View Full Version : Parts Wanted
  1. need 7.4 pushrods and cam swap gasket kit
  2. WTB: 01-02 Style Camaro driver airbag
  3. WTB Firehawk Front Hood Vents & Firebird Dash Pad
  4. 3rd gen Tail lights
  5. WTB: LQ4/LQ9 with 4L80e in NJ area - as complete as possible
  6. Mild aftermarket cam 3 bolt
  7. wtb c5 up brakes
  8. WTB 98-up forumla turn-running lights
  9. need an ecm
  10. WTB ws6 air box radiator support
  11. Wtb: T-top insets and trans am front bumper insert possibly in red
  12. WANTED: Aftermarket 6.5'' speakers
  13. WTB: 90mm cable throttle body
  14. f-body rims
  15. LT1 ECU needed
  16. Anyone got a junk worn out POS...
  17. WTB Blackwing Air Lid
  18. WTB lh8 or fbody oil pan, front acces, starter
  19. WTB lh8 or fbody oil pan, front acces, starter
  20. Bfg kdw i 275/40/17
  21. WTB Under drive pulley...
  22. NTB 100% stock 98-02 wiring harness
  23. WTB/WTT Titanium retainers for Beehive springs
  24. WTB Stock lt1 24lb injectors
  25. Wtb FAST intake!
  26. wtb Intermediate Steering Shaft must be off a 1998-2002 ls1 f-body!
  27. WTB: 93-96 Camaro Tail Light (driver side)
  28. WTB UMI SFC's
  29. Wtb d1sc pro charger kit asap!!!
  30. WTB: Heads
  31. WTB LS1 F Dipstick & Stock Injectors
  32. wtb: 98-02 firebird/trans am driver headlight
  33. WTB: Centercaps for 35th Anniv Rims
  34. 20x10 Boyd coddington slayers for sale less than 1000 miles
  35. WTT mint blue NOS 10lb bottle for your black 10lb bottle
  36. wtb ls1 manual belt tensioner
  37. WTB 93-97 Supercharger kit or Turbo kit
  38. 85mm MAF screen?
  39. WTB 97-98 C5 fuel rail
  40. Wtb slp resonators
  41. WTB: 98+mm lid, 85+mm MAF
  42. WTB: Camaro/Firebird A4 Upper Center Console
  43. WTB: LM-1 or LM-2 Innovative Wideband
  44. WTB - Centerbolt Valve Covers
  45. WTB: Camaro SS floormats and SLP SS grille
  46. Need a4 Shifter and center console shifter bezel
  47. LT1 Intake Components
  48. delete
  49. WTB Hood
  50. Looking for lt1 th350 crossmember.
  51. WTB Black & Chrome Torque Thrust 2 wheels
  52. Looking for 1 7/8 or some stepped headers.
  53. WTB stock ls1 28# injectors
  54. WTB LS6 or LS2 BARE BLOCK in Pennsylvania or surrounding states
  55. 98-02 DRIVERS SIDE Camaro hood hinge (red)
