View Full Version : Generation III Internal Engine
  1. stock 5.3 heads
  2. car running a little ruff at idle?
  3. low rpm ticking
  4. ticking question
  5. Best heads for a tr224/563 112
  6. ??? Lean Oe Rich Mixture Cause Detonation/ping???
  7. Looking for a cam card...
  8. How much oil pressure is too much?
  9. Questions regarding Yella Terra rocker install.
  10. Current best pricing on cams
  11. 5.3 or 6.0 cnc ported heads
  12. Afr Head Gussing Game
  13. Rebuilt Engine: Any precautions I should take??
  14. I need some advice
  15. oil pump install on 98, hell!!!!
  16. leaky rear main?
  17. ???bent Pushrod, Spun Bearing, Lifter???
  18. Budget Build?
  19. Best place to buy a short block?
  20. Help needed ,What is this cam? 24206R
  21. Texas Speed trys a texas quick one on me?
  22. Texas Speeds LS6 Heads/Manifold VS TFS Heads/Comp 90/90 Set up
  23. Finally got around to opening up the old LS6, not good!
  24. Rack n pinion leak?
  25. Bent pushrod, head damage, need opinions
  26. Total Seal piston rings blowby?
  27. Cam and engine temp...
  28. Dart 225s Futral F5: Flycut?
  29. heads and cam combo
  30. PRC stage 2.5 5.3L heads...suggestions on a cam choice
  31. ptv problem??
  32. What cam is this?
  33. so I've been messing around with the DCR calculator, now I have a question or two....
  34. Security Light Help
  35. Need some opinions
  36. Crank Question
  37. Where's The Engine Number Located? (lq9)
  38. Mill heads how much for my application?
  39. car won't start
  40. Autometer w/t sender interact a/m#2277 pics
  41. Head and Deck cleaning
  42. Cam turning over?
  43. Mahle pistons
  44. cam question
  45. question regarding MS4 camshaft and top end
  46. Best way to clean set of heads?
  47. Valvetrain Noise
  48. Rear cover kit
  49. engine tick/ knock only when hot
  50. took off heads, found gunk on 1 piston?
  51. a/f ratio on LS1's/LS6's etc
  52. Weird problem, car falls on its face @ WOT, only when coming off idle
  53. Biggest cam??
  54. ??? Question: On Stock Cam Specs???
  55. slp pulley removal
  56. checker valve springs
  57. bent valve
  58. LS6 Heads
  59. Upgrading 224/228 to Polluter
  60. Another tick???
  61. coolant question
  62. What is the word on those new TSP Heads?
  63. Troubleshooting Steps for Low/No Oil Pressure
  64. Arias Pistons??
  65. About to install heads, want to dump the shortie headers
  66. What heads on a budget 5.3...706's or 241's?
  67. Compression Numbers on new motor, have some questions
  68. Need To Know My Dcr Please!
  69. PRC Cylinder Heads Sale at Texas Speed!
  70. Would Yella Terra Be Worth It.
  71. Charley @ RPM = MAGIC
  72. opinons on numbers after cam
  73. Help with cam choice
  74. Few cam questions.
  75. Valvetrain noise (with video)
  76. rocker help
  77. How many miles are Comp 921's good for?
  78. Fan Problem
  79. cam on stock springs??
  80. Yep..another quess the HP
  81. VIDEO: Tick Performance's NEW Polluter Camshaft at Idle
  82. information on 1997-1988 c5 ls1's
  83. Hows this heads and cam package look?
  84. Most Aggressive Cam Under 600 Lift?
  85. LQ4 setup
  86. Head and cam combo.
  87. LS1 Gone, new 408...what to call it>>
  88. Did I Over Torque My Head Bolts?
  89. anyway to remove lifters w/out removing heads?
  90. What to do with lq4 that needs boring?
  91. squicking from top half???
  92. cleaning lifters?
  93. H/C thoughts...
  94. How to change a fuel pump in a 99TA?
  95. 6.0 swap questions....
  96. Metal Shavings in Oil Check - New Build
  97. Is this Normal?
  98. bearing usage
  99. heads and cam?
  100. Proudly Introducing Tick Performance's Flagship LSx Camshaft: The Polluter
  101. LS1/LS6 Crank offset?
  102. Quick question
  103. Cam specs for a 370?
  104. Help! My Car Is Stalling! Help! My Car Is Stalling! Need Help Asap
  105. Should I sell my motor???
  106. anyone knows why this noise happens?
  107. ported stock heads
  108. what cam is this? and what went wrong with it. with pic's
  109. 121,000 mile cam swap
  110. Does anyone ever do budget stroker builds?
  111. G5X3 and Stage 1 prc LS6 heads
  112. Valve wipe good enough?
  113. Does the LS1 Computer Work With an LS7
  114. car takes forever to return to idle
  115. LG's G5X1 cam owners opinions please
  116. exhaust
  117. Help with my Head/cam checklist!!
  118. Harmonic balancer
  119. New Build..... 6.0 iron..
  120. Tappet Noise?
  121. Throwing codes
  122. Cam bearings
  123. advice on new forged engine
  124. Where to buy
  125. Piston Selection for a Budget 6.0L build?
  126. shortmotor build up- any tips?
