View Full Version : Parts Wanted
  1. Wanted - SLP CME Elbow
  2. misc. LS1 parts needed for a swap
  3. wtb suspension stuff, nitrous, ls parts etc
  4. wtb ls6 intake w/ egr
  5. WTB-Nitrous parts
  6. LSX DBW TAC module harness needed
  7. 1994 Firebird Switch Bezels
  8. UMI Front Solid Sway Bar
  9. WTB a set Of TFS 215 Or TEA 2.0's Or other well worked heads
  10. WTB. 85MM MAF, and a few sensors ... LS1
  11. WTB 4 channel factory 10 bolt (South Carolina)
  12. WTB: T-56 99-02 F-body or GTO
  13. set of patriot gold spring
  14. Looking for LS1 MAC Y-pipe
  15. headrests
  16. WTB ls2 ls3 ls7 t-body for corvette/ctsv/gto
  17. Wtb FAST 78
  18. Firebird W68 V6 ground effects
  19. Need: LS1/2 Fuel Rail Covers
  20. Wtb iac
  21. WTB: Kooks LTs and Catted Y
  22. wtb built 60e or 80e
  23. lt1 6speed trans
  24. wtb: ASAP! FUEL RAILS, DANBURY CT/NYC AREA
  25. wtt a4 harness, for an m6
  26. wtb cutout
  27. WTB 28 lb injectors
  28. WTB- LS7 Block
  29. WTB: Fast 92mm/NW 92mm TB!!!
  30. WTB. c5 corvette parts
  31. LS1/4L60E Converter 3600-4000 stall...
  32. WTB cheap wideband for portable tuning
  33. Need an IAT sensor & grommet that goes in the lid!!!!
  34. WTB 1 Inch Valve Cover spacers for aftermarket Roller Rockers
  35. WTB: TR230 Cam
  36. 17x10.5 Torq Thrust Ms | 3" Elec. Cutout | Stock Catback
  37. WTB: Center Console door
  38. WTB: 799s or 243s
  39. wanted: tb sensors
  40. WTB LT1 flywheel for T56
  41. WTB: LT1 Tubular K Member
  42. Wtb 1998 auto ls1 chevy camaro pcm
  43. 24x reluctor wheel need it now
  44. WTB 42# injectors, IAC valve
  45. knock sensor harness
  46. Wtb: 98 ls1 ecm
  47. WTB: n20 remote bottle opener, and a couple of noids.
  48. WTB: intake
  49. WTB: Cam or Cam Kit
  50. WTB:98-02 Stock TA Parts
  51. SLP 85mm MAF
  52. WTB: HP Tuners Pro
  53. wtb front wheels for 75 vette
  54. **wtb:ported heads,nos kit & underdrive pulley**
  55. ws6 wheel and center caps!!!!
