View Full Version : Generation III Internal Engine
  1. Domed vs. Flat Top Pistons
  2. 243 valves
  3. LQ4 LQ9 Service Manual - LINK
  4. Strongest OEM TTY rod bolts PN 11610158?
  5. Timing chain tensioner/dampener solutions?
  6. Installed and tuned packages!
  7. Head ?'s
  8. Crappy CNC ported 243 heads...
  9. best forged piston for the $$$
  10. 5.3 to 5.7 cam question
  11. fastest n/a 5.3
  12. Garage installed 2in valves on 706's
  13. Timing chain & oil pump ?
  14. Which Route to go with 5.3 Nitrous or Turbo
  15. Really Stupid Question - Which oil (brand and weight) should I be running?
  16. Which Rods to use
  17. What is this around the cylinders?
  18. vrx5 or current cam with tfs 220?
  19. Rpm or vic jr 4 this set-up ???
  20. Rear oil barbell plug
  21. Cranks sensor issues
  22. Is this normal after a cylinder head swap?
  23. LS6 valley cover and aftermarket valve covers help!!
  24. Ls1 bare block
  25. Picked up a 07 5.3
  26. stock pushrods length?????
  27. Got a LS2 short block, What do i need to swap?
  28. mods to break 10's
  29. question flexplate and brackets
  30. Malhe vs Wiseco
  31. Suggestions on piston rings & cam bearings
  32. Long-Term Build Thoughts
  33. Daily driver build gone to far maybe
  34. Piston To Head Clearance?
  35. Am I supposed to be able to do this?!?!
  36. rod bearing question
  37. If you had 500$ to spend on a stock ls1...
  38. Lq4 alternator bracket for ls1 assesories.
  39. Ls1 vs lq4 crank
  40. A few concerns
  41. shortblock assembly questions
  42. Vr1 50 good?
  43. Eagle Rod ?...for 6.0
  44. GEN V engine ?
  45. Engine Break In- Off Street
  46. If anyone is curious to how a cam is cut. Check this out (video)
  47. Line boring an aluminum 5.7 block
  48. how to find TDC?
  49. Bent bolt...help
  50. prc 215cc heads
  51. 243 Heads Compression Ratio w/ .040 Head Gasket
  52. great street racing cam
  53. head removal help/ or price
  54. Thicker oil even with high oil pressure?
  55. Can I swap pistons
  56. Boost - Forced Induction Setup
  57. building beast
  58. heads
  59. White smoke from exhaust
  60. Tick Elite Street Heat Stage 1 Cam
  61. Glow shift oil filter sandwich??
  62. 400hp cam only on nitous tune, is it possible?
  63. can ya reuse timing gear bolts..?
  64. Another YT breakage
  65. cam question
  66. when to upgrade injectors?
  67. 4.8 to 5.3 swap ecm question
  68. LQ4 quick build questions
  69. 1999 T/A stock looking to mod
  70. To Advance or Not
  71. 59cc heads???
  72. Valve cover bolt snapped!!
  73. Valve Spring Compressor HELP
  74. Lq9 pistions pressed backward?
  75. A bout injectors FAST off set in Holley EFI
  76. Help asap
  77. Port and Polish around Chicago IL?
  78. LS1 Any more H.P. ?
  79. Lifter Preload, symptom diagnosis
  80. solid roller cam for carbureted stroked ls1? custom grind?
  81. V-tech sounding LSX?
  82. Bob weight of stock LS1?
  83. 5.3 rod question
  84. How much is my longblock worth?
  85. Windage Tray & Pick-up Tube
  86. 2005 c6 ls6 243 head and rockers on 1998 c5 sl1
  87. Critique my long block build
  88. Differences on Gasket Sets
  89. Who's your preferred Cam grinder....?
  90. brain tolley vavle springs
  91. Exciter ring
  92. Another PR Double-Check Me Thread
  93. Valve train noise
  94. Lq9 Delima
  95. Repairing a cracked cylinder
  96. GM casting numbers, thought this might help.
  97. 408 with Patriot Heads.
  98. Complete gasket set pricing
  99. Cam install TV2
  100. Comp Lifter Max RPM?
  101. Torquer v3/ported 243's idle video
  102. 5.3 upgrades
  103. Cam specs????
  104. ID This Timing Chain
  105. Futral Motorsports Cam
  106. Damn!!!
  107. gas mileage
  108. 243 heads
  109. Milky residue on oil cap.......normal?
  110. Cam for Turbo LQ9 build
  111. seeking build advice
  112. Longtube Headers & ORY Install [LS-1] (Pics)
  113. Can someone help me figure out my Compression ratio
  114. Double check these cam specs please
  115. F13 vs. El Torro
  116. 2000 LQ4 swap questions
  117. cam swap and replacing lifters what gasket set to get??
  118. 243 heads that were milled to 53cc
  119. Push rods ?
  120. Valve spring tool help
  121. need guidance
  122. Need Help Picking Out a Mild Cam
  123. LS swap into 97 suburban
  124. Problem after installing Heads, Cam, DoubleR, FAST102
  125. Had My M6 LS-1 z28 Dyno Tuned.. Amazing Results
  126. Upgrades complete, Thanks for all the help! Couple videos included
  127. bought lq4
  128. Difference between ls2 and lq9
  129. LS1 to LS3sawp?
  130. what caused this?
