View Full Version : Parts Wanted
  1. Wtb 98 fuel bucket assembly
  2. 1993 Camaro Intake, Fuel Rails
  3. WTB: LS6 intake, injectors, Vette fuel rail
  4. WS6 Hood
  5. WTT M6 pedals for A4 pedals
  6. WTB: ud pulley and FTP 98mm air lid
  7. WTB Alky meth kit and BOV
  8. WTB: Truck power steering pump pulley
  9. wtb ecu 94 camaro lt1
  10. WTB LSXRT intake
  11. WTB Fast intake and throttle body
  12. Wtb: 2000 camaro ss 3rd brake light
  13. WTB: 42lb injectors
  14. Need exhaust flange for 2010+camaro or g8
  15. wtb- BMR 4l80 trans mount with built in tq arm mount
  16. ls1 and ls3 parts wanted
  17. wtb t56 for ls motor
  18. Wtb: Gm gen iii gen iv 4.8 5.3 6.0 exhaust manifold rh passenger side 12616288
  19. trickflow 215 heads
  20. FAST 90/90 or 92/92
  21. F body 2 piece Baer Eradispeed
  22. Intake and heads WANTED! LS6 Intake, 243/799 Heads
  23. WTB Catted Off Road Y pipe
  24. Wtb: quarter stick brackets to fit in stock center console
  25. wtb 18'' drag radials
  26. T56
  27. wtb: ls1 f body front accessories & ls6 intake
  28. WTB fbody 9" housing
  29. TR224 Cam
  30. Th400 or TH350 swap parts
  31. WTB K444X05 wiseco pistons
  32. Wanted venturi fill style lower fuel bucket
  33. WTB: LS6 injectorss
  34. Fuel injectors, Oil Pan Needed
  35. WTB: CNC ported heads, rockers, lifters, nitrous
  36. WTB: 2OTL tail pipes for a 3rd gen
  37. L92 head
  38. WTB: 12 Bolt Reluctor
  39. parts needed for my swap
  40. WTB, 93-97 OEM Camaro SS hood
  41. Wtb: Lt1 heads and intake
  42. WTB 93-02 Trans Am Sideskirts
  43. wtb tick master cylinder for 02 ta
  44. Wtb ls1 t56
  45. WTB: DMH 3" cutout butterfly valve (no or bad motor ok)
  46. WTB HP Tuners Pro
  47. Weld Drag Lite XP 16" Help
  48. Weld Drag Lite XP 16" Help
  49. LS1 Intake manifold needed
  50. LS1 Fbody alternator bracket
  51. WTB T56 input shaft, bellhousing and front plate
  52. LS1/LS6 wiring harness TBC t56 2004
  53. Need: T4 Flanges-PS Pulley
  54. wtb 3 channel a4 3.42 gears, 16in wheel center cap and black front plate bracket
