View Full Version : Parts Wanted
  1. WTB: LS1 Intake Base, and SLP Lid or equivalent!
  2. LS-6 intake needed!!!
  3. Wtb leather shift knob
  4. FAST Intake ls6
  5. WTB FTP lid, SLP MAF, 30+lbs injectors
  6. WTB: D/S f body exhaust manifold flange
  7. wtb sfi flexplate
  8. WTB: Leather Seats F/R
  9. WTB: c5/c6 power steering pump/pulley and alt
  10. WTB black ws6 hood 98+
  11. need 6.0 or ls2 head gasket
  12. WTB: PRC stage 2.5 LS6 heads and LS6 intake
  13. WTB LS6 Intake
  14. WTB: fbody power steering pump
  15. WTB piece of wire that runs to O2 sensors and connector
  16. WTB: 93 Trans Am Drivers Side Headlight Motor
  17. list of varioud parts needed..
  18. WTB LS1 6 speed alternator bracket,starter,water pump,crank pulley
  19. 98-02 Passenger side headlight motor.
  20. WTB: Nitrous Parts &/Or Plate Kits!
  21. Camaro SS Wheel (New or Used)
  22. WTB: Shortblock
  23. 98-02 Fbody oil pan and pickup
  24. WTB LT1 T56 Clutch Master/Slave linkage
  25. WTB: Firebird Speaker Cover
  26. WTB: 94-97 T56 VSS and pigtail connector.
  27. WTB: A4 Center Console
  28. WTB: F-BODY Lower Air Box
  29. wtb drivers side seat belt buckle
  30. wtb SFI flexplate
  31. WTB: Strut tower brace for LT1
  32. WTB: LS1 Shorty Headers
  33. LS T56 Input shaft
  34. WTB: 228r or silmilar cam
  35. WTB: Edelbrock Victor race long tube headers and a lot of other Misc parts
  36. WTB: Pewter camaro driver fender and front bumper
  37. WTB 1LE a/c delete bracket/pulley
  38. Wtb:cam springs pushrods and 6.0 headgaskets
  39. Autometer Sending Units
  40. Wtb: Ms4
  41. Want to buy black headliner and sun visors
  42. WTB twin 38mm wastegates
  43. Various Trans Am Parts Needed
  44. 2000 WS-6 Doors
  45. GTO oil pan
  46. Wtb
  47. aftermarket lockup stall
  48. Wanted: stock bird or zr1 wheels with good street tires
  49. wanted list, please look
  50. WTB: 42lb injectors
  51. WTB: Set of drag radials and wheels that will fit a 2006 GTO
  52. 10 spoke SS wheels
  53. wtb - 2 series 3.73s
  54. WTB: 243 LS6 Heads with Sodium Valves
  55. WTB Sun Visors
  56. Wanted: Drag wheel setup.
  57. WTB! driver side headlight assembely/trans am front bumper
  58. WTB Driver's side front brake hard line
  59. WTT: Red Z06 covers for your black covers!
  60. WTB L92 Truck intake fuel rails ASAP!
  61. WTB: ashtray lid, and seatbelt holder on headrest.
  62. Wtb: slp or similar air lid for 01 z28
  63. WTB EFI Live V2
  64. WTB LS1 T56 Bellhousing and mid plate
  65. wtb few lt1 parts for my sons car....94-95 pcm and accessory bracket
  66. WTB quality LS1 Stall converter yank,vig circle D 3,000 to 4,000
  67. WTB T56 for LS1
  68. WTB-FMS/SVO 42lb injectors - Green Tops
  69. Wtb a bmr tcc021
  70. WTB: Artic White TA filler plate
  71. WTB....Used LT1 Lt Headers...
  72. wtb lt1 headers and performance parts
  73. Wanted cats
  74. WTB LS2 Thermostat And Housing And LS1 egr Plug (Blockoff)
  75. WTB ARP rod bolts
  76. ls6 intake manifold
  77. Wanted- Accessory Drive Parts for LS1- F-body Style
  78. Wtb 4.3 vortec engine--2003 s10 compatible
  79. WTB Truck/c6 manifold.
  80. Wtb slp dual dual
  81. wtb sphon adj torque arm for longtubes
  82. wanted slp lanyard!
