View Full Version : Parts Wanted
  1. WTB: 3-Series Torsen carrier for 10 bolt
  2. WTB - FBody Alternator & Brackets
  3. WTB Greg Banish Tuning DVD
  4. wtb harness
  5. slp fan switch wanted
  6. K&N FIPK Trade.
  7. WTB Longblock/4L60E. LS1/2/X Stock or modded. Let me know what you got!
  8. WTB LS6 Intake Manifold, 325 shipped
  9. WTB: Stock Round Leather Camaro Shift Knob/Shifter 1982-1996, Late Model Preferred c
  10. WTB 3 series carrier or 2 series 3.23+ gears
  11. WTB LT1 T56 Crossmember
  12. WTB 97 lt1 gauge cluster
  13. LS Parts Needed
  14. WTB prc 5.3 ls6 or 215cc heads
  15. WTB aftermarket lid or cai for ls1
  16. WTB Ebony console lid
  17. wtb TB
  18. WTB- O2 sensors
  19. WTB Head/Cam package!
  20. WTB: 2.5" inlet Corsa or similar style exhaust tips, 3.5" outlet or bigger
  21. WTB-SD Parts Clutch Pivot Ball Bracket
  22. WTB: MGW short shifter for an fbody
  23. wtb 317 heads
  24. WTB: O2 Simulators
  25. WTB FAST 90mm intake manifold
  26. ***wtb::: 100mm MAF
  27. WTB/WTT draglites/prostars/stock ws6 rims
  28. WTB Drivers seat seatbelt track (trans am)
  29. WTB Hp tuners software and cable!!!!
  30. Wtb:bra
  31. WTB aftermarket lid for '98 z28
  32. WTB shortblock LQ9 408 ?
  33. wtb ebony kick panels
  34. wtb upper 6 speed console
  35. WTB 6.0 Iron Block/Shortblock (New or Used)
  36. backing plates
  37. WTB LS3 heads and intake
  38. Borla catback
  39. WTB HP Tuners Pro and Calibrate Success DVD
  40. WTB: 10" sub box
  41. wtb :: CORSA muffler/catback - 02 formula
  42. wtb 8.5 rear carrier for 99 z71
  43. LS6 Intake
  44. WTB automatic upper console / floor mats / front struts / rear isolators
  45. WTB Katech Connecting Rod Bolts
  46. Traction control bezel
  47. Black Chrome ZR1's anyone have any?
  48. WTB your cracked/broken air lid
  49. wtb mahle forged pistons for stock bore ls1
  50. WTB Ported heads
  51. 243 heads.
