View Full Version : Generation III Internal Engine
  1. Possible head gasket leak? Please help.
  2. help me understand cooling systems
  3. Possible timing chain noise
  4. HPE C+ cam?
  5. I Got a FI Comp Cam and now have a question
  6. patrick g first start up
  7. 9.52 Dynamic Compression ratio, that cant be right what am i calculating wrong?
  8. Problem with low oil pressure (1998 Trans AM A4)
  9. Gm Hot Cam
  10. cam only ls1
  11. Decently priced/quality stock size LS6 piston????
  12. Anyone running probe pistons?
  13. what cam for my a4
  14. Valve seal question
  15. complete list
  16. Swapping in a stock 6.0 short block for a ls1
  17. TFS heads milled to 58cc/compression ratio?
  18. AFR stock valve spring help
  19. Breaking in engine and clutch?
  20. Brand new motor, compression questions
  21. limits of stock bottom end
  22. Most reliable Stock ls1/motor/mods
  23. 6.0 truck question
  24. MS3 vs. MS4
  25. Anybody have an MS4?
  26. LS1 cams...
  27. Another knocking noise..
  28. Super 7 valve locks
  29. How much can u mill 853's
  30. Got my Jantzer ported TB back today... Thanks!
  31. Need some help with injector size!!
  32. what head gaskets to use with 408
  33. head casting number question...
  34. HELP!!!!!! Possilbe engine lock up
  35. MS4s accessories..What do i need?
  36. Ls1+243+.040+ms4=p/v Issues?????
  37. Porting 241's
  38. Valvespring life?
  39. Question about 5.3 heads with 58cc chambers and stock ls1 short block
  40. Pushrod concern
  41. Rebuilding a 98 block
  42. head gasket removal
  43. How much cam can stock rockers take?
  44. help what kind of oil to run at the track
  45. stock main caps max power
  46. CNC Help!
  47. Largest cam that'll fit my current heads/springs setup...
  48. Help with cam identification (and specs)! Supposed to be an HPE-S!
  49. Head Porting Question????
  50. need a combo from texas speed for 500 h/c
  51. ok... tr224 it is then
  52. 90mm Street Warrior LS Intake?
  53. Lingenfelter cylinder heads
  54. ETP Headed guys...pushrod length?
  55. BEST LS1 vavle springs?
  56. oil leak
  57. Problem With Cam Swap (Stripped Bolt)
  58. Props to Speed Inc
  59. 347 First time build!!!!!! pics inside
  60. What kind of gains??
  61. What tools used to tap out head bolt threads??
  62. sudden oil consumption problem
  63. Oil bypass problem...
  64. compression question
  65. LS7 lifter preload
  66. P to V with the patriot 226-226 .580-.580
  67. MTI X1 guys come in
  68. 224R cam hurt mileage?
  69. head bolt torque ??
  70. MS4 , vavle springs and fuel pump + 150 shoot
  71. Diamond Pistons out of hole?
  72. pushrod length
  73. Any One Wanna guess lsa?
  74. 110 or112
  75. Need help identifying sound
  76. running 1.8 rockers only on the exhaust side?
  77. lower compression lower mpg?
  78. TEA and Texas Speed 2,5 CNC LS6 heads?
  79. how much milling of heads is safe?
  80. LS6 Cam
  81. Need help clearing 0305 & 0704 SES codes
  82. E3 Spark plugs
  83. cam swap for next month
  84. help asap!! 228R & pushrods
  85. Different rocker arm/lifter question for you guys....
  86. Ls7 Lifters
  87. PRC 660 springs
  88. need piston help
  89. pushrod question
  90. Marginal gains with FAST 90/ NW tb
  91. the engine hasn't been turned since Feb.
  92. experience with TricK Flow Kit ?
  93. Any pictures of the harland sharp stock rocker bearing rebuild
  94. LS1 rocker arm part #
  95. burn 1.5 quarts every 3000 miles
  96. oil flush
  97. URGENT, are my heads ok? (packinging F up)
  98. any gains with '00 stock vette head's cam?
  99. car wont rev.
  100. Guys with a 224 cam. What heads are you running?
  101. 421 questions
  102. Question on heads
  103. can anyone suggest the right heads??
  104. Is the 5.3 Crankshaft the same as the 5.7?
  105. Need help with cutom grind
  106. Lq4 lifters and rockers
  107. is the FAST tb the only tb i can use on a fast 90intake
  108. Head ? Compression ?
  109. 115 at the trap selections selections ??
  110. is there a cam for stock intake manifold?
  111. g5x3 VII question
  112. Ls9
  113. Hope this is the right place to ask, but have I hurt my car by running 87?
  114. Advice on next mod for my car
  115. To sell the 02 WS6 or not?
  116. Crane 1.7 Roller Rocker Need Help reinstalling...
  117. How to tell if shortblock is ok?
  118. help me pick my cam
  119. 1.8 or 1.7 rocker arms
  120. thinking about upgrading cams - worth it???
  121. Block casting number?
  122. need opinions and advise please
  123. 408ci LS2 setup help
  124. 58cc chamber 5.3 heads?
  125. 393 cid stroker questions
  126. Maximum Head Milling Possible?
  127. spun bearing ?