  55. ls1/t56 complete pullout
  56. Wtb cruise control cable
  57. wtb 85mm slp maf sensor, bellow
  58. 243/799 Heads
  59. F body oil pan
  60. T56 Shifter Boot and Knob!
  61. Texas speed 1 7/8s headers and true dual set i wtb
  62. WTB: 2 LS1 Coil Pack Harness
  63. WTB Stock LS3 Intake Manifold and Rocker/Hardware
  64. 98-02 m6 center console
  65. WTB: 00-02 Chrome SS wheel 17 x 9 and ebony driver sun visor
  66. WTB: Wideband set up
  67. WTB: LS1 Heads and Cam proven package with 425+ rwhp
  68. looking for 2.5" and 3" mandrel exhaust pieces
  69. WTB: Rear Radials 27 or 28 10.5
  70. WTB: front runners for 15x3.75 rims
  71. WTB: Fikse, HRE, Iforged, or CCWs...or any other nice 18" wheels
  72. wtb ls6 intake
  73. WTB SLP Flow Pac kit for 02' TA
  74. WTB...99 Trans am side skirts
  75. WTB: LS1 Coil Packs
  76. headers, x pipe wanted
  77. WTB 98-02 SS hood (preferrably pewter)
  78. wtb 15" drag radials
  79. WTB BBK LS1 intake manifold
  80. lt1 ac bracket
  81. Red GTO Front Seats Wanted
  82. WTB Underdrive Pulley
  83. WTB: TH400 swap parts
  84. Looking for a 5.3 crank and rods
  85. WTB drag wheels and tires
  86. NTB: LT1 Rear Caliper Parking Brake Mount...
  87. wtb oil catch can
  88. flex plate wanted
  89. innovative lc1 lambda chrod
  90. Tan seat for my 01' TA
  91. WTB: Canton Oil Pan for LT1
  92. Heads
  93. comlpete ls3/l92 top end
  94. LS3/L92 heads and rockers (250cc)
  95. Wtb 02 sensors
  96. Meziere Water Pump Heater Core Plugs
  97. WTB PS Pump and Idler
  98. WTB LS6 243's
  99. WTB: full exhaust w/ cutout, 18" wheels
  100. wtb ls1 t56
  101. ls6 intake and 0411 ecu
  102. WTB-Mgw shifter
  103. Wtb complete magnacharger or procharger setup $3500
  104. SS wing
  105. WTB: WS6 Ram Air hood local in Hawaii
  106. Wanted 2012 stock manifold/ mid pipe and white door handles
  107. Wtb
  108. wtb ls3 head
  109. Wtb boost and air/fuel gauge
  110. wtb holley hi ram!!!!!!
  111. WTB: 60-65 LB injectors
  112. WTB: LS3/LS2 shortblock or longblock
  113. Wtb 02 or newer ls6 cam
  114. WTB: REAR DIFF 99 trans am
  115. WTB: 6LE or OEM CME valence
  116. WTB aster bracket for procharger stock 8rib& J bracket+$ or just $$
  117. Aftermarket Poweglide Case
  118. Wtb 102 plate
  119. Ls2 parts needed
  120. WTB LS9 Cam
  121. wtb: F1a procharger kit 4th gen
  122. wtb 4150 throttle body and billet fuel rails
  123. wtb wastegate, bov
  124. Built 4L60e
  125. WTB: Nasty Performance LS7 Fuel Rails
  126. WTB FRONT LCA's
  127. wtb LS-7 short block
  128. Looking to buy a CTS diff carrier assemby
  129. ls6 intake, underdrive, lid , injectors
  130. WTB: Nitrous parts
  131. WTB:ls6 intake+ls1 fuel rail covers
  132. Wtb Vic jr,90' elbow,clutch rated for 1,100 hp, twin 66's or 70's
  133. autokraft or champ oil pan
  134. LS2 crank pulley
  135. WTB Flycutters or RENT
  136. WTB: 97-02 TTOP A PILLAR plastic.
  137. WTB: GTO differential side adjuster
  138. WTB Nitto Nt05 275/40/17
  139. WTB:Electric exhaust cutout!
  140. WTB corvette LS1 Power steering pump
  141. beatbelt bracket, ash tray and triple A-pillar gauge pod with gauges
  142. Wtb/wtt tan interior complete
  143. Wtb T56 transmission and bellhousing for 98-02 ls1 fbody
  144. 93-02 manual sliding seat track needed asap!
