View Full Version : Parts Wanted
  1. WTB-M6 to A4 swap parts-LT1
  2. WTB: New Morel hydraulic lifters for LS2 based motor
  3. WTB: 243 or 799 heads
  4. WTB: 243 heads
  5. Wtb: LS1 F-body windage tray and pick up tube
  6. WTB trans am automatic center console peices!!
  7. looking for pi converter
  8. WTB: LT1 Cold Air Intake
  9. Wtb cme valance
  10. WTB ported 243s
  11. fuel lines
  12. WTB l92,ls3,OR other heads in same catagory
  13. WTB one OEM C5 z06 rear wheel 18x10.5
  14. WTB LT1 Headers and cat back
  15. Wanted!!!! Drivers side window regulator.
  16. WTB: Starter for F-Body T-56 LS1 style
  17. WTB: Forged Shortblock
  18. 2-series gears
  19. alternator relocation bracket
  20. LS2 Throttle body
  21. Lt1 opti Spark plug needed
  22. Long Tube headers wanted.
  23. WTB - wiring harness for power lumbar seats
  24. WTB: ls1 water pump,oil pan, coils, alternator and bracket
  25. WTB: LS1 Valve covers & Brackets for coils
  26. WTB complete emergency brake handle
  27. looking for a supercharger for an lt1
  28. FAST dual WIDEBAND
  29. LS6 manifold for LQ9 317's $ in hand
  30. WTB-center console lid/ rear hatch shocks
  31. WTB: MS3 or similar cam
  32. WTB-Drilled & Slotted Rotors
  33. WTB: 93-97 Firebird Headlight actuator/motors
  34. WTB T56 driving distance from Atlanta
  35. WTB: LS1 Throttle Body Bracket
  36. WTB FAST Intake - TB - Adjustable Rockers - Lifters
  37. wtb some rear brake parts
  38. wtb 15x10 w/ 7.5 BS wheels
  39. WTB: Ebony interior parts (see inside)
  40. wtt/wtb F body car coils I have truck coils!
  41. wheels for a 73 corvette.
  42. Rear Roof Panel
  43. WS6 badge
  44. TCS switch plate
  45. 98 computer z28
  46. WTB 94 z28 a4 Engine Wiring harness
  47. WtB LT1 pistions n/a
  48. WTB 10 spoke SS wheels
  49. WTB: LS6 Longblock, M12 Trans & Z06 Rear
  50. WTB red tops
  51. wtb 42lb injectors now!
  52. Rear shocks 99 f-body new or used
  53. WTB: valve springs, pushrods, timing chain, oil pump
  54. Flat top pistons for a 4.8 or 5.3
  55. Front Clip for 99 Camaro
  56. WTB aftermarket Intake and Throttle body for LS1
  57. WTB: 98 Ls1 Bare Block
  58. WTB 99-up engine harness
  59. parts needed
  60. Gears wanted
  61. MSD Optispark
  62. WTB: PCV System
  63. Need 1998 Camaro Front Bumper Cover
  64. Wanted 98+ T56 Midwest
  65. Looking for 3.73's
  66. WTB Bogart Rears
  67. WTB: Non TCS Cruise control cable 98-02
  68. WTB AC compressor
  69. LT headers with Y pipe and 85 or 90 fast with TB
  70. WTB Trans AM AC/heat vents in middle of dash.
  71. WTB: 243 heads stock
  72. WTB - LT1/4 ARP Head Bolts
  73. WTB 98 AIR fittings
  74. black trans am seats or other
  75. wtb ams 500 or 1000
  76. WTT someone's 9" for my stock rear end...
  77. Reichard Racing Pulley
  78. W.T.B Fast 92mm intake for ls2.
  79. Wtb: Ls1 hot cam
  80. WTb: 90/92mm throttle body
  81. WTB steering column, air box lid, front bumper
  82. WTB 8 rib procharger pulley
  83. WTB: Turbo Kit
  84. PCM grommet
  85. WTB Graphite panel over petals and red box under hood
  86. WTB: Pacesetter LT headers LS1
  87. Wtb: Ls engine front suspension
  88. WTB LSX block
  89. Wtb lower shift boot
  90. WTB cc503 asap
  91. WTB 01 Firebird LS1 o2 simulators!
  92. WTB: 98+ WS6 hood
  93. wtb: 4th Gen parts CASH IN HAND!
