View Full Version : Generation III Internal Engine
  1. is this a good deal on a set of 243 heads???
  2. valve spring deal
  3. ET heads
  4. Oil Pump???
  5. Clearance for pick-up to oil pan?
  6. 98 383 block
  7. I would like to get some more thoughts on the 228/232 .588/.595 cam please?
  8. Hanging idle after install
  9. FAST 90/90 set up or wait for new Weiand
  10. what are the stock part good for
  11. ls6 springs with tr 224 cam
  12. idle prob
  13. heads
  14. Well i did it, The Cam Is In
  15. ls1 crank sprocket?
  16. Magnaflow question
  17. New Patriot Cam
  18. Ignition problem?
  19. Anyone know what kind of hp this cam gives?
  20. Tuner for cam
  21. 383 stroker
  22. trickflow heads????
  23. v4 cam sound clip
  24. roller rocker ratio
  25. slp maf
  26. will my car run?
  27. Is the crany pully a press fit or keyed? I have both.
  28. Low oil pressure after overheat, thoughts?
  29. Heads/cam ?
  30. help with internals
  31. belt throw after a cam swap
  32. Please help me ID my motor (pics)
  33. Looking for PRC S1 LS6 head Results
  34. LS1/LS6 Highest N/A HP Record???
  35. LS6 to Vengeance FAST 90/LS2 90 Results
  36. A4 car 112lsa or 114lsa?
  37. Pics of our LS Project:
  38. mti x1
  39. Is this possible with the engine still in the car???
  40. 1.85 Rockers VTP Clearance Issues?
  41. ok im about to give up.
  42. Thinking of forging my LS1!
  43. Scorpion roller rockers?
  44. Pushrod Question
  45. How much lifter preload comp rockers?
  46. smoke on start, rough idle, ticking. help please.
  47. Head swap help
  48. 395 Stroker!
  49. Spec Stage 1
  50. 383 stroker build - looking for dependable shop
  51. 97 Vette Cam Position Sensor
  52. No oil pressure to rockers
  53. pickin heads
  54. AFR (205) with ms4
  55. h/c tuning help
  56. Ls1 Hp
  57. cam heads and intake diy?s
  58. 04 6.0 block what connecting rod length
  59. Misfire
  60. Crazy Noise at 5k+ RPM??
  61. black smoke?
  62. Need help with cam choice
  63. rev question
  64. 383 hits oilpan. Also what holds the cam rear?
  65. cam, spring question
  66. High rpm damage
  67. whos car wistles after cam swap
  68. pics of my stock pistons/valves.. good? bad?
  69. Another heads question....
  70. Cam?
  71. Heads to mate with MS3 Cam?
  72. PRC Stage 2.5 Heads.. Good or bad?
  73. U-joint help
  74. 5.3L pushrod length on milled
  75. how to pull stock balancer off crankshaft on ls2
  76. I need some opinions on this setup!
  77. Help with pistons selection and CR
  78. tuning after cam install
  79. Head advice
  80. Bought supposed 99 LS1 engine but has 241 heads, what year is it really?
  81. Are my compression figures right?
  82. Confirm My cam is alighned (Please)
  83. wht do i need??
  84. Guages
  85. ls6 how much power?
  86. Opinions on my new heads
  87. change rod bolts with motor still in?
  88. What Intake do I have
  89. New Block for 500rwhp
  90. Cam choice...
  91. high milage ls1
  92. Pulling the Trigger (DD Cam only) Decision.
  93. Any tricks to get the oil pan to drop?
  94. Headers for lowered ss
  95. What Cam Do I Have????
  96. trashed bottom end???
  97. which double roller??
  98. Rev Limiter or Knock Retard????
  99. what heads do i got..
  100. oh snap, carnage pics inside!!
  101. Ls1 - Ls6
  102. Two bolts to the oil pan I forgot where they go?
  103. Rollers check
  104. Installing rings today, quick question. Extra rings?
  105. has anyone got a pulley off with a stock bolt?
  106. best heads for 230/230 .612/.592 111+2 LSA cam?
  107. Might as well get injectors...right?
  108. Alternator is DEAD!!
  109. Any big cam only guys with ported FAST 90 setup?
  110. Torque spec?? Head studs and rod bolts
  111. How can I achieve 400 HP from my stock LS1?
  112. 1/4 mile with the my mods????
  113. future plans for ls1, i have a little bit so far, any suggestions
  114. New to the LS1 - How to mod?
  115. Changing alternator
  116. Pinning crank
  117. how much is a valve job on 5.3's?
  118. Patriot Head And Cam Kits For Ls1
  119. OPINIONS WANTED - might need a shortblock
  120. What is your guess on hp for...
  121. noisy valvetrain .......
  122. help? how to check engine compression ?
  123. Deal or no Deal??
  124. Pics of ported LS1 heads
  125. can someone tell me what pushrod length to get??? Engine specs inside...
  126. Whether to get a cam
  127. Eagle Crank?
  128. TSP heads and cam
  129. How to make an ls1 a monster
  130. 383 or 346?
