View Full Version : Parts Wanted
  1. WTB: Magnaflow #14267 Muffler.
  2. WTB Weld Pro Stars
  3. WTB: LS2 Fuel Rail
  4. WANTED: 3800-4200 stall 200r4 / 6.0 ls
  5. wtb: 98-02 camaro passanger headlight
  6. WTB: LT1 T56 clutch fork
  7. WTB 95 ICM/Coil
  8. wtb motor
  9. WTB: Mid or Long tube headers and SLP style airlid
  10. WTB: LS1 coil packs,coil harness, and coil bracket
  11. wanted to trade: need 98 ls1 pcm serv no 16238212, HAVE 99-00 09354896
  12. 98 Z28 center console lid
  13. ls1 brackets
  14. bosch 1311's
  15. Spare tire assmb. + jack nj/ny/pa
  16. Wtb lt1 t56
  17. Need My T-56 Fixed!!!
  18. 2001 6.0L Truck Rear O2 Sensors
  19. WTB Aftermarket or Ported Heads for 5.3L
  20. WTB:LT1 headers
  21. wtb: l92/l99/ls3 bare block
  22. 3500 stall wanted
  23. WTB: Camaro Stainless Steel berger panel inserts
  24. FAST ported 90 or 92/super sucker ram air
  25. WTB: PT88 turbo
  26. Adjustable flasher
  27. WTB Windshield Wiper Motor Rubber Feet
  28. WTB shortblock or longblock
  29. WT: stock manifolds to fit 2001 LS1
  30. WTB: Gears/headers/LT1 parts
  31. WTB: MAC LS1 headers
  32. WTB Procharger Head Unit only
  33. WTB OEM '98 - '02 SS Spoiler
  34. WTB: .650" Valvesprings
  35. WTB T56 for LT1
  36. WTB: Stock 10 bolt, 3-channel, 3.23 gear or bigger
  37. WTB LS6 Intake
  38. WTB.... Morel Link bar lifters.. ARP Head Studs "04"+
  39. WTB: 17x9/11" TT2s
  40. Looking for a turbo cam LS1/LS6
  41. WTB: 6.0 lq9
  42. WTB stock ls1 pistons
  43. WTB: LT1 Camaro Taillights.
  44. WTB: 3.73 or 3.90 Gears and install kit for my stock 10 bolt
  45. WTB: SS hood scoop insert
  46. WTB head/cam combo, ls6 intake, mgw, suspension parts and more, sell your stuff!---->
  47. ~needed aluminunm driveshaft ls1~
  48. wtb keyless entry remote
  49. wtt magnaflow quad tip for gmmg
  50. WTB: Z06 cam shaft
  51. corvette or f-body accessories
  52. WTB: GMPP ASA Camshaft part#12480110
  53. WTB LS1 solid tensioner
  54. WTB: LT1 Pacesetter ORY for long tubes
  55. Anyone....
  56. wtb-Slp Line-lock
  57. wtb used typhoon polished 96
  58. WTB: Ported LS6 heads
  59. WTB ported ls6 intake
  60. WTB:04 Blk.Front sheet metal and Engine stuff...
  61. looking for a 4l80e core
  62. WTB: BFG G-Force T/A KDW Tire
  63. WTB Coil Packs
  64. LS2/3 Timing Cover
  65. parts needed
  66. WTB ls3/ls7 stock injectors.
  67. [WTB] Torque Conv. / Flexplate bolts, trans dipstick, trans mount etc.
