View Full Version : Generation III Internal Engine
  1. Oil Pan?
  2. Help! Want Cam Suggestions
  3. Ms4 Is Finally In Here Is A Video
  4. 243 castings
  5. Meziere water pump wiring??
  6. Edelbrok heads?
  7. Cam retainer plate
  8. need an engine rebuild and got some questions....
  9. new weiand intake
  10. Why the HELL are my intake runners CRACKING on my Victor JR intake?!!
  11. How's this cam design look?
  12. Clearance needed between windage tray & crank???
  13. Actual cost of stroking stock LS1 to 383
  14. inspect used heads
  15. will these pistons work in 347?
  16. Stock Pushrods
  17. Top reasons to buy coated bearings (cam|rod|main)...
  18. Just installed Fast 92/92 set and having problem's
  19. Car back after Heads and Intake porting
  20. Which Rods and compstar I beam rods anything one use them?
  21. LF Chicago area sponsor to delete codes
  22. Are XE-R/XFI/LSK lobes daily driver streetable, or not?
  23. How would you change my combo?
  24. 383 what to do?
  25. ls1 vs ls6 cam
  26. what head number
  27. Exotic F/I camshaft??
  28. Tr 230/224 opinions
  29. Which 224/230 cam?
  30. BIG 408 Cam Selection Help (Come in)
  31. block swapability...
  32. Please help me!!!!
  33. Ms3 vs. Trex
  34. Emissions Friendly Cam: TS 224R vs TS 228R
  35. LS1 w/ 5.3L 706 heads?
  36. need help this is dumb
  37. Engine Build Software
  38. Need Help Quick If I Take Off My Stock Heads Do I Have To Take Them To A Machine Shop
  39. Questions about potentially bad rod bearings
  40. piston kissed the camber of my head
  41. Magic Stick 4 Good for Nitrous?
  42. Fel-Pro 26190PT head gasket thickness
  43. dome pistons
  44. Valve Springs
  45. o2 extension Pacesetter
  46. 1.75 rockers on stock cam and stock valvesprings
  47. Smokin Deal
  48. Input needed for a possible H/C/I setup
  49. Weich Heads?????
  50. Oil Pressure
  51. Is this piston OK?
  52. re grinding a ls1 cam
  53. Are many people running a 382 Iron Block?
  54. Heads and cam question
  55. Difference Between Vette/ Canaro LS1's
  56. SS Valves vs Titanium & Sodium Filled
  57. cleaning inside of block.
  58. What gasket for V2 PRC 2.5 5.3L?
  59. LQ9 Carnage Pics!
  60. Just fyi
  61. camshaft
  62. popping when auto shifts please help
  63. Dilemma... Patriot 68cc LS6 heads on stock displacement LS1?
  64. lighter flywheel
  65. Question
  66. Advice on crower cam with l92 heads?
  67. MS3 Specs????
  68. rocker arms ?
  69. Whose got the weakest MS3 dyno numbers or 1/4 mile times?
  70. people that have blown up
  71. Best cam for daily driven a4?
  72. 5.3 vs. ls1 rockers
  73. Where to buy valve cover spacers?
  74. Looking at a 99 TA. Have Some Questions..
  75. Motor wants to over heat & oil pressure drops?
  76. need Part numbers for H beam rods
  77. PRC 215cc Specs, Dyno Info & Videos INSIDE!!
  78. External dimensions of 241 or 243 heads?
  79. 04 GTO LS1 w/ Boltons-Low Dyno HP #'s
  80. do i need to rebuild?? please help
  81. Hello LSturd.com
  82. Reluctor wheel swap- Crank removal
  83. Need cam advice & hp gain info for a streetable LS6 motor...
  84. leakdown and compression test results
  85. Looking to do Cam/Heads
  86. Corvette accessories on a 5.3L! Question? Pic inside
  87. turbo motor
  88. Few cam supporting mod question..
  89. JUST BOUGHT CAM...WHAT #'s to EXPECT!!??
  90. Broken PRC ls6 heads... What to replace with? MS3 Cam
  91. need cam help
  92. ls1 to fast 92
  93. TSP cam questions
  94. PRC 5.3 Stage 2.5 Heads + TR224
  95. L19 rod bolt question
  96. How does this sound?
  97. Budget vs. Premium Heads
  98. ¿#&$F$&# Morel lifters = Hogwash?
  99. 00 t/a motor in a 98 T/a
  100. PRC stg 2.5 heads VS. P&P 241
  101. 383 408 402
  102. help me decide on the best head choice.
  103. ~Need advice! Soon to be LS1 owner with a few questions
  104. How much is "too little" PTVC?
  105. Very low RPMs at idle
  106. Odd Sound
  107. Rod bolt question
  108. LQ4 max bore question need help****
  109. max effort heads cam 346's come in.. weiand or fast 92
  110. Dart 205 Pushrod length help!
  111. Brand New Custom Cam Sale $355 Shipped
  112. 1 5/8" Primary's on an LS1?
  113. Time Sert
  114. What am I missing?
  115. will a cloged cat cause bad fuel consumbion?
  116. cam choices
  117. Main Bearing Direction
  118. a4 cam better mileage??
  119. How to get knock sensors out?
  120. car lightly surges when cruising...help please
  121. I think its time for a cam
  122. LS1 Camshaft Engine Dyno Comparision
  123. Big Cam, Cold Start
  124. frustrated with installing pistons.