  145. WTB WS6 lower air box
  146. Wanted: yank ss4000 or FTI 4000 hard hit stall converter
  147. WTB Aeromotive Eliminator Fuel pump
  148. WTB 4.8 or 5.3 short/long block
  149. wtb procharger kit
  150. WTB: Built Ls style T56 and LS3 intake manifold
  151. WTB F-Body T56 offset lever
  152. Ls1 throttle cable bracket stock or
  153. wtb junk ls1 water pump or just the press in top outlet
  154. WTB/WTT: Procharger F2 Head Unit
  155. WTB LS3 stock or ported TB
  156. WTB 1 7/8 kooks lt/kooks ypipe, radio bezel, c5z rims, acvent,ngk afr guage and more!
  157. wheels
  158. Wtb: rear end suspension
  159. Nitrous Outlet Dual Stage 78mm Plate
  160. WTB: fbody rear suspension parts
  161. WTB: SFI bellhousing
  162. WTB 94-95 camaro lt1 computer
  163. Ls T56 full accessories plenum tb rails etc
  164. Parts needed for my Swap
  165. Procharger headunit wanted
  166. gen parts needed qa1--
  167. WTB: Stock GTO Grilles
  168. WTB: Exhaust Hanger + Bushing 02 TA Passenger Side
  169. wtb aftermarket slave and master cylinder
  170. WTB: Gray triangle piece on door side of mirror
  171. wtb:Hp tuner standard or pro
  172. Monsoon radio
  173. looking for a ton of stuff for my 99 z28
  174. stock ls1 fuel rail
  175. Wanted 4.8 crankshafts
  176. a couple miscellaneous parts
  177. wtb ls1/6 pro flo intake
  178. few parts needed
  179. WTB- 98' TA Right side skirt
  180. WTB 98,99 Stock/Ported Throttle Body
  181. Wtb: Ls2 e67 pcm
  182. Wtb turbo parts!!!! Stock heads, arp, gauges, etc!
  183. WTB: LS1 Belt Tensioner
  184. Wtb fast intake 78 90 92 maybe 102 with tb
  185. WTB: Dash pad for '98 Trans Am
  186. WTB accufab 4150
  187. WTB: LS1/LS6 Money Maker intake
  188. WTB: 00-02 Procharger Cruise Control Relocation Bracket
  189. Wtb ls1 flexplate
  190. 6.0 cam wanted for nitrous.
  191. WTB: Trans am Convertible Speakers
  192. WTB - Catch Can for LS6 (CTS-V)
  193. Looking for VFN Sunoco 98-02 Camaro Bolt on hood
  194. needed LS3 build parts
  195. WTB truck tb.
  196. Ls6 Intake..
  197. WTB: Aluminum 10 bolt diff cover
  198. WTB 4l80E flexplate/spacer/bolts
  199. WTB boyd coddington smoothe IIs
  200. wtb f-body cell
  201. Wtb ASA camshaft
  202. WTB LS3 intake valves...
  203. WTB Automatic Pedal Assembly for 98-02 Firebird
  204. WTB= Fast 102 intake/TB LS1/6
  205. WTB 315 s or 335 s for 17rims
  206. WTB Ls1 t56
  207. WTB LT1 LT Headers
  208. WTB passenger tail light for camaro, and stock springs
  209. WTB: Clutch master cylinder U-bolt
  210. black OEM floor mats
  211. wtb racecraft inc or pa k member and a arms 93-2002
  212. wanted: Fast 92 mm tb
  213. WTB chrome a/c vent rings and speaker
  214. LTCC Setup
  215. Wanted 92mm tb, nick Williams or PTM
  216. WTB- F-Body Power Steering pump
  217. ls6 cam or similar
  218. need a t350 cross brace
  219. WTB low mile ls2/ls3 short block
  220. WTB LS1 power steering pump
  221. WTB: LS3/L92 Rockers
  222. need a few fuel type things
  223. exhaust manifols
  224. WTB Truck manifolds
  225. t56
  226. Parts wanted
  227. I need a stall for a 200r4
  228. WTB lt1 1.6 SA Roller Rockers
  229. WTB: Poly motor mount
  230. WTB: Manley Pistons
  231. WTT Turbo motor for nitrous motor 1000RWHP
  232. WTB draglites rims and tires
  233. Stock LS2 243 Heads Take offs
  234. WTB hood latch & release bracket thing & Y pipe bracket
  235. Seat Covers.. charcoal leather, houndstooth...etc
  236. WTB Automatic pedals complete
  237. WTB LS1 (Corvette) Accessory drive
  238. wtb heads!!
  239. WTB: Exhaust tips
  240. WTT Ms3 cam
  241. LQ4 Shortblock
  242. wtb ls 120lb high impedence injectors
  243. WTB fast 102 for LS3
  244. wtb ls6 intake with ported and polished tb
  245. Parts wanted , inj , fuel reg and more
  246. Wtb gto power steering pump
  247. WTB LS6 Intake
  248. WTB: 243 heads
  249. WTB: Aftermarket oil pan
  250. WTB: 99-02 F-body LS1 automatic engine harness
