View Full Version : Parts Wanted
  1. WTB GT2-3 cam
  2. WTB: LS6 Intake Manifold
  3. wtb coils,weather stripping,etc
  4. WTB: 36lb injectors...
  5. Corvette ls2 fuel rail covers
  6. WTB: LS1 or 5.3 parts
  7. WTB: Stand alone nitrous fuel cell F-Body
  8. LS1 main studs
  9. wtb 99+ pcm holder
  10. WTB BMR upper and lower A-arms
  11. Stock MAF
  12. Aftermarket Lid / Bellow
  13. Wtb: tsp torquer v2 or v3 cam
  14. WTB: passenger front Fender- Silver
  15. WTB: 98-02 LS1 Fbody Heater Hoses, other stuff
  16. WTB: misc lsx parts
  17. WTB L92 VVT Timing Chain Cover
  18. Hurst or similar shifter wanted
  19. WTB: 98-02 F Body P/S Pulley
  20. Need exhaust hangers
  21. WTB: 98-02 Firebird Parts / tt2's / hood *UPDATED*
  22. WTB: Top Dash piece(crash pad)
  23. wtb a good working opti for a 93 drive
  24. WTB - Wheels & Exhaust
  25. wtb Fbody Ls1 Pcm Bracket
  26. arh y pipe
  27. I need the power steering bracket on drivers side head
  28. wtb: LS1 steering shaft
  29. Need a short or long -6 nitrous line for testing
  30. WTB 6 speed harness
  31. Wtb:lingenfelter 2 step w/timing retard
  32. WTB: 4L60E Automatic Trans for 1996 Z28
  33. WTB: G8 Vlom tray or valley tray with dod
  34. Hhhheeeelllp!
  35. Need ASAP!!!
  36. WTB: front QA1's
  37. Wtb head studs or bolts and head gaskets
  38. looking for a 503 or a lt4 hotcam
  39. WTB engine covers
  40. WTB 2-3" bullets or single chamber flows
  41. WTB Z06 or truck MAF
  42. WTB ZO6 243 LS6 heads
  43. SLP FRONT Bilstein'S
  44. WTB: 255/50/16 Drag Radials
  45. Need a 98 Camaro rim
  46. LS1 ac tensioner
  47. WTB: Fbody clamshell motor mounts
  48. want truck engine harness
  49. interested in a drivers side quarter
  50. Door Switch Bezel for 97 Z28
  51. WTB: Ram Air Sticker
  52. WTB: Low Coolant Sensor, Salad Shooter Centercaps
  53. WTB. tsp xpipe
  54. Looking for 799/243 heads
  55. wtb lt1 Ho2
  56. LT1 WS6 hood, 3.90 gears for ten bolt
  57. 98-02 Seat belt guides.
