View Full Version : Generation III Internal Engine
  1. ls6 springs and trex
  2. Just Ordered My Lm1...
  3. are patriot gold stage 2 59cc heads ok for a 416?
  4. tfs heads and roller rockers? what was your choice
  5. Any hope for a .600" lift cammed car as daily driver?
  6. rod bolts
  7. Ur chance to spend my $ ...
  8. Just ordered...
  9. 6.0 truck engine
  10. LS1 to an LS6 heads, intake, cam
  11. OK changed out oil !
  12. Compression
  13. TSP and cam experts come in
  14. 97 & 98 corvette owners regulator related
  15. lifter question
  16. PTV, PRC 59cc + TR224 + 0.040" hg
  17. Valve part #
  18. How does this procedure look to you?
  19. piston location at tdc
  20. Help me build bulletproof block
  21. wiring 408 problem!!!
  22. 98 crank and block
  23. quick question
  24. head bolt broke in block
  25. LQx rod strength
  26. Possible StingRay Project - Input Wanted
  27. Is there power left on the table with the MS4 & LS6 2.5 patriots
  28. Diagnosis on higher RPM skipping
  29. Torque Plate Question...
  30. Is it okay to run 50 weight oil?
  31. Will i need to change plugs?
  32. Cadillac Escalade Engine/Trans Swap?
  33. building a shortblock
  34. patriot owners please enter inside
  35. HELP SLP 402 rear main ??? problems
  36. Catch Can
  37. which cam?
  38. Blue And A Lil White Smoke....
  39. x3 and 317 heads
  40. Opinions on these el-cheapo's
  41. Keeper broke during cam swap
  42. What should I look into before I do a cam?
  43. Broken/Cracked Ringlands on stock pistons???
  44. Threw a rod bearing, what are my options?
  45. How many $$$ to clean, deck and torque hone an LS1??
  46. broke a valve!
  47. Getting lower oil pressure than usual??
  48. can you go over kill on springs?
  49. TFS head users
  50. Darton MID Sleeves for 02 LS1 Block
  51. Uggg.. stuck lifter...
  52. how to tell which lifter is bad?
  53. 224/224 112 lsa on stock manifolds
  54. Beehive Springs info
  55. How much idle vacuum with XR275HR-12
  56. What springs for my setup?
  57. Realistic expectations?
  58. What to do? Buy a SB or buy rotating assy?
  59. Trying to decide on exhaust, maybe you guys can help.
  60. Crankshaft ????? Help me decide...
  61. What breaks at 600 rwhp
  62. need some ideas on next step
  63. LSA and boost
  64. ls1 Total Rebuild hp? Part? Mod?
  65. run it or.....?
  66. I need help guys, sorry, just lost at this point
  67. What is wrong?
  68. best cam 4 gto???
  69. What Springs?
  70. Who has used there stock push rods for a mild cam?
  71. install done
  72. How can i tell if lifters are sticking
  73. stock head gasket size?
  74. wanting to buy an intake manifold. NEED SOME ANSWERS
  75. Seafoam with synthetic oil????
  76. Katech rod bolts...where to buy?
  77. Slight Knock/Tick in 2001 LS1
  78. Alrighty, another what heads with this cam thread.
  79. Pushrods/heads/cam compatibility
  80. wiring problem!! 408 install
  81. Buying an LQ9
  82. Need Help With ET Heads
  83. Hydrallic roller lifter install
  84. Cam degreeing questions
  85. Gasket sets?
  86. Christmas Morning!
  87. ARP bolts... best place to buy?
  88. another cam question.
  89. Whats some odd and end stuff to think about? getting ready to put a motor together
  90. Oil level sensor delete plug part number
  91. WTF is this?
  92. Alright guys...Here goes
  93. What heads for my app?
  94. Is 231/238 .617/.605 113+2 lsa to much, will it clear????
  95. Need advice on a CAM please
  96. looking for people using etp heads
  97. Probably shoulda tried the search.
  98. LS1 Gasket Kit???
  99. Any one use torquer v.3 cam
  100. cam help?
  101. whats this mean??? Possible head work??
  102. anyone use comp. adj. rockers with etp heads
  103. who makes z06 style ls1 emblems?
  104. Need Help With These Pain In The A@s ETP Heads
  105. Lifter/rocker tick... possible quieting method + story
  106. Texas Speed 233/239 on 113 LSA
  107. Should I replace spark plugs?
  108. Should i do this cam???
  109. anyone have any ARP head stud sizes?
  110. cam question??? ls1-ls2
  111. wanting thinner reasonably priced head gaskets
  112. solid roller lifters which is the best
  113. Top Speed Heads/Cam pkg
  114. need help installing adjustable rockers on etp heads
  115. Is my rear end falling apart?
  116. the dangers of a cam?
  117. Dyno Results: F13/Patriot Stage II LS6 heads
  118. Loose rocker arm help
  119. Dyno/drag/plug problems *LONG*
  120. what are SVO 30lb injectors compaired to FAST 33lb Fuel Injectors ?
  121. what are SVO 30lb injectors compaired to FAST 33lb Fuel Injectors ?
  122. Wear on cam lobes
  123. Want lower fuel prices?
  124. 4.00" Stroke and stock windage tray?