  56. WTB LS6 Z06 Cam Springs Pushrods
  57. Seat Belts
  58. Wtb ac compressor for 98 z28
  59. WTB ls2/ls3 timing cover with sensor
  60. WTB: GEN-TTR Twin Turbo Kit F-Body
  61. 98 ac compressor
  62. WTB: LS6 Intake
  63. WTB LS1 or LS6 short-block
  64. AC Compressor and F-Body Alternator
  65. WTB: LS1 Motor mounts/TA/Camaro"Clamshells"
  66. LT1 Trans Am Power Antenna
  67. WTB tial 38mm wastegate/ 60-65# injectors!
  68. WTB: flexplate bolts, 4L60E bellhousing bolts, torque converter
  69. WTB lower airbox. Non-WS6.
  70. WTB: 98-02 firebird tail light
  71. wtb powers steering pump mounting bracket and bolts
  72. WTB: Trex
  73. Wtb!! Black c6 zo6 rims in any size would prefer with red pin stripe on lip
  74. 9" 3.00 gears
  75. 98-2002 drivers side spindle
  76. need a foward wiring harness
  77. WTB: 99-02 Trans am engine harness A4
  78. WTB: Good condition LS1 crankshaft
  79. Driveshaft
  80. WTB: LT1 style Z28 155 MPH Cluster
  81. wtb: air lid
  82. 4TH Gen camaro/firebird leather seats
  83. wtb LT1 pistons and rods crank
  84. a4 shift cable for 98-02 camaro
  85. WTB: Y3F / RS rear bumper valance
  86. WTB: Center console 2000+ camaro
  87. WTB Block
  88. WTB: LS1 parts asap!!!
  89. WTB ZR1's 17x9.5 17x11
  90. Need a headlight for my 95 Camaro Z28.
  91. WTB: 3000 to 3500 RPM Stall Converter for 98 Trans Am
  92. Wtb: Built t56
  93. LOOKING FOR LT1 58mm THROTTLE BODY
  94. Looking for 4l60e trans (lt1)
  95. WTB or trade: TNT 78mm Power ring
  96. nitrous kit
  97. WTB ls1 bare block
  98. WTB: 98/02 Firehawk Hood Screens
  99. wtb ac compressor low miles
  100. WTB E40 PCM for 05 GTO
  101. moser 12 bolt girdled axle cover
  102. wtb: stock 1994 lt1 timing cover?
  103. lookin for t56
  104. mac catted y
  105. Wtb 98-02 t/a sunvisors door panels
  106. wtb complete 5.3 pullout
  107. wiring harness and ECU
  108. WTB: Nitrous Controller or Window Switch with TPS
  109. WTB SLP Dual duals or GMMG Axle back system
  110. f body coolant lines all of them
  111. 21mm or 22mm Rear Swaybar
  112. WTB: 18" wheels/tires
  113. WTB: 98-02 1" Rear Lowering Springs
  114. WTB 99-02 M6 wiring harness
  115. WTB: LS2/LS3 Block... or complete motor
  116. wtb-98-02 camaro headlight lenses or headlights
  117. Wtb: Ls1 t56
  118. WTB: 1998 1999 Cruise/Throttle cables off of Non-TCS car
  119. WTB: Ls1 98-02 Engine Clamshell Mounts + T56 Rubber Shift Boot
  120. WTB forged Rotating assembly LS1-CASH-
  121. WTB: LS1 Camaro/ Firebird Accessory Brakets
  122. Wtb: sensors, timing chain, ls2 and ls3 stuff
  123. stock ls1 oil pan
  124. motor mount bolts
  125. WTB: 01-02 LS1 28LB Stock Injectors
  126. Do you have broken 98-02 Firebird/TA front fenders?
  127. wtb 65# injectors asap
  128. WTB Procharger D1SC 8 rib pulley
  129. WTT-WTS like new meaga death cam for another cam
  130. WTB forged motor for boost
  131. WTB: Turbo LQ4 cam
  132. WTB: Ls6 Valley Cover
  133. 98-02 Trans Am Crank Pulley
  134. wtb rear shocks and le2 heads. IT'S MY BIRTHDAY HELP ME OUT!!
  135. 98-02 Trans Am Power Steering Pump & Pulley
  136. Need a set of low mileage DeCarbon shocks (front)
  137. Wtb - LS6 cam
  138. WTB: TA LS1 AC Compressor
  139. WTB 2000-2002 Camaro ECU
  140. WTB Mono blade TB and other parts
  141. Wtb 98-02 t/a sunvisor
  142. WTB FAST LS1 Fuel Rail Kit w/fittings
  143. LT1 oil pan bolts
  144. WTB o2 sensor extensions
  145. Wtb exhaust
  146. WTB 18in chrome tsw, ruff, rpm rims
  147. Wtb ls1 t56
  148. raptor hood
  149. Parts
  150. WTB Lots of LS1 and F Body Parts!
  151. wtb stock tensioner air and egr, rear lca
  152. W T B: Stock 4th Gen F-body REAR calipers (pair)
  153. Wtb afr 225 heads
  154. WTB-GMPP single plane intake with efi
  155. WTB: Stock Camaro hood in the New England area
  156. WTB: 98-02 front right RS Y3F GFX
  157. WTB: Engine stand
  158. WTB: 12 Bolt
  159. looking for a Zexel-Torsen Paddle
  160. WTB ASA cam
  161. i need some stock front strut parts asap
  162. LS1 alternator bracket
  163. Wtb complete 4l60e set up
  164. WTB: T76 or larger
  165. WTB: Autometer Cobalt
  166. WTB MonSoon Deck 00-02 preferred!
  167. WTB a set of sunvisors and ash tray cover
  168. Cash in hand need black passenger door and Driver side A piller
  169. WTB: 98-02 Trans Am Front Bumper Cover
  170. Need the 10308-16 Crane Spring kit quick!
  171. WTB lowering springs cash in hand
  172. wtb: AFR, Trick Flow, All Pro, aftermarket heads!!