  131. rattling or clicking noise (hard to describe)
  132. How do I get desired CR?
  133. LS1 Build Question
  134. Water pump block off???
  135. Are these 243's ok?
  136. LQ4/LQ9 Difference
  137. Upgrades for spring '13 what little things do i need for my LE2 pkg
  138. help on hci ls1
  139. stock cam with prc .650 springs?
  140. LQ9 combo 460 rwhp?
  141. New build prep
  142. oil pressure at 80 psi, wtf?
  143. shoud I be using head bolts or studs?
  144. Roller Rocker Question
  145. L76 Intake on a LS1???
  146. Another Oil Pump Question
  147. Anyone try out Precision Engine Parts cranks? Or any other of there parts?
  148. timing chain
  149. Spun #1 rod bearing?
  150. ARP lube??????
  151. Lq4 with 243 heads?
  152. Best heads for stock-bottom-end LS1 with 228R cam?
  153. Asa cam
  154. Help...low pressure 2nd build
  155. Main Stud Question. PLEASE help!
  156. valve seals
  157. whats the dirveability like?
  158. which valve springs to choose?
  159. question about rockers
  160. Increasing ci. Gains in hp or just torque.
  161. Torquing bottom end ???
  162. ls1 crank
  163. Head/intake swap, now won't start. Backfiring like crazy
  164. Car want crank, silent when I turn key? Battery and starter connection is still good.
  165. OIL LEAK 'the bane of my existence'
  166. Serious redo on LS1, Iron block, or other??
  167. Help me with my build
  168. Compression Ratio on an LQ4
  169. Help me pick an oil pump
  170. Bret Bauer or Ed Curtis?
  171. Heads/Cam LS1 using oil?
  172. Rocker Clacking
  173. Is the LS3 head the same as a L92 head?
  174. Insane crankcase pressure/ oil mist/ blow by
  175. Looking for stock LQ4 piston
  176. 5.3 228 cam peaking aroun 6200 rpm?
  177. Coolant leaking from back of engine (passenger side)
  178. Ticking after head/cam swap... longer pushrods?
  179. will these springs work?
  180. Head/Cam swap advice
  181. AFR 210 Spark Plug Question
  182. When to change valve springs?
  183. Is this oil, sludge, or rust in my coolant?
  184. another pushrod question
  185. Thoughts on EPS cams?
  186. cam bearing wear?
  187. Card'd LS in V6 F-body
  188. Comp 228r in a 5.3
  189. What to do if VVT cam is off from cam card?
  190. melling10295 or 10296
  191. safe pushrod length?
  192. Best gear cam stall combo for a4 daily driver?
  193. OEM LS bearings TRI-Metal?
  194. all gaskets needed for head/intake swap..
  195. New member ls-1 or 6.0??????????????
  196. Help with a Friends Car
  197. How many thousands are cut from 64cc to 61cc's 243 heads?
  198. Fast 90 on a bolt on motor?
  199. cam/head swap and keeping stock like driveability..
  200. TSP PRC 215s or TSP PRC 227s
  201. Oil cylinder heads for storage?
  202. ported head quickie
  203. LS1 Cylinder Head torque
  204. 99 5.3l lm7 + t56
  205. LQ4 for 2006 Raptor 700
  206. How much more Spring lift can you run than Cam lift?
  207. Rod bolts help!
  208. What'd you'll think
  209. knock sensor wire, where it go??
  210. valve lapping question
  211. got 3/4 of a turn to 22ftlbs on stock pushrods, what size and preload?
  212. Houston, I think we have a problem!!!
  213. Need input on my build!!!
  214. Wiper Issues
  215. Should I throw some heads on or wait?
  216. TFS 215 and VRX5 results
  217. Clarification on camshaft thrust bearing
  218. TR CheaTR or TRuTorq?
  219. LS1 Build Help!
  220. Quick question on oil pump install...?
  221. Concave Wheels
  222. rocker question, need help quick..
  223. First Oil Change since Cam Change = metal pieces :(
  224. Advice on selecting new rocker arms, locks & retainers for my application?
  225. PRC 2.5 243 Heads & TSP 220R Cam
  226. Rebuilt LS2 - Burning Coolant and Oil in Exhaust
  227. H/C/I project setup
  228. Cam install?
  229. Cam Degree or straight up?
  230. cam lingenfeltar gt12
  231. swapping coil harness from 241 to 243 heads.
  232. Good cam for these heads
  233. 317 head
  234. Advanced inductions performance rebuild
  235. LQ4 crank
  236. Ticking noise from the lifters
  237. 241 vs 243 heads with big cam
  238. Which Cam for Street / Strip
  239. Biggest cam for stock converter
  240. This cam in my 5.3 ???
  241. Oil on spark plug..
  242. step closer to H/C build being put together..
  243. another pushrod thread
  244. H/C gains
  245. Buy pre-assembled short block 408 lq4 or buy rotating assembly?
  246. lq4 coil swap yeilds definite power increase
  247. Build thoughts, lq9/with what heads
  248. Heads/CAM HELP !!!
  249. Need Help Picking The Right Cam!!
  250. Another "criticize my build" thread