  125. Anyone have a cam fron Dragon race engineering?
  126. cam questionaire?
  127. LQ4 piston suggestions
  128. Dyno Results After 228/228 and 5.3l Heads
  129. best heads??
  130. corvette cam in 99 z28
  131. bearing question
  132. Dyno numbers after cam install
  133. Broken Intake Bolt Question. New Heads?
  134. cleaning block????
  135. cammed A4 what MPG?
  136. Rocker stud pulled out...gotta question.
  137. Anyone ever deal with Nevarez Racing Products in Las Vegas?
  138. Valvespring Overkill?
  139. SES light after thermostat install... coincidence?
  140. largest cam to run without flycutting
  141. 218/228 114 lsa .585 lift your thoughts...
  142. what heads and cam for a 383 stroker?
  143. cam lobes
  144. How hard to install thermostat?
  145. need help ls1
  146. broken headbolt deep inside the block
  147. Do stock rod bearing tangs face out on 1,3,5,7 and in on 2,4,6,8??
  148. any idea's
  149. El es Jaun (toast crank)
  150. Please Help!!!!
  151. adjusting rocker arms
  152. comp cam 918 valve springs...
  153. gasket and mill my 243's
  154. How about this setup?
  155. Gaskets/Bolts Needed For Cam Swap
  156. patriot stage 2 heads (milled 59cc)
  157. MS4 cam
  158. TR 230/224 111 lsa cam
  159. head gasket for torquer 2 and n20?
  160. Yella Terra UltraLite 1.7 RR-Sponsors Please
  161. Put New Motor in...Can anyone tell me where this goes?
  162. biggest cam on ls1 w/ dart 225?
  163. Cam bearing problem
  164. what parts do i "need"
  165. fired my 408 for the first time..got qestions
  166. What causes a stock LS1 to ping?
  167. Finishing up: Engine Intake
  168. car wont run after h/c swap
  169. cam only 400whp
  170. Another "how much RWHP should this make" thread...
  171. Head Gasket
  172. will 97 engine harness plug into 93 harness
  173. Compression maybe?
  174. Car turns over, But wont start! Help!
  175. ok 408
  176. PCV catchcan, still burning oil after cam
  177. New Motor Question
  178. Info on installing 1/2 heads studs in alum block
  179. in need of help
  180. 1.85 Rocker Arms Worth it on STOCK cam?
  181. Sound clips Incld'd - KNOCKING???
  182. MTI G-1 Vs. X-1
  183. looking to make 400rwhp
  184. better the heads requires less of a cam right
  185. sleeved ls1 engine bore 4.100 whats need to run ls7 head/intake
  186. tapping noise on driver side
  187. parts for engine build
  188. confused on motor to go with
  189. HELP! Stripped knock sensor in valley.
  190. HORRIBLE KNOCK!!! Car won't Idle, backfire, etc.. need help!
  191. Any reason to avoid '04 GTO LS1?
  192. LQ4 or LQ9
  193. New gasket kit, which one is the oil pick up o-ring?
  194. Oil coming out the the #7 exhaust port....
  195. 1.85 track results
  196. 406 build
  197. Trv 3 Camshaft! Anyone else?
  198. Port match head to gasket(exhaust)
  199. help ls1
  200. MTI X1 cam sound clip!
  201. Another oil thread........Quakerstate Syn?
  202. What heads for my combo?
  203. Coolant Cross over tube to each head torque spec ?
  204. .030 head gaskets?
  205. NEED HELP with JP 5618T single timing set install
  206. Quick head gasket question
  207. inspection??
  208. Little confused on cam lift..
  209. LS1 Edelbrok cam?
  210. What all does it take
  211. what cam
  212. looking for some exhaust input
  213. Check Engine Light!!!!!! Off & on
  214. what the hell?
  215. lq4 specs
  216. Cam Only 230/230 Track Results...must See
  217. Where can I install a mechanical oil pressure guage?
  218. BAckfiring issues...
  219. BEst Cam
  220. cam help
  221. mpg on a 370vs402vs427
  222. how long do springs last with TRAK cam
  223. Another rebuild question...
  224. help have some trouble
  225. cam help??
  226. need help!! tsp 408 stroker install
  227. The 416 is finally alive!
  228. Is diffrence in cams major?
  229. question
  230. Car wants to die when AC is turned on MAX
  231. Need Valve Seals For Dual SPring
  232. so i got c6 243 heads for my ls1...
  233. 130 trap speed
  234. replacing rockers, is there a special procedure?
  235. will the l92 heads a cam make 500hp on a lq4?
  236. Need help with bullet selection for my LM1, LT's, & ORY
  237. Help! Car leaking oil after hitting huge puddle.
  238. Anyone Else Notice This?
  239. At what point are pistons trash??
  240. Setting PReload on Comp 850-16 lifters
  241. Camshaft exhaust closing events
  242. Eliminating o2s ?
  243. best spark plug to use?
  244. 420+ rwhp cam cars
  245. New Cam Going In
  246. n20 and cam car help
  247. custom grind cam specs
  248. Are coil packs/harnesses side specific?
  249. Cam E.O. emissions legality
  250. Oil pump "bypass" valve question