  56. WTB: B&M shifter 16mm jam nut for t56
  57. WTB: Headlights 98+ Camaro
  58. WTB: rear 02 sims for 2000 camaro ss
  59. DRL module for 99 T/A needed
  60. drag wheels n tires
  61. Ls-1 or LS-2 engine wanted
  62. forged pistons&rods or built short block
  63. WTB: 98-02 Camaro Seats
  64. WTB 98-02 Camaro taillights
  65. alternator pulley
  66. WTB: 90mm throttle body
  67. Wtb: Gm 5.3l
  68. Need some suspension parts!!
  69. WTB: LS1/LS6 Intake
  70. WTB: 10 bolt rear
  71. WTB: Catback
  72. wtb aem fuel pressure gauge
  73. Wtb: ls1/vortec starter
  74. wtb-ls heads
  75. wtb front DRL/turn signal lenses for 98-02 trans am
  76. WANTED: LID, LCAs, reloc. brackets
  77. WTB-----98-02 trans am front bumper cover OEM,chicago
  78. WTB NX Style Nitrous Jets
  79. WTB: Short block or complete engine
  80. WTB LS3 Engine Parts
  81. wtb drivers side window motor
  82. WTB headliner for T-top car
  83. Stealth Cam, CheaTR cam, or the like
  84. Parts needed for a 2000 v/8 trans am
  85. LS1 Rear Calipers and Abutment Brackets Wanted
  86. WTB: Ls1 air lid
  87. WTB: 02 Simulators
  88. WTB Chrome ZR1s
  89. Ls6/ls7 clutch kit w/flywheel
  90. WTB f body exhaust manifolds 01-02 preferably
  91. WTB: #42 INJECTORS, Yella 1.7 ROCKERS, DOUBLE ROLLER TIMMING CHAIN, C6 Z06 chrome
  92. Need A/C line, from top condenser to firewall
  93. Trans Mount
  94. WTB exhaust borla, gmmg, corsa
  95. 17x4.5 (5x4.5 LUG) Weld Alumastar 2.0 front runners
  96. Wtt rims
  97. WTB - T56 lsx
  98. WTB: Complete lsx T56 w/bellhousing/shifter
  99. Need Two 17" C5 Y2K rims
  100. Ground effects for '00 camaro
  101. TT wheels + tires ..
  102. Need P/S Fender for 93-97 Z28
  103. Wanted: Vortech supercharger
  104. Wanted: stock tranny lines for 4th gen camaro
  105. WTB walbro 255 gsl392 pump NEW
  106. Trans Am Stuff
  107. reluctor rings
  108. wtb low mile 243 heads.
  109. looking for stock ls1 car manifolds 98/99
  110. Need parts ! ASAP PLEASE !
  111. WTB/ Cam, pushrods, and springs
  112. stealth sub box wanted jl would be nice pm me billlyb.
  113. WTB: Camaro SS Car Cover, Camaro SS Floor Mats
  114. Need asap
  115. WTB A/C stuff
  116. wtb: 32mm front 1le/ws6 sway bar
  117. WTB: T56 swap
  118. WTB passenger side honeycomb taillight
  119. Torsen posi unit.
  120. WTB Strano Springs, FAST 102mm TB, Koni SA Shocks (Front & Rear)
  121. WTB clutch fluid reservoir (98+)
  122. **WTB** LS1 Short Block/3.9xx pistons
  123. wtb pushrods
  124. WTB: Mufflex 4" catback
  125. looking for a complete stock ls1.
