View Full Version : Generation III Internal Engine
  1. Looking for 500.
  2. Thunder Racing Camshaft "Reverse Split"
  3. Complete LQ9 need suggestions
  4. ls6 intake manifold for sale
  5. Now offering head and cam combo
  6. FAST Vacuum Line
  7. Deciding On A H/C Setup
  8. Oil Pump Timing Chain Scar...
  9. Xtreame RPM Heads?
  10. compression ratio question
  11. broken bolt in crank need help
  12. Need Valvespring Shimming Experts..
  13. do u have oil consumption?
  14. Ran a compression test on my 98 LS1, tell me what you tnk.
  15. LS6 cam..what else should i do
  16. Spark plugs are orange WTF?
  17. getting retuned what shift points for 238/242??
  18. Am I cammed?
  19. LS1 pushrod question
  20. LS1 engine damaged- options?
  21. HOw to make ls1 into 383
  22. YTs and shim kits
  23. Head flow numbers for 6.0 escalade heads?
  24. TSP Torquer V.3 Questions
  25. update
  26. high milage RPM drop?? (long post)
  27. So I have a valve spring problem, not a head problem
  28. rebuilt motor W cam untuned
  29. Hot after H/C install
  30. help! cost to finish H/c
  31. cometic head gasket
  32. Head bolts to studs after engine bore...
  33. LS7 cam in a LS1?????
  34. Cam Install Nightmare!!!! Advice Needed!!!
  35. WIch combination will work with TSP 220cc 5.3L Stage 2.5 CNC heads
  36. Weird Oil Pressure Issue
  37. ls1 piston question
  38. 6.0 LS6 cam 15PSI Comp 918's OK
  39. Machine Shops in the Bay Area
  40. Need camshaft suggestion
  41. Knocking sound after cam installation
  42. ls1 swap questions
  43. New setup video (MS4/PRC 5.3 2.5's)
  44. Milling AFRs
  45. Coolant Overflow Replacemet
  46. 5.3 heads??
  47. smog legal CAM w/o egr for a 99'
  48. gmpp carb intake overkill on cam&spray ls1?
  49. is this good dd cam
  50. Patriots stage 2's
  51. Main cap install
  52. swap torquer 2 for a VRX5?
  53. harlandsharp stock rocker rebuild ???
  54. LS6 Swap Problem...
  55. My Patriot 226 to MS3 swap issue.
  56. Used cam question
  57. Will a vacuum leak cause a high idle and surging?
  58. hesatation
  59. Heads & pulley advice..........
  60. What H/C package will give me aprox 400rwhp. Some offers???
  61. Cars pushing 450RWHP......
  62. need quick suggestions
  63. Car has blown 4 valve cover (passenger side) gaskets in the past week
  64. 00 WS6 Wont Start
  65. First Cam Install...Am I forgetting Anything
  66. Guys with Patriot Dual Golds please come in here
  67. PRC LS6 Heads Get A Face Lift!! 225cc Runners!!!
  68. 119,000 Head and Cam build
  69. Will Trick Flow packages be great??
  70. HELP!!!- Car wants to Rev on its own at times, WTF???
  71. MSD Coils Vs Stock on LS1
  72. MS3 valve train noise..oil?
  73. Oil pick tube. How do I clean it?
  74. et 11* head
  75. largest od valvespring with stock rockers
  76. HELP!!!...new motor problems...
  77. Stock Rocker Arm Broke!!! Help!!!
  78. Stock piston question (LS6 & LS1 Difference)
  79. Valve Covers??
  80. 12.01:1 compression. TR55's or TR6's.
  81. 7th cylinder misfire code on 99 LS1 with hooker 1-7/8?
  82. Putting motor back together. have some questions please.
  83. PICS of my engine carnage, good stuff!!!
  84. pushrod length help
  85. 02 and up ls6 cam id numbers?
  86. lq4/lq9 6.0 crankshaft/block identification (need help quick please!)
  87. GMPP Carb intake gasket part #'s?
  88. how much power can the ls1 block handle
  89. ANOTHER new problem
  90. Fly Cutting question on gt1-1 cam
  91. Never thought i would ask, what HP?
  92. Only those running 98 stlye heads.
  93. Ported and Polished Throttle Body
  94. 6.0?
  95. will this give me at least 400 rwhp/rwtq
  96. ls1 problems
  97. LS1 Oil Consumption
  98. need a little help
  99. Shortblock is together... back on the road soon!
  100. GM Performance Heads
  101. Make the TA non ram air work
  102. Will forgetting to install the oil plunger feed the motor unfiltered oil?
  103. Need help with head decision.
  104. best place to balance?
  105. Headgaskets, 11:1 or 10.6:1?
  106. Flycutting Tools?
  107. Need Tune or drivable for a few miles?
  108. Which cam?
  109. Maxed out MAF, now what?
  110. weird clicking
  111. Best price anyone's received on AFR heads
  112. I am going to have a switch to blow smoke out the tailpipes
  113. ls2 heads?