  83. LT1 M6 console insert.
  84. Ls2 block, looking for bare.
  85. LS1 Victor jr carb manifold
  86. WTB: Tan Camaro Front Seat
  87. WTB: Lt1 Crank, Stock Size forged
  88. nitto 555extreme 275 40 17
  89. WTB: big cam, 36-42lb injectors, fuel pump setup for '98, oil pump
  90. WTB intake coupler bellow LS1
  91. LT1 parts needed. Stall, CC306, ls2 coils.
  92. Real SS spoiler wanted white preferred
  93. WTB: UMI Suspension (anything)
  94. WTB Corbeau Seats for F body
  95. WTB Hot cam, LS6 springs, pushrods
  96. WTB Dedicated Fuel system for C5
  97. wtb ss hood
  98. WTB rails, lines and FPR
  99. WANTED yank ss3200 or ss3600 ....... also eps 22/226 cam
  100. wanted slp lid and bellow!
  101. WTB: Front Lowering Springs BMR, Strano,or Hotchkis
  102. wtb: bolt in subframe connectors
  103. wtb transmission shifter cable
  104. Tfs 220
  105. Wanted: 98-02 front brakes
  106. WTB: lt1 blower cam
  107. WTB LS2+ coil packs+mounting brackets
  108. WTB FAST intake + TB
  109. Stuff for the LT1 build and 98-02 Trans AM front clip parts
  110. 00-02 slp lid and bellow
  111. wtb stock alternator bracket for ls1 fbody
  112. WTB: Black passenger Mirror-2000 Trans Am
  113. ls1 intake
  114. WTB: 98-02 Trans Am 4" slopped ram air hood
  115. WTB: F-Body Ebony 6spd, Center Console
  116. Wanted: Junk LS1 or LS6 block
  117. F-body oil pan
  118. WTB: Stock LS2/LS3 TB
  119. LS1 intake bolts
  120. WTB: F-body Centerbolt Coil Pack Brackets
  121. 3 sereis posi unit
  122. WTB: C5 or C6 pedestals
  123. WTB: 243 heads
  124. WTB 3" Powerstick
  125. WTB Truck alternator/ps bracket
  126. WTB Power Steering Pump/Door handle bezels/Ashtray Cover
  127. WTB: Ebony center console lid
  128. wtb: ls motor
  129. wtb: One Rear O2 Sensor
  130. WTB Black Leather Seats
  131. WTB: 98-02 Trans Am 4" slopped ram air hood
  132. WTB Red 98-02 firebird license plate cover
  133. LT1 Headers
  134. WTB Aftermarket heads (AFR/TFS/ETP/etc)
  135. exhaust manafold or headers for 94 z28
  136. Drag Wheels
  137. WTB: procharger open race valve
  138. WTB: 100 mm maf.
  139. Super victor setup
  140. Black Firebird Shift Knob
  141. Looking for Stall
  142. WTB Fbody catback
  143. WTB: Driver side door hinges
  144. Cruise Control
  145. WTB FAST 90/92 upper shell
  146. WTB: LS6 intake
  147. Wtb firehawk center caps 98-02
  148. LS2 Fuel Injectors
  149. WTB bracket for F-body LS1 PCM
  150. WTB: LS3 valve covers, timing cover, coil packs and throttle body
  151. WTB 3" or bigger electric cutout valve with wiring
  152. WTB: SLP LM2 for 04 GTO .
  153. steering wheel radio buttons
  154. WTB Red Firebird/Trans Am body parts
  155. WTB UMI parts, Bilstein hds, 17x11 silver zr1s
  156. WTB: Streetsweeper Cam asap!
  157. WANTED: Chrome C4 ZR1 17x11 Wheels with or without tires.
  158. shifter knob
  159. Magnaflow tailpipe
  160. WTB: '98 Camaro Driver's Side (LH) A-Pillar (T-Top | Dark Grey)
  161. sllp dual dual
  162. WTB: EFI 24x for 96 LT1
  163. Ported heads
  164. wtb OEM SS HOOD
