View Full Version : Generation III Internal Engine
  1. step closer to H/C build being put together..
  2. another pushrod thread
  3. H/C gains
  4. Buy pre-assembled short block 408 lq4 or buy rotating assembly?
  5. lq4 coil swap yeilds definite power increase
  6. Build thoughts, lq9/with what heads
  7. Heads/CAM HELP !!!
  8. Need Help Picking The Right Cam!!
  9. Another "criticize my build" thread
  10. Are Comp Lifters Better Than LS7 Lifters?
  11. Graphs to compare VRX3 vs VRX4 no heads
  12. Flaw in block. Will this affect it?
  13. LS1 Refresh
  14. Best CNC port program for the 862 heads?
  15. Need Some Help - Coolant Leak
  16. H/C/I Parts List
  17. Valve cover and coil brackets for a 98 to 243 head swap?
  18. proper numbers for aluminum rods?
  19. head question
  20. Serious Problem, need opinions please
  21. Lacking midrange power camaro ls1
  22. wierd noise inside cam only Ls1
  23. Why is my 5.3 crank sticking out?!?
  24. any truth to this info...???
  25. What cam to choose in a stock LS1?
  26. Pushrod question!
  27. Wide Band O2 sensor
  28. Where does the coolant line/hose go?
  29. cam gear 1 or 3 bolt ??? help asap !
  30. What combo to cure my LS1's asthma
  31. LQ9 Cam and Injector Questions
  32. Intermittent lifter noise/misfire after head swap?
  33. N20 347 build
  34. what heads to get to go with ms4 cam
  35. Thinking of upgrading from PP 5.3 heads.
  36. patriot gold dual springs
  37. Smoke after cam install.
  38. EngineTech Valves or Reuse OEM Valves?
  39. LS1 manifold
  40. How many miles is too many to cam a LS1?
  41. Ed Curtis Cam / AFR 205 Install / Results
  42. whats the biggest intake manifold, set of heads I can put on my ls1
  43. Need help identifying a cam
  44. 5.3 questions
  45. bought an ls1 that needs some refreshing advice plez
  46. Cam help!
  47. bearings... replace or not. pics inside.
  48. Help Id these connecting rods?
  49. Where to shift at?
  50. spark plugs for 408 replacing LS6
  51. What ls6 heads to run with torquer v3
  52. California only Mobil 1 engine oils?
  53. Does anyone know if this cam will work/make close to 450rwhp??
  54. cam for lotus esprit ls6 swap
  55. Torque Wrench for installing heads
  56. what type of head can I put on my ls1 ??????????
  57. LS oil gallery fitting
  58. Double row timing chain + Meling 10355 oil pump
  59. Crank bolt removal..almost to easy
  60. LS1 Build Help
  61. If you take the intake and valley cover off, can you see...
  62. is it worth building a 383 stroker with a LM7?
  63. finished my streetsweeper HT install(Vid inside)
  64. etp heads
  65. LS6 heads
  66. Rebuilding my LQ4 for my BMW. Basic Questions
  67. Question about comp 977-16 springs
  68. 6.0 vs ls1?
  69. I think I have a problem, I just don't know what it is.
  70. well it rebuild time
  71. Rebuilt Engine Break-In Time?
  72. 5.3 head choice! Need help
  73. need to know what cam i bought??
  74. a little help
  75. 2000 camaro ls1 sitting
  76. tsp torquer v2 and .600 lift springs
  77. What cam, intake - Mild 5.3 street rod
  78. How bad does fuel mileage suffer?
  79. Question about stroker crank for 5.3
  80. Head gasket bore diameter?
  81. Hot cam Help!
  82. What Heads to get?
  83. Replacing rod bolts while motor is still in car?
  84. 383 stroker build
  85. Heads for boosted LS1383 stroker?
  86. need help tracking down a noise.
  87. Bought used arf heads on here.. this is what i got.. What to do?
  88. short block price?
  89. RapTR and etp 215 head combo
  90. Help me decide what camshaft to go with!
  91. Overheating/bleeding FIXED
  92. Valve Float?
  93. lq9 compression options
  94. is it necessary to have heads decked?
  95. Help!! I think I have a Lifter Problem
  96. Anyone using TFS heads with stock rockers?
  97. How much would different heads help
  98. F13 cam, no low end pull...
  99. Which cam should I go with?
  100. How to tell the PRC LS6 stage 1 and stage 2.5 Heads apart???
  101. cam card help
  102. gen 4 rods/pistons in a gen 3 block?
  103. Oil pressure gos down when I floor it. Help!!
  104. Need some help from the cam/head guru's
  105. Wow, She's a Winner!
  106. LS1 Engine Upgrades in 68 camaro
  107. Are these Yella Terra rockers useable?
  108. Camshaft for Magnacharger
  109. need pointed to RELIABLE vendor that has goodshortblocks
  110. 97/98 LS Engine Headgasket ?
  111. 853 heads really that bad or is it just a matter of opinion
  112. Exhaust question??
  113. HELP!!! Car is consuming coolant and has a knock!!
  114. what cam and specs please?
