View Full Version : Parts Wanted
  1. lt1 heads performance
  2. Wtb prom burner (burn 2) and or moates ostrich 2
  3. WTB: ARP 134-4703 Head Studs For LS7
  4. WTB - Lifter rods and Balancer tool
  5. Trans Am Front Bumper Plastic
  6. 4inch Crank for ls2 24x wTD
  7. Radiator Baffling for 98 TA
  8. Wtb ls1 parts please look
  9. LS3 block or resleeved ls2 block
  10. Need Firebird/Trans am Int Dash, Dash Pad etc!!!!
  11. LS6 cam
  12. ls1 or ls6 bare or short block
  13. WTB: LS3 Balancer
  14. WTB bigs n littles, sunoco hood, etc
  15. 4.070" pistons -11 for ls3 for boost (wisco)
  16. WTB: M6 torque arm bracket
  17. AC Compressor Needed
  18. WTB: 2 17X11" Zr1's (Preferably all Black)
  19. Misc 2001 Trans Am Parts Wanted!
  20. wtb: odbII lt1 a4 wiring harness
  21. lt1 posi rear and driveshaft
  22. WTB: Msd Digital 6 Plus or Mallory 685
  23. WTB Strange 12 Bolt Housing
  24. tensioner
  25. wtb 1 speedline wheel
  26. Wanted B&B or Magnafow catback
  27. WTB Looking for Black or Dark ebony leather front seats and rear seats
  28. WTB: Quicktime 6036 Bellhousing
  29. wtb. hood latch cable 98-02 camaro.
  30. WTB: rear driver side quarter molding, ash tray lid
  31. T/A seat w/lumbar wiring harness
  32. WTB: Racetronix Kit, BMR U&LCA and LS6 Intake
  33. WTB: T6 Turbo Blanket
  34. WTB:275 40r17 tires
  35. tripple gauge pillar and some gauges
  36. SLP lid needed!
  37. WTB: Chrome SS 10 Spokes
  38. wtb: bolt bolts and more bolts
  39. WTB: LT1 cam + 98-99 SLP lid
  40. I have money in paypal right now for a EBONY radio bezel
  41. Ws6 lower air box
  42. WTB: 15x10 wheels with 4.5" back spacing
  43. Will pay $100 for Red MBA Washer Reservoir Cap 98-02 FBODY
  44. WTB: Gen IV wiring harnesses
  45. 3 inch sweet thunder muffler and 3 inch metallic cats
  46. 224r or 228r cam
  47. 90mm or 92 mm fast intake
  48. WTB: 275/50/15 m/t e.t. street radials
  49. wtb 224-228 cam
  50. WTB afr 205 heads
  51. WTB: LT1 head
  52. wtb wastegate
  53. WTB: 3 Bar Map Sensor
  54. WTB non working opti
  55. LS1 4 Channel backing plates&ebrake parts
  56. WTB: Lq9 shortblock
  57. 6.0 Shortblock wtb
  58. Meizer Electric water pump for ls1
  59. ss rims
  60. GMPP single plane (EFI) for LS3 or L92
  61. callies 4.0" crank 58x & Callies rods
  62. WTB 4l60e
  63. WTB Cam ~224-234 under .600" 112
  64. WTB Strange Race Brakes Front/Rear!!!
  65. LS1 t-56 4th Gear / imput shaft
  66. Looking for aftermarket or modded heads for my LS1..
  67. wtb : built t56 trans
  68. WTB: Tan T-Top Shades
  69. Wtt fast ecu for pt88 or gt88
  70. WTB - FTRA o2 sims , smooth below truck trotle body
  71. Edelbrock Pro-Flo 7140
  72. WTB Camaro Key Fob
  73. WTB: Firebird Monsoon Sail Panel Speaker
  74. WTB: UMI Non Adjustable Torque Arm
  75. Help! WTB: Stock intake bellow
  76. WTB slicks for a 16" rim
  77. T56 for LS1 in good working condition
  78. WTB LT1 Performance Flywheel
  79. WTB: TR224 or similar cam
  80. WTB: Mallett 396/XMS style wheels for C5
  81. wtb lt1 355 shortblock (aka AChotrod's setup)
