View Full Version : Generation III Internal Engine
  1. cam help needed
  2. I need opinions.
  3. Lots of questions, Cam, springs, rods, flashtuning, BOOST?
  4. Which Cam
  5. Please Figure this one out!?!
  6. MTI Z1 cam on stock heads/block??
  7. 6.0 oil pump
  8. pushrod length ls6 heads and hotcam
  9. Help my friend choose a cam for his 00 T/A A4
  10. duration at .200 for MTI X1?
  11. cam install prices
  12. Will the ev6 body fit in the ls1/6 fuel rail?
  13. which year model cars w/ 243 heads had the good valves
  14. Its Back?!? 218/228 Hot Chili Cam?
  15. Preload questions and effects..
  16. Patriot Gold Valvesprings Questions
  17. Victor Jr or Super Vic
  18. Valvetrain Upgrade
  19. Fast 92mm intake w/ tb
  20. next mod?
  21. Hows my part list for H/C swap?
  22. camshaft?
  23. "pins" in the oil
  24. Goal: 400hp dream: 450 to the wheels
  25. Engine Knock?
  26. Someone help
  27. Can some one give me some compression calculations please?
  28. question on l92 setup
  29. Need your opinion on this cam
  30. Actual pics/mappings of aggressive lobes
  31. H0w much to mill to get 11.1 compression
  32. Cam in A4 with stock stall???
  33. to LS6 or not??
  34. Lingenfelter gt3 cam?
  35. Reverse or regular cam
  36. 99 Firebird
  37. FAST 92 onto ls1
  38. What heads to buy?
  39. Do I need two pushrod checkers to check my yella terras?
  40. Installing heads/cam on '05 chevy LQ4 - What should be replaced/upgraded?
  41. best head?
  42. Porting Stock LS6 Heads
  43. INTAKES- LS6 vs LS2
  44. dtc 332 and are my heads good or bad?
  45. How can I tell between a LS1 and LS6 block?
  46. What about this head/cam combo?
  47. trick flow heads?
  48. Awsome service @ TSP
  49. 5.3 Heads
  50. LSK lobs chart
  51. Anybody use legend h beam rod
  52. Do 1.8 rockers normally require longer or shorter pushrods..?
  53. LS1 to LS6
  54. Comp Cams: New LSR Series Cams - 27 new grinds
  55. PAC 1521 Springs?
  56. l92 head question
  57. LQ4 iron heads...
  58. gmmusclecarman's big 408 build thread!
  59. whos using K1 rods? how do u like them?
  60. Lsa ?
  61. Checking Timing?
  62. Cherry bomb Catback Exhaust system?
  63. Phone # Harland Sharp?
  64. What kind of gears for my midwest 9" rear?
  65. To Mill Or Not To Mill PRC Stg 2.5 5.3 heads
  66. LQ9/LQ4 Forged Motor Strength
  67. Stock short block might have blow it up ? need help went lean?
  68. Changed MAF and car feels slower
  69. I'm thinking of a cam swap....
  70. ticking
  71. My first attempt at my own custom grind
  72. Pushrod length
  73. any destroked builds out there
  74. can i get 440rwhp with this setup?
  75. ebay sps rod bolts
  76. are 01+ 28lb injectors sufficient for H/C?
  77. What do i need to make 450rwhp?
  78. pick a cam or stall first.
  79. #806 head castings?
  80. ok dont know whre to post if but help if you can thaks
  81. Cam swap with pictures
  82. Need cam suggestions
  83. ****Which cam? Torquer V.2 or Tr 230***
  84. Need help please.
  85. What will I need to do to break 7k?
  86. Hotcam+1.8+ls6 springs?
  87. MLS or solid copper?
  88. WTB: LS1 or LS6 Timing Chain Dampener (Tan/Beige) - New or Used
  89. Head gasket leaking, deciding on doing everything...what all is needed?
  90. How to get more low end power / torque
  91. Head/Cam break in procedure?
  92. What wieght of oil
  93. Cam Help
  94. Head gasket less than 0.040"?
  95. Is it worth me upgrading to 241 heads over 853 heads?
  96. Upgrading rod bolts, should I replace rod bearings??
  97. Ls1 block to l92
  98. Comp 228/230 to a 228R any gain?
  99. cam install help please
  100. knock sensor low voltage
  101. What cam to use???
  102. 243/head/valve question
  103. what is 4.8l rod lenght
  104. Anyone heard a collasped lifter?
  105. anyone runnig Comp cams LSL cam lobes
  106. Bearing Assembly lube
  107. l92 heads on a iron 6.0 block
  108. ARP head studs 1/2" too long 6.0 iron
  109. Tach not working question
  110. 440 engine build
  111. 395 ls stroker combo?
  112. Cam sensor what does it do and what are symptoms when its not working ?
  113. Are these Patriot Gold valvesprings? *pics*
  114. Stock Head Gaskets .050?
  115. My engine rebuild W/pics
  116. rockers
  117. whats my comp ratio? -32cc
  118. prc 5.3 and street sweeper Hi tq
  119. PRC or Edelbrock?
  120. LPE oil pump...questions?
  121. Good hot cam for a dd?
  122. AFR 205s, ported FAST92, 232/234 ?
  123. Excessive Pressure in the Crank Case..?
  124. Roller rockers
  125. Anyone here ever run a predator cams branded camshaft?
  126. Help please!!!
  127. Question about Ls1
  128. Forged Bottom End Pricing
  129. what do 5.3 heads need to be milled to make 11:5 compression?
