View Full Version : Generation III Internal Engine
  1. my 35th le
  2. How weak are my 98 rods and rod bolts??
  3. 7.425 or 7.400 pushrods for GM ASA CAM
  4. Just stripped the threads on a rocker arm bolt...
  5. First impressions of new setup
  6. Question has been asked before!!!
  7. Cam w/ stock pushrods
  8. Engine just started surging.
  9. Question about motor life
  10. Quick help please!!
  11. greatest invention known to man!!!
  12. worth porting 853's??
  13. TFS Heads and a MS4?
  14. what cam would be the best?????
  15. Cam Swap Q's
  16. coolant flow
  17. guages
  18. Dart Pro 205 or TSP 5.3 stage 2.5
  19. Pushrod Length??????
  20. Misfire/detination/backfire,cutting out on 1999 346 100 miles.
  21. cam question
  22. Flush oil from coolant system
  23. $2000 to spend on engine.
  24. Heads stall at 0.550 lift
  25. lq4 h/c Question lt4 jay or burger or anybody
  26. cross section of LS head
  27. ls1 build questions, Help!
  28. changing cam lifter question
  29. hissing noise at engine shut off!
  30. AFR Heads = Quality and Performance...
  31. stock bore stroker
  32. Cats and cam?
  33. cam help
  34. smoking after h/c install
  35. typical gains from aftermarket rockers?
  36. Need timing chain on stock LS-1 but future H/C within 2 years, help...
  37. 02 ZO6 cam swap
  38. Too good to be true (rockers)?
  39. which gasket to run? TEA stage II LS6 heads
  40. blew tranny and have small shaving in oil?
  41. lq9 rpm question for big cam.......
  42. Guys with over 550rw N/A. Are you still running the MAF?
  43. I have an oil pressure problem...
  44. ls1 in an ls2 vehicle
  45. What could cause increased clutch presure with increased speed??
  46. ls1 383 possible?
  47. forged motor?
  48. Misfiring and popping
  49. Improved Racing Oil Baffle
  50. upgrading injectors
  51. cam and ls6 numbers
  52. i have a choice on 2 heads, which ones should i go for?
  53. balancer removal
  54. How can I tell shop used Studs on my heads
  55. I need pistons for LQ4
  56. Looking at buying f-body with mods - what should it make approx?
  57. Engine finally done w/ pics
  58. LS6 install wow!
  59. PTV=Bent Push Rod. Is this piston okay? (pics)
  60. seafoamed and odd results
  61. Found Inexpensive Source for Metric Hex Flanged Bolts
  62. German Castrol 0w30 Synthetic
  63. How big of a cam can I use
  64. How much can you bore an LS1
  65. LS1 LS6 rear cover different?
  66. parts for my 6.0
  67. Front engine oil leak (blown front main?)
  68. iron block part #'s please
  69. heads torque
  70. Crankshaft Rear Oil Plug Removal
  71. Bolt on LS1 + cam vs Stock Z06 2002
  72. stock cam?
  73. Engine trouble ...dont know what it is..PLEASE HELP
  74. Difference between FM14 and torquer2?
  75. Checking P/V clearance discussion
  76. help deciding on a cam
  77. stock injectors big enough?
  78. Rebuilding motor. Parts list & Prices
  79. How do I find out what has been done internally?
  80. How much does a LS1 longblock weigh?
  81. Cam ok for DD??
  82. gasket surfaces on heads
  83. Replace Knock Sensors?
  84. harland sharp roller rockers dont work well
  85. springs
  86. LSx small journal rods?
  87. What the heck happen to my cam?
  88. ARP stud stuck in block!
  89. 58cc heads on a stock lq4 6.0 what compression?
  90. Idel issues resolved
  91. MS4 Cam LS6 heads trouble???
  92. What size allan wrench sockets will I need to remove coolant plugs on the block?
  93. how to tell a 4.8 from a 5.3
  94. Got the cam package today
  95. what makes more power (CAMS_
  96. NEED help ASAP
  97. Cam package from texas-speed
  98. Anyone know if I can do 1.8 ratio rockers as a bolt-on?
  99. Need some advice.
  100. LS2 timing set question
  101. G5X4 + LS6 heads + bolt-ons =??
  102. Been doing my cam research...more Q's than answers. Help appreciated
  103. Best setup to get 600hp without forced induction?
  104. 224/224 powerband?
  105. LS1 & LT1 lifters the same?
  106. installing tips for a gen III to a GenIV
  107. smellin oil????
  108. Need options!! h/c package
  109. Will TEA stage 2 ls6 heads and vindicator like cam make 450rwhp?
  110. best cam for 243 heads non ported yellow springs
  111. curiosity
  112. HELP!! Adjusting Comp 1.85 Pro Magnum Rocker Arms
  113. Anyone Running Comp R Lifters On 346 Forged?
  114. !!!99 LS1 Forged H/C Car Trouble Shooting!!! PLease Help Me Guys!!!
  115. 6.0L In a thirdgen - H/C/I Help with cam/output
  116. 98 z28 with a 5.3 need help!!!! anybody please lol
  117. oil pressure gauge connection.....
  118. Cam valve events need
  119. Need fast answer about AFR 225s and PR length!
  120. 220/220 114 cam question
  121. 383 vs 402 stroker
  122. Big Problems
  123. Cam gurus come in here....
  124. Ok serious cam question and suggestions needed
  125. porting 243s, how much?
