View Full Version : Parts Wanted
  1. WTB ls1 camaro/firebird oil pan
  2. WTB GM 85mm Z06/truck MAF, ORY
  3. wtb ls2 heads to convert my ls1 over to a ls2 setup
  4. WTB: FACTORY WS6 Wheels
  5. Looking for wheels
  6. WTB LS3 Exhaust Manifolds, Pair, Shipping to WI 54956
  7. ALDL cable
  8. Tranny Cooler With Fan
  9. WTB: 1 WS6 Wheel
  10. Need a pewter front fender!!!!!! asap
  11. WTB: LS1 Parts
  12. Need a Steering Wheel!
  13. WTT my Nitto Dr for street tires
  14. wtb- rearmount turbo piping
  15. Looking for a FAST 90/90 or 92
  16. WTB Crank Pinning Tool
  17. Need stock 99-02 catback asap! And a high flow catted y-pipe
  18. WTB ls6 intake
  19. WTB: grey sunvisors for a 97 z28
  20. WTT 228/232 custom grind for "stealth"
  21. eibach FRONT springs
  22. WTB: 02 LS6 cam & springs
  23. wtb carb intake
  24. WTB: Cam swap parts
  25. WTB front grille
  26. WTB Fast 78mm throttle body
  27. Need LS1 rear caliper brackets
  28. turbo kit a-body
  29. WTB 9 inch
  30. WTB: LS1/T56 engine harness
  31. WTB electric nitrous pressure gauge
  32. I need a rebuildable 1995 4l60e
  33. WTB: Stock LT1 roller lifters
  34. WTB 98-02 Camaro RS GFX kit
  35. Wtb a after market k member
  36. WTT.. Magnaflow catback for 3" duals
  37. WTB: Stock T56 shifter
  38. need 10 bolt 4 channel and 460le tranny
  39. WTB AC Accumulator mounting bracket
  40. WTB: 93-01 f-body carpeting 97-01 center console
  41. TRADE MY C6 silver 18" fronts for 19x11" rears
  42. Wtb procharger 6rib blower pulley
  43. wtb wrecked front fenders
  44. 10 Bolt Rear
  45. WTB: Trans Am drivers leather seat. or both front seats.
  46. MSD Ignition LS1 / LS6 Blaster Coil Pack PN# 82458
  47. WTB powdercoated 10 spokes
  48. F-body exhaust
  49. WTB LS1 Ebay Headers, Cam and valvesprings
  50. clutch alignment tool and remote bleeder
  51. WTB: truck alt bracket.
  52. WANTED WTB- LS2 LS3 Exhaust Manifolds- Corvette Style
  53. WTB: inside driver mirror plastic piece
  54. WTB: cam for 5.3
  55. wtb: throttle body
  56. WTB: 6.0 Head Gasket; Wideband gauge etc
  57. WTB: Aluminum Driveshaft
  58. WTB: Procharger Fan shroud.. i have fan
  59. WTB 1 LS1 valve cover bolt
  60. slp lt1 cai
  61. WTT Lid, Airbox, Filter for K&N FIPK
  62. Sponcers and members i need parts!!
  63. I need a drive shaft, th400 to moser 12 bolt
  64. WTB-Rims for my 95 camaro
  65. WTB LS1 radiator prefer around ST Louis area
  66. WTB Antenna assembly motor and all and a Oil Dip Stick
  67. WTB : T56 6 speed
  68. WTB or TRADE, Ground Control Coil Over setup