  82. WTB: 98-02 OEM SS Hood
  83. WTB LS1 f body oil pan
  84. Wtb: Firehawk SLP Car Cover
  85. WTB - Panhard bar stock bolt and nut to fit 95 T/A LT1
  86. WTB: Drag wheel setup... have cash
  87. WTB Pro Stars
  88. WTB: Plastic Flange that covers flywheel
  89. Looking for ls1 oil pan - anyone buy from gmpartdirect.com?
  90. WTB: Smallish cam (112 lsa or narrower)
  91. Lights and mirror
  92. C5 under hood light cover
  93. WTB: MSD 6010 750cfm carb F body oil pan
  94. WTB Driver Side door Speaker mount/tray - Trans Am
  95. wtb: T56 for ls1
  96. WTB used big nitrous solenoids
  97. WTB: Engine Block
  98. wtb coil brackets
  99. WTB: manual mirrors
  100. WTB ls2 Flywheel
  101. tfs/afr heads for 3.9 bore
  102. WTB forced induction cam and springs
  103. Wtb-a Cheap 93-97 camaro hood(SS,Cowl,Ect)
  104. WTB shift knob
  105. LS3 bare block
  106. WTB: Air lid, short stick
  107. WTB: TSP cam 233/239 112
  108. Backing Plates
  109. l92?
  110. looking for ls2,fastntake, 243 heads,,line lock,
  111. PS pump side MIRRORS
  112. I need an ls6 rotating assembly
  113. star skinnies,78mm nitrous plate
  114. Wtb factory cd player and A4 Shifter knob
  115. WTB 3.905 Pistons.
  116. WTT:Pro5.0 for mgw
  117. WTB SS scoop hood. JUST NEED SCOOP. CAN BE DAMAGED
  118. ac Compressor
  119. wtb trans am interior parts
  120. turbo, 67mm- 76mm
  121. WTB : Camaro/Firebird 93-2002 T56 6 speed Lower Shifter Boot
  122. WTB: Revxtreme catch can 02 LS1
  123. WTB 93-97 f-body axles
  124. WTB OEM SS Spoiler LS Style
  125. set of ls truck coils
  126. WTB ASAP! Racetronix fuel pump hot wire harness
  127. WTB SLP MAF 85mm
  128. WTB ASAP LT1 Master to Slave clutch line/hose
  129. Trade eibach prokit for BMR lowering springs
  130. Wtb
  131. WTB:ls1 PCM/t56 and Alternator
  132. Z06 camshaft 02+
  133. i need parts
  134. WTB: Upgraded driveshaft for T56/9" combo
  135. wtb 15x3.5 pro stars
  136. WTB - 4l60e to LSx
  137. WTB ebony door handle bezel and window switch bezel for Trans Am
  138. LS2 block
  139. WTB: OEM Catalytic Converters
  140. WTB Hp tuners MPVI
  141. WTB Swaybar U bolt(rear) and ABS sensor
  142. WTB 5 speed
  143. WTB air lid
  144. Wtb lq4/lq9 bare block
  145. Needing hptuners
  146. wtb qa1 or strange front coilovers with springs
  147. needed bunch of LT1 stuff (updated)