  114. oh so i want to take my motor out
  115. what fuel rails with fast, FRC's, fuel regulator(for return syle car)
  116. 3/8 pushrods in a stock ls
  117. I need an lsx specific guide
  118. Push Rod Length
  119. New 402-Oil Pressure?
  120. Oil pressure readings w/ real gauge?
  121. Can you re-use torque to yeild head bolts if they haven't been heat cycled?
  122. Largest Cam wit tsp prc stage 2.5 5.3's milled to 59cc
  123. Calculating final compression for motor build?
  124. Bottom end assembled w/pics
  125. Dyno numbers and Cam Questions
  126. Finally fired the new motor up today! but...
  127. Crazy Cam Install Question
  128. Another "Take a Guess" thread..
  129. Which first? cam or intake?
  130. Fast 90/90
  131. TTP Equalizer 3 cam with a 383 stroker
  132. Part# for oil pick-up o-ring not GM#
  133. AC Delco Platinum Sparks
  134. Can any one tell me what cam this is??
  135. Looking for a thicker head gasket and help with figureing comp. ratio
  136. Valvtrain Noise (I searched)
  137. Which spark plug to use in a ls1 1999?
  138. Ls2 & 5.3 heads better?
  139. My setup (gains?)
  140. engine bolts
  141. Ring Gap Measuring Question...
  142. Underdrive Pulley
  143. Old Lifters New Cam
  144. 1.7 RR's on a stock cam...
  145. B body or F body Where would you guys go in 2009?
  146. does ls1/ls6 motor come with oil pan?
  147. Blower cam
  148. MS3 prc 5.3 2.5 heads RWHP
  149. What is a 799 casting head for the ls1?
  150. Another pushrod thread..
  151. how to reinstall stock rockers?
  152. Max pressure on stock rockers
  153. lq4 in a 01 Camaro w/T56
  154. 99-00 lq4 crankshaft longer
  155. Building a n/a 370ci, which direction for H/C/I?
  156. L92 Heads Better To Buy Complete Or Bare?
  157. LQ4 ?'s
  158. Cam with stock drivetrain?
  159. will 92mm TB fit 90mm Intake manifold?
  160. Need EGR block off plate help -- doin work now and i'm stuck
  161. LS6 Heads and cam
  162. Max lift on stock LS1 springs????
  163. LS1 vs 5.3L
  164. idle issue..
  165. Which cam??
  166. roller rocker question
  167. need to know what you think
  168. Quick Question about ARP rod bolts
  169. lsa
  170. Compression Help Please
  171. reinstalling engine & cradle- fit with mac mids installed?
  172. Cooling System Vacuum Leak
  173. Need Help With Cam Choice--Help
  174. Will this run on 92 octane?
  175. Opinions on this combo. . .
  176. what cam to get
  177. what power levels with LS2or6 ported heads?
  178. ls1 383 come on in!!!!!!
  179. Block honing and piston size?
  180. LS1 gurus please help
  181. LS4 Flywheel?
  182. 99 motor to 98 car???
  183. Dart 225's and TSP 233/239 112lsa PTV??
  184. Big CI vs. small CI + FI
  185. Porting LS6 Intake
  186. Whos running a 233/239 cam w/ TSP 2.5 5.3l heads?
  187. I Need Flow Charts ( 243 Heads ) Intake
  188. Oil Pump & Timing Chain
  189. What pushrods for Cam?
  190. Part no for injector o-rings and washer ?
  191. Rev limiter
  192. Solid roller questions
  193. Good Setup???
  194. problem when mashing out!!
  195. Trying to Id heads?
  196. How much rwhp is in a '04 Z06 Vette?
  197. HELP Please.. SLP timing chain and oil pump install questions
  198. meziere pump?
  199. C/H swap with motor in car????
  200. XRE vs Cam motion lobes
  201. Compcams Pro Magnum 1.85 Rockers Keep Coming Loose
  202. Boosted short block
  203. Will these springs be sufficient.
  204. ported 6.0 alum. heads?
  205. Dyno #'s are in!
  206. h/c or paint/body work
  207. Dart 205 vs. TSP stg 2.5 5.3's
  208. Which head bolt kit for head swap?
  209. Cammin my ls1
  210. heads for weekend car?
  211. Which heads for G5X2?
  212. Need 370ci build advice
  213. In need of quality advice
  214. Where to get custom cam for ls1??
  215. main and rods bearings
  216. HPE Megadeath
  217. Complete Engine Buildup in 30 Days?
  218. need help on a build
  219. cam/head setup for daily driver
  220. Rev to 6500 on stock ls1
  221. small cams and dual springs?
  222. Vengeance cam with PRC heads?
  223. Which is faster a bone stock SS Camaro are a Ws6 both are 2001?
  224. Just picked up my first cam, got some questions
  225. power to be gained..
  226. Cammed 402s...need your input...
  227. well... looks like the 408 is dead :(
  228. How many needle bearings in a stock LS1 rocker?
  229. $1200 limit for heads what ones
  230. Urgent! Need some help problem after rocker install
  231. Oil pump bolt size?
  232. Extended Warranty...?
  233. so why a lid?
  234. Is a stall a true necessity for a cam?
  235. How much power can I get from a zo6 cam?
  236. Quick rod bolt question for you engine builders
  237. Oil
  238. What 383 cam?
  239. I need some direction for C5 engine mods?
  240. Comp 918's...
  241. Valvetrain tapping
  242. tell me about this shortblock
  243. ??? About 243 heads
  244. trex and carb
  245. what year throttle bodies are diff.?
  246. got some dart 205's on the way
  247. Timing chain: should be "loose" or no?
  248. car aint runnin good eek!
  249. 59 cc heads PTV with tv 2 cam???
  250. Cam Size