  58. Wanted: 2 front Bogart Bolted Rt's. May trade
  59. WTT: Oil Pans
  60. WTB 383-ls6 stroker kit.
  61. wtb oil pressure sending unit for ls1
  62. LS6 Intake
  63. Wtb svo green top 42#inj flow matched & zo6 ls6 hollow steam valves
  64. WTB: Tubular Lower A-Arms
  65. WTB 05-06 GTO UD Pulley
  66. Wtb stock left tail
  67. Looking for subframe connectors Prefer Edelbrock Weld in
  68. WTB: boost ready shortblock/longblock
  69. WTB Sponsors, Im looking for Cometic head gaskets
  70. WTB: coil pack bracket
  71. 9inch drive shaft wanted
  72. 98-02 Firebird/Formula Front Bumper
  73. WTB: Complete Corsa exhaust system(LS-1 Camaro).
  74. WTB 17" drag radials
  75. WTB 98-02 Camaro SS Hood OEM
  76. Looking for a stall
  77. Wtb: Any oem ls7 intake!
  78. LT1 turbo hot side, boost guage etc.
  79. WTB: 42# injectors.
  80. WTB: 1 rear Koni SA
  81. WTB truck coil packs-brackets, harness
  82. WTB 60lb Injectors for LS1
  83. Looking for an 80-88mm turbo
  84. Wtb: Lid (any condition)
  85. WTB unused 305 or 315 tires for 17" rim
  86. WTB Torq Thrust M's (black)(17x9 & 17x10.5)
  87. WTB: ls6 lightweight valves
  88. Wtb ls1 inake, oil pan. 36 to 42lb injectors
  89. WTB: 93-97 Camaro Front Bumper Cover
  90. WTB: NBM T/A drivers side mirror
  91. looking for aem wideband
  92. WTB AFR 225 heads
  93. WTB Turbo Items
  94. WTB: 2.5" electric cutouts
  95. LT1 Longblock
  96. Wtb ss wheels chicago
  97. OEM silver ram air decals
  98. WTB : Motor mount stands for LS1
  99. 150mph 98-02 Camaro Guage cluster.. Lower miles Under 70k
  100. WTB longblock or shortblock and some heads, pittsburgh, pa area or 200 mile radius
  101. WTB: LS1 Parts
  102. WTB wide band O2 sensor an gauge
  103. LS1 wanted!
  104. WTB LS2 balancer!!! GOT IT
  105. pi or circle d stall wanted
  106. rear brakes any shape!
  107. Wtb: Any ls7 balancer ! Can pay today
  108. WTB Your Artic White TA side moldings!
  109. **** WTB: LS1 Motor & T56 Trans for BMW Swap ***
  110. Looking for ls2,ls3 block also heads
  111. wtb 98 fbody pcm
  112. 3 to 5 Wire MAF Adaptor
  113. WANTED- WTB- Alternator Bracket- LS1 LS2 Camaro Firebird GTO
  114. bmr radiator cover/pm harness/air dam
  115. wanted / ls1 /4l60e stall converter /3000 to 3800
  116. WTB: climate control switches for '98 TA
  117. wanted ls1/ style injectors
  118. pro charger
  119. wtb: 4l60e auto harness or pigtails
  120. WTB: Kooks 1 7/8" headers for GTO
  121. WTB Nitrous Blow Down Tube
  122. wtb - 4 channel backing plates
  123. WTB: Aftermarket Kmember
  124. WTB: MTX Thunderform pre-amplified stealth box
  125. WTB:New Pushrods
  126. WTB LS1 Oil Dipstick assembly
  127. wanted SLP dual dual over axle pipe
  128. WTB: Trailblazer SS Manifolds
  129. WTB WS6 Badge!
  130. WTB electric cutout
  131. wtb a few small items
  132. WTB Triangle Piece behind Window LOOK PICTURE
  133. WTB stock springs for camaro ss
  134. WTB Camaro 97-02 Ebony Center Console LID
  135. WTB: SLP Loudmouth Catbck
  136. rear end
  137. Paying top $ for converters
  138. WTB: 15x8/10 wheel (racestars, prostars ect.)
  139. wtb: 98-02 trans am front turn signal covers CLEAR
  140. WTB: Built F.I. motor (347, 370, 402, etc) ASAP CASH IN HAND!
  141. WTB: Built F.I. motor (347, 370, 402, etc) ASAP CASH IN HAND!
  142. WTB fast 78 intake manifold!
  143. WTB: C5 Corvette Headers
  144. roll cage
  145. WTB Driver's ebony floormat
  146. Need!! 3.42 3 channel 10 bolt!
  147. Wtb complete line lock kit
  148. WTB White Camaro Door for 4th gen
  149. WTB: 26in drag radial/slick to fit 15x8 weld wheel
  150. center bolt valve covers with coil racks
  151. 2001 camaro glove box BRAND NEW!!!
