View Full Version : Parts Wanted
  1. Lightly used set of 4 KYB AGX
  2. looking for an aftermarket oil pan, accumulator, relocation kit
  3. Nitrous switch panel and bottle
  4. PRC 5.3 Stage 2.5
  5. WTB fuel cell
  6. speaker backing
  7. WTB 01-02 WS6 Wheels/Tires
  8. WTB: Lid and Stock MAF
  9. WTB 4l80e parts
  10. WTB Injectors for 2002 LS1
  11. LQ4 with LS2 intake
  12. wtb C6 Corvette power steering pump with pulley
  13. WTB 275/40/17 tires
  14. WTB all 4 center caps for the ABS 16" chrome TA wheels
  15. Wtb: Any engine harness from any c6
  16. Wtb: Any engine harness from any c5
  17. wtb: oem ws6 exhaust tips
  18. mickey thompson et street 275 40 17
  19. wtb: A few t56 parts
  20. WTB AC compressor
  21. WTB: LS1 crankshaft
  22. wtb ls1 fuel rails stock
  23. WTB - 5.3 decent shortblock or 5.3 longblock
  24. Wtb air lid clamps
  25. 9 inch or 12 bolt
  26. WTB Mac Midlength Headers & Y-pipe
  27. Need aftermarket ECU for a 93
  28. WTB: Lid, LT's, ORY
  29. WTB: LS2 Crankshaft
  30. WTB 243's and oil pan
  31. 4150 throttle body
  32. WTB grill for ss hood 98-2002
  33. wtb Black Wheels preferably torq thrust m
  34. wtb 6.0 crankshaft fantastic shape
  35. WTB: hardened/chromoly 7.425" pushrods
  36. wtb black rims preferably torq thrust m
  37. WTB: TFS 245 6 bolt heads
  38. 98-02 T/A drivers side headlight assembly
  39. WTB Red driver side mirror for a Firebird.
  40. '98 C5 ECU for automatic
  41. 4l60e working or 4l65e
  42. Heavy Duty F-Body Rear End Assembly
  43. wtb t56 tailhousing
  44. WTB: Procharger D1SC Or F1A
  45. Bought a new set from texas speed. Please delete
  46. WTB 7.4 hardend pushrods
  47. WTB: Mac Midlenth Headers & Y-pipe
  48. WTB...PS pump bracket...
  49. WTB Timing cover & hub
  50. WTB LS3 rocker bolts. ASAP
  51. wtb 99-02 v8 harness
  52. K-member,fenders,air bags
  53. WTB: Ebony Automatic Center Console Lid
  54. WTB Stock Front Ls1 Coil Springs
  55. 98-02 f body shocks.