  69. WTB: NBM SS Hood and fender 98-02
  70. EMERGENCY! WTB: 1 CTS-V Wheel/looks unimportant!
  71. WTB: Stock 01-02 stock F-body exhaust manifolds, y-pipe, catback
  72. wtb: 3.5" y-pipe
  73. Wtb rear main cap lt1
  74. WTB: 2002 Factory (Base) SS catback
  75. ls6 intake
  76. WTB: Black 10-spoke Camaro SS wheels
  77. WTB: 05-06 GTO Corsa Sport
  78. WTB LS6 intake
  79. Wtb autometer boost n fuel gauge
  80. WTB: 97 LT1 PCM - $65 shipped
  81. WTB: 98 LS1 PCM - $125 shipped
  82. WTB: 44mm wastegate
  83. Camaro Firebird PCV Breather Vacuum Line Hose for sale
  84. Wtb kateck red belt tensioner mount
  85. wtb - Rear Adj. LCA's ASAP
  86. WTB white TA front bumper cover and passenger side skirt
  87. WTB: 98 Fuel Sending Unit
  88. WTB: 93-02 Red TA rear bumper cover
  89. Turbo Kit
  90. need a 6.0 knock sensor and ls3 ntake manifold bolts
  91. ls2 fuel rail
  92. LCA, Brackets, 5.0, Torque Arm, DSSL, Front bumper
  93. 93 T/A Computer
  94. draglites with 275/60/15 drag radials
  95. tspxpipe,42injectors,catback,pro5.0,fastintake
  96. WTB Fbody ps & alternator brackets and tensioner.
  97. WTB: Front Upper A-Arm mounts
  98. WTB LS1 T56 Driveshaft
  99. Z06 cam '01 or 02-04 either or......
  100. WTB: HP Tuners Pro VCM Suite
  101. A/c lines bolt (the 1 that holds the hose manifold onto the comp)
  102. WTB: UMI Torque Arm Tranny Mount
  103. WTB: some parts for a v6 to v8 swap ls1 camaro
  104. WTB PWR window motors
  105. Need a complete LS1 Camaro airbox
  106. SLP Eibachs
  107. WTB: A 4L80e Trans
  108. wtb: fast 92/102 mm intake set
  109. Looking for an S60
  110. WTB: Aftermarket LT1 camshaft
  111. Procharger Parts,Pulleys, Shrouds, Etc
  112. wtb 99-02 camaro gauge cluster with 68K miles! ASAP!!
  113. wtb throttle cable, cruise, abs delete
  114. pair of t-tops....broken glass is ok!
  115. Looking for a set of drag wheels
  116. wtb nitrous stuff
  117. Wtb: sunoco wide smooth hood
  118. WTB P/P Throttle body
  119. 93-97 Left rear caliper.
  120. 98 Camaro Cluster WANTED 45-65k miles LS1
  121. Autometer Phantom FP and Nitrous gauge
  122. WTB LS1 main studs
  123. Wtb lid
  124. WTB:Rear drag wheels and tires
  125. Anyone have 1 OEM C5 Z06 rear wheel - Fedex lost mine.
  126. wtb- 68cc or bigger heads name brand!
  127. 12bolt and built 4l60e
  128. 98-02 Camaro Dashboard
  129. WTB: Kooks ORY Pipe
  130. WTB: TA spoiler wing hatch Trans Am high rise
  131. WTB Front Ground Effects/Hardtop Roof Section
  132. WTB: SunVisor Tan LH
  133. s480 turbo wanted new or used!