  115. LS1 crank removal?
  116. 5.3 build
  117. LM4 5.7 B4C Build
  118. What are the car cooling system pressure test leak locations?
  119. please confirm my pushrod length befoe I order
  120. XER Lobed Cams Eating Lifters?
  121. set up for ms4cam
  122. LQ4 cam bearing pic
  123. Opinions?? Lq9 Build
  124. Long push rods effect ptv clearance??
  125. Creating a monster
  126. how to identify ls6 heads
  127. Least amount of time to SAFELY soak lifters??
  128. What do i need ? LY6 block into ls1
  129. rocker play after new head and cam intstall helppp
  130. Debating on ported heads or aftermarket heads
  131. Help!!! wont start.
  132. 243 heads and cam swap questions
  133. what the hell is this?! came out on the drain plug *pics inside* please help!
  134. Does a cooling system pressure test show if you have a vacuum leak?
  135. Ls1 2000 radiator help
  136. What head gasket for lq4 370?
  137. LS1 944 Dyno results
  138. Help!!! Engine swap now overheating.
  139. Cam Swap Parts List?
  140. Rocker keeps coming loose.
  141. What now?
  142. lq4 build need cam spec help, with stock sounding idle
  143. Please help with cam specs
  144. Max cam lift standard gen3
  145. will this cam fit with standard heads...
  146. 5.3 head gasket suggestions?
  147. questions about porting heads
  148. hp i can get with some mods
  149. need help identifying 6.0 block, pic inside
  150. timing chain slack ?
  151. will these valve springs suffice? TRAK cam
  152. Need some help with Cam/pushrods
  153. Correct Rocker install
  154. Need help choosing a cam...
  155. heads cam and exhaust setup
  156. whats wrong inside my motor?
  157. Used cam question
  158. best oil pump out there?
  159. Timing cover clearance...?
  160. Name that Piston
  161. cam help for dd
  162. 243 heads
  163. Am I on the right track with my 383ls1 build?
  164. Heads Build??
  165. valve train noise issues - updated 10/11, compcam trunions installed
  166. Compression question (317's on 5.7)
  167. LUNATI valve springs
  168. Getting ready to purchase Cam and others...
  169. blew up my ls1
  170. cam too tight ???
  171. decent combo??
  172. Where to get my heads cnc'd 862#
  173. Should I have my heads ported more or buy new?
  174. Matching converter to h/c combo
  175. Finally Getting H/C Need Some Help...
  176. Help Identify Ported 862 heads
  177. I don't think I will use an ARP Harmonic Damper Bolt again.
  178. Does this sound like a warped head?
  179. Changing oilpan
  180. Dart 205 & RHS 205
  181. Urgent ls1 issues got race this weekend
  182. G5X4 cam stock bottom but....
  183. Cold start and stall...valvetrain chirp?
  184. Comp Cam High Energy Lifters
  185. 404 stroker piston installation (video)
  186. LS7 lifters
  187. 600+ Cam springs?
  188. LS1 to LS2 Heads on '98 T/A. Need help before buying
  189. Help me pick a cam/stall for DAILY DRIVER 68 Camaro w lq4/ls3 heads.
  190. cam size range for 98 ls1
  191. Whats this noise? Video inside
  192. cam install question
  193. LS1 383 Build
  194. stock 6.0 or 408 pump gas motor. need alot of torque and help
  195. AFR Heads? Bronze guides + Rockers
  196. 228r Cam Swap Results Video.
  197. 212 / 218 cam in 5.3 liter vortec (video inside)
  198. ls1 to iron 5.7 slight knock noise?
  199. High oil pressure causes CEL
  200. 6.0 LQ4 Options
  201. BBK Manifold not fitting???
  202. wierd ticking noise
  203. MY FIRST H/C/I 346 N/A Build lots of PICS.!!! Updated page 2 and 3
  204. Double check my 370 specs (compression)
  205. Can someone identify this part please
  206. LQ4 build... Need some help please!!
  207. help with some issues with my car
  208. Got a problem (ls1)
  209. lq4 370 build N/A
  210. Thompson Motorsports review
  211. H/C/I car down 1qt. oil after 500 miles
  212. Compression test cost?
  213. 98 rod bolts
  214. Lq9 408- f1x combination need advice!
  215. Blower Cam Input?
  216. 408 pistons?
  217. Am I Ready-Break In??
  218. sleeper... how far can you go?
  219. Do I need to change parts....
  220. bronze guides VS powdered metal guides ?
  221. fast 102 sensor placement
  222. Question about rocker geometry/ lash
  223. Need suggestions from fellow LS1 modders
  224. Just a simple power question... ('98 LS1)
  225. 862 heads
  226. Tightest "Quench"...
  227. Oil capacity
  228. Anyone had a water pump fail and leak air INTO cooling system?
  229. Lifter issue - please help
  230. help! im putting together my heads and cam set up
  231. Couple questions
  232. help deciding.
  233. How much should I expect to pay for a basic LS1 shortblock rebuild?
  234. Head bolt question aftermarket heads.
  235. Can I use stock intake port seals on fast 92?
  236. Think you can ID this Cam?
  237. Pushrods, probably a dumb question.
  238. Broken valve spring, was I losing any power?
  239. changed valve springs and car slowed down
  240. aftermarket accessory drive
  241. 5.3 piston question please help.
  242. Reusing gaskets
  243. 99 camaro need help
  244. Titanium Nitride coating on valves?
  245. 408 exhaust options
  246. dropped 3 lifters and a pushrod during f body cam swap
  247. Joe Gibbs LS30 oil
  248. Needle Bearings While Changing Oil?
  249. Roller tips failed on both #7 cylinder liters. Cause?
  250. zr1