  125. Turbo vs. Supercharger sounds??
  126. Head/Cam swap tomorrow....WISH ME LUCK!!!
  127. Should the new front and rear seals go in this easy?
  128. What are the BEST HEADS for a N/A 346?
  129. Help! cant get my oil pan 2 drop
  130. Internals
  131. Comp Cams 54-000-11...is this
  132. Need some help, measuring PTVC!
  133. Which way does the motor spin?
  134. How to deal with a spun rod bearing?
  135. Reinstalling stock rockers on new heads
  136. couple of Katech rod bolts questions
  137. another cam &head question
  138. Lunati Voodoo 60510 Cam
  139. New set up
  140. Building a 402 H/C lq9
  141. need help to diagnose problem
  142. lq4 question
  143. Fired up the car after 2 years.....open headers!!
  144. Yellow terra or harland sharp roller rockers
  145. Will this cam fit in an LQ9 block?
  146. '04 lq4?
  147. wanting forged 347 pistons
  148. mobil 1 5w-40 full syn
  149. lq4 lq9
  150. What Oil Weight for a Cammed LS1
  151. 5.3L head question
  152. how would a small cam do in a big cubed ls
  153. water in valve covers / pcv!!!!
  154. tourqe specs
  155. Engine break in questions??
  156. Which ARP head bolts???
  157. Mild clattering from top end - problem or normal?
  158. lm7 vs l33, need advise
  159. is the melling m295 and 10295 oil pump the same?
  160. What lil things should I check/do before I make a major screwup lol???
  161. Good assembly shop in CT??
  162. missing vital parts any help with part ## ??
  163. Cam dimensions please !
  164. Vavle Springs too big=damage.
  165. 5.3 to 6.0
  166. get a few questions with MS3 and TSP heads
  167. Gaskets
  168. cheap e-bay cam copy..anyone use one?
  169. 383 or 396 ??
  170. Will PP Dual Springs Hurt Perfomance With TR224 Cam?
  171. Cleaning tops of piston durring H/c
  172. 2 into 1
  173. want to be close to 500 wheel
  174. Please help Idle Problems and Shifting Problems
  175. Need advice on handling this situation...
  176. Power Potential for 5.3L?
  177. Is it worth the trouble for higher compression
  178. LS1 383 long block assembly price
  179. LS1 Twin Turbo RPM Range
  180. 02 zo6 cam?
  181. 228r or torquer v2 AGAIN - pt4000 3.73 auto
  182. afr 225
  183. Anyone know if someone makes a Ti keeper?
  184. guestimate how much WHP this would be?
  185. Ticking after gettting on it hard.
  186. High Compresion on Pump Gas?
  187. After Cam change, start up smoke
  188. 241's VS 853's
  189. head interchangeable
  190. Is there any good ls1 how to dvd's
  191. ANY 500HP recipes???
  192. Cam ???
  193. 5.3 PRC Stage 2 w/ 1.75 rockers?
  194. LT/ hi flow cats and emmisions?
  195. wanting 380-400rwhp in my ls1 help?
  196. calling pat g
  197. What gaskets will I need?
  198. Head removal question
  199. Cam Question
  200. Looking for fbody ls1 front accessory...
  201. Cam set-up. Please Help.
  202. mustang GONE.. hello '00 trans am...
  203. 2.055 in valve in factory ls intake seat?
  204. 383 stroker questions!
  205. Started LS1, doesn't idle, car shakes, cold PS header/hot DS header, bad cam?
  206. reuse main bolts?
  207. O2 sensors
  208. Track Results
  209. Smoke from Oil Filler
  210. Looking for 500bhp.
  211. Cam Supporting Mod's??
  212. LS1 rebuild
  213. do i need different pushrods?
  214. Thinking of camming my DD 01 T/A WS6 M6 - Need some answers/opinions
  215. rocker geometry? please help
  216. How much cross flow from the rear coolant crossover pipe?
  217. any 11 second cam only's here? VIDS PLEASE
  218. ???agressive Stock Cam Sound???
  219. Question...
  220. new 408
  221. Ktech or arp rod bolt for stock lq4 rods
  222. older z06 ls6 heads,cam and other stuff on my 01 ss
  223. Narrowed my cam choice down to 2!
  224. Harlan Rocker Versions?
  225. main stud questions
  226. Will a pre 02 6.0 work with a 4l60e?
  227. Speed Inc. SI5 cam with AFR 205s
  228. Basic H/C swap. Head bolts or no?
  229. Engine building manuals
  230. Cam and Washington emissions
  231. MAC Header bolt question
  232. Opinions needed
  233. after h/c install, water comes out of exhaust tips?
  234. new cam
  235. question about 6.125 rod in a 6.0 lq4
  236. Missfire when A/C is running
  237. Engine STILL Misfiring - Need Help
  238. $$$ Engine rebuild
  239. Need some expert valvetrain guidance
  240. quick knock sensor question
  241. My Cam Swap on 01 Trans Am
  242. Looking into forged pistons for a lq4 6.0 couple questions
  243. 383 build questions
  244. LS1 rear cover tool needed.
  245. ls1 oil pump shim
  246. Possible missing crank angle sensor
  247. LSX motor cam sensor question.
  248. Need 5.3 engine or new shortblock
  249. Do any sponsors carry mufflex Y pipes
  250. I hate cams