  128. porting heads
  129. heads and cam?
  130. Checking Stock Heads
  131. Valve spring compressor help
  132. Cleaning head bolt holes
  133. Its time for a rebuild
  134. ws6tore
  135. Leakdown test question?
  136. Found a decent 347.. Tell me...
  137. Heads worth swap?? 806's for 241's??
  138. 5.3; what heads?
  139. forgot to put dowel pins in head
  140. stripped some upper rocker threads
  141. .171 pre load. Need some advice here on pushrod needed.
  142. help on exhaust
  143. Question about valve seals (which to get, and why?)
  144. Advice needed on cam selection
  145. Custom hydraulic cam and EWP, or Solid Roller?
  146. TSP 5.3 1.5 PTV question
  147. Has anyone hit 500rwhp with non-aftermarket heads?
  148. Anybody running West Coast Cylinder Heads ls6's?
  149. used block maching suggestions
  150. Z06 retainers? different from oem LS1?
  151. +.050" installed height retainers?
  152. should i install arp rod bolts on my 80 k motor?
  153. Morel Lifters
  154. Sponsors!!! Need lumpy daily driver cam
  155. What gains will i see
  156. Rpm Vs. Victor Jr Carb Intake Need Help?
  157. Patriot stg 3 Ls6 heads. What HP loss?
  158. 6.0 lq crank
  159. Help! Arp Head Bolts!
  160. which heads
  161. Patriot Heads Wont Fit Ls1?
  162. What's The Best Combo......
  163. got a quick ? bout heads and cam
  164. 383 with spray
  165. 00 lq4 work with t56 ?
  166. gouge on head sealing surface
  167. 224/224 .581/.581 TSP 5.3 Stage 2.5 Heads Gas Mileage
  168. MS3 gas mileage
  169. Tooks for checking PTVC
  170. Comp spring replacement
  171. help me build it right!
  172. Ok guys one more question before I pick up my car.
  173. So uhh... This is what a valve stem seal spring looks like... right?
  174. Head studs on LQ9 block...
  175. SPONSERS!! I need a short block!
  176. What Cam Do I have (pic is hard to see)
  177. what boost psi will stock243 heads start lifting. who ports ls2 heads
  178. How much vacuum does stock LS1 make
  179. Proper way to install OIL PAN GASKET?
  180. Ms4
  181. LS1 Guys, HELP!
  182. LS1 Hot Cam Installed
  183. aftermarket 3.905 pistons with stock weight
  184. 99 T/A cam swap
  185. Stock LS6 heads and cam able to pass smog?
  186. mods installed
  187. lq4 power loss
  188. Patriot LS6 STG 3 has 70CC exhaust runner?
  189. couple questions on this set up
  190. corvette intake ???????
  191. Engine guru's inside PLEASE!
  192. Problems...is it just a matter of tuning?
  193. truck 02 sensors used instead of 02 extensions?
  194. 232/234 .595/.598 cam anyone?
  195. TEA Stg 1.5 5.3l Heads and a 233/239 cam
  196. patriot performance pak
  197. The engine is back in my TA, have 2 questions
  198. Double Roller Oil Pump Clearance?
  199. What Do You Think Of Cam
  200. Anyone relocate knock sensors on an LS1/6?
  201. GM crank pulley/harmonic balancer bolt part number
  202. LQ4 Help
  203. Solid Roler Questions
  204. strange changes in car, Anyone have any Ideas?
  205. ZO6 oil pump ??? Whats the difference
  206. Jesel J2K Rocker PT ## ????
  207. Katech conecting rod bolts
  208. Texas 228r And 5.3 Heads
  209. please guys need some help
  210. Hi some LS1 Tech questions
  211. do these dyno number seem right?
  212. Best deal on mahle forged pistons ?
  213. cheater cam gains?
  214. Help with options
  215. Anyone using Canton oil cooler?
  216. my setup
  217. Engine tech q's
  218. New water pump?
  219. ok so heres my plan for a"mild" 383 build
  220. Oil Burning question
  221. oil pump still good after blown motor?
  222. cam head decision help
  223. ls6 heads
  224. LQ4 questions...
  225. What springs should i use??
  226. Considering Livernois motorsports heads... help?
  227. Looking for comments on my new book...
  228. Cam swap problem. Please help
  229. Reluctor wheel same for 98 and 2000 LS1??
  230. LS1 to LS6 conversion??
  231. Need help, in middle of cam swap
  232. Need help choosing a head/cam package
  233. What heads for my cam?
  234. head/cam swap gaskets
  235. Valve Springs
  236. help me choose a cam
  237. finished new setup short video
  238. Cam break-in
  239. How high can you rev a stock ls1 shortblock?
  240. I just did the 4th gear at 75mph gear ratio test?
  241. HELP!!! Engine Cranks But Wont Start?!?!?!?!
  242. which throttle body gasket
  243. stroker estimates...
  244. LS1 in reverse rotation
  245. Bearing question
  246. What kind of oil for 160k?
  247. Bone head engine builder built my motor and it made 5 whole passes.
  248. O Ring ????????
  249. rod bearing problem?
  250. 383 refresh almost done....