  94. WTB: LS2 / LS6/ Comp 918 or Comparable springs and retainers
  95. WTB stock LS1 car valve covers
  96. WTB Auto Transmission
  97. WTB fbody front accessories
  98. Intake parts
  99. WTB Camaro Exterior Parts
  100. WTB: LS1 spark plug wires
  101. WTB 402 ls2, 427 ls2, ls7, shortblock maybe long block
  102. 69 Z28 Emblems
  103. WTB: front cover, pulley, exhaust. etc
  104. wtb: grinded calipers
  105. WTB: HVAC Control Knobs for 98-02 Trans Am
  106. Chrome TTII's
  107. red top injectors LT1 Camaro
  108. WTB Ebony Spare Tire Panel Lock Screws...MINT!!!
  109. trans cooling lines
  110. E-Brake set up for 4th gen LS1
  111. 4l60e 1994 lt1
  112. forged parts and other motor build parts
  113. wtb 90mm nitrous plate and driveshaft
  114. wtt 04 yfz 450 for ls1/t56 pullout
  115. LT1 Waterpump Drive
  116. WTB: Tail light center section, Tail lights, & Lower airbox assy.
  117. WTT Worked 317s FI head for a 243/799 heads
  118. Ss emblems
  119. need 60lb. injectors for an LS-2
  120. F-body ls1 oil pan needed badly!!
  121. WTB good crank
  122. ebony console, shift boot
  123. D585 Coil Kit
  124. AJE swap kmember, motor mounts,headers
  125. WTB 98-02 Firebird Drivers Side Headlight
  126. WTB: ls1 engine harness (manual)/pcm/coils
  127. A4 pedal assembly
  128. Wtb:15x10" alumastars or magnums...
  129. WTB '95 LT1 A4 engine harness
  130. wtb: coolant crossover tube
  131. WTB: GTO oil pan
  132. WTB CCW Rear? Drag Pack
  133. wanted bad ls1 block for mock up in the maryland area
  134. WTB: 224r cam/springs
  135. WTB: Lt1 accessory bracket and throttle body?
  136. Stock 98-02 F-body Harmonic Balancer
  137. Wanted posi and drive shaft
  138. WTB 3 Channel Axle Shaft in Texas
  139. ARP Headbolts, Stock vette balancer
  140. WTB: complete ls3 intake, used fbody oil pan complete
  141. looking for after market rear end
  142. suspension wanted asap qa1 lca php etc..
  143. WTB 1 Coil Pack, MAP Sensor, Coolant Crossover
  144. Wtb some parts for my 00 Trans AM
  145. LS6 springs
  146. WTB Oil Pan
  147. Looking for 243/LS6 heads
  148. WTB: LS1 AC compressor
  149. Need LT1 stepped headers
  150. Default WTB: ATI LS7 underdrive damper 918620U
  151. Looking for an LS1 ENGINE
  152. WANTED!! forged pistons 4.000 or bigger, performance rods, used!
  153. t56 swap complete!
  154. WTB- stock LT1 pistons
  155. wtb stock fbody oil pan w/pickup and MS3 cam
  156. procharger fan & shroud with hold down
  157. Set of Big and Littles... (15's) prostars ect...
  158. 2000 camaro ebony leather seat covers...
  159. WTB: SLP LS6 INTAKE - Cash in hand
  160. LS1 airfilter holder tray!!
  161. WTB Computer 12200411 Gen 3 R/B DBC
  162. 93-97 DS camaro front fender
  163. wtb supercharger kit
  164. Wtb f-body procharger parts
  165. WTB: 02 Trans Am Owners Manual---seat belt loo[p
  166. Want to buy some used TFS 220 as cast heads!!!
  167. Looking for LS1 front ground effects
  168. Want to buy 98-02 Camaro DS fender, front and rear bumper cover
  169. T76 or something equivilant....
  170. prokit springs
  171. Ls engine / trans
  172. motor clamshells wanted for fbody ls1
  173. Camaro SS Hood 1999-2002
  174. need driver's side camaro door panel switch cluster and frt speaker grills
  175. WTB Driver side Window Motor
  176. 9" or 12 bolt needed
  177. i need a trans am hood strut bracket that bolts to hood
  178. Wtb fast intake an tb
  179. cheap set of lt1 heads
  180. ls1 headers....PLEASE READ POST!!