  152. Wiper cowl
  153. 98 pcm
  154. WTB: NBM Body Parts
  155. WTB: LS1 T56 Input Shaft and Front Plate
  156. WTB 93-02 Firebird /Camaro Convertible Tonneau cover
  157. wtb fbody Ashtray and m6 shifter boot
  158. WTB 3:90 gears
  159. wtb ls1 harmonic pulley
  160. WTB: 98-up LS1 T/A Tubular K-Member
  161. WTB: stainless y-pipe
  162. WTB: TFS heads/YT rocker arms
  163. wtb 3000-3200 stall
  164. wtb light socket
  165. WTB: Valve Stem Seals & Roller Rockers
  166. window sweep
  167. WTB: NX Shark Nitrous Nozzle
  168. WTB: f-body upper a-arm mounting brackets
  169. powerglide /th350 crossmember 93 camaro
  170. WTB O2 sim
  171. Wtb cam
  172. WTB: camaro leather seats
  173. Lsx license plates
  174. WTB: wire harness for 01 z28
  175. firebird/ta 93-97 shift knob
  176. WTB: Panhard bar relocation
  177. ls6 valves
  178. Wanted:Chrome T/A or WS6 Wheels
  179. Wanted: Ls1 alternator bracket w/ pulley
  180. WTB: built 4l60e for under $1000
  181. WTB Fuel Injector
  182. WTB T56 for LS1
  183. Aftermarket LT1 cam/valve springs
  184. WTB: Drag radials!!
  185. Wtb et streets/slicks
  186. WTB Cheap wheels an Tires
  187. WTB: 96-97 Embossed nose firebird emblem
  188. WTB: F-body alternator bracket
  189. WTB stock crank
  190. 25% pulley for camaro
  191. WTB: nitrous blow down tube KIT!
  192. WTB this front shock part
  193. Looking for bare l92 heads
  194. WTB 6010 msd
  195. Wtb: ls3 thermostat housing, ls6 coolant crossover
  196. WTB 4" cutout
  197. WTB Pusher Fans
  198. WTB: 102mm cable driven TB. LS3 Valley cover
  199. Wtb fast intake!
  200. WTB: Lowering Springs
  201. WTB: Stock 10 bolt rear differential cover bolts
  202. Looking for some stock LT1 parts....
  203. WTB. LQ4 or LQ9 short, long, bare, no damage
  204. WTB: 15x10 Prostars
  205. WTB: F1 Procharger
  206. wtb 1 15x10 7.5 bs pro star
  207. hp tuner
  208. c6 and truck manifolds
  209. WTB: rear O2 pigtail (harness side)
  210. Wtb dual valve springs for ls engine
  211. WTB: rear end
  212. WTB: 42lb injectors
  213. WTB: tsp true duals
  214. WTB: ls1 42lb injectors
  215. WTB some LS stuff
  216. wanted: FTI 3800 stall for th400
  217. WTB: Yella Terra 1.7 Roller rockers & Ported TB
  218. WTB complete gasket set & bearings for LS1
  219. WTT: My built th350 setup For T56 setup
  220. LT4 Springs
  221. WTB: Melling 10296, Cloyes IRL or Katech C5, Bosch 044, Aeromotive 10 micron inline
  222. WTB 1969 chevelle disc brake kit conversion kit /ls1 headers
  223. WTB fast 78 or 90 intake
  224. WTB ls1 header setup...
  225. WTB-Corvette Harmonic Balancer
  226. ls6 cam
  227. WTB: Styrofoam Wedge that sits behind front fascia.
  228. Looking for braided line
  229. wtb scoggin dickin ls3 cable bracket
  230. Wanted stock intake duct
  231. WTB 6.125 Rods
  232. WTB: Ebony Console Lid
  233. WTB- NEW Exahaust manifold gaskets and BOLTS!
  234. Looking for a DM performance main girdle and the required arp main studs
  235. WTb C5 rear end!!
  236. steel f-body ls1 exhaust manifolds
  237. NEED LS1 oil pan ASAP!!
  238. 98-02 Rear backing plates and Park Brake
  239. Looking for headers LT1 fbody
  240. WTB: 98-02 Firebird Taillights
  241. WTB: 243/799 Heads
  242. Fikse Wheels
  243. WTB Ls motor set up
  244. WTB Ls6 intake, Ls1 Windage Tray, F-Body Oil Pan!
  245. wtb ls9 or l92 head gasket
  246. WTB: shift cable bracket for 4l60
  247. Wtb: Pacesetter lt's and gaskets
  248. wtb 90/92mm lid,maf,bellow
  249. wtb lq4 or lq9
  250. WTB: LS1 Motor Mounts