  148. M6 cross member and console wanted
  149. WTB LT1 Heads
  150. WTB: A-pillar panel
  151. OEM SS LS1 spoiler
  152. WTB: SLP/ATI UD pulley
  153. WTB:T-Handle shifter
  154. WTB black 2002 camaro rims
  155. Need slp lid n k&n filter..
  156. Callias rods ls1 6.125"
  157. Meizer Electric water pump for ls3
  158. WTB- Coated Pacesetters for 99+ with EGR/AIR
  159. WTB:Banish DVD with fuel tables
  160. WTB: Rear springs rubber isolators
  161. WTB: T/A lumbar seat wiring harness
  162. wtb/wtt 18in wheels for 17in wheels
  163. Wtb ls1 tb
  164. WTB LS1 Parts
  165. Need A/C compressor 98-02 Fbody
  166. 315/35R17 tires wanted (need 2)
  167. wtt ls6 intake for vic jr
  168. After market y-pipe
  169. WTB: fbody accessories
  170. WTB Headlamp
  171. wtb 7.375 pushrods
  172. WTT - Spohn Tunnel Mount TQ w/Drive Shaft Loop
  173. WTB or WTT 93-97 LT1 fenders for 98-02 camaro fenders
  174. WTB: Truck Manifold
  175. Taillights
  176. "WANTED" LS6 hollow stem intake &/ or exhaust valves
  177. WTB Anti Roll bar
  178. WTB Z06 cam
  179. WTB: 27 Spline Slip Yoke for TH350, 4L60E or T56
  180. WTT: Felpro head gaskets, sell or trade+$$$ for thinner
  181. WTB: 6.0 GTO oil pan
  182. WTB-Lowering springs for 98-02 camaro
  183. Wtb tr224-112
  184. F body Water Pump
  185. WTB-UD pulley
  186. ls1 main a/c line
  187. wtb: 3" manual cutout
  188. Looking for emergency brake adjustment screw...
  189. wtb-N20 dry kit
  190. wtb heads
  191. wtb 98-02 camaro L&R fenders OEM
  192. WTB SBC Pistons
  193. WTB: LS6 Intake in Oklahoma TODAY!!!
  194. wtb rear end cover/girdle, studs, 4.10 gears
  195. WTB LS2 pistons / rods or LQ9 pistons / rods
  196. WTB: CTS-V pick up tube!! and other stuff
  197. WTB: drivers side truck manifold (05)
  198. WTB Differential Spacers/Shims
  199. WTB Helms manual
  200. WTB: F-body LS1 K-member & LCA's
  201. WTB: Wiring harness for 99+
  202. Dual dual
  203. WTB: MGW Shifter
  204. wtb 93-96 style console and 6 spd plate
  205. WANTED: Stock 98-02 camaro grill!!!
  206. Trade my big cam(240/244) for your small one(<228)
  207. t-56 ls1 front adapter plate
  208. Have a spare MSD wire laying around?
  209. wtb-line lock,cage, bigs n littles
  210. WTB: LT1 Timing Cover W/ Crank Sensor Port
  211. WTB: SSR T56 and 06 Trailblazer SS Engine Harness
  212. WTB: LS1 Bellhousing bolts and pressure plate bolts
  213. WTB: 3 Charcoal Dash Parts For 98-2002 Camaro..Come Inside
  214. 894 hid kit
  215. WTB-O2 extensions and etc
  216. WTB: 4L60 Alum. driveshaft, Water Pump, LS1 P/S Pump, LS1 Starter
  217. need 1 non-chrome 16" snowflake rim
  218. WTB : 93 94 95 96 97 98 99 00 01 02 Camaro Firebird Trans Am Seats
  219. WTB: (1) L92 Intake and (1) L92 Exhaust Valve.
  220. WTB/trade an LT1 or LS1 MAF with screen for NOS bottle
  221. wtb: super vic, vic jr or fast 102
  222. wtb: cam, springs, hardened pushrods
  223. WTB Wiper arm
  224. WTB passenger taillight '02 TA firebird
  225. WTB: 6 speed upper console
  226. FAST 78mm intake
  227. WTB: 243's or 799 heads
  228. WTB: Koni shocks
  229. fast 90 or fast 92 intake
  230. wtb crome trans am wheels in nc reasonable
  231. wanted Patriot 8501 springs and ati 918853 superdamper
  232. WTB prc237s,tfs,afr heads for 6.0 block
  233. WTB: Rear caliper brackets
  234. Looking for prostars or draglites and a roll cage
  235. PNP switch wiring pigtail
  236. wtb;complete turbo setup
  237. WTB off road Y-pipe slip flange for 01 trans am ls1 type.
  238. Wtb front lower control arms.
  239. Wtb: Ls1 fuel rails
  240. Wtb: Throttle body
  241. WTB: LT1 Non-TCS/ASR Throttle and Cruise Control Cables
  242. wtb 98-02 camaro pan
  243. WTB: 99-02 Rear Camaro bumper in good shape
  244. wtb: 3 channel 10 bolt with 3:42's or higher
  245. WTB exhaust parts
  246. WTB LS1 Intake Bolts
  247. fuel tank bucket...2002
  248. Wtb lots of parts bolt on stuff n nos kit
  249. Wanted: rear 15x10 7.5" BS Pro Stars or drag lites
  250. Wtb: Ls6 intake