  131. cam install prices
  132. can i run this cam with a stock stall?
  133. Cam for stock heads
  134. Dyno tomorrow,guess numbers
  135. What heads to get
  136. ms4 with patriot stage 2 heads
  137. How much power before I have to start worrying?
  138. Livernois Stg 3 LS6 heads to big for G5X3??
  139. Cam
  140. Props to Texas Speed!
  141. Will 04 injectors fit my ls1?
  142. AFR still the best LSX head on the market?
  143. what size dowel
  144. rear cover question
  145. possible 500rwhp stock cube?
  146. Melling 10296
  147. P0336 problems
  148. 383 power
  149. ls6 cam sizing questions
  150. Guru's pls help?
  151. Valve Spring/Rocker Arm question
  152. Rod bolt wont come out of end cap
  153. All aftermarket cams etched?
  154. all around what head is better the 853's or the 5.3's
  155. Harland sharp is a rip off IMO
  156. Quick Cam install question
  157. Flat spot in powerband?
  158. Oil pump o rings?
  159. Question about CTS v ls6 motor???
  160. what cams better MS3 or MS4???
  161. Considering my options
  162. Connecting rod Q.
  163. Wanting to inch up. 5.3 to 5.7
  164. PRC Predator heads
  165. Good brand of push rods
  166. please help!!! LSX noob needs cam help
  167. 317 heads-help
  168. Loud noise COMES AND GOES, help diagnose please!
  169. Tune/breakin new engine,clutch?
  170. X1 can plus stock tune, can I drive the car hard?
  171. need 2 find a good cam!
  172. Car Idling bad, Sputtering.
  173. Ported 98' oil pump.. Have a question
  174. Which Cam?TR224, 224R, 228R?
  175. cam and main bearings
  176. do i have all my parts for the cam swap?
  177. Alright guys, which rod and main bearings should I be using
  178. Head Swap --- Gasket Confusion
  179. LS1 top ten aftermarket proformance parts supplies?
  180. Need to change reluctor ring..
  181. gm head bolt part #
  182. spec'd my own cam...what do you think
  183. H/C install
  184. Cam spec opinions...
  185. F10 vs f11 vs f12 cam
  186. help 383 sroker on an LS1
  187. Cam Advice, newb ( long )
  188. AIR System with breather? HELP
  189. head help
  190. is it necessary to shim springs with a trex
  191. What determines spring pressure/rate you want?
  192. Head Stud Question.......
  193. Budget shortblock
  194. Heads/Cam Opinions
  195. TR224 Cam
  196. what are the stock valve size on 5.3's?
  197. how deep can you fly cut stock pistons?
  198. I am not sure what to expect
  199. Patrick G cam!!!
  200. 5.3l
  201. EGR Removal
  202. LS1 style engine back in 1985?
  203. Plug gap for PRC 2.5 5.3 heads stock cubes?
  204. LS6 or thunder racing 224 cam?
  205. 5.3 heads
  206. started cam install today!
  207. anyone have a junk 5.3/5.7/6.0 LS block?
  208. PRC Stage 1.0 LS6 CNC Ported Heads with a 224/112lsa?
  209. Check out what the UPS guy brought today
  210. kinda dumb but anyone ever break
  211. Light hone fit what rings?
  212. 5.3 allways cast iron ?
  213. LSL Lobes (LOL lobes)
  214. will it be worth the swap>>>>
  215. weird tapping after throttle is dropped lifters tapping
  216. dcr, info
  217. 5.3s and pushrod length
  218. Need some input on heads for 224 224 cam
  219. biggest cams with no ptv issues
  220. LSX Block - Small or Big Block?
  221. Pics of my DIY ported heads
  222. ALMOST done! Need head gasket advice
  223. Motor falls flat after 6800
  224. Valvetrain Opinions Wanted Please...
  225. redline Q's
  226. anyone have a good link for 317 heads ?
  227. Need a set of center bolt valve covers, where to look?
  228. 3.185 stroke+6.500 rod=what piston??
  229. dcr HELP
  230. dcr help
  231. best cam for my heads
  232. Slight damage on Crank reluctor ring...can it be fixed?
  233. Dealer refuses to do Crank position relearn
  234. No ls6 gasket kits??? Where to get.
  235. stock injector power range
  236. hydraulic lifters???
  237. Overheat help Im stumped
  238. Crane gold roller pushrod length??
  239. injectors?
  240. Thinking about 1.85 rockers
  241. How to remove the rear main seal?
  242. ETP 225 or 240 heads 6 bolts heads which one need info?
  243. Few question on Valve springs
  244. Mill stock heads? Run Thinner Head Gasket? Installing 225/229 .580"/.590" 114 Cam...
  245. Valvetrain swap question!!!
  246. quick questions on replacing valvesprings
  247. isky springs?
  248. could use some help?
  249. Smoke Screen???
  250. *****************Cartek Heads and Cam Special**********