  56. NM: WTB LS1 (or LS2/3/6) with T56
  57. WTB Lower Shifter Boot
  58. Struts and Shifter
  59. WTB bilstien stocks and lowering springs
  60. front mount turbo kit
  61. WTB: 383 LS1 Rotating Assembly (complete or parts)
  62. WTB ls1 LT headers + Y pipe (for 2000 camaro SS
  63. WTB: LS1 pistons
  64. WTB: LS1 Cam
  65. WTB EFI live v1
  66. WTB: 17" HRE Wheels 547R
  67. lt1 thermostat housing
  68. Compressor Wanted
  69. Headlight lid door wanted
  70. WTB/WTT ARH ORY and/or 3" Cutouts for LPP true duals
  71. WTB - 1 243 or 799 head
  72. wtb stock 4l60e torque arm mount
  73. WTB LS1 or LS1 engine....
  74. WTB LT1 1 7/8 headers
  75. truck intake cover
  76. WTB: Stock LS1 Throttle body
  77. wtb throttle cable bracket and dipstick
  78. WTB 98-02 Camaro headlights any condition- BOUGHT
  79. 2 96-00 WS6 wheels wanted
  80. WTB: LS1 alt/ps brackets
  81. WTB: PCV for 2000 Z28 - From intake to valve cover
  82. 98-02 Camaro headlights
  83. fast 90 w/ tb
  84. 00+ Non TCS Throttle Cable
  85. WTB: 3"electric cutout
  86. Im lookin for a pair of polished 17x3.5 Weld RTS wheels
  87. Need few odd parts to get car rolling again
  88. Foose Spank 6 18x8
  89. WTB 5.3 ECM tuned for swap
  90. WTB - Mickey Thompsons
  91. WTB LS1/2/6 w/ T56 for custom swap
  92. WTB: RH Cat or Cat Shell from 00 - 02 Fbody
  93. wtb:ls2 timing chain cover w/sensor
  94. I need ~ charcoal sun visors visor and Shift boot frame
  95. wtb 17-18' wheels
  96. WTB- t/a mirror and ground effects.
  97. 7.4 hardened pushrods
  98. Wtb: 6l80e
  99. 04-06 GTO Fuel pump mounting flange
  100. WTB Ls2 block. ls3 heads/intake
  101. 80lb Injectors
  102. Wtb turbo hotside
  103. 243 or 799 heads
  104. WTB---Fast intake and TB
  105. ls1 throttle bracket
  106. WTB: Black American Racing Torq-Thrust M Wheels
  107. WTB: 4l80 flexplate
  108. WTB: C5 Engine Mount Pedestals
  109. wtb a lt1 shortblock.
  110. drivers side ttop piece
  111. wtb used ls3/l92 style 1 head only 823/821 casting
  112. WTB Curbed/Rashed 17x9.5 ZR1's
  113. wtb used ls3 offset rocker intake side only 8 set
  114. GTO Parts
  115. WTB 98-02 passenger headlight assembly
  116. WTB 90 mm cable driven tb
  117. WTB set of 317 heads
  118. Good/Clear Headlights
  119. strano's front and rears wanted?!!!
  120. WTB: Trans Am Ebony Drivers side Dash Vent.
  121. WTB: 1 good 243 head
  122. WTB Air Lid and Bellow
  123. WTB G5x3
  124. wtb lid, gears, ram air, maf, spoiler
  125. WTB 275/40/18 or 275/35/18 tires
  126. Wtb: 98 ls1 pcm
  127. WTB two 275 40 17 drag radial
  128. WTT My 418 LS3 for Stock LS3
  129. WTB: Monterey Maroon Metalic both quarter panels
  130. WTB drag wheels for Fbody
  131. wtb lq4 shortblock
  132. wtb oem 98 camaro grille
  133. WTB - TBSS Intake
  134. Mighty Mouse Spacers for a 05 CTS-V
  135. WTB, LS starter, 58x cranks sensor and LS dipstick/tune
  136. WTB stock LS1 intake and T/B
  137. WTB 93-96 Camaro Tail Lights
  138. Wtb 5.3 or 6.0 truck motor
  139. WTB, Adjustable Ta, TA relocation for m6, and MGW shifter
  140. wtb1: 2.5 electric cutout
  141. Tires wanted! 275/40/17
  142. LT1 shortblock
  143. Valve Covers
  144. WTB-ASAP! Ls1 coil packs
  145. trade pro stars for street setup c5dd,
  146. wtb lq9 short or long block
  147. Sell me a high pressure AC line!!!!
  148. WTB: 6.0L Block, north east
  149. WTB - little round "grill" in A pillar
  150. WTB: FAST Xfi
  151. wtb stock fuel rail and ls1 intake and t.b. Needing a 00 to 02 camaro harness engine
  152. wtb slp grille cam springs and ta fender
  153. Need LS1 and transam parts
  154. WTB 44lb+ injector set of 8
  155. WTB 1998 LS1 Engine harness
  156. WTB Z06 cam
  157. WTB - Radio Bezel for a 99 Camaro
  158. WTB hot side kit
  159. wtb used comp cam 570 to 600 liftcam send me your prices
  160. WTB: TV cable for 93 Camaro 4L60
  161. anyone have an lt1 t56 full swap?