  134. Looking for an Ebony M6 Console
  135. WTB: 98-02 Red Driver's Side Mirror
  136. WTB: Synister Motorsport power steering pulley
  137. LT1 alum intake elbow - 3.5" round inlet-> BBK
  138. WTB Procharger Crank Pulley (GTO)
  139. Wtb fast 92mm
  140. need a 4l60
  141. wtb. 4L80E conveter
  142. WTB: ASA Cam
  143. WTB 93-99 CAMARO Steering Wheel
  144. wtb 3 to 5 wire MAF adaptor
  145. WTB F-body LS1 parts
  146. Want to buy a 2002 PCM asap
  147. Wtb ls1 y pipe and o2 simulators
  148. wtb..95 lt1 auto trans
  149. WTB LS1/LS2 gto oil pan and ls1 ported throttle body
  150. Used GM vented Opti and harness wanted!!!
  151. wtb. racegate springs
  152. wanted
  153. WANTED- Camaro Shop Service Manuals 2001 or 2002
  154. Lt1 cai
  155. wtb 1 17x9 gunmetal zr1
  156. WTB Plastic pieces around steering column
  157. LT1 1LE Elbow
  158. wtb 2001 trans am drivers headlight motor
  159. WTB: Looking for a stock LT1/LS1 intank fuel pump setup, lines, etc anything you got
  160. p-AYR plastic LS mockup block
  161. WTB: Chrome Vent Rings (Trans Am)
  162. WTB: LT1 Spark Plug Wires
  163. Trans Am Monsson Sail Panel Speaker Wanted and Gauge Bezel
  164. WTB New ARP Rod Bolts, Springs, Rockers
  165. WTB 78mm nitrous outlet plate
  166. WTB FAST 90/90 or 92/92
  167. WTB LS1 crank pulley, LS2 GTO fuel rail and power steering pulley
  168. wtt/wtb used cranks,rods, pistons
  169. Wtb: Edlebrock vic jr LS1 carb intake and ignition
  170. WTB: Fast + Moneymaker setup
  171. WTB Hotchkis Springs
  172. WTB: 95 Formula stuff, 97+ A4 console, more
  173. wanted, ls2/lq9 pistons or aftermarket
  174. Wanted: Fbody A/C Compressor
  175. Looking for a used 90 mm F.A.S.T intake...
  176. WTB QA1 or Strange Drag shocks
  177. Borla/Corsa LT1 cat back or axle back
  178. WTB Speakers
  179. WTB fast 90 or 92 intake.....
  180. WTB!!! QTP stainless longtube race style headers and 25% ud pulley
  181. WTB: LQ9 6.0L crank
  182. WTB: Right front Navy Blue Metallic fender for 4th Gen Z28
  183. WTB one C5 Z06 18 x 9.5 wheel
  184. WTB: MTI clear lid
  185. WTB-Random Parts
  186. Black m6 console
  187. WTB - OEM LS1 crank and OEM LS1 rod
  188. WTB Double Din or mids/tweets/subs..
  189. wtb-driver side A arm
  190. WTB: Coil pack bracket
  191. wtb aftermarket ls1 kmember
  192. WTB: Trans Am Headlight Assy
  193. wtb pistons for a 370
  194. Looking for LT1 Headers......
  195. wtb a4 rubber transmission mount
  196. WTB Flywheel Holding & Balancer Install Tools
  197. wtb ls1 shorty.
  198. WTB: 10 Bolt 4Ch. 342 Posi Unit In Good Condition, SLP/FTRA Ram Air
  199. WTB:airaid intake for 06 c6
  200. WTB: 98-02 Camaro Hood
  201. WTB stock manifolds and cats for '01 LS1
  202. WTB LQ9 or LQ4 longblock
  203. LT1 SS air box
  204. WTB 4.030 pistons asap
  205. WTB ls6 intake or a TPIS 90 intake
  206. 99 camaro console parts
  207. wtb 85mm lid and autometer II sport or pro comp gauges
  208. WTB: Trans Am P/S Body parts
  209. looking for m/t et streets
  210. WTB: Fuel Pump for LT1
  211. WTB: 4.8 Flattop pistons
  212. wtb:transmission tunnel boot
  213. Wtb: Oil pump and ls2 timing chain!
  214. WTB CTS-V Rim(S)
  215. Need Driver and Passenger door outter weatherstrips
  216. ls6 z06 cam
  217. Wtb: l92 efi victor/4150 tb
  218. wtb.....ls1 oilpan for g-body swap...
  219. WTB TA Groundeffect
  220. WTB Roll bar or roll cage
  221. WTB Forged motor for boost
  222. WTB: Alternator Bracket and Pulley
  223. WTB 10 spokes
  224. WTB Stock WS6 Lid
  225. wtb: 98-02 wings west front lip for trans am or firebird
  226. WTB for 2001 T/A Mint or NOS Carpet and Rear panels( panel with seat belt/speaker)
  227. WTB: Any sponsors have 243 ls6 castings
  228. WTB- 275/60/15 DR's
  229. WTB LS2/7 Flywheel !!!
  230. WTB: GTO 6spd Tranny
  231. Used F14 cam
  232. WTB: Transmissions cores. T56 and TR6060
  233. aftermarket LS6 intake and TB wanted!!
  234. WTB: (2) GTO Spare rim/tire and stock 98+ Camaro taillights
  235. WTB 16x8 wheels for trans am (for winter)
  236. Aftermarket Parts
  237. WTB: LS1 Ram Air Hood Grilles, TA Front Bumper Cover
  238. WTB: LS1 Oil Pan, TCI Flexplate, MSD Coil Pack
  239. WTB OEM SS Hood for 98-02
  240. wtb on car adjustable panhard bar
  241. LS2 conversion parts needed
  242. wtb-nice set of heads 70-72 cc
  243. Need a 4th gen rubber filler neck W/ gas cap.
  244. WTB Power steering pump with reservoir and pulley
  245. WTB: stock ls1 fbody accessories
  246. wtb front skinnies that will clear fact. 93-02 fbod brakes w/0 spacer or GTO spare
  247. Need interior pieces...
  248. WS6 Badge and Centercap
  249. Stock 4.8 Cam
  250. 9" rear
