View Full Version : Generation III Internal Engine
  1. engine balancing question
  2. Help me with my cam selection please....
  3. got a new cam question
  4. oil pressure probem, need help
  5. cam and head question
  6. 224 cam...5.3 or 5.7 heads?
  7. Porting oil pump
  8. ls1s, 2 cycle or 4 cycle engines, i know this is a dumb Qs, but i need to know
  9. Engine Lift Procedure?...
  10. Crankshaft repair/ DE De De award
  11. TSP 231/237 Cam
  12. MTI X1 w/114 LSA?
  13. Valve spring shims?
  14. squeaky noise help...
  15. Comin home on leave soon, would like new toys waiting.
  16. So I am starting my refresh of my 383 Let's talk bearings & Rings
  17. Cam Suggestion
  18. PRC Springs ?
  19. miss fire
  20. Trickflow Heads w/Scorpion Rockers
  21. Cam choice TR 227/224-114 or TR 224/224-112
  22. Weird sound in the motor.
  23. Texas Speed Cam Install??
  24. Matching a cam to head flow numbers
  25. Help with fuel rail bolt
  26. Rockers question
  27. Engine backfired, now I don't have any spark
  28. Trying to diagnose Oil Pressure problem
  29. I have a couple questions about ls1 lifter trays or retainers
  30. 402 up and running, hanging throttle??
  31. Lightest Stock Stroke crank
  32. What are 217 heads? ( lq4 / lq9 question )
  33. i want pistons and rods for heads and cam
  34. Install in Progress Help Spin Crank to TDC for pushrod??????
  35. oil pressure, cranking??
  36. engine assy
  37. Compression > w/ big shortblock?
  38. cam feedback
  39. need info. please help
  40. STS feedback
  41. 383 vs 408
  42. Called a few places and noone can get me the rod bearings I need??
  43. How do these head stack up?
  44. need help please
  45. Help with patriot heads please.
  46. SLP Intake
  47. Stuck on Picking Heads and cam package.Help
  48. Crank Freeze Plug
  49. Questions about cammed LS1's...
  50. White Smoke
  51. What is the part number for the ls6 coolant crossover lines?
  52. Who has tried Mobile 1 0W30?
  53. 2000 LS1 in 68 Camaro...
  54. Valve stem seal install HELP!
  55. How much difference will there be between these runner sizes?
  56. Lound bang at Idle and low rpm
  57. rods and pistons
  58. Need 1 NEW exhaust valve seal
  59. PRC heads flowed locally, need another cam
  60. cam and emissions in MD
  61. LS2 timing chain damper
  62. Need Lifter to check PTV clearance - where do I get one?
  63. New 408 offer
  64. Oil Everywhere!
  65. Need Someone With a 5.3 Vortec......
  66. Questions
  67. What Do You Think My 2001 Z28 is worth?
  68. WTF is this??????
  69. Started the rebuild
  70. Help needed!!! LS1 missing!!!!
  71. need help
  72. slight hesitation at part throttle at low to mid rpm
  73. Need some help figureing out compression ratio.
  74. L92 shortblock w/ LS6 heads
  75. comp 928 springs stock retainers
  76. spark gap
  77. new 416 ls3 is here..
  78. Budget build
  79. Cam for my setup
  80. Cam Pro's, help me Spec a new cam for me
  81. Is this a good 383 setup?
  82. New Engine
  83. help find the problem
  84. Mamo FAST 90/90 is on!
  85. Ticking noise AHHH SH*#
  86. Head gaskets
  87. what numbers can i expect with this setup...
  88. Engine Making a funny Noise
  89. power from gl hot cam
  90. Is it Normal after H/C install?
  91. Heads?
  92. (help)what kinda springs and retainer?? pics inside
  93. Shitty Sounding Lsi
  94. Some spring questions...
  95. My setup in the works...
  96. camshft driveability
  97. cam comparo 228r vs 230/230 600 predZ spec
  98. question about polishing the ports on heads
  99. How much can I mill my heads??
  100. Spending tax money..
  101. Head studs?
  102. converter/cam
  103. 408 opinions
  104. aluminum heads ?
  105. F13 is in
  106. Gas mileage with the addition of heads?
  107. G5x3 Clearance Question
  108. Loud Knock when Cold HELP!!!!!
  109. Whats the best way to address blow-by?
  110. Few questions about Gen3 assembly and Patriot golds.
  111. Stupid to cam without aftermarket heads?
  112. Upping compression with 853 heads and stock cam ('99 LS1)
  113. LQ4 Starter part number?
  114. what can i expect?
  115. Engine rebuild?????
  116. im having trouble with my 99 vette...help
  117. Best 5.3L Heads For The Money?
  118. ms3 cam requirements
  119. stock shortblock quench?
  120. fast lsx 92mm or 90mm which should i get?