  68. 99-02 ls1 ecu
  69. headlights stealth sub box corners and side markers
  70. WTB ORY-pipe
  71. WTB v6 camaro title
  72. WTB: LT1/4 4 bolt block (Stock/Untouched)
  73. ls1 alt
  74. WTB BMR Kmember/a-arms
  75. Needed! 1 wiseco gfx napier 2nd ring 3.905
  76. WTB: 4L80E aftermarket torque converter
  77. WTB: Stock WS6 Rims
  78. WTB like new condition Billet grill 98-02 camaro
  79. GTO A/C Compressor and bracket
  80. WTB: 98-99 ported throttle body!
  81. WTB: Meziere Heater Plugs
  82. WTB '94/95 T56 LT1 engine harness ASAP
  83. SS brake line for 98-02 T/A
  84. WTB: SLP cats
  85. WTB: Driver side 98+ camaro taillight.
  86. WTB: ls2 longblock any price any milage let me know!!
  87. WTB:lower air box and baffle
  88. WTB LS2 shortblock
  89. LS2/3 Valley Cover
  90. WTB: Bottle heater with all wiring.
  91. WTB: LS6 intake
  92. bolts
  93. WTB: Ford 9" Gears 4.30, and 31 Spline Spool
  94. wanted , YANK SS3600 converter
  95. fs New NX automatic bottle heater
  96. WTB: C210 connector from LT1 f-body
  97. I news some ls1 backing plates and caliper brackets asap!!
  98. Need ls1 backing plates and caliper brackets asap!!
  99. Lower Control Arms
  100. WTB: 97/98 LS1 PCMs
  101. 98-02 Dash pad
  102. WTB LS2 cable throttle body
  103. wtt chrome dd c5
  104. wtb aftermarket throttle body and drivers seat
  105. 98-02 Camaro left side rear quarter panel exterior
  106. Ls1 Dipstick
  107. WTB: Vinci/crane handheld tuner for 98 Camaro
  108. WTB: aftermarket adjustable panhard bar
  109. WTB: LS1 F-body oil pan, tray, pickup tube
  110. WTB:aftermarket t56 bell housing
  111. wtt- magic stick-4 cam
  112. Stock front o2 sensors
  113. WTB: LS1 Oil pan Pickup Tube
  114. Want to buy: Ported throttle body for LS1 f-body
  115. I want to buy a sts turbo kit or procharger must be in perfect working order
  116. Looking for a ls1 throttle body spacer plate!!!!
  117. I need 4.070 pistons 4 my LS3
  118. Gears for 68 Camaro
  119. ls1 Fuel rail.
  120. WTB used 6spd reverse lockout solenoid
  121. WTB: Adjustable Shift Light
  122. WTB: Spohn Solid Motor Mounts
  123. WS6 hood
  124. WTB: LS1 T56 working or rebuildable
  125. WTB: 2002 or similar stock manifold/header bolts
  126. WTB: Reichard Racing D1sc 8-rib Blower Pulley, 3.55"-3.65"
  127. WTB: Turbo friendly cam
  128. WTB:LS1 Throttle cable and bracket
  129. LT1 STS Kit
  130. looking for fast intake and tb!!..and injectors!!
  131. Looking for some rear shocks to buy or trade toward my penske 7500's (rear)
  132. WTB 2 17x9" ws6 wheels
  133. Wtb set of morels mech/hyd, and tbss intake/tb/rails
  134. Want a cam that loves n2o
  135. 78mm nitrous plate
  136. WTB: TR224 Camshaft.
  137. TT2's
  138. wtb stock ls6 heads and 3000rpm stall
  139. WTB Chrome Trans Am 16" Wheel
  140. WTB full set of 98-02 Fbody calipers and brackets
  141. WTB A4 console for 98-99 Camaro
  142. WTB 98-02 12 bolt or 9" rear end
  143. 3 series 12bolt lsd!!!
  144. prc double valve springs needed anyone have them?
  145. Wtb: Weld pro stars 15x10
  146. L76 injectors ev1 to ev6 connector and bolts to mount fuel rail on 76 intake
  147. WTB: Windshield Wiper Linkage, Part out people, look
  148. WTB: 98-02 Firebird Monsoor Door Speaker RH
  149. Clutch Disk worn out is ok
  150. WTB: Built th400
  151. lt1 parts wanted Ram air box, electric wp, ud pulley ect.
