaro badges
  194. WTB frc's, ebony interior parts
  195. WTB some LS stuff for 24x conversion
  196. Wiring harness, vette alt bracket and more.
  197. Wiring harness, vette alt bracket and more.
  198. WTB/WTT C5 Engine Harness and PCM
  199. WTB: LT1 Valvetrain / EWP
  200. Used ProCharger
  201. LT1 Needed
  202. wtb shocks and sway bar
  203. WTB: 00-02 Camaro Monsoon HU
  204. Wtb bolt in sfc's for ttop car
  205. WTB long tube headers( no ebay crap)
  206. Wtb 99-02 ls1/m6 harness uncut
  207. WTB: Head Unit
  208. WTB HPTuners PRO
  209. Nick Williams 90mm throttle body
  210. Wtb
  211. WTB: ls1 alternator bracket
  212. wtb 00-02 throttle body cam or 98-99 non tcs throttle cable GM#12565559
  213. WTB Stock WS6 wheels and tires
  214. WTB All engine sensors and coil harnesses
  215. wtb stock ls1 or oversize ls1 valves
  216. wtb 6.125 rods
  217. Stock alternator bracket.
  218. WTB - Banks exhaust for FBODY
  219. Wtb gas cable non traction control
  220. wtb 6.0 liter
  221. WTB: Borla XR-1
  222. Wtb Cheap ls1 Aftermarket Cam around 550 lift Asap!!
  223. WTB: 6.0L truck exaust Manifolds
  224. WTB 4.8l rotating assembly
  225. Trade AR15 for turbos or l76 motor
  226. WTB: Clutch Master Cylinder
  227. WTB P-Ayr Plastic Mockup LS1 block
  228. WTB: Need Power Steering Bracket for 00 T/A.
  229. WTB: 1996 LT1 alternator for Camaro
  230. wtb: LS1 parts again
  231. WTB Mufflex 4 Inch Catback With Flowmaster Muffler
  232. wtb 96mm tb
  233. WTB: LS1 Camaro Alternator / Brackets
  234. Need Y pipe
  235. Wanted: 7.450 Pushrods
  236. Wheels and Tires
  237. WTB: stock upper and lower front control arms
  238. Ecm, ecu, pcm ?
  239. wtb cam for l92's gm asa, hot cam or stock ls2,ls3 ls6 cam
  240. Borla XR-1 & Autometer Fuel Pressure
  241. Wanted: BBK intake
  242. WTB Dual Aeroforce Scan gauges with White LEDs
  243. Need LS1 600 lift valve springs
  244. Wtb: Suncoast raptor hood 98-02
  245. LS1 oil pan front accessories
  246. ls1 parts few nos parts
  247. WTB WS6 Air Box
  248. WTB ls1 or 6.0 short block
  249. WTB driveshaft for 9"
  250. WTB: Stock Monsoon Firebird Driver's Side Door Speaker