  126. tfs 215 on a 346 compression is??
  127. comp cam 232/234 114 xcr ?
  128. Lightweight rods?
  129. Overheating.......
  130. Higher oil pressure than usual
  131. What heads with MS4 cam
  132. 7 Cylinder LQ4?
  133. 370 build
  134. 346 Blown VS. 408 Bottle Fed which is faster?
  135. Catch can completely dry????
  136. cam and stall question
  137. My Trans am is dead
  138. How long did it take for you to receive parts for you heads/cam combo?
  139. Salt in fuel tank
  140. Colorado Camshaft?
  141. startup after ls6 manifold swap
  142. LS7 oil pump require LS7 crank?
  143. 2.08/1.60 valves for a 370ci?
  144. School me on steam vents
  145. ok crank plug install and removal advice?
  146. NEEDED!!! ACTUAL measurements of MLS gaskets
  147. Thoughts on TEA stage 2 ls6 heads.
  148. what needs to be done to rev my 99
  149. lq4/lq9 part numbers well oil dipstick ones.
  150. MS3 cam...
  151. milling 853's
  152. All LS6 Heads Have Yellow Springs?
  153. detonation problems
  154. FAST Intakes - Is a LS6 Coolant Pipe Kit required?
  155. oil pump pressure relief valve
  156. what can you do with a stock LS1 block?? 346 vs 370 (boost related)
  157. Need Quick Help
  158. timing chain noise
  159. How will my car run with this combo?
  160. Broke oil sending unit...hurray
  161. New project for me.......
  162. gm asa cam and 243 ls6 stock heads # projections?
  163. ls1 head gasket blew, aftermarket or oem?
  164. CC228 Cam on 115LSA...decent for NA or change?
  165. curious about push rods...
  166. how are 250cc intake runners????
  167. PatrickG please chime in on this. heads cam combo question
  168. Oil out of flywheel holes
  169. Head bolt holes and FAST questiion
  170. 98 heads on a 00 block
  171. ls7 lifter kits
  172. Patriot stage 3's & MS3
  173. Engine trouble after cam swap
  174. Help!!
  175. I'm a ricer, need a different boost cam
  176. Will I need to flycut?? help me out please
  177. want to go 6.0 in my ws6
  178. cam too big to pass smog in CALIFORNIA?????
  179. car hesitates off idle, ~3000 RPM
  180. spark plugs
  181. what gaskets are needed for rebuild
  182. ARP Head Studs too Much for N/A?
  183. best cam only cam
  184. trickflow as cast heads, do they have any for big bores
  185. Oil Life
  186. what do you think of my oil pressure??
  187. 228/228 114 ok on stock TC?
  188. 04 GTO check engine oil on display
  189. What wrong with 4.060 bore?
  190. Oil pressure problem solved!!!
  191. im getting a ms3 installed what do i need
  192. Oil Pump Swap Advice
  193. 224/228 114+2 cam numbers
  194. to coat the pistons or not
  195. Need advice FAST!
  196. doing my cam swap..
  197. to rebuild or start fresh?
  198. tune question for cam swap
  199. What are the best heads for a stock cubed LS1????
  200. TSP True Dual Vs. UMI Tunnel Brace
  201. ETP 265 rocker options?
  202. easy question... springs
  203. HP tv, drill lifter holders for oil?
  204. mls gasket for 853 with notch
  205. 5.3 GMC PU - sheared off exhaust bolts?
  206. Big cam guys, how to increase vacuum for brakes.
  207. Pics from tear down
  208. swapping shortblock ls1-ls6- did i miss anything?
  209. oil plug fitting size////plus a oil pressure question all in one thread
  210. Need Cam Info
  211. compression ratio on LQ4 with stock ls1 heads?
  212. lifters-best bang for the buck
  213. EXTREMELY lost again
  214. Need Help
  215. Ported 5.3Ls bad idea for carbed .651 lift cam?
  216. low oil pressure reading
  217. Help Needed Troubleshooting Valvetrane issue. Pictures
  218. need some feedback on the comp r lifters
  219. shiming the oil pump spring
  220. i have 2 questions
  221. swap heads w/ motor in car?
  222. possible bent pushrod
  223. Want cam -> predator? vengance? etc?? help
  224. can someone post the gm hotcam spec card?
  225. quest for 600hp
  226. LQ4 with trak cam questions
  227. Stock rockers with aftermarket Cam??
  228. Kooks Or Slp??????????
  229. max horsepower build
  230. 408 setup questions guys chime in please
  231. Isky Cams
  232. Question About the rear of LQ9 Block ?
  233. is 500 unrealistic on a 346 for a DD?
  234. porting stock heads
  235. compcam 228/230 cam question???
  236. looking for a great cam...come help me out.
  237. Damage from accident?
  238. Please recommend Heads!
  239. Please steer me in the right direction on my rebuild!
  240. wierd exhaust noise
  241. Lifters
  242. Might be in the clear!
  243. For those that have used a helicoil to repair crank thread Have a question?
  244. speed inc fuel rails
  245. LS1 weight
  246. p0240 bank 1, replaced sensors already
  247. what cam with these mods???
  248. Flattened Lifter
  249. Baffling Cadillac lifter noises.....
  250. ASP pulley rebuild....