  130. oil pressure high at idle
  131. cam lift with head swap ?
  132. What is this on my oil drain plug?
  133. Replace these cam bearings? (Pics inside)
  134. heads worth the money?
  135. will this work with a 402 ??
  136. Ebay Head stud kit
  137. 408 turbo valve size
  138. Heads, Cam and Injectors?
  139. Help with new cam!!!!
  140. Keep EFI or change to carbed? (LQ9)
  141. LQ4 Cam Selection Help
  142. cam installation
  143. i want to build a building a 396
  144. How much can you mill
  145. misfire ?
  146. need some help setting up new TT 408
  147. Good streetable head cam package??
  148. Can I get 400rwhp out of a cam and bolt on 6.0?
  149. run problem
  150. Found out whats wrong with my LS1.. best way to proceed?
  151. Head/Cam Package
  152. Piston to valve clearance
  153. Any idea what this engine is?
  154. Is 7000 a safe rev limit for occasional 1/4 mile runs ?
  155. 2005 GTO cam into 2000 LS1?
  156. cam for PRC 2.5 LS6 with Vig 3200 Stall?
  157. 5.3, 02 zo6 cam, 853 heads. HOW MUCH CAN I MILL?
  158. how much flow improvement with just polishing my heads
  159. tsp 370
  160. pulling block
  161. more lift?
  162. rod orientation (on crank)
  163. question about fast 92mm intake on a stock bottom end heads and cam ls1
  164. New Head Bolts/Studs
  165. What characteristics would an 83mm crank feel like?
  166. cam help?
  167. Question on proper setup (rebuild)
  168. TEA stg 3 heads for ls2?
  169. Pushrod Length Question - Intake/Exhasut measure different...
  170. Short Block
  171. 5.3 build up for 02 silverado rcsb
  172. Cam Help
  173. how high of comression can be ran on pump gas
  174. Question About LS1 Heads
  175. LS1 build thread, here goes
  176. 5.7 vs 6.0 build power difference
  177. Budget 6.0L, 5.3 heads?
  178. vibe problem
  179. Stock Fuel System?
  180. possible ring or piston issue
  181. oil pump?
  182. What heads??
  183. lq9 engine
  184. fm-14 in and car dies ..tuned
  185. Will i need to fly cut
  186. ??? about the schwanke engine
  187. Can stock 97-98 806 heads bolt to a 4.8L with not valve clearance issues?
  188. What is this sound?
  189. Stock heads value?
  190. PCV system
  191. 113+2 idle
  192. Can someone give me a step by step on adjusting comp rocker arms?
  193. Broken lifter/rocker arm?
  194. HELP!! MAJOR engine bogging and stalling!
  195. Another cam thread. Stalled Auto. Long Write-Up.
  196. ................texas Speed .....need Your Help!!!!!!!!!!!!
  197. Close to 400hp?
  198. 5.3 heads with stock cam and spray
  199. trick flow 515hp kit
  200. someone catch me up
  201. cam for carb'd 6.0
  202. What is Record rwhp on stock short block?
  203. 5.3 head?
  204. i have a #7 problem too
  205. tv 2 cam..what do shift at?
  206. #7 has no compression....
  207. Offset or on center rods?
  208. supporting internal mods for AFR 205's and torquer v2 combo
  209. Help with identifying waht type of rocker arm I have
  210. F-14 vs Torquer V3
  211. Cam Bearing Selection
  212. Installing heads and cam on a 2002 camaro with 54,000 mile what should I replace
  213. Anyone Ever flooded their engine
  214. C5 Head/Cam/Compression Questions
  215. Anyone running this TB...
  216. New Set-Up, what do you think?
  217. How are your LS7 Lifters holding up?
  218. "Piston slap" a weak point in engine?
  219. Need help with cam selection with prc stage 2.5 5.3 heads on stalled a4
  220. Will ls2 lifter trays work in an ls1?
  221. Need Help and i have search everywhere...
  222. LS1 Custom Turbo
  223. cam over 600 lift?
  224. dip stick
  225. anyonever blown both head gaskets at once?
  226. Pushrods too long cause backfire out of valve?
  227. Does a car get better gas mileage when the engine is running hot or cold.?
  228. *Sigh another suggest a cam thread
  229. X1 Cam and AFR 205s
  230. Squeak/chirp *not a pulley or header gasket*
  231. early christmas to myself
  232. where to find torque?
  233. how much are stock injectors good for in a 2001 auto Z28
  234. Morel Lifters , who has best price on them?
  235. anyone know of a place that can port the LS6 intake around Austin TX?
  236. Tsunami cam questions.
  237. Heads for stock cam
  238. If i have 10.8:1 with 5.3 heads, what would i have with 6.0 heads
  239. Cam for my 04Z06
  240. LS1 pcv system
  241. TR 224, 400rwhp?
  242. PRC 5.3 2.5 to mill or not?
  243. lifter replacement problem
  244. Several problem ws6
  245. LQ9 vs. LQ4, BLOCK only
  246. stroker build
  247. hurt something on friday...
  248. LS7 lifters /set up-preload
  249. LS2 lifter buckets better than LS1 buckets???
  250. 5.3L 396 stroker?