  165. wtb:billet specialties streetlites for fbody
  166. WTB: SLP Smooth Bellow!!! F-Body
  167. WTB 98-02 T/A TTOP weatherstripping
  168. WTB: LS6 Intake.
  169. 10 spoke camaro ss wheels
  170. wtb h.o hood asap
  171. LS2 or LS7 Block or Shortblock
  172. WTB: 96 hub and balancer
  173. WTB: 4l80E dust cover
  174. Strano, Bilstein, LCA's, SFC's, PHB, Stealth Sub box
  175. Trade my ms4 for ms3 or good nitrous cam
  176. wtb headers,ud pulley
  177. WTB: Universal Nitrous(wet) kit
  178. Lingenfelter LNC-002
  179. WTB: Flip up headlight Bolts.. PLEASE LOOK INSIDE
  180. Stolen truck recoverd WTB broken part
  181. looking for ls1 t56
  182. WTB-TSP True Duals or similar setup
  183. LT1 K member, oil pan, timing set, shocks, headers, etc.
  184. WTB: 9" rear, trans am lettering
  185. WTB: Ls1 Parts...
  186. ls1 stuff, gas tank
  187. LT1 aluminum intake elbow
  188. fuel lines from filter to sender. need uncut off of 00-02
  189. WTB: Stock LS3 / L92 exhaust valves
  190. WTB LS1 Backing Plates
  191. Looking for a Procharger D1SC
  192. WTB: Truck intake, coil, map sensor,
  193. wtb: 3" high flow cats
  194. Wtb: Lt1 frc's
  195. LS6 Yellow Valve Springs
  196. wtb stall for ls1 4l60e, sfi flexplate, air lid, ash tray...exc
  197. WTB: 98-02 Camaro Hood
  198. WTB C6 Wheels
  199. WTB: 98-02 Camaro Front Grille Insert
  200. WTB: 2005 Corvette C6 AUTO Engine Harness!
  201. wtb ds door bezel
  202. WTB Blower pistons
  203. WTB: 1997 Z28 or SS gauge cluster??
  204. WTB: LCA PHrod subframes 255lph fuel pump
  205. Wtb Stand Alone
  206. WTB: NBM Body Parts
  207. wtb:42# injectors
  208. WTB Swappable Rear End
  209. WTB TB spacer!
  210. WTB valve spring kit
  211. WTB 10 bolt supprt cover
  212. WTB: Long Tubes W/ORY
  213. WTB:Front drive accessories, and misc
  214. WTB LS2 Mitsubishi style coils and harnesses
  215. F.A.S.T 92mm intake
  216. rear end
  217. WTB: Grey Torque Thrust 2's or Chrome Cragar S/S
  218. wtb-t56 lt1 swap
  219. Headers,shocks,pulley, etc.
  220. WTB: Stock DBC Throttle Body
  221. WTB 98-02 Camaro FRONT DRIVERS side fender
  222. WTB: SLP LM2 resonator
  223. WTB 07+ gas pedal plug and harness from... anything
  224. WTB: 60lb injectors
  225. wtb 1 silver ss ten spoke wheel
  226. WTB electric cutouts
  227. WTB; LS6 intake or FAST 78
  228. Wtb center console lid
  229. got'em!
  230. WTB: 17" street lites
  231. WTB: Lots of Stuff
  232. Ac
  233. wtb stall converter
  234. 5.0 shifter,boot,knob
  235. WTB: 243 or 799 heads
  236. Needed: hurst shifter jam nut
  237. Coil overs, 9", adjustable pan hard with bushings...
  238. wtb
  239. wtb ls3
  240. Ebony vert seatbelts
  241. Wtb:3rd gen bird spoiler
  242. WTB: 4" stainless cut out and 4" straight exhaust pipe
  243. WTB LS7 set of lifter.
  244. Wanted: FAST 90 or 92
  245. WTB: 10 bolt rear with 3.23 or 3.42
  246. LT1 6 speed Engine Harness
  247. WTB::LS1 f-body clutch master
  248. LT1 Clutch and Zeitronix ZT-2 Wideband.
  249. Low milage TBI 350
  250. Wtb ls7 block with cracked sleeve