  152. WTT: built 4l60e / edge 3800 converter for t-56 set up
  153. Need 4 channel stock rear
  154. 9'/12 bolt
  155. Needing a Dash.
  156. WTB: LC-1 Wideband
  157. WTB: Stock Ebony Floor Mats for Camaro
  158. Acura cl parts needed
  159. Wanted c5 magnaflow exhaust tips
  160. WTB: LS1 or LS6 short block
  161. Torquer V2/V3, MS3/4, F13, 224R, 228R Cams Wanted
  162. WTB: Ls6 Short Block
  163. WTB: 04+ CTS-V Rear Calipers
  164. ls1 efi vitoor jr set up
  165. WTB: fuel pump
  166. Looking for antenna
  167. Wanted: Foam back rest for 00 Camaro new or VERY good used.
  168. Wtb 9 inch 93-97
  169. wtb 93-97 TUBULAR PARTS
  170. Wtb steering wheel 98-02
  171. Procharger P1SC headunit
  172. ARP Head Studs & Main Studs, LS1 Carb Intake, Meziere Pump, etc
  173. WTB Borla plates
  174. WTB wheels....
  175. WTT or Sale Z06 wheels/ 241's/ tools for......
  176. Black Firebird Rear Hatch in MI
  177. wtb 9 inch center section
  178. WTB: True duals or magnaflow catback
  179. wtb: fuel tank lines
  180. WTB- Detroit Locker for my 10 bolt
  181. injectors needed
  182. WTB: Ls2 Valley Cover
  183. wtb
  184. Wanted asap 350turbo for lt1
  185. WTB: Camaro T56 Shift Block / Lever
  186. wtb lt1 longtube headers and y pipe
  187. WTB: LS1 manifold
  188. WTT Stainless Steel Borla Adj. Cat Back for SLP Dual/Dual in FL
  189. LS6 Heads 243 castings
  190. Rocker assembly tie bar
  191. looking for a 9"
  192. need lindy cutting tools 2.08/1.6
  193. WTB: LS1 or LS2 corvette, oil pan
  194. WTB Cam swap parts
  195. wtb 98 gray dash
  196. WTB: driveshaft for TH400
  197. wtb ls2 vett fuel rail covers
  198. TH350/TH400 4000+ stall, SBC or LS1
  199. lt1 fuel pump
  200. f-body oil pan
  201. I need parts for my 81 Olds Sport Omega
  202. LS1 PCV Catch Can
  203. WTB 97 Z28 speedo/cluster
  204. WTB: Trans Am DRL Lamps
  205. WTB 98+SLP SS SPOILER no aftermarket
  206. WTB: 90mm DBW throttle body
  207. WTB: Ebrake Assembly
  208. WTB: valve spring compressor
  209. WTB LT1 performance parts, springs, cash in hand
  210. Looking for C5 rear calipers
  211. WTB: ls6 style coolant lines
  212. WTB Bassani exhaust..
  213. WTB: Silver GM ZR1's
  214. 6MM Wheel spacer X2
  215. need stock 6.2L parts asap!!!
  216. ws6 short stick
  217. Why isnt the for sale posting section working???
  218. WTB: LS6 intake and 25% pulley
  219. WTB 90mm Nitrous outlet Plate
  220. WTB: Upper radiator hose w/o ps cooler
  221. Berger Panel, ebony radio bezel, and ebony pass ac vent
  222. WTB plug n play injectors
  223. WTB: LS1 Stroker Cam, lifters, head gaskets
  224. WTB Corsa Clone Tips or Corsa Tips
  225. WTB: Door Speaker for Camaro Z28 w/Monsoon (4wire)
  226. Abs delete and line lock for 98-02
  227. wtb Procharger or CCW's
  228. WTB: MMM Rear Bumper Cover
  229. FOUND THEM: WTB TA/WS6 Seats
  230. MS3 Cam
  231. Core T56 Needed
  232. wtb: strange 12 bolt
  233. wtb:ls1 t56. 99+ m6 harness. n2o bottles
  234. WTB: 10 Spoke SS Wheel Center Caps.
  235. Interior parts needed
  236. ls1 brake parts
  237. WTB: One Black ZR1 with NARROW machined lip (will consider buying 2)
  238. WTB: 10 bolt 4 Channel Rear End
  239. wtb clutch master
  240. need this
  241. wtb: long lube headers for 02 firebird
  242. WTB LSx intake bolts
  243. WTB: Drag radials
  244. WTB: 96-97 LT1 timing cover, 2001-2002 LS1 PCM GM# 12200411, LS2 coil packs
  245. WTB/WTT auto shifter/console/pedals
  246. looking for some 1980 camaro parts or info
  247. WTB- Longtubes for 94 lt1
  248. WTB-Lowering springs
  249. WTB: Low Miles LS7 Crank in Perfect Shape 12568820 - CHEAP !!!
  250. WTB- Ported Throttlebody