  52. 2002 TA 3rd brake light
  53. LS6 Intake and 4:10 series 3
  54. LS1 intake
  55. Wanted some parts..
  56. Wtb ls1 pistons and rings
  57. WTB LT1 Cold air intake CAI
  58. LS1 AC CompressorL
  59. WTB: Borla Adjustable Exhuast Plates
  60. WTB: Auto Wiring Harness/PS pump backet
  61. LT1 Valve Train parts
  62. wtb/wtt for 243's
  63. WTB drivers side headlight assembly
  64. WTB: Long Tube Headers
  65. wtb console lid, ss hood insert, and grill for 98 ss
  66. wtb ebcm from 98 ss
  67. LS1 radiator
  68. WTB.. looking for T-TOP DRIVER SIDE
  69. ls1 starter
  70. Left Front Fender And hood needed for 02 camaro
  71. 2010 LS3 Camaro Exhaust Manifolds
  72. wtb intake
  73. WTB: LS1 T56 Input Shaft and Front Plate
  74. WTB: LS6 intake, rails, tbody etc.
  75. wtb front runners
  76. Wtb borla or 2OTL for 97
  77. WTB: Lingenfelter 58x to 24x reluctor converter module
  78. WTB fbody ls1 dipstick tube and dipstick
  79. WTB 2002 Camaro Center console lid black
  80. WTT Brand New Michelin Pilots 275-40-17/285-40-17
  81. wtb: corvette front acc's 02- up
  82. WTB: LS1 Powersteering Reservoir
  83. wtb: 98-02 camaro headlight lenses
  84. motor mounts
  85. WTB Pacesetter longtubes for LT1
  86. Clutch, brake pedal wiring harness for switches
  87. wtb 2 275/40/17 and 2 315/35/17
  88. wtb wot/window switch
  89. WTB: MTI air lid
  90. WTB: abs module for 99 or newer
  91. wtb corsa
  92. wtb intake
  93. slp ss grill,lcas,lcarb,injectors 30 or 42lb,slp bellow
  94. null
  95. WTB:98-02 firebird ash tray
  96. Wtb:big tube headers for 02 camaro
  97. WTB: Throttle Cable Bracket from a truck
  98. WTB 98-02 camaro parts
  99. WTB - LT1 o2 extension - flat 4 pin
  100. WTB A/C condensor, Stock pulley system, Water pump!
  101. wtb 20-24 foot enclosed trailer.
  102. A Pillar trim
  103. WANT ls1/ls6 Longblock! In CA or can ship!
  104. wtb:: 100mm MAF & 92mm TB
  105. WTB ls1 f~body pick up tube and w~tray
  106. wtb: msd 7531 box w/ harness
  107. LS1 Rear Brake LH backing plate
  108. WTB: ls6 coolant crossover
  109. WTB 7.450 pushrods
  110. WTB 275/40/17 MT DR's
  111. wtb: LS6 intake
  112. WTB LT1 Catted Y pipe
  113. WTB: Drivers Headlight assembly for 00 TA
  114. wtb Engine 99 and up wiring harness, 2 long Engine bolts that go thru the clamshells