  181. WTB: LT1 turbo setup or supercharger setup
  182. Front Bumper
  183. 2000 trans am rim.
  184. WTB 1 of the following wheels:
  185. Need A4 Shifter/Ebony Upper Console
  186. Single ARP bolt and stand bolts
  187. Ls1 Intake Gasket needed
  188. WTB 1 10 Spoke SS wheel!!
  189. WTB: Monsoon AMP bolts, Battery Hold Down, Rear Panel Screw
  190. wtb: lt4 engine
  191. 275/40/17 DRs wanted in SE MI
  192. WTB 98-02 10 bolt relocation brackets
  193. WTT- built 4L60E w 3600 conv for T56.. LS1
  194. WTB: Rear end - 12 bolt or 9 inch
  195. WTB Passenger side front fender and ground effects for 2000 T/A
  196. wtb: 3in. cutout, 93-96 dash pad, auto top console
  197. WTB nitrous switch panel
  198. WTB: WS6 lower airbox
  199. WTB: Pewter T/A body parts
  200. WTB: Headlight motors
  201. WTB: shift knob
  202. 93-02 camaro driverside 1/4 panel body moulding
  203. wtb 3rd gen parts
  204. 95 camaro foward wiring harness
  205. Need 99-up LS1 Coils and brackets
  206. Handheld tuner
  207. WTB 4l60e for ls1
  208. WTB: SLP Dual/Dual over the axle pipe
  209. WTB: F-body/GTO underdrive pulley
  210. WTB: LS3 Fuel Rail
  211. need 95 camaro throttle cable and y-pipe
  212. WTB: 2004 GTO AC Evaporator Tube
  213. wtb:water pump tensioner for ls1 and lt1 m6 crossmember
  214. wtb:t56 tail housing asap!!!
  215. WTB: ls1 m6 radiator
  216. GTO procharger parts
  217. Need A Set Of 1.8 Rockers!!!!
  218. WTB: Trans Am Tail lights and ebony door panels..
  219. WTB 98 Valve Covers
  220. WTB - LS2 bare block
  221. seats
  222. Needed: Stock ls1 camaro crank pulley asap!!
  223. wtb: Wheels (19x11) for fbody
  224. Broken, worn, tired T56 Transmission WANTED
  225. WTB: Stock '96-99 SS wheels (ZR1 style)
  226. WTB: SLP dual dual cat back (or muffler) from 345hp package
  227. WTB: Wilwood brakes
  228. WTB: OEM LT1 SS Camaro hood
  229. Chevy Monza
  230. Wtb line lock
  231. WTB: 2003 Grand Prix chrome rims
  232. WTB LS1 bare block!
  233. WTB: Adjustable shocks and gears
  234. WTB: 9" parts
  235. WTB: Dash, Dash Pad, and Steering Wheel Air Bag
  236. Wtb 99-02 harness and pcm auto
  237. Convertible Top Boot Cover
  238. Need a dbw pedal cable, 03-05 truck/tahoe/yukon
  239. LS1 engine *any shape* T56
  240. lt1 ss hood
  241. Wtb headers, cam, springs, lid, and exh for ls1 fbody!
  242. WTB set of injectors good to 500rwhp
  243. WTB good set of heads for 383 stroker
  244. WTB 97 - 02 Camaro dash and 97 Z28 gauge cluster
  245. WTB Freedom Designs spoiler
  246. WTB - GTO oil pan
  247. Wtb: Ash tray for 99 t/a
  248. WTB: C5 Corvette Tensioner Pulley
  249. WTB: 02-04 LS6 factory cam (Corvette Z06 or Cadillac CTS-V)
  250. WTB: O2 Sensor Simulators for 03 Silverado