  126. Need Power Antenna
  127. WTB: 12 bolt
  128. WTB: LS1 Electric Fans
  129. K&N FIPK CAI for 3.4/LT1
  130. Wtb 2000 a4 ls1 pcm
  131. WTB flexplate, arp rod bolts, melling oil pump, ect.
  132. WTB: EBONY camaro door panels/interior parts
  133. WTB kb bap
  134. WTB: Underdrive pulley for F body LS1
  135. Wtb stall converter
  136. WTB: Long tubes/ off road x for my 04 GTO
  137. WTB: used 4l80e
  138. rear wanted
  139. High Imp. 80+ lb/hr injectors
  140. WTB 1 7/8's and 104 mm lid
  141. WTB hood and spoiler for lt1
  142. WTB: 2000 Camaro Arm rest/console lid
  143. WTB: l92 or ls3 clean undamaged bare block
  144. fikse fm 10 17x9.5 17x11
  145. >WTB: (1) OEM Monsoon sail panel speaker
  146. want to buy a set of arp rod bolts
  147. WTB. LS3 block or short block
  148. WTB stroker LS for boost
  149. 18x9.5 chrome rims, ruff/tsw or rpm
  150. WTB: 5.3L Block
  151. WTB/WTT: Driver and Pass. Headlight Assembly
  152. WTB: 93-97 Trans am side gfx, and inner wheel plastic
  153. Camaro SS Portfolio
  154. WTB: F-Body oil pan and 36-39lb injectors
  155. WTB: Sodium Filled Exhaust Valves
  156. WTB LS1 radiator support also lid
  157. WTB:WTT LCA's SLP or MTI Lids
  158. Wanted single junk head
  159. WTB: Lid for 02 Camaro
  160. WTB Ashtray Cover
  161. LT1 parts. Clutch/ARP/Head gaskets.
  162. WTB 2 Callies Compstar rods for LS1
  163. WTB: LS1 FBODY Front Drive Accessories
  164. Wtt!
  165. WTB: ONE Nitto 555R 275/40/17
  166. WTB: LS6 manifold and TB
  167. WTB Moser 12 bolt or 9"
  168. WTB: Rear tail panel " Berger "
  169. Looking for Ebrake actuators LS1 rear
  170. Rear LS1 Caliper Abutment Brackets needed, and pads
  171. Want to buy: Stock LS1 Camaro springs, local to Indianapolis
  172. WTB- 4 Chrome 16" Factory Pontiac Wheels
  173. WTB: Coilovers; QA1 or Strange
  174. Wtb asap!!!!!
  175. WTB: Power Antenna and Driver Side Mirror
  176. WTB: 01-02 ebony trans am vent
  177. WTB: LT4 Hotcam, CC503, CC305, or similar cam
  178. WTB ws6 or zr1 wheels near WV
  179. need stock LS1 rods and pistons
  180. ground down caliper brackets
  181. WTB LS1 Main Stud Kit
  182. WTB: SLP Grill
  183. WTB Stock F Body Fuel Lines
  184. WANTED - LS3/6L80e combo
  185. WTB: Ls1 lower air box (part where lid sits)
  186. WTB: Katech or ARP High Performance rod bolts
  187. WTB Fast 78/90 Damaged or Cracked OK
  188. WTB: Fbody motor mounts
  189. WTB Numerous Parts
  190. WTB: 4L80e converter, head studs
  191. WTB: LS1 Timing Tuner
  192. NTB Antenna sembly..
  193. WTB 4L60e
  194. WTB: HPTuners Pro
  195. WTB: Tires, Front Bumper, Upper Dash
  196. WTB - LS1/LS6 Injector locking clips
  197. Z06 cam
  198. NEEDED: Clutch master cylinder MC reservoir cap
  199. I Need Intake Bolts & F Body Dipstick
  200. WTB- LS7 Lifters, LS6 Cam, LS1 F/R Main seals, ARP main bolts
  201. wtb ls1 coil brackets/harness
  202. wtb any diagnostics tool that reads realtime sensor values
  203. Stock Ls2 header
  204. Ls1 power steering Reservoir
  205. WTB: Fuel Rails ASAP
  206. ls2 tb needed and front acc drive brackets short oil fill tube
  207. WTB: Rear driver side panel
  208. WTB coil pack brackets for LS6 heads
  209. WTB: Parts for mustang swap
  210. WTB: Intake bbk,weiand or typhoon,ls6 & Hoosier 315 Drag radials
  211. WTB/WTT for LS2 or LS3 block
  212. wtb:good stock throttle body
  213. WTB : Your Used LSX Cam!
  214. WTB: 82-02 Fuel relief valve
  215. WTB ls2 throttle body
  216. WTB: WS6 or WS9 hood/INTAKE/TB/Y2K DD 18" wheels
  217. WTB: ZR1 17X11 Silver wheels GS Offset!
  218. Fog lights
  219. WTB Cam and stock stuff
  220. WTB Stand alone dedicated fuel system
  221. WTB: stock injectors 26 or 28.8, plug wires, tb non-dbw
  222. HP tuners & wideband
  223. Stock 98-02 Z28 Emblem
  224. WTD: SLP strut tower brace
  225. WTB: Intake coupler
  226. WTB LS6 Intake # 12573572 Corvette
  227. NEED MIRROR BRACKET (drivers)
  228. WTB Differential (Auburn, Torsen, Eaton)
  229. WTB aftermarket torque arm for 2000 Camaro SS
  230. Wtb: Ls1/lq4/lq9
  231. 373 gears
  232. WTB: automatic trans. parts
  233. WTB: Edelbrock Pro-Flow XT Ls1 intake
  234. wtb 04+ arp head bolts!
  235. WTB C5 Z06 Red Fuel Rail Covers
  236. need to buy some ls1 parts
  237. NJ: WTB: LT1 intake, 4th gen black & grey seats, TPI performance parts
  238. WTB: Drivers Side Headlight Assembly and Fog Light
  239. WTB: Short block
  240. WTB: broken or damaged tails T/A
  241. WTB: List of OE and Aftermarket LT1 Z Parts
  242. WTB FAST 90/90 setup and 42lb injectors
  243. WTB: 99+ valve covers, coil brackets, bolts
  244. WTB: Drag brakes for Ford 9"
  245. Wtb. F-body oil pan...
  246. 60lb ls1 injectors needed
  247. qa1 coilovers
  248. WTB!!! front shock/strut rubber top mounts 98-02 fbody
  249. WTB 98-02 camaro rear side markers
  250. WTB: Grey 97+ Manual Firebird Console