  162. WTB 60# Injectors flow matched - LS2
  163. WTB two 275 40 17 tires!!!! asap!!!!
  164. WTB: Triple A pillar pod-HARDTOP
  165. WTB HPTuners
  166. WTB 295 & 275 35 18 tires
  167. WTB SFCs.
  168. WTB: LS1 power steer return line, 1 LS1 coil, PCV set up
  169. Wtb built ls1 or ls3 shortblock
  170. WTB Forged Rods
  171. WTB..hooker y-pipe
  172. WTB: 1 Chrome/Non Chrome 10 Spoke SS Wheel
  173. Multipe Parts Needed
  174. wtb 98-02 pass taillight
  175. WTB Monsoon speaker
  176. ecu 12586243
  177. Wtb ssra
  178. LTB borla adjustable plate...
  179. WTB LS1 block (Broken, damaged, otherwise unusable)
  180. WTB PTE7675 turbo
  181. WTB Patriot Gold Extreme Valve Springs
  182. Non-EGR Truck Manifolds Wanted
  183. WTB GTO oil pan + 5.3 exhaust manifolds
  184. Want To buy 9in ford rear end
  185. WTB 4l60e (not a stock one)
  186. WTB 10 bolt rear (prefer near MA)
  187. sell me your skinny's
  188. Convertible switch bezel w/ TCS
  189. WTB: LS1 F Body Accessories
  190. Wanted SS Grille insert.
  191. wtb 3rd gen ls swap mounts and ls3 carb intake
  192. WTB : Cam in 220+ duration area
  193. Trans Am Front BUMPER 93-97 wanted in good condition.
  194. WTB- FTP Lid, 98 mm or 104mm
  195. WTB-ORY for Kooks LTs, F-body
  196. WTB fuse boxes+wiring, TPS and IAC throttle body sensors
  197. Wtb alternator bracket
  198. WTB: FRC's for LS1
  199. WTB or WTT 04 gto pan for F body pan
  200. WTB Intake
  201. WTB non Tc throttle cable
  202. wtb 04 Z06 maf
  203. WTB LS1 crank
  204. WTB: Front wheel hub, Trans am filler panel
  205. WTB ls6 intake
  206. WTB ls6 valley cover
  207. 102mm cable tb wanted
  208. WTT: My LS1 for your LQ4 (longblock)
  209. Wtb: Oem or Reps 18" Svt Cobra Rims
  210. wtb: 347 block 3.903 or 3.905
  211. WTB 02+ LS6 Cam
  212. WTB Fast intake
  213. WTB: 4L60E shift linkage
  214. f-body dipstick and tube for a ls1
  215. Wtb gto oil pan
  216. WTB; Firehawk Ebony Floormats
  217. Wtb ls1 parts
  218. WTB Hood release cable complete.
  219. WTB Ls1 4l60e Dipstick
  220. WTB: T56 near Phoenix
  221. Fbody oil pan
  222. WTB: 93-96 Dash top panel
  223. Wtb 98-02 OEM Camaro front grill
  224. Wtb-lt1 ss hood!
  225. WTB Camaro driver headlight (housing)
  226. wtb nitrous
  227. TRADE - 95 lt1 M6 harness for 95 Auto harness
  228. WTB: lsx block main caps
  229. 98 LS1 coils
  230. WTB Ebony sun visors
  231. WTB driver side front fender 2000 WS6
  232. WTB Ebony Door Panels 2000 ws6
  233. p600b procharger
  234. Wtb. Ls3 intake and fuel rail
  235. Wtb. Methanol kit
  236. WTB: upper console POCKET off a non TCS car
  237. WTB:Cruise control cable for non TCS car
  238. wtb 9inch fors nodular case and gears.
  239. wtb 80 or 83lb ls1 style injectors
  240. LS1 piston... found Thanks
  241. WTB FAST Intake
  242. WTB: Cadillac CTS-V engine parts (supercharged 6.2L LSA)
  243. Wtb shocks and springs
  244. WTB: Complete LS2 Intake and Corvette accessory drive setp
  245. WTB: 1 275/40 r17 M/T DR
  246. WS6 wheels for new style ZR1 wheels
  247. WTB: TSP ORY for 02 Camaro
  248. WTB 1998 Computer
  249. WTB gto sway bars
  250. WTB: G80/GU6 Option code 3.42 10 bolt rear for 2000 Trans Am