  121. Single timing chain
  122. What thread size is the coolant temp sender in the head?
  123. Best heads for 224 cam with 112 lsa?
  124. help, quick crank question
  125. Installing Cam b4 Ehaust ?
  126. dyno results tr230
  127. What spring compressor?
  128. 3" or 2.5" collectors?
  129. What size Cam???
  130. 230/232 .612/.595 ptv issues 64cc heads??
  131. allen plug size
  132. Block ID
  133. how about rods , pistons , MS4 and ptiriot 64cc
  134. P/V clearance and cam timing adv. relations
  135. Cam question
  136. 6.0 Guys Look Please
  137. yt lifter preload?
  138. Scorpions vs YT Ultralights Rocker
  139. scat i beam?
  140. 5.3L questions
  141. Assembly Help!!
  142. strokers
  143. 224/230 .581 .592 114 Lsa
  144. guess my hp?
  145. Finally getting ready to take the plunge
  146. spring compressor help!
  147. Lq4 ?
  148. cam swap coming
  149. best cam for build
  150. Burning oil question.
  151. Ls1 Using oil
  152. 243 Heads intake seat in port
  153. Best cam to pair with LS6 springs
  154. looking for the best shop around sacramento ca for ls1's
  155. cam grind???
  156. prc terminator heads?
  157. crank ???
  158. Degree a TREX?
  159. Time to change valve springs?
  160. When to change patriot double gold springs?
  161. how much HP
  162. Flow #'s of 241's after Port/Polish?
  163. valve seals
  164. Tomorrow is THE day!
  165. 6.0 oil pan
  166. 383 Cam?
  167. how high would you spin a stock shortblock poll
  168. which roller rockers?
  169. Valve Float
  170. 853 casting heads????
  171. What To Gap NGK Tr6s To? H/C/I
  172. Oil comparison pdf, what does everything think about this
  173. Couple of Q's on cam swap.
  174. stroker.
  175. Help!!!! With Disconnecting Return Line
  176. I'm going for max efficiency
  177. Hot cam set off misfire code at idle?
  178. Heads for 220 cam . . .
  179. Hard starting and tach not working
  180. lifter install question - middle of a build- Help!
  181. LQ9 Heads on a LS1
  182. flakes on my oil plug? help!
  183. VRX5 from Vengeance
  184. What mods next?
  185. Cam swap. Timing cover/oilpan install question
  186. Check out my 418 combo.
  187. H/C setup Whats the numbers going to the tires
  188. H/C and setup questions
  189. Picked up set of 5.3 heads casting 862 got some questions
  190. Texas Speed! Help!
  191. Engine knock need help
  192. balance fly cut ? one off -.025
  193. where to send heads
  194. Melling Oil pump
  195. 228R or MTI R1
  196. Rod knocking question about fixing it
  197. cam question...
  198. Torquer V3 Question
  199. TFS Stage 3 cam or Vengeance?
  200. cam is in, idle clip inside.
  201. 400 bucks for head install? good?
  202. 6.0L Head gasket delemma
  203. Still Ticking!After Pushrods
  204. Summer Cam Selection...
  205. another "how much HP" with G5X2/LS6
  206. German Castrol
  207. Re-Ring for Track Car - Questions
  208. problem with smoke , need help
  209. C.A.T. brand internals?
  210. PCV hose
  211. question on installing my engine
  212. Will #241 heads fit a 5.3l engine?
  213. 370 vs 408
  214. LT1 oil pressure fluxuates
  215. How to check if all 8 cylinders are firing
  216. Trick Flow "as cast" heads
  217. lsx build
  218. What kind of power?
  219. trick flow cam or trak cam
  220. Anyone know the difference from LG's G5X3 and the G5X3 version 2?
  221. H/C set up with procharger in mind for the future
  222. help putting slp under drive pulley
  223. Plugs?
  224. SES Light after missed shift
  225. New service Offering
  226. PTV clearance question / scenario for the experts
  227. Need Advice ,Budget Rebuilding My ls1
  228. 23x's cam duration ?'s
  229. How to get 52cc chambers
  230. cam question
  231. Stock cam ?
  232. Worn Comp Cam lobes and oil additives
  233. h/c opinons
  234. oil pan drop
  235. WTB New assembled LS1 block
  236. anyone running tsp torquer v3 in your vette?
  237. Anyone run a 5.3 head with 59cc? 224r cam
  238. I read there was a problem with the futral f13 camshafts a while back??
  239. idle video finally tr 230
  240. Largest cam on stock LS1 springs.
  241. Another cam swap thanks to LS1Howto and LS1Tech
  242. SLP 402 shortblock, good buy or not ??
  243. Pushrod help
  244. Fel Pro head gaskets and copper spray??
  245. What is need to upgrade my cam from a TR224 to something BIGGER!
  246. How comparible will this Comp be to TR230/224?
  247. Rust on cam
  248. Camaro Flywheel - to - Corvette
  249. oil pan
  250. All New Version 2 PRC 5.3l Cylinder Head Pics!