  115. WTB fast 92 intake
  116. WTB 12 bolt or 9''
  117. 806 heads valve covers
  118. wtt 04 gto pan or 06 ls2 corvette pan for f body ls1 pan
  119. WTB Suspension, Exhaust, Converter
  120. Wtb: 93-97 trans am fender
  121. BMR Xtreme Duty Sway Bar
  122. wtb. sct tuner
  123. WTB GM 845 or CRANE 227 cam
  124. D-1SC Standard Rotation - Procharger head unit only
  125. WTB: COMPLETE supercharger or turbo kit
  126. WTB lt1 ac compressor
  127. Pistons 3.903"
  128. Wtb mti x-1 cam
  129. WTB: G6X3 cam
  130. WTB: 98-02 Navy Blue Metallic Driver's Side Power Mirror Assembly
  131. Used 04+ head bolt set
  132. WTB 98/02 Transam Taillight Passenger side
  133. WTB-ls1 shortblock
  134. WTB: LS2/3 driver's side valve cover.
  135. WTB LQ9 piston
  136. WANTED! LS1 Fans
  137. Wanted: Set of standard height valve covers without coil studs
  138. WTB: HP Tuner Cable
  139. WTB: electric FP, OP and h20 temp gauges
  140. wtb: 92mm Throttle Body
  141. WTB: PA/NJ - FAST 102 ls7 intake, tb, coils, wires.
  142. in need of c6 parts
  143. LT1 Parts Needed
  144. wtb. abs block 2000 4 channel trans am
  145. 98-02 t56 lower shifter boot
  146. wtb c6/gto stock headers
  147. WTB unusable ls block and rods
  148. WTB: 93-02 Trans Am Side Skirts/Front Bumper Parking Lights
  149. 98-02 camaro/firebird rear brake backing plates
  150. WTB - Ported LS2 TB!
  151. ls6 intake
  152. WTB LS6 Intake
  153. WTB Traction control and fog lamp switch for 98-02 camaro
  154. hood struts and brackets
  155. WTB C5 alternator
  156. 5.7 Vortec Heads
  157. WTB:99 stock y-pipe,with cats and stock torque arm
  158. WTB: T-rex, prc duals, long tubes, for 00 camaro
  159. WTB A/C Line
  160. wtb: lm7,lq4,lq9 parts
  161. 3 channel brake lines
  162. 3.20" 8 Rib Procharger Pulley
  163. TA needs restored plus extra's HP FTW
  164. WTB: Ebony Dash - Firebird Trans Am
  165. WTB: Headlight harness from body to motor
  166. WTB: Stock/Factory LS3/L92 Pistons
  167. WTB stock LS1 crank and rods
  168. wtb t56 countershaft and input shaft
  169. WTB all bolt ons for a stock 01 T/A
  170. Wtb: Gears
  171. WTB Magnaflow Tips
  172. WTB: afr/prc/tea heads, fast manifold, larger tb
  173. 3 channel 3.23/3.42 rear end near MD
  174. WTB stock ls1 throttle body
  175. wanted slp ss grill,short throw shifter,suspension parts
  176. WTB: Any 04-06 GTO MANUAL SHIFTER!
  177. WTB ARP head bolts, '04-newer
  178. WTB Aftermarket Lid
  179. Need one window felt guide from a 98-02 F-body.
  180. WTB: Fuel Injector retaining clips for electrical connector
  181. WTB 98mm lid, trunion rockers
  182. Camaro z28 front fender 98-02
  183. WTB: Newer GTO oil pan..
  184. WTB wideband
  185. wtb 4l60e for a ls1
  186. Want to buy oxygen sensors
  187. Want to buy Mass Air Flow
  188. WTB T/A Performance Rear Differential Cover for 10 bolt
  189. Need a trans am or camaro ls1 harmonic balancer
  190. Looking for a stock 4l70e
  191. WTB: 4th gen discontinued trim pieces #10410095, 10410094
  192. Need tires
  193. WTB N2O Parts!!!!
  194. ams 1000
  195. 7.350" LSX pushrods and lifter trays
  196. WTB: LH Door Mirror (Black) & SLP Smooth Bellow
  197. 01+ lq4
  198. Lookin for 12bolt, 9", S60, 8.8. Any upgraded rear. Or center sections/housings
  199. Wtb: Front filler panel
  200. WTB: 8rib Procharger Pulleys
  201. wtb: lookin for some parts for heads and cam swap
  202. wtb: plate cover 98-02 TA
  203. WTB: LS1 Coils & Brackets
  204. WTB Bose door speakers!
  205. wtb misc ls6 conversion parts
  206. my friend wants a cam too!
  207. LS 4.00" Stroke Crankshaft & 6.125 Rods with ARP 2000 Bolts
  208. WTB cam package... 228r..
  209. WTB Ram air
  210. looking for a 3.8 egr valve
  211. procharger race valve
  212. Wtb
  213. Looking for stock spare tires
  214. WTB F-BODY alternator mount and Water pump
  215. WTB guages and ZO6 items look inside
  216. WTB intake stock ls1 fuel injectors, fuel rail, stock ls1 intake
  217. Wtb/wtt eibach springs. Wtb winter tires
  218. WTB: LS6, Victor jr. EFI or Pro-flo XT intake
  219. LS1 alternator! GOOD ONE!
  220. WTB: Front RS ground effects 98 Z28
  221. 99-03 Silverado oil cooler lines
  222. 96-97 lt1 auto harness needed
  223. WTB 4L60E shifter cable bracket
  224. wtb torquer v2 cam
  225. L-92 Intake(carb type)
  226. wtb ls2 timing cover/cam sensor
  227. Anyone have a new clutch they decided not to use?
  228. wtb some heads for boost
  229. Need stock and aftermarket parts!
  230. 243 Heads
  231. WTB (or trade for) '05 Truck TAC module and pedal and other stuff..
  232. Camaro Power window switches (driver and pass) Wanted
  233. wtb: LT1 Polished radiator shroud
  234. WTB T56 Trans
  235. WTB LS1 crank pulley/harmonic balancer and bolt
  236. two front ground effect pieces-camaro
  237. Wtb: Msd 2 step #8733
  238. WTB: need roll bar for fbody
  239. Roller rockers
  240. WTB Ls6 Intake Manifold and Ported TB
  241. WTB 4L80E parts & bellhousing bolts, Stall convertor
  242. Looking for wheels to clear the brakes on a LS1..
  243. wanted stock lower control arms
  244. WTB ls1 short or long block
  245. WTB electric fans 98-02 F body
  246. wtb ls1 powersteering pump w/ lines, stock fuel injetors
  247. WTB ignition coils
  248. WTB: Stock rear Decarbon dust boot covers - WILL PAY WELL
  249. Wanted: Precision 76gts Turbo. Please ASAP!!
  250. I need a LS1 alternator bracket.