  127. quick question guys
  128. bolts question
  129. ls6 heads
  130. 862 Heads
  131. new toys, need clearance advise
  132. LS4 Harmonic Balancer on a LS1
  133. Need Torque specs for oil pan install
  134. LS6 intake question
  135. machine shop help kansas
  136. Cracked block by head bolt hole.......
  137. Stock rod question
  138. 4.0 Crank?
  139. 2nd ls1 swap .. looking for the biggest cam on stock springs . help !
  140. valve spring, and pushrod ?
  141. What causes this damage to a cam?
  142. What specific clay to get to check PTVC?
  143. solid roller 408 non adjustable valvetrain ?
  144. any Patriot reps on here? 1 bad valve lock, and 1 missing
  145. alittle bit of help needed
  146. IS there something wrong with this cam. PICS
  147. Oil Pressure Sensor and wire
  148. Supporting mods for a TR224....
  149. Which cam for my set up?
  150. does anyone know the GM part number for the stock head bolt kit GM offers for the LS1
  151. Working on my new HC setup...took some pics
  152. I need to know if my timing chain is ok
  153. first ls1 build, a few simple questions
  154. after installing a cheatr cam whats the gas smell from?
  155. Push Rod Length-Anyone have this combo?
  156. Oil pressure at idle
  157. Sleeper build
  158. What size are the oil pump bolts?
  159. Dual Springs Noisy?
  160. LS7 lifters and LSL lobes?
  161. My 1st LS1 build, help inside
  162. Quick ? on 241s
  163. Good article on all genIII motors
  164. how strong is stock crank
  165. 5.3 heads on ls1
  166. Better block Iorn or aluminum?
  167. tr ls2 cheater cam in a ls1
  168. Tr 230/224
  169. cam selection cam guys come in please
  170. LS2 cam vs LS6 cam ideas?(with x1.8rockers on #799 heads)
  171. What gasket do you guys suggest for my set up?
  172. All valvespring tools backordered?
  173. new motor... already knocking, please help
  174. Mobil 1 No More
  175. Crazy Idle issues
  176. LM7 Heads and Cam Sound Right???
  177. Copper Spray GM MLS Head Gaskets?
  178. LS2 heads on LS1 HELP!!!
  179. blew it up today
  180. head amd cam combo
  181. Rust on crank
  182. texas speed ?
  183. Cheap Motor Build?
  184. LQ4 missfire
  185. Wiil this cam work good under boost
  186. Oil Pan Gasket
  187. dart 250cc heads on 408 stroker or AFR 205s on forged 346???
  188. 160 Thermo question
  189. Switching valve springs on new AFR heads (still off the car)?
  190. My combo
  191. Buy new timing chain and oil pump?
  192. heads/cam?
  193. 04 gto oil psi
  194. what do you think of this setup
  195. MS3 & PRC 2.5 5.3l 63cc
  196. Oil pressure dropping with load, options?
  197. Ticking lifters... try seafoam!
  198. D/FW Engine Shop Recommendation
  199. 500Hp
  200. opinions on best cam for.................
  201. 02 Z06 -Whats it going to make?
  202. What H/C combo?
  203. l92 vs ported 243`s
  204. parts trippel checked for h/c swap
  205. ?'s about lsa and advance
  206. MAJOR Issues With TFS/TEA and LME!!!
  207. Serious problem, help please!
  208. good DD cam?
  209. Pulled head, should I change the oil???
  210. Can someone help me identify this cam?
  211. Nicks/gashes on top of valves
  212. LM7 with LS6 heads
  213. low oil Indicator??
  214. PRC 5.3 Vs. TFS 215 cc
  215. yet another head and cam question
  216. LS1 and 5.0 Mustang same firing order?
  217. What Springs are these...?
  218. what kinda cam should i run with my set up
  219. cant get this thing to run right
  220. Stroker plus Boost ?
  221. boosted 383 stroker
  222. ARP Head Stud Possibl Cross Threaded. Q about it.
  223. wat should i get first???
  224. 853 castings on a 98 ls1, what head gasket?plz help
  225. Anyone bought PRC 5.3l Stg 2.5 Heads and wished they bought the AFR 205's
  226. 450hp H/C combo
  227. Ls1 Rebuild
  228. best heads for my set up
  229. I want to Texas-Speed my car. H/C questions
  230. futral cam
  231. Basic heads/cam Decision Questions
  232. need help - vibration
  233. Whos got some Morel lifters
  234. Stock Cylinder Heads?
  235. Cam which one to buy
  236. Pulling Motor: Top or Bottom (which is best for my situation)
  237. Bad Performance
  238. Looking to upgrade to 85mm mass air info needed
  239. Will LS1/LS6 Head Gaskets Work on my 5.3?
  240. stock lifter diagnosis?
  241. Spring/Pushrod Changes-Necessary?
  242. Shop vac = clean head removal
  243. When is an Injector upgrade needed
  244. weird ac problem
  245. Am I crazy...???
  246. Are lifters required with new cam?
  247. LS1 oilpan fit 6.0 iron???
  248. LS1 Heads and a Cam Question
  249. Compression ????
  250. Got my Z running HCI VRX5 TFS 215s Idle clip