  173. WTB: 78mm nitrous plate
  174. HI fellow ls1techers I need a set of pedestal mounts.
  175. WTB: stock 10 bolt 3 channel rearend
  176. Firebird / TA passenger side head light assembly
  177. need driver side ttop for 96 trans am
  178. Looking for hp tuners pro
  179. WTB: 98 or 97 LS1 PCM - $125
  180. WTB: 98+ ls1 a/c compressor
  181. wtb: pair of mufflers for dual setup
  182. SLP HO Hood
  183. WTB TA firebird front fiberglass bumper support pic inside
  184. Wtb horn
  185. Wiper Blade Arms
  186. hot side pipes for turbo setup wanted.
  187. Wtb
  188. fuel cell, 9 inch, and racing seats
  189. Need rear end parts donated, 00 WS6 (OE 10-bolt)
  190. WTB 7.350" hardened pushrods
  191. WTB: Front, lower and upper a-arms......
  192. WTB: Tranny cooler w/ elec. fan...ne brand
  193. WTB wheels with tires
  194. wtb; stock ls1 t56 shifter
  195. ls1 t56 bellhousing
  196. WTB: Backing plates
  197. 455 short block
  198. ls1 headlight switch
  199. wtb ls1 block
  200. Vette Wagon wheels
  201. wtb bilstein shocks
  202. WTB: LS2 or LS3 block
  203. WTB: 99 Camaro fuel pump assembly
  204. looking for a 3200-3400 stall
  205. WTB ls1 fbody t56 shift selector block and cup
  206. WTB Stall Converter 3000 + For LT1 !!!
  207. WTB MSD 8876 Wiring harness
  208. WTB Engine harness and ECM for LS3
  209. Need a Stock LS1 Crank- No Spun Bearings
  210. WTB: Stock RearEnd in Kansas
  211. trade my stalled for your six speed.
  212. ISO Fast Intake manifold
  213. Wtb Headlight motor and window motor.
  214. WTB: Windage tray nuts and pickup-tube bolt
  215. LT1 Cooling Fans/Radiator
  216. WTB tires that fit 18x10.5 rims
  217. WTB: LT1 A/C Parts...
  218. Wtb msd 6010
  219. WTB ashtray door
  220. WTB Air Lid and Base, Dash Pad, Fuse Door
  221. WTB fast 90 intake for use with 4 bolt tb
  222. wtb slicks
  223. WTB: LS1/4L60E Aluminum Driveshaft & Yoke
  224. lookig for nasty performance gas tank with sender
  225. WTB Clam shell bracket for the F-Body torqu arm
  226. wtb: 2800-3400 lock up stall converter
  227. WTB Trans Cooler new in box only
  228. WTB: LS1 Oil Pan
  229. WTB: LS6 Intake and Black TTM's
  230. wtb 700r4 setup for f-body
  231. <<WTB>> DBW pedal assembly with connector and pigtail
  232. Wtb: 5.3l
  233. WTB: Complete LS1 Intake
  234. wtb: d1sc headunit
  235. WTB. 92mm drive by cable TB
  236. Wtb tsp 228r
  237. pewter body parts
  238. WTB lq4 or lq9 short block or long block
  239. WTB TSP True Duals: Who's got some?
  240. WTB C5 Brake Conversion
  241. WTB D585 truck coils, brackets and harness
  242. Flex a lite fans
  243. WTB-Panchard Bar & SFC's
  244. Eboost2
  245. need 4l60e planetaries ASAP
  246. Bell Housing for LS1 T56 (Trans Am)
  247. WTB: silverado cats
  248. WTB 99-02 Ls1/T56 Engine Harness
  249. Need a standalone fuel system for my nitrous
  250. looking for ls1 f-body passenger steering knuckle
